06-Layer 3 - IP Routing
HomeSupportSwitchesS9820 SeriesReference GuidesMIB CompanionH3C S9820-8C MIB Companion-Release 6715-6W10006-Layer 3 - IP Routing
12-OSPFV3-MIB
12-OSPFV3-MIB 501.51 KB
OSPFV3-MIB
About this MIB
Use this MIB to obtain OSPFv3 information.
MIB file name
rfc5643-ospfv3.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ospfv3MIB(191)
Scalar objects
ospfv3RouterId
Object (OID)
Access
Value range
Implementation
ospfv3RouterId (1.3.6.1.2.1.191.1.1.1)
read-write
Ospfv3RouterIdTC
Unsigned32(1..'FFFFFFFF'h)
Unique identifier of a router in an AS.
Supports only the read operation.
ospfv3AdminStatus
Object (OID)
Access
Value range
Implementation
ospfv3AdminStatus (1.3.6.1.2.1.191.1.1.2)
read-write
Status
INTEGER{
enabled (1),
disabled (2)
Enabled indicates that a minimum of one interface is in up state. Disabled indicates that no interface is in up state.
ospfv3VersionNumber
Object (OID)
Access
Value range
Implementation
ospfv3VersionNumber (1.3.6.1.2.1.191.1.1.3)
read-only
INTEGER
version3 (3)
Version number (3).
As per the MIB.
ospfv3AreaBdrRtrStatus
Object (OID)
Access
Value range
Implementation
ospfv3AreaBdrRtrStatus (1.3.6.1.2.1.191.1.1.4)
read-only
TruthValue
true(1),
false(2)
Whether the device is an ABR.
As per the MIB.
ospfv3ASBdrRtrStatus
Object (OID)
Access
Value range
Implementation
ospfv3ASBdrRtrStatus (1.3.6.1.2.1.191.1.1.5)
read-write
TruthValue
true(1),
false(2)
Whether the device is an ASBR.
ospfv3AsScopeLsaCount
Object (OID)
Access
Value range
Implementation
ospfv3AsScopeLsaCount (1.3.6.1.2.1.191.1.1.6)
read-only
Gauge32
INTEGER(0..4294967295)
Number of AS external LSAs.
As per the MIB.
ospfv3AsScopeLsaCksumSum
Object (OID)
Access
Value range
Implementation
ospfv3AsScopeLsaCksumSum (1.3.6.1.2.1.191.1.1.7)
read-only
Unsigned32
Standard MIB values.
Sum of checksums in external LSAs.
As per the MIB.
ospfv3OriginateNewLsas
Object (OID)
Access
Value range
Implementation
ospfv3OriginateNewLsas (1.3.6.1.2.1.191.1.1.8)
read-only
Counter32
Number of new LSAs that have been originated. This number is incremented each time the device originates a new LSA.
As per the MIB.
ospfv3RxNewLsas
Object (OID)
Access
Value range
Implementation
ospfv3RxNewLsas (1.3.6.1.2.1.191.1.1.9)
read-only
Counter32
Number of newly received LSAs, excluding self-originated LSAs.
As per the MIB.
ospfv3ExtLsaCount
Object (OID)
Access
Value range
Implementation
ospfv3ExtLsaCount (1.3.6.1.2.1.191.1.1.10)
read-only
Gauge32
Number of Type-5 LSAs.
As per the MIB.
ospfv3ExtAreaLsdbLimit
Object (OID)
Access
Value range
Implementation
ospfv3ExtAreaLsdbLimit (1.3.6.1.2.1.191.1.1.11)
read-write
Integer32
Integer32(-1..'7FFFFFFF'h)
Maximum number of non-default ASEs in the LSDB. A value of -1 indicates no limit.
ospfv3ExitOverflowInterval
Object (OID)
Access
Value range
Implementation
ospfv3ExitOverflowInterval (1.3.6.1.2.1.191.1.1.12)
read-write
Unsigned32
Time that the router takes to leave the OverflowState. 0 indicates the router does not leave the OverflowState until it is restarted.
ospfv3DemandExtensions
Object (OID)
Access
Value range
Implementation
ospfv3DemandExtensions (1.3.6.1.2.1.191.1.1.13)
read-write
TruthValue
true(1),
false(2)
Support for demand routing.
ospfv3ReferenceBandwidth
Object (OID)
Access
Value range
Implementation
ospfv3ReferenceBandwidth (1.3.6.1.2.1.191.1.1.14)
read-write
Unsigned32
Reference bandwidth in Kbps for calculating the interface cost.
When the value is divided by 1000, the decimal number will be ignored.
ospfv3RestartSupport
Object (OID)
Access
Value range
Implementation
ospfv3RestartSupport (1.3.6.1.2.1.191.1.1.15)
read-write
INTEGER
none(1), plannedOnly(2), plannedAndUnplanned(3)
Support for GR.
If the value changes from 1 to 2 or 3, IETF GR is supported.
If the value changes between 2 and 3, the original GR type remains unchanged.
ospfv3RestartInterval
Object (OID)
Access
Value range
Implementation
ospfv3RestartInterval (1.3.6.1.2.1.191.1.1.16)
read-write
Ospfv3UpToRefreshIntervalTC
Unsigned32 (40..1800)
GR timeout timer.
Value range: 40 to 1800.
ospfv3RestartStrictLsaChecking
Object (OID)
Access
Value range
Implementation
ospfv3RestartStrictLsaChecking (1.3.6.1.2.1.191.1.1.17)
read-write
TruthValue
true(1),
false(2)
Whether the strict LSA checking capability is enabled for GR.
Default: false(2).
ospfv3RestartStatus
Object (OID)
Access
Value range
Implementation
ospfv3RestartStatus (1.3.6.1.2.1.191.1.1.18)
read-only
INTEGER
notRestarting(1), plannedRestart(2), unplannedRestart(3)
Graceful restart state.
As per the MIB.
ospfv3RestartAge
Object (OID)
Access
Value range
Implementation
ospfv3RestartAge (1.3.6.1.2.1.191.1.1.19)
read-only
Unsigned32 (1..1800)
Remaining time for the current graceful restart.
As per the MIB.
ospfv3RestartExitReason
Object (OID)
Access
Value range
Implementation
ospfv3RestartExitReason (1.3.6.1.2.1.191.1.1.20)
read-only
INTEGER
none(1), inProgress(2), completed(3) timedOut(4), topologyChanged(5)
GR exit reason.
As per the MIB.
ospfv3NotificationEnable
Object (OID)
Access
Value range
Implementation
ospfv3NotificationEnable (1.3.6.1.2.1.191.1.1.21)
read-write
TruthValue
true(1),
false(2)
Whether OSPFv3 notification is enabled.
If the value of this object is true(1), all OSPFv3 notifications are enabled.
ospfv3StubRouterSupport
Object (OID)
Access
Value range
Implementation
ospfv3StubRouterSupport (1.3.6.1.2.1.191.1.1.22)
read-only
TruthValue
true(1),
false(2)
Support for stub router.
As per the MIB.
ospfv3StubRouterAdvertisement
Object (OID)
Access
Value range
Implementation
ospfv3StubRouterAdvertisement (1.3.6.1.2.1.191.1.1.23)
read-write
INTEGER
doNotAdvertise(1), advertise(2)
Whether to advertise stub router LSAs.
As per the MIB.
ospfv3DiscontinuityTime
Object (OID)
Access
Value range
Implementation
ospfv3DiscontinuityTime (1.3.6.1.2.1.191.1.1.24)
read-only
TimeStamp
TimeTicks
Most recent system startup time.
As per the MIB.
ospfv3RestartTime
Object (OID)
Access
Value range
Implementation
ospfv3RestartTime (1.3.6.1.2.1.191.1.1.25)
read-only
TimeStamp
TimeTicks
Time when the most recent GR occurred.
As per the MIB.
Tabular objects
ospfv3AreaTable
About this table
This table contains parameter and statistics information about each area on the device.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ospfv3AreaId.
Object (OID)
Access
Value range
Implementation
ospfv3AreaId (1.3.6.1.2.1.191.1.2.1.1)
not-accessible
Ospfv3AreaIdTC
Unsigned32 (0..'FFFFFFFF'h)
Area ID, a 32-bit integer that uniquely identifies an area.
As per the MIB.
ospfv3AreaImportAsExtern (1.3.6.1.2.1.191.1.2.1.2)
read-create
INTEGER
importExternal(1),   importNoExternal(2),   importNssa(3)
Area type, stub, NSSA, or common area.
ospfv3AreaSpfRuns (1.3.6.1.2.1.191.1.2.1.3)
read-only
Counter32
Time of route calculations in the area.
As per the MIB.
ospfv3AreaBdrRtrCount (1.3.6.1.2.1.191.1.2.1.4)
read-only
Gauge32
Number of reachable ABRs in the area.
As per the MIB.
ospfv3AreaAsBdrRtrCount (1.3.6.1.2.1.191.1.2.1.5)
read-only
Gauge32
Number of reachable ASBRs in the area.
As per the MIB.
ospfv3AreaScopeLsaCount (1.3.6.1.2.1.191.1.2.1.6)
read-only
Gauge32
Number of LSAs in the LSDB of the area.
As per the MIB.
ospfv3AreaScopeLsaCksumSum (1.3.6.1.2.1.191.1.2.1.7)
read-only
Unsigned32
Sum of the checksums of the LSAs in the area.
As per the MIB.
ospfv3AreaSummary (1.3.6.1.2.1.191.1.2.1.8)
read-create
INTEGER
noAreaSummary(1),
sendAreaSummary(2)
Whether to send summary LSAs to stub and NSSA areas.
Supports read and write operations.
ospfv3AreaRowStatus (1.3.6.1.2.1.191.1.2.1.9)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Area state.
ospfv3AreaStubMetric (1.3.6.1.2.1.191.1.2.1.10)
read-create
BigMetric
Integer32(0..16777215)
Cost of the default route advertised to a stub or NSSA area.
Default: 1.
Value range: 0 to 16777214.
ospfv3AreaNssaTranslatorRole (1.3.6.1.2.1.191.1.2.1.11)
read-create
INTEGER
always(1), candidate(2)
Ability of the NSSA ABR to translate Type-7 LSAs into Type-5 LSAs.
ospfv3AreaNssaTranslatorState (1.3.6.1.2.1.191.1.2.1.12)
read-only
INTEGER
enabled(1),
elected(2),
disabled(3)
State for the NSSA ABR to become capable of translating Type-7 LSAs into Type-5 LSAs.
As per the MIB.
ospfv3AreaNssaTranslatorStabInterval (1.3.6.1.2.1.191.1.2.1.13)
read-create
Unsigned32
Time period during which the elected translator continues to perform translation after determining that its services are no longer required.
Default: 0.
Value range: 0 to 900.
ospfv3AreaNssaTranslatorEvents (1.3.6.1.2.1.191.1.2.1.14)
read-only
Counter32
Number of role changes.
As per the MIB.
ospfv3AreaStubMetricType (1.3.6.1.2.1.191.1.2.1.15)
read-create
INTEGER
ospfv3Metric(1),   ableCost(2), mparable(3)
Cost type of the default route advertised to a stub or NSSA area.
ospfv3AreaTEEnabled
(1.3.6.1.2.1.191.1.2.1.16)
read-create
TruthValue
true(1),
false(2)
Whether TE is enabled.
Supports only the read and write operations.
ospfv3AsLsdbTable
About this table
This table contains information about LSDB information of an AS.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfv3AsLsdbType, ospfv3AsLsdbRouterId, and ospfv3AsLsdbLsid.
Object (OID)
Access
Value range
Implementation
ospfv3AsLsdbType (1.3.6.1.2.1.191.1.3.1.1)
not-accessible
Unsigned32
Unsigned32(0..'FFFFFFFF'h)
LSA type.
As per the MIB.
ospfv3AsLsdbRouterId (1.3.6.1.2.1.191.1.3.1.2)
not-accessible
Ospfv3RouterIdTC
Router ID of the device that generates the LSA.
As per the MIB.
ospfv3AsLsdbLsid (1.3.6.1.2.1.191.1.3.1.3)
not-accessible
Ospfv3LsIdTC
Unsigned32 (1..'FFFFFFFF'h)
LS ID.
As per the MIB.
ospfv3AsLsdbSequence (1.3.6.1.2.1.191.1.3.1.4)
read-only
Ospfv3LsaSequenceTC
Integer32
LSA sequence number.
As per the MIB.
ospfv3AsLsdbAge (1.3.6.1.2.1.191.1.3.1.5)
read-only
Ospfv3LsaAgeTC
Unsigned32 (0..3600)
LSA age.
As per the MIB.
ospfv3AsLsdbChecksum (1.3.6.1.2.1.191.1.3.1.6)
read-only
Integer32
Checksum.
As per the MIB.
ospfv3AsLsdbAdvertisement (1.3.6.1.2.1.191.1.3.1.7)
read-only
OCTET STRING
OCTET STRING(1..65535)
LSA information, including the header.
As per the MIB.
ospfv3AsLsdbTypeKnown (1.3.6.1.2.1.191.1.3.1.8)
read-only
TruthValue
true(1),
false(2)
Whether the LSA type is unknown.
As per the MIB.
ospfv3AreaLsdbTable
About this table
This table contains information about LSDB information of an area.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfv3AreaLsdbAreaId, ospfv3AreaLsdbType, ospfv3AreaLsdbRouterId, and ospfv3AreaLsdbLsid.
Object (OID)
Access
Value range
Implementation
ospfv3AreaLsdbAreaId (1.3.6.1.2.1.191.1.4.1.1)
not-accessible
Ospfv3AreaIdTC
Area from which the LSA was received.
As per the MIB.
ospfv3AreaLsdbType (1.3.6.1.2.1.191.1.4.1.2)
not-accessible
Unsigned32
LSA type.
As per the MIB.
ospfv3AreaLsdbRouterId (1.3.6.1.2.1.191.1.4.1.3)
not-accessible
Ospfv3RouterIdTC
As per the MIB.
ospfv3AreaLsdbLsid (1.3.6.1.2.1.191.1.4.1.4)
not-accessible
Ospfv3LsIdTC
LS ID.
As per the MIB.
ospfv3AreaLsdbSequence (1.3.6.1.2.1.191.1.4.1.5)
read-only
Ospfv3LsaSequenceTC
Integer32
As per the MIB.
ospfv3AreaLsdbAge (1.3.6.1.2.1.191.1.4.1.6)
read-only
Ospfv3LsaAgeTC
LSA age.
As per the MIB.
ospfv3AreaLsdbChecksum (1.3.6.1.2.1.191.1.4.1.7)
read-only
Integer32
Checksum.
As per the MIB.
ospfv3AreaLsdbAdvertisement (1.3.6.1.2.1.191.1.4.1.8)
read-only
OCTET STRING
As per the MIB.
ospfv3AreaLsdbTypeKnown (1.3.6.1.2.1.191.1.4.1.9)
read-only
TruthValue
true(1),
false(2)
As per the MIB.
ospfv3LinkLsdbTable
About this table
This table contains link-scope LSDB information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfv3LinkLsdbIfIndex, ospfv3LinkLsdbIfInstId, ospfv3LinkLsdbType, ospfv3LinkLsdbRouterId, and ospfv3LinkLsdbLsid.
Object (OID)
Access
Value range
Implementation
ospfv3LinkLsdbIfIndex (1.3.6.1.2.1.191.1.5.1.1)
not-accessible
InterfaceIndex
Integer32(1..2147483647)
Interface index.
As per the MIB.
ospfv3LinkLsdbIfInstId (1.3.6.1.2.1.191.1.5.1.2)
not-accessible
Ospfv3IfInstIdTC
Unsigned32(0..255)
Instance ID.
As per the MIB.
ospfv3LinkLsdbType (1.3.6.1.2.1.191.1.5.1.3)
not-accessible
Unsigned32
LSA type.
As per the MIB.
ospfv3LinkLsdbRouterId (1.3.6.1.2.1.191.1.5.1.4)
not-accessible
Ospfv3RouterIdTC
As per the MIB.
ospfv3LinkLsdbLsid (1.3.6.1.2.1.191.1.5.1.5)
not-accessible
Ospfv3LsIdTC
LS ID.
As per the MIB.
ospfv3LinkLsdbSequence (1.3.6.1.2.1.191.1.5.1.6)
read-only
Ospfv3LsaSequenceTC
Integer32
As per the MIB.
ospfv3LinkLsdbAge (1.3.6.1.2.1.191.1.5.1.7)
read-only
Ospfv3LsaAgeTC
LSA age.
As per the MIB.
ospfv3LinkLsdbChecksum (1.3.6.1.2.1.191.1.5.1.8)
read-only
Integer32
Checksum.
As per the MIB.
ospfv3LinkLsdbAdvertisement (1.3.6.1.2.1.191.1.5.1.9)
read-only
OCTET STRING
As per the MIB.
ospfv3LinkLsdbTypeKnown (1.3.6.1.2.1.191.1.5.1.10)
read-only
TruthValue
true(1),
false(2)
As per the MIB.
ospfv3HostTable
About this table
This table contains host route information (not supported in the current software version).
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are ospfv3HostAddressType and ospfv3HostAddress.
Object (OID)
Access
Value range
Implementation
ospfv3HostAddressType (1.3.6.1.2.1.191.1.6.1.1)
not-accessible
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
Host route address type.
Not supported
ospfv3HostAddress (1.3.6.1.2.1.191.1.6.1.2)
not-accessible
InetAddress
OCTET STRING(0..255)
Host route address.
Not supported
ospfv3HostMetric (1.3.6.1.2.1.191.1.6.1.3)
read-create
Metric
Integer32(0..'FFFF'h)
Host route cost.
Not supported
ospfv3HostRowStatus ( 1.3.6.1.2.1.191.1.6.1.4)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Not supported
ospfv3HostAreaID (1.3.6.1.2.1.191.1.6.1.5)
read-create
Ospfv3AreaIdTC
ID of the area to which the host route belongs.
Not supported
ospfv3IfTable
About this table
This table contains OSPFv3 interface information.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ospfv3IfIndex and ospfv3IfInstId.
Object (OID)
Access
Value range
Implementation
ospfv3IfIndex (1.3.6.1.2.1.191.1.7.1.1)
not-accessible
InterfaceIndex
Interface index.
As per the MIB.
ospfv3IfInstId (1.3.6.1.2.1.191.1.7.1.2)
not-accessible
Ospfv3IfInstIdTC
Unsigned32(0..255)
Interface instance ID.
As per the MIB.
ospfv3IfAreaId (1.3.6.1.2.1.191.1.7.1.3)
read-create
Ospfv3AreaIdTC
Area ID.
ospfv3IfType (1.3.6.1.2.1.191.1.7.1.4)
read-create
INTEGER
broadcast(1),
nbma(2),
pointToPoint(3),
pointToMultipoint(5)
Interface type.
Loopback interfaces do not support the write operation.
ospfv3IfAdminStatus (1.3.6.1.2.1.191.1.7.1.5)
read-create
Status
INTEGER{
enabled (1),
disabled (2)
Administrative state of the interface.
ospfv3IfRtrPriority (1.3.6.1.2.1.191.1.7.1.6)
read-create
DesignatedRouterPriority
Integer32(0..'FF'h)
DR priority of the interface.
ospfv3IfTransitDelay (1.3.6.1.2.1.191.1.7.1.7)
read-create
LSA transmission delay.
Value range: 1 to 1800.
ospfv3IfRetransInterval (1.3.6.1.2.1.191.1.7.1.8)
read-create
Retransmission interval of the interface.
ospfv3IfHelloInterval (1.3.6.1.2.1.191.1.7.1.9)
read-create
HelloRange
Integer32(1..'FFFF'h)
Hello interval of the interface.
ospfv3IfRtrDeadInterval (1.3.6.1.2.1.191.1.7.1.10)
read-create
Ospfv3DeadIntervalRangeTC
Dead interval.
When the value of ospfv3IfRtrDeadInterval is larger than 65535, this object returns 65535.
ospfv3IfPollInterval (1.3.6.1.2.1.191.1.7.1.11)
read-create
Unsigned32
Poll interval.
Value range: 1 to 65535.
ospfv3IfState (1.3.6.1.2.1.191.1.7.1.12)
read-only
INTEGER
down(1), loopback(2),
waiting(3),
pointToPoint(4),
designatedRouter(5),
backupDesignatedRouter(6),
otherDesignatedRouter(7),
standby(8)
Interface state.
As per the MIB.
ospfv3IfDesignatedRouter (1.3.6.1.2.1.191.1.7.1.13)
read-only
Ospfv3RouterIdTC
DR address.
As per the MIB.
ospfv3IfBackupDesignatedRouter (1.3.6.1.2.1.191.1.7.1.14)
read-only
Ospfv3RouterIdTC
BDR address.
As per the MIB.
ospfv3IfEvents(1.3.6.1.2.1.191.1.7.1.15)
read-only
Counter32
Number of interface state changes.
As per the MIB.
ospfv3IfRowStatus (1.3.6.1.2.1.191.1.7.1.16)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
ospfv3IfDemand (1.3.6.1.2.1.191.1.7.1.17)
read-create
TruthValue
true(1),
false(2)
Whether the interface performs demand routing.
ospfv3IfMetricValue (1.3.6.1.2.1.191.1.7.1.18)
read-create
Metric
Interface cost.
Value range for loopback interfaces: 0 to 65535.
Value range for other interfaces: 1 to 65535.
ospfv3IfLinkScopeLsaCount (1.3.6.1.2.1.191.1.7.1.19)
read-only
Gauge32
Number of link-scope LSAs.
As per the MIB.
ospfv3IfLinkLsaCksumSum (1.3.6.1.2.1.191.1.7.1.20)
read-only
Unsigned32
LSA checksum.
As per the MIB.
ospfv3IfDemandNbrProbe (1.3.6.1.2.1.191.1.7.1.21)
read-create
TruthValue
true(1),
false(2)
Whether neighbor probing is enabled.
ospfv3IfDemandNbrProbeRetransLimit (1.3.6.1.2.1.191.1.7.1.22)
read-create
Unsigned32
Number of neighbor probing times.
ospfv3IfDemandNbrProbeInterval (1.3.6.1.2.1.191.1.7.1.23)
read-create
Unsigned32
Neighbor probing interval.
ospfv3IfTEDisabled (1.3.6.1.2.1.191.1.7.1.24)
read-create
TruthValue
true(1),
false(2)
Whether TE is enabled on the interface.
The value is fixed at false(2).
ospfv3IfLinkLSASuppression (1.3.6.1.2.1.191.1.7.1.25)
read-create
TruthValue
true(1),
false(2)
Whether LSA suppression is enabled.
ospfv3VirtIfTable
About this table
This table contains OSPFv3 virtual interface information.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ospfv3VirtIfAreaId and ospfv3VirtIfNeighbor.
Object (OID)
Access
Value range
Implementation
ospfv3VirtIfAreaId (1.3.6.1.2.1.191.1.8.1.1)
not-accessible
Ospfv3AreaIdTC
ID of the area to which the virtual interface belongs.
As per the MIB.
ospfv3VirtIfNeighbor (1.3.6.1.2.1.191.1.8.1.2)
not-accessible
Ospfv3RouterIdTC
Router ID of the virtual neighbor.
As per the MIB.
ospfv3VirtIfIndex (1.3.6.1.2.1.191.1.8.1.3)
read-only
InterfaceIndex
Virtual interface index.
As per the MIB.
ospfv3VirtIfInstId (1.3.6.1.2.1.191.1.8.1.4)
read-only
Ospfv3IfInstIdTC
Unsigned32(0..255)
Virtual interface instance ID.
As per the MIB.
ospfv3VirtIfTransitDelay (1.3.6.1.2.1.191.1.8.1.5)
read-create
Transmission delay of the virtual interface.
ospfv3VirtIfRetransInterval (1.3.6.1.2.1.191.1.8.1.6)
read-create
Retransmission interval of the virtual interface.
ospfv3VirtIfHelloInterval (1.3.6.1.2.1.191.1.8.1.7)
read-create
HelloRange
Hello interval of the virtual interface.
Value range: 1 to 8192.
ospfv3VirtIfRtrDeadInterval (1.3.6.1.2.1.191.1.8.1.8)
read-create
Dead interval of the virtual interface.
Default: 40.
Value range: 1 to 32768.
ospfv3VirtIfState (1.3.6.1.2.1.191.1.8.1.9)
read-only
INTEGER
down(1),
pointToPoint(4)
Virtual interface state.
As per the MIB.
ospfv3VirtIfEvents (1.3.6.1.2.1.191.1.8.1.10)
read-only
Counter32
Number of virtual interface state changes.
As per the MIB.
ospfv3VirtIfRowStatus (1.3.6.1.2.1.191.1.8.1.11)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
ospfv3VirtIfLinkScopeLsaCount (1.3.6.1.2.1.191.1.8.1.12)
read-only
Gauge32
Number of link LSAs on the virtual interface.
As per the MIB.
ospfv3VirtIfLinkLsaCksumSum (1.3.6.1.2.1.191.1.8.1.13)
read-only
Unsigned32
Sum of checksums in link-scope LSAs.
As per the MIB.
ospfv3NbrTable
About this table
This table contains OSPFv3 neighbor information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfv3NbrIfIndex, ospfv3NbrIfInstId, and ospfv3NbrRtrId.
Object (OID)
Access
Value range
Implementation
ospfv3NbrIfIndex (1.3.6.1.2.1.191.1.9.1.1)
not-accessible
InterfaceIndex
Egress interface index.
As per the MIB.
ospfv3NbrIfInstId (1.3.6.1.2.1.191.1.9.1.2)
not-accessible
Ospfv3IfInstIdTC
Unsigned32(0..255)
Egress interface instance ID.
As per the MIB.
ospfv3NbrRtrId (1.3.6.1.2.1.191.1.9.1.3)
not-accessible
Ospfv3RouterIdTC
Router ID of the neighbor.
As per the MIB.
ospfv3NbrAddressType (1.3.6.1.2.1.191.1.9.1.4)
read-only
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
Neighbor address type.
As per the MIB.
ospfv3NbrAddress (1.3.6.1.2.1.191.1.9.1.5)
read-only
InetAddress
Neighbor address.
As per the MIB.
ospfv3NbrOptions (1.3.6.1.2.1.191.1.9.1.6)
read-only
Integer32
Priority of the neighbor.
As per the MIB.
ospfv3NbrPriority (1.3.6.1.2.1.191.1.9.1.7)
read-only
Integer32(0..'FF'h)
Option field of the neighbor.
As per the MIB.
ospfv3NbrState (1.3.6.1.2.1.191.1.9.1.8)
read-only
INTEGER
down(1),
attempt(2),
init(3), twoWay(4),
exchangeStart(5),
exchange(6), loading(7),
full(8)
Neighbor state.
As per the MIB.
ospfv3NbrEvents (1.3.6.1.2.1.191.1.9.1.9)
read-only
Counter32
Number of neighbor state changes.
As per the MIB.
ospfv3NbrLsRetransQLen (1.3.6.1.2.1.191.1.9.1.10)
read-only
Gauge32
Retransmission queue length.
As per the MIB.
ospfv3NbrHelloSuppressed (1.3.6.1.2.1.191.1.9.1.11)
read-only
TruthValue
true(1),
false(2)
Whether hello packets are being suppressed to the neighbor.
As per the MIB.
ospfv3NbrIfId (1.3.6.1.2.1.191.1.9.1.12)
read-only
InterfaceIndex
Neighbor interface ID.
As per the MIB.
ospfv3NbrRestartHelperStatus (1.3.6.1.2.1.191.1.9.1.13)
read-only
INTEGER
notHelping(1),      helping(2)
Whether the router is acting as a GR helper for the neighbor.
As per the MIB.
ospfv3NbrRestartHelperAge (1.3.6.1.2.1.191.1.9.1.14)
read-only
Remaining time of the GR interval when the router is acting as a GR helper for the neighbor.
As per the MIB.
ospfv3NbrRestartHelperExitReason (1.3.6.1.2.1.191.1.9.1.15)
read-only
INTEGER
none(1),       inProgress(2),      completed(3),      timedOut(4),      topologyChanged(5)
GR helper exit reason.
As per the MIB.
ospfv3CfgNbrTable
About this table
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ospfv3CfgNbrIfIndex, ospfv3CfgNbrIfInstId, ospfv3CfgNbrAddressType, and ospfv3CfgNbrAddress.
Object (OID)
Access
Value range
Implementation
ospfv3CfgNbrIfIndex (1.3.6.1.2.1.191.1.10.1.1)
not-accessible
InterfaceIndex
Configured neighbor interface index.
As per the MIB.
ospfv3CfgNbrIfInstId (1.3.6.1.2.1.191.1.10.1.2)
not-accessible
Ospfv3IfInstIdTC
Unsigned32(0..255)
Configured neighbor interface instance ID.
As per the MIB.
ospfv3CfgNbrAddressType (1.3.6.1.2.1.191.1.10.1.3)
not-accessible
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
Configured neighbor address type.
As per the MIB.
ospfv3CfgNbrAddress (1.3.6.1.2.1.191.1.10.1.4)
not-accessible
InetAddress
Configured neighbor address.
As per the MIB.
ospfv3CfgNbrPriority (1.3.6.1.2.1.191.1.10.1.5)
read-create
Integer32(0..'FF'h)
Configured neighbor priority.
Only neighbors on an NBMA network support the write operation.
ospfv3CfgNbrRowStatus (1.3.6.1.2.1.191.1.10.1.6)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
ospfv3VirtNbrTable
About this table
This table contains OSPFv3 virtual neighbor information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfv3VirtNbrArea and ospfv3VirtNbrRtrId.
Object (OID)
Access
Value range
Implementation
ospfv3VirtNbrArea (1.3.6.1.2.1.191.1.11.1.1)
not-accessible
Ospfv3AreaIdTC
Area to which the virtual neighbor belongs.
As per the MIB.
ospfv3VirtNbrRtrId (1.3.6.1.2.1.191.1.11.1.2)
not-accessible
Ospfv3RouterIdTC
As per the MIB.
ospfv3VirtNbrIfIndex (1.3.6.1.2.1.191.1.11.1.3)
read-only
InterfaceIndex
As per the MIB.
ospfv3VirtNbrIfInstId (1.3.6.1.2.1.191.1.11.1.4)
read-only
Ospfv3IfInstIdTC
Unsigned32(0..255)
As per the MIB.
ospfv3VirtNbrAddressType (1.3.6.1.2.1.191.1.11.1.5)
read-only
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
Virtual neighbor address type.
As per the MIB.
ospfv3VirtNbrAddress (1.3.6.1.2.1.191.1.11.1.6)
read-only
InetAddress
Virtual neighbor address.
As per the MIB.
ospfv3VirtNbrOptions (1.3.6.1.2.1.191.1.11.1.7)
read-only
Integer32
Option field of the virtual neighbor.
As per the MIB.
ospfv3VirtNbrState (1.3.6.1.2.1.191.1.11.1.8)
read-only
INTEGER
down(1),
attempt(2),
init(3),
twoWay(4),
exchangeStart(5),
exchange(6),
loading(7),
full(8)
State of the virtual neighbor.
As per the MIB.
ospfv3VirtNbrEvents (1.3.6.1.2.1.191.1.11.1.9)
read-only
Counter32
Number of virtual neighbor state changes.
As per the MIB.
ospfv3VirtNbrLsRetransQLen(1.3.6.1.2.1.191.1.11.1.10)
read-only
Gauge32
As per the MIB.
ospfv3VirtNbrHelloSuppressed (1.3.6.1.2.1.191.1.11.1.11)
read-only
TruthValue
true(1),
false(2)
Whether hello packets are being suppressed to the virtual neighbor.
As per the MIB.
ospfv3VirtNbrIfId (1.3.6.1.2.1.191.1.11.1.12)
read-only
InterfaceIndex
As per the MIB.
ospfv3VirtNbrRestartHelperStatus (1.3.6.1.2.1.191.1.11.1.13)
read-only
INTEGER
Whether the router is acting as a GR helper for the virtual neighbor.
As per the MIB.
ospfv3VirtNbrRestartHelperAge (1.3.6.1.2.1.191.1.11.1.14)
read-only
Remaining time of the GR interval when the router is acting as a GR helper for the virtual neighbor.
As per the MIB.
ospfv3VirtNbrRestartHelperExitReason (1.3.6.1.2.1.191.1.11.1.15)
read-only
INTEGER
As per the MIB.
ospfv3AreaAggregateTable
About this table
This table contains information about configured OSPFv3 summary routes.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ospfv3AreaAggregateAreaID, ospfv3AreaAggregateAreaLsdbType, ospfv3AreaAggregatePrefixType, ospfv3AreaAggregatePrefix, and ospfv3AreaAggregatePrefixLength.
Object (OID)
Access
Value range
Implementation
ospfv3AreaAggregateAreaID (1.3.6.1.2.1.191.1.12.1.1)
not-accessible
Ospfv3AreaIdTC
Area where the summary route resides.
As per the MIB.
ospfv3AreaAggregateAreaLsdbType (1.3.6.1.2.1.191.1.12.1.2)
not-accessible
INTEGER
interAreaPrefixLsa(8195), nssaExternalLsa(8199)
LSA type.
As per the MIB.
ospfv3AreaAggregatePrefixType (1.3.6.1.2.1.191.1.12.1.3)
not-accessible
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
Summary network address type.
As per the MIB.
ospfv3AreaAggregatePrefix (1.3.6.1.2.1.191.1.12.1.4)
not-accessible
InetAddress
OCTET STRING(0..16)
Summary network address.
As per the MIB.
ospfv3AreaAggregatePrefixLength (1.3.6.1.2.1.191.1.12.1.5)
not-accessible
InetAddressPrefixLength
Unsigned32(3..128)
Summary network address length.
As per the MIB.
ospfv3AreaAggregateRowStatus (1.3.6.1.2.1.191.1.12.1.6)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
ospfv3AreaAggregateEffect (1.3.6.1.2.1.191.1.12.1.7)
read-create
INTEGER
advertiseMatching(1),
doNotAdvertiseMatching(2)
Whether subnets are included in the summary route.
ospfv3AreaAggregateRouteTag (1.3.6.1.2.1.191.1.12.1.8)
read-create
Unsigned32
Tag information.
ospfv3VirtLinkLsdbTable
About this table
This table contains OSPFv3 link-scope LSDB information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ospfv3VirtLinkLsdbIfAreaId, ospfv3VirtLinkLsdbIfNeighbor, ospfv3VirtLinkLsdbType, ospfv3VirtLinkLsdbRouterId, and ospfv3VirtLinkLsdbLsid.
Object (OID)
Access
Value range
Implementation
ospfv3VirtLinkLsdbIfAreaId (1.3.6.1.2.1.191.1.13.1.1)
not-accessible
Ospfv3AreaIdTC
ID of the area to which the virtual link belongs.
As per the MIB.
ospfv3VirtLinkLsdbIfNeighbor(1.3.6.1.2.1.191.1.13.1.2)
not-accessible
Ospfv3RouterIdTC
As per the MIB.
ospfv3VirtLinkLsdbType (1.3.6.1.2.1.191.1.13.1.3)
not-accessible
Unsigned32
LSA type.
As per the MIB.
ospfv3VirtLinkLsdbRouterId (1.3.6.1.2.1.191.1.13.1.4)
not-accessible
Ospfv3RouterIdTC
As per the MIB.
ospfv3VirtLinkLsdbLsid (1.3.6.1.2.1.191.1.13.1.5)
not-accessible
Ospfv3LsIdTC
LSA LS ID.
As per the MIB.
ospfv3VirtLinkLsdbSequence(1.3.6.1.2.1.191.1.13.1.6)
read-only
Ospfv3LsaSequenceTC
Integer32
As per the MIB.
ospfv3VirtLinkLsdbAge (1.3.6.1.2.1.191.1.13.1.7)
read-only
Ospfv3LsaAgeTC
LSA age.
As per the MIB.
ospfv3VirtLinkLsdbChecksum(1.3.6.1.2.1.191.1.13.1.8)
read-only
Integer32
LSA checksum information.
As per the MIB.
ospfv3VirtLinkLsdbAdvertisement (1.3.6.1.2.1.191.1.13.1.9)
read-only
OCTET STRING
LSA advertisement content.
As per the MIB.
ospfv3VirtLinkLsdbTypeKnown (1.3.6.1.2.1.191.1.13.1.10)
read-only
TruthValue
true(1),
false(2)
Whether the LSA type is known.
As per the MIB.
ospfv3NotificationEntry
About this table
This table contains information used for OSPFv3 notification generation.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table has no indexes.
Object (OID)
Access
Value range
Implementation
ospfv3ConfigErrorType (1.3.6.1.2.1.191.1.14.1)
accessible-for-notify
INTEGER
badVersion(1),
areaMismatch(2),
unknownNbmaNbr(3),
unknownVirtualNbr(4),
helloIntervalMismatch(5),
deadIntervalMismatch(6),
optionMismatch(7),
mtuMismatch(8),
duplicateRouterId(9),
noError(10)
Type of the configuration error.
As per the MIB.
ospfv3PacketType (1.3.6.1.2.1.191.1.14.2)
INTEGER
hello(1),
dbDescript(2),
lsReq(3),
lsUpdate(4),
lsAck(5),
nullPacket(6)
Packet type.
As per the MIB.
ospfv3PacketSrc (1.3.6.1.2.1.191.1.14.3)
InetAddressIPv6
Source address of the packet.
As per the MIB.
Notifications
ospfv3VirtIfStateChange
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.191.0.1
Virtual interface state changes.
Informational
Informational
N/A
ON
Notification triggers
This notification is generated when the state of a virtual interface changes to Point-to-Point or changes from Point-to-Point to another state. To reduce unnecessary notifications caused by virtual interface up events, no virtual interface state change notification will be sent within 2 times the dead interval since the virtual interface state changes to a value other than DOWN.
This issue occurs when one of the following conditions exists:
·     The state of a virtual interface changes from P2P to Down, or from Down to P2P.
·     The router ID of a virtual link neighbor changes.
System impact
If the state of a virtual interface changes from Down to P2P, it has no negative impact on services.
If the state of a virtual interface changes from P2P to Down, the virtual interface will be disconnected and OSPFV3 route calculation will fail. Services might be interrupted.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtif-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtif-state-change command.
Objects
OID (object name)
Index nodes
Value range
(ospfv3RouterId)
N/A
Ospfv3RouterIdTC
 (ospfv3VirtIfState)
ospfv3VirtIfAreaId
INTEGER
down(1)
pointToPoint(4)
Recommended action
To resolve this issue:
1.     Use the display ospfv3 vlink command to view the state of the virtual interface.
¡     If the state of the virtual interface changes from Down to P2P, no action is required.
¡     If the state of the virtual interface changes from P2P to Down, proceed to step 2.
2.     Use the display ospfv3 spf-tree command to identify whether the flags of the SPF node corresponding to the neighbor router ID of the virtual interface include the S flag. This flag indicates that the neighbor is reachable.
¡     If yes, check whether the virtual interface settings are configured correctly on both the local end and the remote end.
¡     If no, check for the cause of the unreachability.
3.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfv3NbrStateChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.2
Neighbor state changes.
Informational
Informational
N/A
ON
For DR and BDR, this notification is generated when the state of a neighbor changes to FULL or changes from FULL to another state. For DRother, this notification is sent when the state of a neighbor changes to 2-way or changes from 2-way to another state.
To reduce unnecessary notifications caused by interface up events, no neighbor state change notification will be sent within 2 times the dead interval since the interface state changes to a value other than DOWN.
·     The state of a neighbor changes from Attempt or any other state to 1-Way or Down, or from Down or any other state to 2-Way or Full.
·     The local and remote ends have different interface settings (such as the hello timer, dead timer, and authentication settings).
·     OSPFv3 is restarted by the reset ospfv3 process command.
·     The state of a neighbor in an NBMA or broadcast network changes from Full to another state or changes from another state to Full.
System impact
The process of OSPFv3 neighbor establishment involves a series of neighbor state changes, including Down, Attempt, Init, 2-Way, ExStart, Exchange, Loading, and Full.
If the state of a neighbor progresses, it has no negative impact on services.
If the state of a neighbor regresses, services might be interrupted.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 neighbor-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 neighbor-state-change command.
Objects
OID (object name)
Index nodes
Value range
 (ospfv3RouterId)
N/A
Ospfv3RouterIdTC
(ospfv3NbrState)
Neighbor state.
ospfv3NbrIfIndex
ospfv3NbrIfInstId
ospfv3NbrRtrId
INTEGER
down(1)
attempt(2)
init(3)
twoWay(4)
exchangeStart(5)
exchange(6)
loading(7)
full(8)
Recommended action
1.     Use the display ospfv3 peer command to view the state of the neighbor. You can view the State field in the command output.
¡     If the neighbor state is Full, no action is required.
¡     If the neighbor state is not Full, proceed to step 2.
2.     Use the display interface interface-type interface-number command to view the state of the neighbor-facing interface on the local end.
¡     If the interface is up, proceed to step 3.
¡     If the neighbor interface is down, check whether the shutdown command is executed on the interface.
-     If yes, execute the undo shutdown command on the interface, and then proceed to step 3.
-     If no, proceed to step 3.
3.     Use the ping command to identify whether the IPv6 address of the remote interface is reachable.
¡     If yes, proceed to step 4.
¡     If no, proceed to step 6.
4.     Use the display ospfv3 interface command to view the state of the OSPFv3 interface. You can view the State field in the command output.
¡     If the neighbor-facing interface is down, proceed to step 6.
¡     If the neighbor-facing interface is not down, proceed to step 5.
5.     Use the display ospfv3 interface verbose command to check whether the local and remote ends use the same interface settings, including the hello timer, dead timer, poll timer, OSPFv3 network type, and authentication settings.
¡     If yes, proceed to step 6.
¡     If no, use the following commands to modify inconsistent interface settings and make sure that the local and remote ends use the same interface settings.
-     ospfv3 timer hello
-     ospfv3 timer dead
-     ospfv3 timer poll
-     ospfv3 network-type
-     ospfv3 authentication-mode
6.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfv3VirtNbrStateChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.3
Virtual neighbor state changes.
Informational
Informational
N/A
ON
This notification is generated when the state of a virtual neighbor changes to FULL or changes from FULL to another state. To reduce unnecessary notifications caused by virtual interface up events, no virtual neighbor state change notification will be sent within 2 times the dead interval since the virtual interface state changes to a value other than DOWN.
·     The state of a virtual neighbor regresses (for example, changing from Full to 1-Way or Down) or progresses to the final state (for example, Full).
·     The state of the physical interface on which the virtual link is established changes.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtneighbor-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtneighbor-state-change command.
Objects
OID (object name)
Index nodes
Value range
(ospfv3RouterId)
N/A
Ospfv3RouterIdTC
(ospfv3VirtNbrState)
Virtual neighbor state.
ospfv3VirtNbrArea
ospfv3VirtNbrRtrId
INTEGER
down(1)
attempt(2)
init(3)
twoWay(4)
exchangeStart(5)
exchange(6)
loading(7)
full(8)
Recommended action
1.     Use the display ospfv3 interface and display ipv6 interface brief commands to view the state of the physical interface on which the virtual link is established.
¡     If the physical state of the interface is Down, check whether the interface has been shut down.
-     If yes, execute the undo shutdown command on the interface, and then proceed to step 2.
-     If no, proceed to step 2.
¡     If the link layer protocol state of the interface is Up, proceed to step 2.
2.     Use the display ospfv3 peer command to view the state of the neighbor.
¡     If the State field displays Full, proceed to step 3.
¡     If the State field does not display Full, proceed to step 5.
3.     Use the display ospfv3 spf-tree command to identify whether the flags of the SPF node corresponding to the neighbor router ID of the virtual interface include the S flag. This flag indicates that the neighbor is reachable.
¡     If no, proceed to step 5.
4.     Use the display ospfv3 vlink and display current-configuration configuration ospfv3 commands to identify whether the local and remote ends use the same settings, such as the hello timer, dead timer, and poll timer.
¡     If yes, proceed to step 5.
¡     If no, use the vlink-peer command to configure the same settings for both the local and remote ends, and then check whether the notification is cleared.
-     If yes, the troubleshooting is complete.
-     If no, proceed to step 5.
5.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfv3IfConfigError
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.4
Interface configuration error.
Informational
Informational
N/A
ON
This notification is generated when a non-virtual interface receives a packet from another router with mismatched configuration. This issue occurs when one of the following conditions exists:
·     The local interface and the remote interface use different interface settings.
·     The link layer protocol changes.
System impact
This issue typically has no negative impact as long as the local interface and the remote interface use the same settings after configuration correction.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 if-cfg-error command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 if-cfg-error command.
Objects
OID (object name)
Index nodes
Value range
(ospfv3RouterId)
N/A
Ospfv3RouterIdTC
(ospfv3IfState)
Interface state.
ospfv3IfIndex
ospfv3IfInstId
INTEGER
down(1)
loopback(2)
waiting(3)
pointToPoint(4)
designatedRouter(5)
standby(8)
(ospfv3PacketSrc)
IPv6 packet that cannot be identified by a neighbor.
N/A
InetAddressIPv6
OCTET STRING (16)
(ospfv3ConfigErrorType)
OSPFv3 configuration error type.
N/A
INTEGER
badVersion(1)
areaMismatch(2)
unknownNbmaNbr(3)
optionMismatch(7)
mtuMismatch(8)
noError(10)
(ospfv3PacketType)
OSPFv3 data packet type.
N/A
INTEGER
hello(1)
dbDescript(2)
lsReq(3)
lsUpdate(4)
lsAck(5)
nullPacket(6)
Recommended action
1.     Use the display ospfv3 interface interface-type interface-number command to identify whether the local OSPFv3 interface and the remote OSPFv3 interface use the same settings.
¡     If yes, proceed to step 3.
¡     If no, proceed to step 2.
2.     Perform the following tasks to clear the notification:
a.     Use the following commands to reconfigure the local or remote OSPFv3 interface, ensuring that the two interfaces use the same settings:
-     ospfv3 timer dead
-     ospfv3 timer poll
b.     Identify whether the notification is cleared:
3.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
ospfv3VirtIfConfigError
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.5
Virtual interface configuration error.
Informational
Warning
N/A
ON
This notification is generated when an OSPFv3 virtual interface on a router receives a packet from another router with mismatched configuration. This issue occurs when the interface settings on the ends of a virtual link are not the same.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtif-cfg-error command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtif-cfg-error command.
Objects
OID (object name)
Index nodes
Value range
(ospfv3RouterId)
N/A
Ospfv3RouterIdTC
(ospfv3VirtIfState)
ospfv3VirtIfAreaId
INTEGER
down(1)
pointToPoint(4)
N/A
INTEGER
badVersion(1)
areaMismatch(2)
unknownNbmaNbr(3)
optionMismatch(7)
mtuMismatch(8)
noError(10)
(ospfv3PacketType)
N/A
INTEGER
hello(1)
dbDescript(2)
lsReq(3)
lsUpdate(4)
lsAck(5)
nullPacket(6)
Recommended action
1.     Use the display ospfv3 vlink and display current-configuration configuration ospfv3 commands to identify whether the two ends of the virtual link use the same interface settings.
2.     Use the vlink-peer command to reconfigure an end of the virtual link, ensuring that the two ends of the virtual link use the same settings. Then, identify whether the notification is cleared:
¡     If yes, the troubleshooting is complete.
¡     If no, proceed to step 3.
ospfv3IfRxBadPacket
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.6
A non-virtual interface receives an error packet.
Informational
Warning
N/A
ON
This notification is generated when a non-virtual interface receives an OSPFv3 packet that cannot be parsed. This issue occurs when one of the following conditions exists:
·     The length of the OSPFv3 packet is incorrect.
·     The OSPFv3 packet has content errors.
System impact
When a non-virtual interface receives an OSPFv3 packet that cannot be parsed, it discards the packet. If the packet is a hello packet, the neighbor that sends the packet might go down.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 if-bad-pkt command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 if-bad-pkt command.
Objects
OID (object name)
Index nodes
Value range
(ospfv3RouterId)
N/A
Ospfv3RouterIdTC
(ospfv3IfState)
Interface state.
ospfv3IfIndex
ospfv3IfInstId
INTEGER
down(1)
loopback(2)
waiting(3)
pointToPoint(4)
designatedRouter(5)
standby(8)
(ospfv3PacketSrc)
IPv6 packet that cannot be identified by the neighbor.
N/A
InetAddressIPv6
OCTET STRING (16)
(ospfv3PacketType)
N/A
INTEGER
hello(1)
dbDescript(2)
lsReq(3)
lsUpdate(4)
lsAck(5)
nullPacket(6)
Recommended action
Collect alarm information and configuration data, and then contact H3C Support for help.
ospfv3VirtIfRxBadPacket
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.7
A virtual interface receives an error packet.
Informational
Informational
N/A
ON
A notification sent when a virtual interface receives an OSPFv3 packet that cannot be parsed.
This notification is generated when a virtual interface receives an OSPFv3 packet that cannot be parsed. This issue occurs when one of the following conditions exists:
System impact
When a virtual interface receives an OSPFv3 packet that cannot be parsed, it discards the packet. If the packet is a hello packet, the neighbor that sends the packet might go down.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtif-bad-pkt command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtif-bad-pkt command.
Objects
OID (object name)
Index nodes
Value range
(ospfv3RouterId)
N/A
Ospfv3RouterIdTC
(ospfv3VirtIfState)
ospfv3VirtIfAreaId
INTEGER
down(1)
pointToPoint(4)
(ospfv3PacketType)
N/A
INTEGER
hello(1)
dbDescript(2)
lsReq(3)
lsUpdate(4)
lsAck(5)
nullPacket(6)
Recommended action
ospfv3IfStateChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.10
Interface state changes.
Informational
Warning
N/A
ON
This notification is generated when the state of a non-virtual interface changes from DR to Down or changes to the Point-to-Point, DR, BDR, or DRother state. This issue occurs when one of the following conditions exists:
·     The physical interface comes up or goes down.
·     The router priority for the interface changes and DR/BDR election is performed.
System impact
This issue might affect the state of neighbors. If the state of an OSPFv3 interface regresses (for example, changing to Down), it will be disconnected from its neighbors.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 if-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 if-state-change command.
Objects
OID (object name)
Index nodes
Value range
(ospfv3RouterId)
N/A
Ospfv3RouterIdTC
(ospfv3IfState)
Interface state.
ospfv3IfIndex
ospfv3IfInstId
INTEGER
down(1)
loopback(2)
waiting(3)
pointToPoint(4)
designatedRouter(5)
standby(8)
Recommended action
1.     Use the display ospfv3 interface command to view the interface state.
¡     If the interface state is Down, proceed to step 2.
¡     If the interface state is not Down, no action is required.
2.     Use the display interface interface-type interface-number command to view the state of the interface.
¡     If the interface is in up, proceed to step 3.
¡     If the interface is not up, check whether the interface has been shut down.
-     If yes, execute the undo shutdown command on the interface.
ospfv3NssaTranslatorStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.11
A router's ability to translate type-7 LSAs into type-5 LSAs changes.
Informational
Warning
N/A
ON
This notification is generated when a router's ability to translate OSPFv3 type-7 LSAs into OSPFv3 type-5 LSAs changes. This issue occurs when one of the following conditions exists:
·     The translate-always keyword of the nssa command is configured or canceled on an NSSA ABR.
·     An NSSA ABR has been configured with a new router ID and the change is already in effect.
·     The device becomes an ABR or its role changes from ABR to another.
System impact
When the translator in an NSSA area changes, the former translator must flush the Type-5 LSAs translated from Type-7 LSAs and the new translator translates new OSPFv3 type-7 LSAs into OSPFv3 type-5 LSAs. This might cause temporary AES route flapping.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 nssatranslator-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 nssatranslator-status-change command.
Objects
OID (object name)
Index nodes
Value range
(ospfv3RouterId)
N/A
Ospfv3RouterIdTC
(ospfv3AreaNssaTranslatorState)
Method for the NSSA ABR to become capable of translating Type-7 LSAs into Type-5 LSAs.
ospfv3AreaId
INTEGER
enabled(1)
elected(2)
disabled(3)
Recommended action
1.     If the nssa translate-always command is configured on the local device, use the display ospfv3 command to identify whether the 7/5 translator state field displays Enabled.
¡     If yes, no action is required.
¡     If no, proceed to step 7.
If the nssa translate-always command is canceled on the local device, use the display ospfv3 command to identify whether the 7/5 translator state field displays Disabled.
¡     If the 7/5 translator state field displays Disabled, proceed to step 2.
¡     If the 7/5 translator state field displays Elected, no action is required.
2.     Use the display ospfv3 lsdb router command to identify whether the Options field in the router LSAs of an NSSA ABR contains the Nt bit.
3.     If the local device has been configured with a new router ID and the change is already in effect, identify whether the NSSA translator role is correct after the network topology is stable.
¡     If no, proceed to step 4.
4.     Identify whether other NSSA ABRs have been configured with new router IDs. After the network topology is stable, identify whether one of the new router IDs is larger than the local router ID.
5.     If a new NSSA ABR has been added in the area, identify whether the router ID of the new NSSA ABR is larger than the local router ID after the network topology is stable.
If the new device is not an ABR, proceed to step 6.
6.     Check whether the ospfv3NbrStateChange or ospfv3IfStateChange notification is generated on the local and neighbor devices.
¡     If yes, perform the recommended actions to clear the notification.
7.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfv3RestartStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.12
GR restarter state changes.
Informational
Warning
N/A
ON
This notification is generated when the state of the GR restarter changes. This issue occurs when one of the following conditions exists:
·     The device stops GR.
·     The device starts GR.
System impact
If the state of the GR restarter changes due to a GR failure, this issue will affect services.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 grrestarter-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 grrestarter-status-change command.
Objects
OID (object name)
Index nodes
Value range
(ospfv3RouterId)
N/A
Ospfv3RouterIdTC
(ospfv3RestartStatus)
GR restarter state.
N/A
INTEGER
notRestarting(1)
plannedRestart(2)
unplannedRestart(3)
(ospfv3RestartInterval)
GR timeout interval.
N/A
(ospfv3RestartExitReason)
Reason why the device exited GR restarter state.
N/A
INTEGER
none(1)
inProgress(2)
completed(3)
timedOut(4)
topologyChanged(5)
Recommended action
1.     If you are manually performing an active/standby switchover or restarting the OSPFv3 process with GR, no action is required. Otherwise, proceed to step 2.
2.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfv3NbrRestartHelperStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.13
The GR helper state of a neighbor changes.
Informational
Warning
N/A
ON
This notification is generated when the GR helper state of a neighbor changes. This issue occurs when one of the following conditions exists:
·     The neighbor becomes the GR helper.
·     The neighbor stops being the GR helper.
System impact
If the GR helper state of a neighbor changes due to a GR failure, this issue will affect services.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 grhelper-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 grhelper-status-change command.
Objects
OID (object name)
Index nodes
Value range
(ospfv3RouterId)
N/A
Ospfv3RouterIdTC
(ospfv3NbrRestartHelperStatus)
GR helper state of the neighbor.
ospfv3NbrIfIndex
ospfv3NbrIfInstId
ospfv3NbrRtrId
INTEGER
notHelping(1)
helping(2)
(ospfv3NbrRestartHelperAge)
GR helper aging timer.
ospfv3NbrIfIndex
ospfv3NbrIfInstId
ospfv3NbrRtrId
(ospfv3NbrRestartHelperExitReason)
Reason why the neighbor exited GR helper state.
ospfv3NbrIfIndex
ospfv3NbrIfInstId
ospfv3NbrRtrId
INTEGER
none(1)
inProgress(2)
completed(3)
timedOut(4)
topologyChanged(5)
Recommended action
ospfv3VirtNbrRestartHelperStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.14
The GR helper state of a virtual neighbor changes.
Informational
Warning
N/A
ON
This notification is generated when the GR helper state of a virtual neighbor changes. This issue occurs when one of the following conditions exists:
·     The virtual neighbor becomes the GR helper.
·     The virtual neighbor stops being the GR helper.
System impact
If the GR helper state of a virtual neighbor changes due to a GR failure, this issue will affect services.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtgrhelper-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtgrhelper-status-change command.
Objects
OID (object name)
Index nodes
Value range
(ospfv3RouterId)
N/A
Ospfv3RouterIdTC
(ospfv3VirtNbrRestartHelperStatus)
GR helper state of the virtual neighbor.
ospfv3VirtNbrArea
ospfv3VirtNbrRtrId
INTEGER
notHelping(1)
helping(2)
(ospfv3VirtNbrRestartHelperAge)
ospfv3VirtNbrArea
ospfv3VirtNbrRtrId
(ospfv3VirtNbrRestartHelperExitReason)
Reason why the virtual neighbor exited GR helper state.
ospfv3VirtNbrArea
ospfv3VirtNbrRtrId
INTEGER
none(1)
inProgress(2)
completed(3)
timedOut(4)
topologyChanged(5)
Recommended action
