06-Layer 3 - IP Routing
HomeSupportSwitchesS9820 SeriesReference GuidesMIB CompanionH3C S9820-8C MIB Companion-Release 6715-6W10006-Layer 3 - IP Routing
04-HH3C-ISIS-MIB
04-HH3C-ISIS-MIB 82.41 KB
HH3C-ISIS-MIB
About this MIB
Use this MIB to obtain all IS-IS process IDs by using the hh3cIsisSysInstance node.
MIB file name
hh3c-isis.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIsis(59)
Global objects
hh3cIsisSysInstance
Object (OID)
Access
Value range
Implementation
hh3cIsisSysInstance (1.3.6.1.4.1.25506.2.59.1.1.1.1.1)
read-only
Integer32
Integer32 (1..65535)
Process node.
As per the MIB.
hh3cIsisCircIndex
Object (OID)
Access
Value range
Implementation
hh3cIsisCircIndex
(1.3.6.1.4.1.25506.2.59.1.3.1.1.1)
not-accessible
IndexInteger
N/A
Interface index node.
As per the MIB.
hh3cIsisCircIfIndex
Object (OID)
Access
Value range
Implementation
hh3cIsisCircIfIndex
(1.3.6.1.4.1.25506.2.59.1.3.1.1.2)
read-only
InterfaceIndex
N/A
As per the MIB.
hh3cIsisAdjProtoType
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.59.1.2.1.1)
accessible-for-notify
INTEGER
ipv4(1)
ipv6(2)
IP protocol type.
As per the MIB.
hh3cIsisAdjProtoState
Object (OID)
Access
Value range
Implementation
hh3cIsisAdjProtoState (1.3.6.1.4.1.25506.2.59.1.2.1.2)
INTEGER
down (1)
initializing (2)
up (3)
IS-IS neighbor state.
As per the MIB.
Tabular objects
hh3cIsisSysTable
About this table
This table contains information about all IS-IS process IDs.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIsisSysInstance.
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Process node.
As per the MIB.
hh3cIsisCircTable
About this table
This table contains information about all interfaces enabled with IS-IS.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIsisSysInstance and hh3cIsisCircIndex.
Object (OID)
Access
Value range
Implementation
hh3cIsisCircIndex
not-accessible
Unsigned32
Unsigned32(1..100)
As per the MIB.
hh3cIsisCircIfIndex
read-only
Integer32
As per the MIB.
Notifications
hh3cIsisAdjacencyProtocolChange
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.59.0.1
Address family state change
Informational
Warning
N/A
ON
Notification triggers
This notification is generated when a change in address family has occurred.
Possible reasons for this notification include:
·     Adding the IPv4 address family.
·     Deleting the IPv4 address family.
·     Adding the IPv6 address family.
·     Deleting the IPv6 address family.
System impact
IS-IS might recalculate routes, resulting in route flapping and service traffic flapping.
Status control
ON
CLI: Use the snmp-agent trap enable isis adjacency-protocol-change command.
OFF
CLI: Use the undo snmp-agent trap enable isis adjacency-protocol-change command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.138.1.10.1.1 (isisNotificationSysLevelIndex)
System level index.
N/A
IsisLevel
level1(1)
level2(2)
level1and2(3)
1.3.6.1.2.1.138.1.10.1.2 (isisNotificationCircIfIndex)
Interface index.
N/A
Unsigned32
Unsigned32(1..2147483647)
1.3.6.1.2.1.138.1.10.1.3 (isisPduLspId)
LSP ID.
N/A
IsisLinkStatePDUID
OCTET STRING (8)
(hh3cIsisAdjProtoType)
Protocol type.
N/A
INTEGER
ipv4(1)
ipv6(1)
 (hh3cIsisAdjProtoState)
N/A
INTEGER
down (1)
initializing (2)
up (3)
1.3.6.1.2.1.31.1.1.1.1 (ifName)
Interface name.
ifIndex
DisplayString
OCTET STRING(0..255)
Recommended action
To resolve the issue:
1.     Check whether the address family change is normal. Execute the display this command in IS-IS view on the source device to whether the address family configured on the source device is consistent with that of the local device.
2.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
