05-Layer 3 - IP Services
HomeSupportSwitchesS9820 SeriesReference GuidesMIB CompanionH3C S9820-8C MIB Companion-Release 6715-6W10005-Layer 3 - IP Services
03-HH3C-ARP-TRAP-MIB
03-HH3C-ARP-TRAP-MIB 673.78 KB
HH3C-ARP-TRAP-MIB· 1
About this MIB· 1
MIB file name· 1
Root object 1
Scalar objects· 1
hh3cARPTrapEntryChassis· 1
hh3cARPTrapEntrySlot 1
hh3cARPTrapEntryIfName· 1
hh3cARPTrapEntryThreshold· 1
hh3cARPTrapDynamicEntryNum·· 2
hh3cARPTrapStaticEntryNum·· 2
hh3cARPTrapOtherEntryNum·· 2
hh3cARPTrapSuppEntryNum·· 2
hh3cARPTrapLocalConflictIf 3
hh3cARPTrapLocalConflictMac· 3
hh3cARPTrapLocalConflictIP· 3
hh3cARPTrapLocalSrcMac· 3
hh3cARPTrapLocalSrcIp· 3
hh3cARPTrapLocalDstMac· 4
hh3cARPTrapLocalDstIP· 4
hh3cARPTrapLocalPeVlan· 4
hh3cARPTrapLocalCeVlan· 4
hh3cARPTrapLocalInboundIf 4
hh3cARPTrapMoveUserIP· 5
hh3cARPTrapMoveUserMAC· 5
hh3cARPTrapMoveLocalIf 5
hh3cARPTrapMoveLocalPeVlan· 5
hh3cARPTrapMoveLocalCeVlan· 5
hh3cARPTrapMoveRemoteIF· 6
hh3cARPTrapMoveRemotePeVlan· 6
hh3cARPTrapMoveRemoteCeVlan· 6
hh3cARPTrapUIPCPRcvMac· 6
hh3cARPTrapUIPCPRcvPVid· 6
hh3cARPTrapUIPCPRcvCVid· 7
hh3cARPTrapUIPCPRcvIf 7
hh3cARPTrapUIPCPLocalMac· 7
hh3cARPTrapUIPCPLocalPVid· 7
hh3cARPTrapUIPCPLocalCVid· 7
hh3cARPTrapUIPCPLocalIf 8
hh3cARPTrapUIPCPIpAddr 8
hh3cARPTrapAckIfName· 8
hh3cARPTrapAckSourceIP· 8
hh3cARPTrapSpeedLimitChassis· 8
hh3cARPTrapSpeedLimitSlot 9
hh3cARPTrapSpeedLimitSupValue· 9
hh3cARPTrapSpeedLimitCurValue· 9
hh3cARPTrapSpeedLimitSupType· 9
hh3cARPTrapPktValidCheckIf 9
hh3cARPTrapPktValidCheckMac· 10
hh3cARPTrapPktValidCheckIp· 10
hh3cARPTrapPktValidCheckVlan· 10
hh3cARPTrapPktValidtCheckSvlan· 10
hh3cARPTrapGatewayCheckIf 10
hh3cARPTrapGatewayCheckSlot 11
hh3cARPTrapGatewayCheckIp· 11
hh3cARPTrapDtcDropVlanPktChassis· 11
hh3cARPTrapDtcDropVlanPktSlot 11
hh3cARPTrapDtcDropVlanPktIfName· 11
hh3cARPTrapDtcDropVlanPktVlanId· 12
hh3cARPTrapDtcDropVlanPktServId· 12
hh3cARPTrapDtcDropVlanPktType· 12
hh3cARPTrapDtcDropVsiPktChassis· 12
hh3cARPTrapDtcDropVsiPktSlot 12
hh3cARPTrapDtcDropVsiPktIfName· 13
hh3cARPTrapDtcDropVsiPktVlanId· 13
hh3cARPTrapDtcDropVsiPktServId· 13
hh3cARPTrapDtcDropVsiPktType· 13
hh3cARPTrapDtcDropIfPktChassis· 14
hh3cARPTrapDtcDropIfPktSlot 14
hh3cARPTrapDtcDropIfPktIfName· 14
hh3cARPTrapDtcDropIfPktVlanId· 14
hh3cARPTrapDtcDropIfPktServId· 14
hh3cARPTrapDtcDropIfPktType· 15
hh3cARPTrapMacMismatchChassis· 15
hh3cARPTrapMacMismatchSlot 15
hh3cARPTrapMacMismatchIfName· 15
hh3cARPTrapMacMismatchIP· 15
hh3cARPTrapMacMismatchVrf 16
hh3cARPTrapMacMismatchMac· 16
hh3cARPTrapEntryCheckChassis· 16
hh3cARPTrapEntryCheckSlot 16
hh3cARPTrapEntryCheckIfName· 17
hh3cARPTrapEntryCheckIP· 17
hh3cARPTrapEntryCheckMac· 17
hh3cARPTrapEntryCheckPeVlan· 17
hh3cARPTrapEntryCheckCeVlan· 17
hh3cARPTrapEntryCheckPortIfName· 18
hh3cARPTrapPktQueChassis· 18
hh3cARPTrapPktQueSlot 18
hh3cARPTrapPktQueNum·· 18
Notifications· 18
hh3cARPTrapThresholdAlarm·· 18
hh3cARPTrapThresholdResume· 20
hh3cARPTrapSlotThresholdAlarm·· 20
hh3cARPTrapSlotThresholdResume· 22
hh3cARPTrapIfThresholdAlarm·· 23
hh3cARPTrapIfThresholdResume· 24
hh3cARPTrapSuppThresholdAlarm·· 24
hh3cARPTrapSuppThresholdResume· 25
hh3cARPTrapMACConflictAlarm·· 26
hh3cARPTrapMACConflictResume· 28
hh3cARPTrapMACIPConflictAlarm·· 29
hh3cARPTrapMACIPConflictResume· 30
hh3cARPTrapIPConflictAlarm·· 31
hh3cARPTrapIPConflictResume· 33
hh3cARPTrapHostMoveAlarm·· 34
hh3cARPTrapHostMoveResume· 35
hh3cARPTrapUserIpConflictAlarm·· 36
hh3cARPTrapAckStrictCheckAlarm·· 37
hh3cARPTrapSpeedLimitAlarm·· 38
hh3cARPTrapSpeedLimitResume· 39
hh3cARPTrapPacketValidCheckAlarm·· 40
hh3cARPTrapGatewayCheckAlarm·· 41
hh3cARPTrapGatewayCheckResume· 42
hh3cARPTrapDtcDropVlanPktAlarm·· 43
hh3cARPTrapDtcDropVsiPktAlarm·· 44
hh3cARPTrapDtcDropIfPktAlarm·· 45
hh3cARPTrapMacMismatchAlarm·· 46
hh3cARPTrapMacMismatchResume· 47
hh3cARPTrapEntryCheckAlarm·· 48
hh3cARPTrapPktQueThresholdAlarm·· 49
hh3cARPTrapPktQueThresholdResume· 50
HH3C-ARP-TRAP-MIB
About this MIB
Use this MIB to output notifications for the ARP module.
MIB file name
hh3c-arp-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cARPTrap(217)
Scalar objects
Object (OID)
Access
Value range
Implementation
hh3cARPTrapEntryChassis (1.3.6.1.4.1.25506.2.217.1.1.1)
accessible-for-notify
Unsigned32
Unsigned32
Chassis number for the notification.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapEntrySlot (1.3.6.1.4.1.25506.2.217.1.1.2)
Unsigned32
Unsigned32
Slot number for the notification.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapEntryIfName (1.3.6.1.4.1.25506.2.217.1.1.3)
DisplayString
OCTET STRING  (0..255)
Interface name for the notification.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapEntryThreshold (1.3.6.1.4.1.25506.2.217.1.1.4)
Unsigned32
Standard MIB values.
Alarm threshold.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapDynamicEntryNum (1.3.6.1.4.1.25506.2.217.1.1.5)
Unsigned32
Number of dynamic ARP entries.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapStaticEntryNum (1.3.6.1.4.1.25506.2.217.1.1.6)
Unsigned32
Number of static ARP entries.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapOtherEntryNum (1.3.6.1.4.1.25506.2.217.1.1.7)
Unsigned32
Number of other ARP entries.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapSuppEntryNum (1.3.6.1.4.1.25506.2.217.1.1.8)
Unsigned32
Number of ARP suppression entries.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapLocalConflictIf (1.3.6.1.4.1.25506.2.217.2.1.1.1)
OCTET STRING
OCTET STRING  (1..47)
Interface that receives the conflicting ARP packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapLocalConflictMac (1.3.6.1.4.1.25506.2.217.2.1.1.2)
OCTET STRING
OCTET STRING  (1..15)
Sender MAC address in the conflicting ARP packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapLocalConflictIP (1.3.6.1.4.1.25506.2.217.2.1.1.3)
IpAddress
Sender IP address in the conflicting ARP packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapLocalSrcMac (1.3.6.1.4.1.25506.2.217.2.1.1.4)
OCTET STRING
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapLocalSrcIp (1.3.6.1.4.1.25506.2.217.2.1.1.5)
IpAddress
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapLocalDstMac (1.3.6.1.4.1.25506.2.217.2.1.1.6)
OCTET STRING
Target MAC address in the conflicting ARP packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapLocalDstIP (1.3.6.1.4.1.25506.2.217.2.1.1.7)
IpAddress
Target IP address in the conflicting ARP packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapLocalPeVlan (1.3.6.1.4.1.25506.2.217.2.1.1.8)
Unsigned32
Outer VLAN of the conflicting ARP packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapLocalCeVlan (1.3.6.1.4.1.25506.2.217.2.1.1.9)
Unsigned32
Inner VLAN of the conflicting ARP packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapLocalInboundIf (1.3.6.1.4.1.25506.2.217.2.1.1.10)
OCTET STRING
Physical interface corresponding to the VLAN interface that receives the conflicting ARP packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapMoveUserIP (1.3.6.1.4.1.25506.2.217.2.2.1.1)
IpAddress
Sender IP address in the ARP packet whose port changes.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapMoveUserMAC (1.3.6.1.4.1.25506.2.217.2.2.1.2)
OCTET STRING
Sender MAC address in the ARP packet whose port changes.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapMoveLocalIf (1.3.6.1.4.1.25506.2.217.2.2.1.3)
OCTET STRING
Name of the port before migration.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapMoveLocalPeVlan (1.3.6.1.4.1.25506.2.217.2.2.1.4)
Unsigned32
Outer VLAN of the ARP packet before port migration.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapMoveLocalCeVlan (1.3.6.1.4.1.25506.2.217.2.2.1.5)
Unsigned32
Inner VLAN of the ARP packet before port migration.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapMoveRemoteIF (1.3.6.1.4.1.25506.2.217.2.2.1.6)
OCTET STRING
Name of the port after migration.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapMoveRemotePeVlan (1.3.6.1.4.1.25506.2.217.2.2.1.7)
Unsigned32
Outer VLAN of the ARP packet after port migration.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapMoveRemoteCeVlan (1.3.6.1.4.1.25506.2.217.2.2.1.8)
Unsigned32
Inner VLAN of the ARP packet after port migration.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapUIPCPRcvMac (1.3.6.1.4.1.25506.2.217.2.3.1.1)
OCTET STRING
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapUIPCPRcvPVid (1.3.6.1.4.1.25506.2.217.2.3.1.2)
Unsigned32
Outer VLAN of the local interface on which the conflict occurs.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapUIPCPRcvCVid (1.3.6.1.4.1.25506.2.217.2.3.1.3)
Unsigned32
Inner VLAN of the local interface on which the conflict occurs.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapUIPCPRcvIf (1.3.6.1.4.1.25506.2.217.2.3.1.4)
OCTET STRING
Local interface on which the conflict occurs.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapUIPCPLocalMac (1.3.6.1.4.1.25506.2.217.2.3.1.5)
OCTET STRING
MAC address in the local ARP entry.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapUIPCPLocalPVid (1.3.6.1.4.1.25506.2.217.2.3.1.6)
Unsigned32
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapUIPCPLocalCVid (1.3.6.1.4.1.25506.2.217.2.3.1.7)
Unsigned32
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapUIPCPLocalIf (1.3.6.1.4.1.25506.2.217.2.3.1.8)
OCTET STRING
Name of the interface that receives the ARP packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapUIPCPIpAddr (1.3.6.1.4.1.25506.2.217.2.3.1.9)
IpAddress
IP address in the local ARP entry.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapAckIfName (1.3.6.1.4.1.25506.2.217.2.4.1.1)
OCTET STRING
Interface that receives the packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapAckSourceIP (1.3.6.1.4.1.25506.2.217.2.4.1.2)
IpAddress
Sender IP address in the received ARP packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapSpeedLimitChassis (1.3.6.1.4.1.25506.2.217.2.5.1.1)
Unsigned32
Number of the chassis that sends ARP packets or ARP Miss messages.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapSpeedLimitSlot (1.3.6.1.4.1.25506.2.217.2.5.1.2)
Unsigned32
Slot number for the ARP packets or ARP Miss messages.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapSpeedLimitSupValue (1.3.6.1.4.1.25506.2.217.2.5.1.3)
Unsigned32
Sending rate limit (in pps) for ARP packets or ARP Miss messages.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapSpeedLimitCurValue (1.3.6.1.4.1.25506.2.217.2.5.1.4)
Unsigned32
Current sending rate (in pps) for ARP packets or ARP Miss messages.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapSpeedLimitSupType (1.3.6.1.4.1.25506.2.217.2.5.1.5)
INTEGER
packet(1)
miss(2)
Rate limit type.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapPktValidCheckIf (1.3.6.1.4.1.25506.2.217.2.6.1.1)
OCTET STRING
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapPktValidCheckMac (1.3.6.1.4.1.25506.2.217.2.6.1.2)
OCTET STRING
Sender MAC address in the ARP packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapPktValidCheckIp (1.3.6.1.4.1.25506.2.217.2.6.1.3)
IpAddress
Sender IP address in the ARP packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapPktValidCheckVlan (1.3.6.1.4.1.25506.2.217.2.6.1.4)
Unsigned32
VLAN ID for the ARP packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapPktValidtCheckSvlan (1.3.6.1.4.1.25506.2.217.2.6.1.5)
Unsigned32
Service VLAN ID for the ARP packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapGatewayCheckIf (1.3.6.1.4.1.25506.2.217.2.7.1.1)
OCTET STRING
Name of the interface that receives the ARP attack packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapGatewayCheckSlot (1.3.6.1.4.1.25506.2.217.2.7.1.2)
Unsigned32
Slot number of the interface module that receives the ARP attack packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapGatewayCheckIp (1.3.6.1.4.1.25506.2.217.2.7.1.3)
IpAddress
Sender IP address in the received ARP attack packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapDtcDropVlanPktChassis (1.3.6.1.4.1.25506.2.217.2.8.1.1)
Unsigned32
Number of the chassis in which ARP attack detection drops a packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapDtcDropVlanPktSlot (1.3.6.1.4.1.25506.2.217.2.8.1.2)
Unsigned32
Number of the slot on which ARP attack detection drops a packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.217.2.8.1.3)
OCTET STRING
Interface on which ARP attack detection drops a packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapDtcDropVlanPktVlanId (1.3.6.1.4.1.25506.2.217.2.8.1.4)
Unsigned32
ID of the VLAN on which ARP attack detection drops a packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapDtcDropVlanPktServId (1.3.6.1.4.1.25506.2.217.2.8.1.5)
Unsigned32
ID of the service where ARP attack detection drops a packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapDtcDropVlanPktType (1.3.6.1.4.1.25506.2.217.2.8.1.6)
INTEGER
sourceMacInvalidDrop (1)
destMacInvalidDrop (2)
ipInvalidDrop (3)
ipcimNobindingDrop (4)
Reason why ARP attack detection drops a packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapDtcDropVsiPktChassis (1.3.6.1.4.1.25506.2.217.2.9.1.1)
Unsigned32
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapDtcDropVsiPktSlot (1.3.6.1.4.1.25506.2.217.2.9.1.2)
Unsigned32
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapDtcDropVsiPktIfName (1.3.6.1.4.1.25506.2.217.2.9.1.3)
OCTET STRING
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapDtcDropVsiPktVlanId (1.3.6.1.4.1.25506.2.217.2.9.1.4)
Unsigned32
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapDtcDropVsiPktServId (1.3.6.1.4.1.25506.2.217.2.9.1.5)
Unsigned32
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapDtcDropVsiPktType (1.3.6.1.4.1.25506.2.217.2.9.1.6)
INTEGER
ipInvalidDrop (3)
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapDtcDropIfPktChassis (1.3.6.1.4.1.25506.2.217.2.10.1.1)
Unsigned32
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapDtcDropIfPktSlot (1.3.6.1.4.1.25506.2.217.2.10.1.2)
Unsigned32
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapDtcDropIfPktIfName (1.3.6.1.4.1.25506.2.217.2.10.1.3)
OCTET STRING
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapDtcDropIfPktVlanId (1.3.6.1.4.1.25506.2.217.2.10.1.4)
Unsigned32
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapDtcDropIfPktServId (1.3.6.1.4.1.25506.2.217.2.10.1.5)
Unsigned32
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapDtcDropIfPktType (1.3.6.1.4.1.25506.2.217.2.10.1.6)
INTEGER
ipInvalidDrop (3)
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapMacMismatchChassis (1.3.6.1.4.1.25506.2.217.2.11.1.1)
Unsigned32
Chassis number for the MAC address inconsistency.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapMacMismatchSlot (1.3.6.1.4.1.25506.2.217.2.11.1.2)
Unsigned32
Slot number for the MAC address inconsistency.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapMacMismatchIfName (1.3.6.1.4.1.25506.2.217.2.11.1.3)
OCTET STRING
Interface name for the MAC address inconsistency.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapMacMismatchIP (1.3.6.1.4.1.25506.2.217.2.11.1.4)
IpAddress
IP address in the static ARP entry.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapMacMismatchVrf (1.3.6.1.4.1.25506.2.217.2.11.1.5)
Unsigned32
VPN instance for the static ARP entry.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapMacMismatchMac (1.3.6.1.4.1.25506.2.217.2.11.1.6)
OCTET STRING
MAC address in the static ARP entry.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapEntryCheckChassis (1.3.6.1.4.1.25506.2.217.2.12.1.1)
Unsigned32
Chassis number for the ARP entry check.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapEntryCheckSlot (1.3.6.1.4.1.25506.2.217.2.12.1.2)
Unsigned32
Slot number for the ARP entry check.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapEntryCheckIfName (1.3.6.1.4.1.25506.2.217.2.12.1.3)
OCTET STRING
Interface name for the ARP entry check.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapEntryCheckIP (1.3.6.1.4.1.25506.2.217.2.12.1.4)
IpAddress
IP address in the original ARP entry.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapEntryCheckMac (1.3.6.1.4.1.25506.2.217.2.12.1.5)
OCTET STRING
MAC address in the original ARP entry.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapEntryCheckPeVlan (1.3.6.1.4.1.25506.2.217.2.12.1.6)
Unsigned32
Inner VLAN of the original ARP entry.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapEntryCheckCeVlan (1.3.6.1.4.1.25506.2.217.2.12.1.7)
Unsigned32
Outer VLAN of the original ARP entry.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapEntryCheckPortIfName (1.3.6.1.4.1.25506.2.217.2.12.1.8)
OCTET STRING
Interface name for the original ARP entry.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapPktQueChassis (1.3.6.1.4.1.25506.2.217.2.13.1.1)
Unsigned32
Chassis number for the ARP packet queue.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapPktQueSlot (1.3.6.1.4.1.25506.2.217.2.13.1.2)
Unsigned32
Slot number of the card where the ARP packet queue resides.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cARPTrapPktQueNum (1.3.6.1.4.1.25506.2.217.2.13.1.3)
Unsigned32
Number of packets cached in the ARP packet queue.
As per the MIB.
Notifications
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.217.1.0.1
The number of global ARP entries exceeded the alarm threshold.
Error
Warning
1.3.6.1.4.1.25506.2.217.1.0.2 (hh3cARPTrapThresholdResume)
OFF
Notification triggers
This notification is generated when the number of ARP entries learned by the device exceeds the alarm threshold (80% of the upper entry limit).
System impact
If the number of ARP entries continues to increase, the device might not learn new ARP entries because of insufficient resources, which causes service interruption.
Status control
ON
CLI: Use the snmp-agent trap enable arp entry-limit command.
OFF
CLI: Use the undo snmp-agent trap enable arp entry-limit command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.217.1.1.4 (hh3cARPTrapEntryThreshold)
Alarm threshold.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.1.1.5 (hh3cARPTrapDynamicEntryNum)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.1.1.6 (hh3cARPTrapStaticEntryNum)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.1.1.7 (hh3cARPTrapOtherEntryNum)
N/A
Unsigned32
Recommended action
1.     Execute the display arp all command to compare the numbers of static and dynamic ARP entries.
¡     If the number of static ARP entries is larger, go to step 2.
¡     If the number of dynamic ARP entries is larger, go to step 3.
2.     Based on the network planning and service deployment, Identify whether the static ARP entries are necessary.
¡     If the static ARP entries are necessary, go to step 3.
¡     If the static ARP entries are not necessary, execute the undo arp command to delete specified ARP entries or execute the reset arp static command to clear all static ARP entries. Make sure the operation does not affect services.
3.     Execute the arp max-learning-number command to set a larger dynamic ARP learning limit for the device. Execute the arp max-learning-num command to set larger dynamic ARP learning limits for interfaces.
4.     If the issue persists, collect configuration files and alarm information, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
The number of ARP entries dropped below the alarm threshold.
Recovery
Warning
N/A
OFF
This notification is generated when the number of ARP entries learned by the device drops below the alarm threshold (60% of the upper entry limit).
System impact
The device can learn ARP entries normally. No negative impact on services.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Alarm threshold.
N/A
Unsigned32
N/A
Unsigned32
N/A
Unsigned32
N/A
Unsigned32
Recommended action
No action is required.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.1.0.3
The number of ARP entries on the card exceeded the alarm threshold.
Error
Warning
1.3.6.1.4.1.25506.2.217.1.0.4(hh3cARPTrapSlotThresholdResume)
OFF
This notification is generated when the number of ARP entries learned by a card exceeds the alarm threshold (80% of the upper entry limit).
System impact
If the number of ARP entries on the card continues to increase, the card might not learn new ARP entries because of insufficient resources, which causes service interruption.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.217.1.1.1 (hh3cARPTrapEntryChassis)
Chassis number.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.1.1.2 (hh3cARPTrapEntrySlot)
Slot number.
N/A
Unsigned32
Alarm threshold.
N/A
Unsigned32
N/A
Unsigned32
Recommended action
1.     Execute the display arp command to view dynamic ARP entries on the card.
2.     Based on the network planning and service deployment, Identify whether the dynamic ARP entries are necessary.
¡     If the dynamic ARP entries are necessary, go to step 3.
¡     If the dynamic ARP entries are not necessary, execute the undo arp command to delete specified ARP entries. Make sure the operation does not affect services.
3.     Execute the arp max-learning-number command to set a larger dynamic ARP learning limit for the card.
Basic information
OID
Event
Severity
Default status
The number of ARP entries on the card dropped below the alarm threshold.
Recovery
Warning
N/A
OFF
This notification is generated when the number of ARP entries learned by a card drops below the alarm threshold (60% of the upper entry limit).
System impact
The card can learn ARP entries normally. No negative impact on services.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Chassis number.
N/A
Unsigned32
Slot number.
N/A
Unsigned32
Alarm threshold.
N/A
Unsigned32
N/A
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.1.0.5
The number of ARP entries on the interface exceeded the alarm threshold.
Error
Warning
1.3.6.1.4.1.25506.2.217.1.0.6(hh3cARPTrapIfThresholdResume)
OFF
This notification is generated when the number of ARP entries learned by an interface exceeds the alarm threshold (80% of the upper entry limit).
System impact
If the number of ARP entries on the interface continues to increase, the interface might not learn new ARP entries because of insufficient resources, which causes service interruption.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.217.1.1.3 (hh3cARPTrapEntryIfName)
Interface name.
N/A
DisplayString
Alarm threshold.
N/A
Unsigned32
N/A
Unsigned32
Recommended action
1.     Execute the display arp command to view the dynamic ARP entries on the interface.
3.     Execute the arp max-learning-num command to set a larger dynamic ARP learning limit for the interface.
Basic information
OID
Event
Severity
Default status
The number of ARP entries on the interface dropped below the alarm threshold.
Recovery
Warning
N/A
OFF
This notification is generated when the number of ARP entries learned by an interface drops below the alarm threshold (60% of the upper entry limit).
System impact
The interface can learn ARP entries normally. No negative impact on services.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Interface name.
N/A
DisplayString
Alarm threshold.
N/A
Unsigned32
N/A
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.1.0.7
The number of ARP suppression entries on the device exceeded the alarm threshold.
Error
Warning
1.3.6.1.4.1.25506.2.217.1.0.8(hh3cARPTrapSuppThresholdResume)
OFF
This notification is generated when the number of ARP suppression entries learned by the device exceeds the alarm threshold (80% of the upper entry limit).
System impact
If the number of ARP suppression entries on the interface continues to increase, the device might not learn new ARP suppression entries because of insufficient resources, which causes service interruption.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Alarm threshold.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.1.1.8 (hh3cARPTrapSuppEntryNum)
N/A
Unsigned32
Recommended action
1.     Execute the display arp suppression xconnect-group command to view ARP suppression entries.
2.     Based on the network planning and service deployment, Identify whether the ARP suppression entries are necessary.
¡     If the ARP suppression entries are necessary, go to step 3.
¡     If the ARP suppression entries are not necessary, execute the reset arp suppression xconnect-group command to clear ARP suppression entries.
3.     If the issue persists, collect configuration files and alarm information, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
The number of ARP suppression entries on the device dropped below the alarm threshold.
Recovery
Warning
N/A
OFF
This notification is generated when the number of ARP suppression entries learned by the device drops below the alarm threshold (60% of the upper entry limit).
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Alarm threshold.
N/A
Unsigned32
N/A
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.1.0.1
The sender MAC address in the received ARP packet and the MAC address of the local device conflicted.
Error
Major
1.3.6.1.4.1.25506.2.217.2.1.0.2(hh3cARPTrapMACConflictResume)
OFF
This notification is generated when the sender MAC address in the received ARP packet is the same as the MAC address of the local device.
This notification might be generated when the following events occur:
·     An endpoint on the network has the same MAC address as that of the local device.
·     The network has a loop.
System impact
The conflict might cause service interruption.
Status control
ON
CLI: Use the snmp-agent trap enable arp local-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable arp local-conflict command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.217.2.1.1.1 (hh3cARPTrapLocalConflictIf)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.1.1.2 (hh3cARPTrapLocalConflictMac)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.1.1.5 (hh3cARPTrapLocalSrcIp)
N/A
IpAddress
1.3.6.1.4.1.25506.2.217.2.1.1.8 (hh3cARPTrapLocalPeVlan)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.1.1.9 (hh3cARPTrapLocalCeVlan)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.1.1.10 (hh3cARPTrapLocalInboundIf)
N/A
OCTET STRING
Recommended action
1.     Configure STP to Identify whether the network has a loop.
2.     Identify whether another device on the network has the same MAC address as that of the local device.
¡     If you can identify the device that has the same MAC address, change the MAC address of the device.
¡     If you cannot identify the device that has the same MAC address, change the MAC address of the corresponding interface.
Basic information
OID
Event
Severity
Default status
The condition that the sender MAC address in the received ARP packet and the MAC address of the local device conflicted was cleared.
Recovery
Major
N/A
OFF
This notification is generated when the interface does not receive any ARP packet in which the sender MAC address is the same as the interface MAC address within 3 minutes.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET STRING
N/A
OCTET STRING
N/A
IpAddress
N/A
Unsigned32
N/A
Unsigned32
N/A
OCTET STRING
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.1.0.3
The sender MAC and IP addresses in the received ARP packet and the MAC and IP addresses of the local device conflicted.
Error
Major
1.3.6.1.4.1.25506.2.217.2.1.0.4(hh3cARPTrapMACIPConflictResume)
OFF
This notification is generated when the sender MAC and IP addresses in the received ARP packet are the same as the MAC and IP addresses of the local device.
·     The network has an ARP packet attack.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET STRING
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.1.1.3 (hh3cARPTrapLocalConflictIP)
N/A
IpAddress
1.3.6.1.4.1.25506.2.217.2.1.1.6 (hh3cARPTrapLocalDstMac)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.1.1.7 (hh3cARPTrapLocalDstIP)
N/A
IpAddress
N/A
Unsigned32
N/A
Unsigned32
N/A
OCTET STRING
Recommended action
2.     If the network does not have any loop, identify the source through capturing packets, and then edit the IP and MAC addresses of the device that sends the ARP packet.
Basic information
OID
Event
Severity
Default status
The condition that the sender MAC and IP addresses in the received ARP packet and the MAC and IP addresses of the local device conflicted was cleared.
Recovery
Major
N/A
OFF
This notification is generated when the interface does not receive any ARP packet in which the sender IP and MAC addresses are the same as the interface IP and MAC addresses within 3 minutes.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET STRING
N/A
OCTET STRING
N/A
IpAddress
N/A
OCTET STRING
N/A
IpAddress
N/A
Unsigned32
N/A
Unsigned32
N/A
OCTET STRING
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.1.0.5
The sender IP address in the received ARP packet and the IP address of the local device conflicted.
Error
Major
1.3.6.1.4.1.25506.2.217.2.1.0.6(hh3cARPTrapIPConflictResume)
OFF
This notification is generated when the sender IP address in the ARP packet is the same as that of the local device.
·     Another device on the network has the same IP address as that of the local device.
·     The network has an ARP packet attack that forges the sender IP address.
System impact
The gateway information of the user might be edited by the attacker, which causes an ARP packet attack. As a result, user services might be interrupted.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET STRING
N/A
IpAddress
1.3.6.1.4.1.25506.2.217.2.1.1.4 (hh3cARPTrapLocalSrcMac)
N/A
OCTET STRING
N/A
Unsigned32
N/A
Unsigned32
Recommended action
1.     Identify whether another device on the network has the same IP address as that of the local device.
¡     If you can identify the device that has the same IP address, change the IP address of the device.
¡     If you cannot identify the device that has the same IP address, change the IP address of the corresponding interface. Make sure the operation does not affect services.
2.     Identify whether an ARP packet attack exists on the network and identify the attack source through capturing packets.
Basic information
OID
Event
Severity
Default status
The condition that the sender IP address in the received ARP packet and the IP address of the local device conflicted was cleared.
Recovery
Major
N/A
OFF
This notification is generated when the interface does not receive any ARP packet in which the sender IP address is the same as the interface IP address within 3 minutes.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET STRING
N/A
IpAddress
N/A
OCTET STRING
N/A
Unsigned32
N/A
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.2.0.1
The access port for a host changed.
Error
Warning
1.3.6.1.4.1.25506.2.217.2.2.0.2(hh3cARPTrapHostMoveResume)
OFF
This notification is generated when the user port migrates after you enable recording user port migrations.
System impact
The user port migration might cause service interruption. Too many user port migrations might degrade the device performance.
Status control
ON
CLI: Use the snmp-agent trap enable arp user-move command.
OFF
CLI: Use the undo snmp-agent trap enable arp user-move command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.217.2.2.1.1 (hh3cARPTrapMoveUserIP)
N/A
IpAddress
1.3.6.1.4.1.25506.2.217.2.2.1.2 (hh3cARPTrapMoveUserMAC)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.2.1.3 (hh3cARPTrapMoveLocalIf)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.2.1.4 (hh3cARPTrapMoveLocalPeVlan)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.2.1.5 (hh3cARPTrapMoveLocalCeVlan)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.2.1.6 (hh3cARPTrapMoveRemoteIF)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.2.1.7 (hh3cARPTrapMoveRemotePeVlan)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.2.1.8 (hh3cARPTrapMoveRemoteCeVlan)
N/A
Unsigned32
Recommended action
1.     Identify whether the user port migration is reasonable.
2.     If the issue persists, collect configuration files and alarm information, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
The condition that the access port for a host changed was cleared.
Recovery
Warning
N/A
OFF
This notification is generated when the access port for the user does not change within 3 minutes.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
IpAddress
N/A
OCTET STRING
N/A
OCTET STRING
N/A
Unsigned32
N/A
Unsigned32
N/A
OCTET STRING
N/A
Unsigned32
N/A
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.3.0.1
User IP address conflicted.
Error
Warning
N/A
OFF
This notification is generated when a user IP address conflict occurs. The conflict occurs if an incoming ARP packet has the same sender IP address as an existing ARP entry but a different sender MAC address.
System impact
The network might have conflicting IP addresses, which causes route oscillation, service interruption, or traffic interruption.
Status control
ON
CLI: Use the snmp-agent trap enable arp user-ip-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable arp user-ip-conflict command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.217.2.3.1.1 (hh3cARPTrapUIPCPRcvMac)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.3.1.2 (hh3cARPTrapUIPCPRcvPVid)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.3.1.3  (hh3cARPTrapUIPCPRcvCVid)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.3.1.4 (hh3cARPTrapUIPCPRcvIf)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.3.1.5 (hh3cARPTrapUIPCPLocalMac)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.3.1.6  (hh3cARPTrapUIPCPLocalPVid)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.3.1.7 (hh3cARPTrapUIPCPLocalCVid)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.3.1.8 (hh3cARPTrapUIPCPLocalIf)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.3.1.9 (hh3cARPTrapUIPCPIpAddr)
N/A
IpAddress
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.4.0.1
The received ARP packet was not the ARP reply to the ARP request sent by the device.
Error
Warning
N/A
OFF
This notification is generated when the following conditions are met:
·     You enable ARP active acknowledgement in strict mode on the device.
·     When the device receives an ARP reply, it does not send any ARP request to the sender IP address in the reply within the probe interval.
System impact
Some normal ARP replies and ARP requests might be dropped, which affects normal services.
Status control
ON
CLI: Use the snmp-agent trap enable arp active-ack command.
OFF
CLI: Use the undo snmp-agent trap enable arp active-ack command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.217.2.4.1.1 (hh3cARPTrapAckIfName)
Interface that receives the ARP packet.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.4.1.2 (hh3cARPTrapAckSourceIP)
N/A
IpAddress
Recommended action
1.     Identify whether an ARP packet attack exists on the network and identify the attack source through capturing packets.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.5.0.1
The sending rate of ARP packets or ARP Miss messages exceeded the alarm threshold.
Error
Warning
1.3.6.1.4.1.25506.2.217.2.5.0.2(hh3cARPTrapSpeedLimitResume)
OFF
This notification is generated when the sending rate of ARP packets or ARP Miss messages exceeds the alarm threshold.
System impact
Some normal ARP packets might be dropped, which causes traffic interruption.
Status control
ON
CLI: Use the snmp-agent trap enable arp rate-limit command.
OFF
CLI: Use the undo snmp-agent trap enable arp rate-limit command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.217.2.5.1.1 (hh3cARPTrapSpeedLimitChassis)
Chassis number.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.5.1.2 (hh3cARPTrapSpeedLimitSlot)
Slot number.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.5.1.3 (hh3cARPTrapSpeedLimitSupValue)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.5.1.4 (hh3cARPTrapSpeedLimitCurValue)
Current sending rate (in pps) of ARP packets or ARP Miss messages.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.5.1.5 (hh3cARPTrapSpeedLimitSupType)
Rate limit type.
N/A
INTEGER
packet(1)
miss(2)
Recommended action
1.     Identify whether an ARP packet attack exists on the network. Identify the source for the IP packets with unresolvable destination IP addresses through capturing packets and Identify whether the source is reasonable.
Basic information
OID
Event
Severity
Default status
The sending rate of ARP packets or ARP Miss messages dropped below 60% of the alarm threshold.
Recovery
Warning
N/A
OFF
This notification is generated when the sending rate of ARP packets or ARP Miss messages drops below 60% of the alarm threshold.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Chassis number.
N/A
Unsigned32
Slot number.
N/A
Unsigned32
N/A
Unsigned32
N/A
Unsigned32
Rate limit type.
N/A
INTEGER
packet(1)
miss(2)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.6.0.1
The device received an invalid ARP packet.
Error
Warning
N/A
OFF
This notification is generated when the device receives an invalid ARP packet.
System impact
An ARP packet attack might exists on the network, which affects device operation.
Status control
ON
CLI: Use the snmp-agent trap enable arp packet-check command.
OFF
CLI: Use the undo snmp-agent trap enable arp packet-check command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.217.2.6.1.1 (hh3cARPTrapPktValidCheckIf)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.6.1.2 (hh3cARPTrapPktValidCheckMac)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.6.1.3 (hh3cARPTrapPktValidCheckIp)
N/A
IpAddress
1.3.6.1.4.1.25506.2.217.2.6.1.4 (hh3cARPTrapPktValidCheckVlan)
VLAN ID of the ARP packet.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.6.1.5 (hh3cARPTrapPktValidtCheckSvlan)
Service VLAN ID of the ARP packet.
N/A
Unsigned32
Recommended action
¡     If the notification is generated continuously, identify the attack source through capturing packets.
¡     If the notification is not generated continuously, no action is required.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.7.0.1
The device received an ARP packet in which the sender IP address is the same as the gateway IP address.
Error
Warning
1.3.6.1.4.1.25506.2.217.2.7.0.2( hh3cARPTrapGatewayCheckResume)
OFF
This notification is generated when the device receives an ARP packet in which the sender IP address is the same as the gateway IP address.
System impact
The network might have a device which forges the gateway. This might affect normal services.
Status control
ON
CLI: Use the snmp-agent trap enable arp gateway-check command.
OFF
CLI: Use the undo snmp-agent trap enable arp gateway-check command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.217.2.7.1.1 (hh3cARPTrapGatewayCheckIf)
Interface that receives the ARP attack packet.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.7.1.2 (hh3cARPTrapGatewayCheckSlot)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.7.1.3 (hh3cARPTrapGatewayCheckIp)
Sender IP address in the ARP attack packet.
N/A
IpAddress
Recommended action
1.     Identify whether another device on the network has the same IP address as the gateway IP address.
¡     If the device that has the same IP address as the gateway IP address exists, change the IP address of the device.
¡     If the device that has the same IP address as the gateway IP address does not exist, an attack might exist. As a best practice, identify the attack source through capturing packets.
Basic information
OID
Event
Severity
Default status
The condition that the device received an ARP packet in which the sender IP address is the same as the gateway IP address was cleared.
Recovery
Warning
N/A
OFF
This notification is generated when the device does not receive any ARP packets in which the sender IP address is the same as the gateway IP address within 3 minutes.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET STRING
N/A
Unsigned32
N/A
IpAddress
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.8.0.1
ARP attack detection dropped a packet on a VLAN interface.
Informational
Warning
N/A
OFF
This notification is generated when ARP attack detection drops a packet on a VLAN interface.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable arp detection-drop command.
OFF
CLI: Use the undo snmp-agent trap enable arp detection-drop command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.217.2.8.1.1 (hh3cARPTrapDtcDropVlanPktChassis)
Chassis number.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.8.1.2 (hh3cARPTrapDtcDropVlanPktSlot)
Slot number.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.8.1.3 (hh3cARPTrapDtcDropVlanPktIfName)
Interface name.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.8.1.4 (hh3cARPTrapDtcDropVlanPktVlanId)
VLAN ID.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.8.1.5 (hh3cARPTrapDtcDropVlanPktServId)
Service ID.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.8.1.6 (hh3cARPTrapDtcDropVlanPktType)
N/A
INTEGER
ipInvalidDrop (3)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.9.0.1
ARP attack detection dropped a packet on a VSI interface.
Informational
Warning
N/A
OFF
This notification is generated when ARP attack detection drops a packet on a VSI interface.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.217.2.9.1.1 (hh3cARPTrapDtcDropVsiPktChassis)
Chassis number.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.9.1.2 (hh3cARPTrapDtcDropVsiPktSlot)
Slot number.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.9.1.3 (hh3cARPTrapDtcDropVsiPktIfName)
Interface name.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.9.1.4 (hh3cARPTrapDtcDropVsiPktVlanId)
VLAN ID.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.9.1.5 (hh3cARPTrapDtcDropVsiPktServId)
Service ID.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.9.1.6 (hh3cARPTrapDtcDropVsiPktType)
N/A
INTEGER
ipInvalidDrop (3)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.10.0.1
ARP attack detection dropped a packet on a Layer 2 Ethernet interface.
Informational
Warning
N/A
OFF
This notification is generated when ARP attack detection drops a packet on a Layer 2 Ethernet interface.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.217.2.10.1.1 (hh3cARPTrapDtcDropIfPktChassis)
Chassis number.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.10.1.2 (hh3cARPTrapDtcDropIfPktSlot)
Slot number.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.10.1.3 (hh3cARPTrapDtcDropIfPktIfName)
Interface name.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.10.1.4 (hh3cARPTrapDtcDropIfPktVlanId)
VLAN ID.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.10.1.5 (hh3cARPTrapDtcDropIfPktServId)
Service ID.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.10.1.6 (hh3cARPTrapDtcDropIfPktType)
N/A
INTEGER
ipInvalidDrop (3)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.11.0.1
The MAC address in the static ARP entry was inconsistent with the actual MAC address.
Error
Warning
1.3.6.1.4.1.25506.2.217.2.11.0.1(hh3cARPTrapMacMismatchResume)
OFF
This notification is generated when the MAC address in the static ARP entry is inconsistent with the MAC address in the received ARP packet.
System impact
The short static ARP entry cannot be resolved, which affects normal services.
Status control
ON
CLI: Use the snmp-agent trap enable arp mac-mismatch command.
OFF
CLI: Use the undo snmp-agent trap enable arp mac-mismatch command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.217.2.11.1.1 (hh3cARPTrapMacMismatchChassis)
Chassis number.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.11.1.2 (hh3cARPTrapMacMismatchSlot)
Slot number.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.11.1.3 (hh3cARPTrapMacMismatchIfName)
Interface name.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.11.1.4 (hh3cARPTrapMacMismatchIP)
N/A
IpAddress
1.3.6.1.4.1.25506.2.217.2.11.1.5 (hh3cARPTrapMacMismatchVrf)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.11.1.6 (hh3cARPTrapMacMismatchMac)
N/A
OCTET STRING
Recommended action
Identify whether the MAC address in the ARP packet is correct.
·     If the MAC address is correct, edit the static ARP entry.
·     If the MAC address is incorrect, the ARP packet is invalid and no action is required.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.11.0.2
The MAC address in the static ARP entry is consistent with the actual MAC address.
Recovery
Warning
N/A
OFF
This notification is generated when the MAC address in the static ARP entry is consistent with the MAC address in the received ARP packet.
System impact
The short static ARP entry is resolved and services become normal.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Chassis number.
N/A
Unsigned32
Slot number.
N/A
Unsigned32
Interface name.
N/A
OCTET STRING
N/A
IpAddress
N/A
Unsigned32
N/A
OCTET STRING
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.12.0.1
The device received an ARP packet which edited an existing ARP entry.
Informational
Warning
N/A
OFF
This notification is generated when the device receives an ARP packet in which the information is inconsistent with the existing ARP entry.
System impact
User spoofing exists on the network, which affects normal services.
Status control
ON
CLI: Use the snmp-agent trap enable arp entry-check command.
OFF
CLI: Use the undo snmp-agent trap enable arp entry-check command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.217.2.12.1.1 (hh3cARPTrapEntryCheckChassis)
Chassis number.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.12.1.2 (hh3cARPTrapEntryCheckSlot)
Slot number.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.12.1.3 (hh3cARPTrapEntryCheckIfName)
Interface name.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.12.1.4 (hh3cARPTrapEntryCheckIP)
N/A
IpAddress
1.3.6.1.4.1.25506.2.217.2.12.1.5 (hh3cARPTrapEntryCheckMac)
MAC address in the modified ARP entry.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.217.2.12.1.6 (hh3cARPTrapEntryCheckPeVlan)
Inner VLAN of the modified ARP entry.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.12.1.7 (hh3cARPTrapEntryCheckCeVlan)
Outer VLAN of the modified ARP entry.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.12.1.8 (hh3cARPTrapEntryCheckPortIfName)
Interface name in the modified ARP entry.
N/A
OCTET STRING
Recommended action
1.     Identify whether the ARP entry change is reasonable.
¡     If the change is reasonable, no action is required.
¡     If the change is unreasonable, identify the ARP packet source through the MAC address. Identify whether an ARP packet attack exists and take attack prevention measures.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.217.2.13.0.1
The number of packets cached in the ARP packet queue exceeded the threshold.
Error
Warning
1.3.6.1.4.1.25506.2.217.2.13.0.2( hh3cARPTrapPktQueThresholdResume)
ON
This notification is generated when the number of packets cached in the ARP packet queue exceeds 4K.
System impact
The network might have an ARP attack, which affects normal service operation.
Status control
ON
CLI: Use the snmp-agent trap enable arp pkt-threshold command.
OFF
CLI: Use the undo snmp-agent trap enable arp pkt-threshold command.
Objects
OID (object name)
Index nodes
Value range
(hh3cARPTrapPktQueChassis)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.13.1.2 (hh3cARPTrapPktQueSlot)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.217.2.13.1.3 (hh3cARPTrapPktQueNum)
N/A
Unsigned32
Recommended action
·     Identify whether the network has an ARP attack and identify the attack source by capturing packets if an ARP attack exists.
·     If the issue persists, collect configuration files and alarm information, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
The number of packets cached in the ARP packet queue dropped below the threshold.
Recovery
Warning
N/A
ON
This notification is generated when the number of packets cached in the ARP packet queue drops below 3K.
System impact
No negative impact on the system.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
Unsigned32
N/A
Unsigned32
N/A
Unsigned32
Recommended action
