05-Layer 3 - IP Services
HomeSupportSwitchesS9820 SeriesReference GuidesMIB CompanionH3C S9820-8C MIB Companion-Release 6715-6W10005-Layer 3 - IP Services
21-UDP-MIB
21-UDP-MIB 71.91 KB
UDP-MIB
About this MIB
This MIB is defined by RFC 4113. Use this MIB to obtain the UDP endpoint information and UDP packet statistics.
MIB file name
rfc4113-udp.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).udp(7)
Scalar objects
udpInDatagrams
Object (OID)
Access
Value range
Implementation
udpInDatagrams (1.3.6.1.2.1.7.1)
read- only
Counter32
Standard MIB values.
Total number of UDP datagrams delivered to applications.
As per the MIB.
udpNoPorts
Object (OID)
Access
Value range
Implementation
udpNoPorts (1.3.6.1.2.1.7.2)
read-only
Counter32
Total number of received UDP datagrams for which no application exist at the destination port.
As per the MIB.
udpInErrors
Object (OID)
Access
Value range
Implementation
udpInErrors (1.3.6.1.2.1.7.3)
read-only
Counter32
Number of received UDP datagrams that cannot be delivered for reasons other than the lack of an application at the destination port.
As per the MIB.
udpOutDatagrams
Object (OID)
Access
Value range
Implementation
udpOutDatagrams (1.3.6.1.2.1.7.4)
read-only
Counter32
Total number of UDP datagrams sent from this end.
As per the MIB.
udpHCInDatagrams
Object (OID)
Access
Value range
Implementation
udpHCInDatagrams (1.3.6.1.2.1.7.8)
read-only
Counter64
Total number of UDP datagrams delivered to applications, for devices that can receive more than 1 million UDP datagrams per second.
Not supported
udpHCOutDatagrams
Object (OID)
Access
Value range
Implementation
udpHCOutDatagrams (1.3.6.1.2.1.7.9)
read-only
Counter64
Total number of UDP datagrams sent from this end entity, for devices that can transmit more than 1 million UDP datagrams per second.
Not supported
Tabular objects
udpTable
About this table
Use this table to obtain IPv4 UDP listener information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are udpLocalAddress and udpLocalPort.
Object (OID)
Access
Value range
Implementation
udpLocalAddress (1.3.6.1.2.1.7.5.1.1)
read-only
IpAddress
Local IP address for the UDP listener. The value 0.0.0.0 indicates that the UDP listener can accept datagrams for any interface.
As per the MIB.
udpLocalPort (1.3.6.1.2.1.7.5.1.2)
read-only
Integer32
Integer32 (0..65535)
Local port number for the UDP listener.
As per the MIB.
udpEndpointTable
About this table
Use this table to obtain information about UDP endpoints on which a local application is receiving or sending datagrams.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are udpEndpointLocalAddressType, udpEndpointLocalAddress, udpEndpointLocalPort,  udpEndpointRemoteAddressType, udpEndpointRemoteAddress, udpEndpointRemotePort, and udpEndpointInstance.
Object (OID)
Access
Value range
Implementation
udpEndpointLocalAddressType (1.3.6.1.2.1.7.7.1.1)
not-accessible
InetAddressType
Address type of udpEndpointLocalAddress. Only
IPv4, IPv4z, IPv6, and IPv6z addresses are expected. The value unknown(0) indicates that the datagrams for all local IP addresses are received.
Only support ipv4(1) and ipv6 (2).
udpEndpointLocalAddress (1.3.6.1.2.1.7.7.1.2)
not-accessible
InetAddress
Local IP address of the UDP endpoint.
As per the MIB.
udpEndpointLocalPort (1.3.6.1.2.1.7.7.1.3)
not-accessible
InetPortNumber
Local port number of the UDP endpoint.
As per the MIB.
udpEndpointRemoteAddressType (1.3.6.1.2.1.7.7.1.4)
not-accessible
InetAddressType
Address type of udpEndpointRemoteAddress. Only IPv4, IPv4z, IPv6, and IPv6z addresses are expected. The value unknown(0) indicates that the datagrams for all remote IP addresses are received.
udpEndpointRemoteAddress (1.3.6.1.2.1.7.7.1.5)
not-accessible
InetAddress
Remote IP address of the UDP endpoint.
As per the MIB.
udpEndpointRemotePort (1.3.6.1.2.1.7.7.1.6)
not-accessible
InetPortNumber
Remote port number of the UDP endpoint.
As per the MIB.
udpEndpointInstance (1.3.6.1.2.1.7.7.1.7)
not-accessible
Unsigned32
Unsigned32 (1..4294967295)
Instance ID of the UDP connection, used for distinguishing multiple processes connected to the same UDP endpoint.
As per the MIB.
udpEndpointProcess (1.3.6.1.2.1.7.7.1.8)
read-only
Unsigned32
System's process ID for the process associated with the endpoint. The value is 0 if no such process exists.
As per the MIB.
