03-HH3C-IPRAN-DCN-MIB | 136.67 KB |
HH3C-IPRAN-DCN-MIB (IPRAN)
About this MIB
This MIB describes how to use the network management System (NMS) to manage and control remote network elements in the data communication network (DCN) and obtain running states and online and offline notifications.
MIB file name
hh3c-ipran-dcn.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIpRanDcn(152)
Tabular objects
hh3cIpRanDcnInfoObject
About this table
This table contains network element information about the local device.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
This table does not contain indexes.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpRanDcnNeId (1.3.6.1.4.1.25506.2.152.1.1.1.1) |
read-only |
Hh3cIpRanNeId |
OCTET STRING (4) |
NE ID of the local device. |
As per the MIB. |
hh3cIpRanDcnNeIpType (1.3.6.1.4.1.25506.2.152.1.1.1.2) |
read-only |
InetAddressType |
ipv4(1) |
NE IP address type of the local device. |
As per the MIB. |
hh3cIpRanDcnNeIp (1.3.6.1.4.1.25506.2.152.1.1.1.3) |
read-only |
InetAddress |
OCTET STRING (0..255) |
NE IP address of the local device. |
As per the MIB. |
hh3cIpRanDcnMask (1.3.6.1.4.1.25506.2.152.1.1.1.4) |
read-only |
InetAddress |
Subnet mask of the NE IP address of the local device. |
As per the MIB. |
hh3cIpRanDcnMAC (1.3.6.1.4.1.25506.2.152.1.1.1.5) |
read-only |
MacAddress |
OCTET STRING (6) |
Bridge MAC of the local device. |
As per the MIB. |
hh3cIpRanDcnVendor (1.3.6.1.4.1.25506.2.152.1.1.1.6) |
read-only |
DisplayString |
SIZE (0..255) |
Vendor of the local device. |
As per the MIB. |
hh3cIpRanDcnNeInfoTable
About this table
This table contains information about all network elements in the DCN network.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cIpRanDcnNeInfoNeId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpRanDcnNeInfoNeId (1.3.6.1.4.1.25506.2.152.1.1.2.1.1) |
read-only |
Hh3cIpRanNeId |
OCTET STRING (4) |
NE ID. |
As per the MIB. |
hh3cIpRanDcnNeInfoNeIpType (1.3.6.1.4.1.25506.2.152.1.1.2.1.2) |
read-only |
InetAddressType |
ipv4(1) |
NE IP address type. |
As per the MIB. |
hh3cIpRanDcnNeInfoNeIp (1.3.6.1.4.1.25506.2.152.1.1.2.1.3) |
read-only |
InetAddress |
NE IP address. |
As per the MIB. |
hh3cIpRanDcnNeInfoMetric (1.3.6.1.4.1.25506.2.152.1.1.2.1.4) |
read-only |
Integer32 |
Standard MIB values. |
Distance from the local NE to the remote NE. |
As per the MIB. |
hh3cIpRanDcnNeInfoDeviceType (1.3.6.1.4.1.25506.2.152.1.1.2.1.5) |
read-only |
DisplayString |
Device type of the NE. |
As per the MIB. |
hh3cIpRanDcnNeInfoMAC (1.3.6.1.4.1.25506.2.152.1.1.2.1.6) |
read-only |
MacAddress |
OCTET STRING (6) |
Bridge MAC of the NE. |
As per the MIB. |
hh3cIpRanDcnNeInfoVendor (1.3.6.1.4.1.25506.2.152.1.1.2.1.7) |
read-only |
DisplayString |
Vendor of the NE. |
As per the MIB. |
hh3cIpRanDcnTrapObjects
About this table
This table contains information about the NE that has state change most recently.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpRanDcnNeNumber (1.3.6.1.4.1.25506.2.152.1.2.1) |
read-only |
Integer32 |
Total number of online NEs in the DCN network. |
As per the MIB. |
hh3cIpRanDcnNeChangeMode (1.3.6.1.4.1.25506.2.152.1.2.2) |
read-only |
INTEGER |
online (1), offline (2) |
Current state of the NE that has state change most recently. |
As per the MIB. |
hh3cIpRanDcnCompanyName (1.3.6.1.4.1.25506.2.152.1.2.3) |
read-only |
DisplayString |
Vendor name of the NE that has state change most recently. |
As per the MIB. |
hh3cIpRanDcnDeviceType (1.3.6.1.4.1.25506.2.152.1.2.4) |
read-only |
DisplayString |
Device type of the NE that has state change most recently. |
As per the MIB. |
hh3cIpRanDcnDeviceMac (1.3.6.1.4.1.25506.2.152.1.2.5) |
read-only |
MacAddress |
OCTET STRING(6) |
Bridge MAC of the NE that has state change most recently. |
As per the MIB. |
Notifications
hh3cIpRanDcnNeOnline
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.152.1.3.0.1 |
An NE comes online. |
Recovery |
N/A |
OFF |
Notification triggers
This notification is generated when a new NE comes online in the DCN network.
System impact
No negative impact on services.
Status control
ON
CLI: Use the auto-report command.
OFF
CLI: Use the undo auto-report command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.152.1.1.2.1.1 (hh3cIpRanDcnNeInfoNeId) |
NE ID. |
hh3cIpRanDcnNeInfoNeId |
Hh3cIpRanNeId |
OCTET STRING (4) |
1.3.6.1.4.1.25506.2.152.1.1.2.1.2 (hh3cIpRanDcnNeInfoNeIpType) |
InetAddressType |
ipv4(1) |
1.3.6.1.4.1.25506.2.152.1.1.2.1.3 (hh3cIpRanDcnNeInfoNeIp) |
NE IP address. |
InetAddress |
1.3.6.1.4.1.25506.2.152.1.2.3 (hh3cIpRanDcnCompanyName) |
Device vendor name. |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.152.1.2.4 (hh3cIpRanDcnDeviceType) |
Device type. |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.152.1.2.5 (hh3cIpRanDcnDeviceMac) |
Bridge MAC of the device. |
N/A |
MacAddress |
OCTET STRING (6) |
Recommended action
No action is required.
hh3cIpRanDcnNeOffline
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.152.1.3.0.2 |
An NE goes offline. |
Error |
Warning |
1.3.6.1.4.1.25506.2.152.1.3.0.1 (hh3cIpRanDcnNeOnline) |
OFF |
This notification is generated when an NE goes offline in the DCN network.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
NE ID. |
Hh3cIpRanNeId |
OCTET STRING (4) |
InetAddressType |
ipv4(1) |
NE IP address. |
InetAddress |
Recommended action
hh3cIpRanDcnNeIdConflict
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.152.1.3.0.3 |
An NE ID conflict occurs. |
Error |
Warning |
1.3.6.1.4.1.25506.2.152.1.3.0.4 (hh3cIpRanDcnNeIdConflictClear) |
ON |
This notification is generated when two or more devices have the same NE ID.
System impact
NMS cannot correctly manage devices, configuration cannot be deployed to the devices, and newly added services become abnormal.
Status control
ON
CLI: Use the snmp-agent trap enable dcn neid-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable dcn neid-conflict command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
NE ID. |
Hh3cIpRanNeId |
OCTET STRING (4) |
Recommended action
To resolve this issue:
1. Edit the NE ID for the network element that generates the notification, and then wait until the conflict is cleared.
2. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.152.1.3.0.4 |
The NE ID conflict is cleared. |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the NE ID conflict is cleared after you specify a unique value in the DCN network for the conflicting NE ID.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable dcn neid-conflict-clear command.
OFF
CLI: Use the undo snmp-agent trap enable dcn neid-conflict-clear command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
NE ID. |
Hh3cIpRanNeId |
OCTET STRING (4) |
Recommended action
hh3cIpRanDcnNeIpConflict
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.152.1.3.0.5 |
An NE IP address conflict occurs. |
Error |
Warning |
1.3.6.1.4.1.25506.2.152.1.3.0.6 (hh3cIpRanDcnNeIpConflictClear) |
ON |
This notification is generated when two or more devices have the same NE IP address.
System impact
The NEs with conflicting IP addresses might be hosted, and NMS cannot correctly manage the devices.
Status control
ON
CLI: Use the snmp-agent trap enable dcn neip-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable dcn neip-conflict command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
NE IP address. |
InetAddress |
Recommended action
1. Edit the NE IP address for the network element that generates the notification, and then wait until the conflict is cleared.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.152.1.3.0.6 |
The NE IP address conflict is cleared. |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the NE IP address conflict is cleared after you specify a unique value in the DCN network for the conflicting NE IP address.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable dcn neip-conflict-clear command.
OFF
CLI: Use the undo snmp-agent trap enable dcn neip-conflict-clear command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
NE IP address. |
InetAddress |
Recommended action
