- 05-Layer 3 - IP Services
- 01-HH3C-ARP-RATELIMIT-MIB
- 02-HH3C-ARP-SUPPRESSION-MIB
- 03-HH3C-ARP-TRAP-MIB
- 04-HH3C-DHCP-SNOOP2-MIB
- 05-HH3C-DHCP4-CLIENT-MIB
- 06-HH3C-DHCP4-MIB
- 07-HH3C-DNS-MIB
- 08-HH3C-FIB-MIB
- 09-HH3C-IP-ADDRESS-MIB
- 10-HH3C-IPFW-MIB
- 11-HH3C-IPV6-ADDRESS-MIB
- 12-HH3C-ND-TRAP-MIB
- 13-HH3C-TCP-MIB
- 14-IP-FORWARD-MIB
- 15-IP-MIB
- 16-IPV6-ICMP-MIB
- 17-IPV6-MIB
- 18-IPV6-TCP-MIB
- 19-IPV6-UDP-MIB
- 20-TCP-MIB
- 21-UDP-MIB
10-HH3C-IPFW-MIB | 185.81 KB |
HH3C-IPFW-MIB
About this MIB
Use this MIB to obtain IP forwarding information and configure IP forwarding.
MIB file name
hh3c-ipfw.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIpfw(211)
Scalar objects
hh3cIpfwIfIndex
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpfwIfIndex (1.3.6.1.4.1.25506.2.211.2.1.1) |
accessible-for-notify |
InterfaceIndex |
Integer32 (1..2147483647) |
Index of the interface from which packets are received. |
As per the MIB. |
hh3cIpfwPeerAddress
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpfwPeerAddress (1.3.6.1.4.1.25506.2.211.2.1.2) |
OCTET STRING |
OCTET STRING (0..255) |
Destination IP address of received packets. |
As per the MIB. |
hh3cIpfwInterfaceName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpfwInterfaceName (1.3.6.1.4.1.25506.2.211.2.1.3) |
OCTET STRING |
Name of the interface from which packets are received. |
As per the MIB. |
hh3cIpfwChassis
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpfwChassis (1.3.6.1.4.1.25506.2.211.2.1.4) |
Unsigned32 |
Unsigned32(0..2147483647) |
Chassis number. |
As per the MIB. |
hh3cIpfwSlot
Access |
Syntax |
Value range |
Implementation |
hh3cIpfwSlot (1.3.6.1.4.1.25506.2.211.2.1.5) |
Unsigned32 |
Slot number. |
As per the MIB. |
hh3cIpfwVsysID
Access |
Syntax |
Value range |
Implementation |
hh3cIpfwVsysID (1.3.6.1.4.1.25506.2.211.2.1.6) |
Unsigned32 |
vSystem ID. |
As per the MIB. |
hh3cIpfwIPv4FragBufSrcAddress
Access |
Syntax |
Value range |
Implementation |
hh3cIpfwIPv4FragBufSrcAddress (1.3.6.1.4.1.25506.2.211.2.1.7) |
OCTET STRING |
Source IPv4 address of the packet that triggered the alarm notification. |
As per the MIB. |
hh3cIpfwIPv4FragBufDstAddress
Access |
Syntax |
Value range |
Implementation |
hh3cIpfwIPv4FragBufDstAddress (1.3.6.1.4.1.25506.2.211.2.1.8) |
OCTET STRING |
Destination IPv4 address of the packet that triggered the alarm notification. |
As per the MIB. |
hh3cIpfwIPv6FragBufSrcAddress
Access |
Syntax |
Value range |
Implementation |
hh3cIpfwIPv6FragBufSrcAddress (1.3.6.1.4.1.25506.2.211.2.1.9) |
OCTET STRING |
Source IPv6 address of the packet that triggered the alarm notification. |
As per the MIB. |
hh3cIpfwIPv6FragBufDstAddress
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpfwIPv6FragBufDstAddress (1.3.6.1.4.1.25506.2.211.2.1.10) |
OCTET STRING |
Destination IPv6 address of the packet that triggered the alarm notification. |
As per the MIB. |
hh3cIpfwMbufAllocFailedNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpfwMbufAllocFailedNum (1.3.6.1.4.1.25506.2.211.2.1.11) |
Unsigned32 |
Standard MIB values. |
As per the MIB. |
Tabular objects
hh3cIpfwSpeedTable
About this table
This table obtains IPv4 and IPv6 packet forwarding rate information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cIpfwSpeedStatIfIndex and hh3cIpSpeedStatIpType.
Access |
Syntax |
Value range |
Implementation |
hh3cIpfwSpeedStatIfIndex (1.3.6.1.4.1.25506.2.211.1.1.1.1) |
not-accessible |
InterfaceIndex |
Interface index. |
As per the MIB. |
hh3cIpfwSpeedStatIpType (1.3.6.1.4.1.25506.2.211.1.1.1.2) |
not-accessible |
INTEGER |
ipv4(1), ipv6(2) |
IP protocol type. |
As per the MIB. |
hh3cIpfwSpeedStatInterval (1.3.6.1.4.1.25506.2.211.1.1.1.3) |
read-only |
Unsigned32 |
Packet statistics collection period. |
As per the MIB. |
hh3cIpfwSpeedStatInPkts (1.3.6.1.4.1.25506.2.211.1.1.1.4) |
read-only |
Counter64 |
Incoming packet rate. |
As per the MIB. |
hh3cIpfwSpeedStatOutPkts (1.3.6.1.4.1.25506.2.211.1.1.1.5) |
read-only |
Counter64 |
Outgoing packet rate. |
As per the MIB. |
read-only |
Counter64 |
As per the MIB. |
hh3cIpfwSpeedStatOutBytes (1.3.6.1.4.1.25506.2.211.1.1.1.7) |
read-only |
Counter64 |
As per the MIB. |
hh3cIpfwSpeedStatInBits (1.3.6.1.4.1.25506.2.211.1.1.1.8) |
read-only |
Counter64 |
Incoming bit rate. |
As per the MIB. |
hh3cIpfwSpeedStatOutBits (1.3.6.1.4.1.25506.2.211.1.1.1.9) |
read-only |
Counter64 |
Outgoing bit rate. |
As per the MIB. |
hh3cIpfwMTUTable
About this table
This table obtains IPv4 and IPv6 interface MTU information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cIpfwMTUIfIndex and hh3cIpfwMTUIpType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpfwMTUIfIndex (1.3.6.1.4.1.25506.2.211.1.2.1.1) |
not-accessible |
InterfaceIndex |
Interface index. |
As per the MIB. |
hh3cIpfwMTUIpType (1.3.6.1.4.1.25506.2.211.1.2.1.2) |
not-accessible |
INTEGER |
ipv4(1), ipv6(2) |
IP protocol type. |
As per the MIB. |
hh3cIpfwMTUValue (1.3.6.1.4.1.25506.2.211.1.2.1.3) |
read-only |
Unsigned32 |
· If the value for hh3cIpfwMTUIpType is ipv4(1), the value range is 1280 to the maximum interface MTU. The maximum interface MTU varies by interface type. · If the value for hh3cIpfwMTUIpType is ipv6(2), the value range varies by device model and interface type. |
Interface MTU. |
As per the MIB. |
Notifications
hh3cIpfwPktNumExcAlarm
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.211.2.0.1 |
Disordered packets detected. |
Error |
Warning |
1.3.6.1.4.1.25506.2.211.2.0.2(hh3cIpfwPktNumExcAlarmResume) |
ON |
Notification triggers
This notification is generated when the length of the buffered packet queue exceeds the alarm threshold because the device receives a large number of fragments that require reassembly.
System impact
The device received too many fragments, some of which are disordered, and the device cannot complete fragment reassembly in time. This might cause packet loss and affect service operation.
Status control
ON
CLI: Use the snmp-agent trap enable ip-forwarding command.
OFF
CLI: Use the undo snmp-agent trap enable ip-forwarding command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.211.2.1.1 (hh3cIpfwIfIndex) |
Index of the interface from which the packets are received. |
N/A |
InterfaceIndex |
1.3.6.1.4.1.25506.2.211.2.1.2 (hh3cIpfwPeerAddress) |
IP address of the interface from which the packets are received. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.211.2.1.3 (hh3cIpfwInterfaceName) |
Name of the interface from which the packets are received. |
N/A |
OCTET STRING |
Recommended action
Use the IP address and interface information in the alarm message to identify the fragment source and verify if the fragments are valid. If the fragments are invalid, enable anti-attack measures against the source as a best practice to avoid effect on service operation.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.211.2.0.2 |
Disordered packet alarm removal |
Recovery |
Warning |
Recovery |
ON |
This notification is generated when the threshold exceeding alarm (buffered packet queue length threshold) is removed.
System impact
No negative impact on services.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
InterfaceIndex |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
hh3cIpfwIPv4VfrExcAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.211.2.0.3 |
IPv4 VFR buffer limit violation. |
Error |
Warning |
1.3.6.1.4.1.25506.2.211.2.0.4(hh3cIpfwIPv4VfrExcAlarmResume) |
ON |
This notification is generated when one of the following items exceeds the limit:
· Quantity of the fragments buffered by IPv4 VFR.
· Quantity of entries in the IPv4 fragment fast forwarding table.
System impact
Service interruption will occur because the device discards the fragments that IPv4 VFR cannot reassemble.
Status control
ON
CLI: N/A
OFF
CLI: N/A
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.211.2.1.4(hh3cIpfwChassis) |
Chassis number. |
N/A |
Unsigned32 |
Integer32 (0..2147483647) |
1.3.6.1.4.1.25506.2.211.2.1.5(hh3cIpfwSlot) |
Slot number. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.211.2.1.6(hh3cIpfwVsysID) |
vSystem ID. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.211.2.1.7(hh3cIpfwIPv4FragBufSrcAddress) |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.211.2.1.8(hh3cIpfwIPv4FragBufDstAddress) |
N/A |
OCTET STRING |
Recommended action
To resolve this issue:
1. Identify whether the number of IPv4 fragments in the current system is correct by capturing packets from the system.
2. Repeat the display system internal ip packet-drop statistics command in probe view, and observe the values of the following fields in the command output:
¡ Fragments in queue for virtual reassembly reach the limit
¡ Virtual fragment reassembly failed
3. Collect the results of the steps above, and then contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.211.2.0.4 |
Recovery from IPv4 VFR buffer limit violation. |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the device recovers from a condition of IPv4 VFR buffer limit violation.
System impact
No negative impact on the system.
Status control
ON
CLI: N/A
OFF
CLI: N/A
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number. |
N/A |
Unsigned32 |
Slot number. |
N/A |
Unsigned32 |
vSystem ID. |
N/A |
Unsigned32 |
Recommended action
No action is required. Please contact H3C Support.
hh3cIpfwIPv6VfrExcAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.211.2.0.5 |
IPv6 VFR buffer limit violation. |
Error |
Warning |
1.3.6.1.4.1.25506.2.211.2.0.6(hh3cIpfwIPv6VfrExcAlarmResume) |
ON |
· Quantity of the fragments buffered by IPv6 VFR.
· Quantity of entries in the IPv6 fragment fast forwarding table.
System impact
Service interruption will occur because the device discards the fragments that IPv6 VFR cannot reassemble.
Status control
ON
CLI: N/A
OFF
CLI: N/A
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number. |
N/A |
Unsigned32 |
Slot number. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.211.2.1.6(hh3cIpfwVsys) |
vSystem ID. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.211.2.1.9(hh3cIpfwIPv6FragBufSrcAddress) |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.211.2.1.10(hh3cIpfwIPv6FragBufDstAddress) |
N/A |
OCTET STRING |
Recommended action
1. Identify whether the number of IPv6 fragments in the current system is correct by capturing packets from the system.
2. Repeat the display system internal ipv6 packet-drop statistics command in probe view, and observe the values of the following fields in the command output:
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.211.2.0.6 |
Recovery from IPv6 VFR buffer limit violation. |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the device recovers from a condition of IPv6 VFR buffer limit violation.
System impact
Status control
ON
CLI: N/A
OFF
CLI: N/A
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Chassis number. |
N/A |
Unsigned32 |
Slot number. |
N/A |
Unsigned32 |
vSystem ID. |
N/A |
Unsigned32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.211.2.0.7 |
MBUF allocation failure |
Error |
Warning |
N/A |
ON |
This notification is generated due to memory insufficiency.
System impact
Packet failure occurs, interrupting services.
Status control
ON
CLI: snmp-agent trap enable ip-forwarding
OFF
CLI: undo snmp-agent trap enable ip-forwarding
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.211.2.1.11(hh3cIpfwMbufAllocFailedNum) |
Number of MBUF allocation failures. |
N/A |
Unsigned32 |
As per the MIB. |
Recommended action
1. Check the device for memory insufficiency.
2. Stop unused services and downsize services with high memory usage.
