- 04-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-MAC-INFORMATION-MIB
- 08-HH3C-MAC-TRAP-MIB
- 09-HH3C-PROTOCOL-VLAN-MIB
- 10-HH3C-QINQV2-MIB
- 11-HH3C-SUBNET-VLAN-MIB
- 12-HH3C-VMAP-MIB
- 13-HH3C-VOICE-VLAN-MIB
- 14-HH3C-LswMSTP-MIB
- 15-HH3C-LswVLAN-MIB
- 16-IEEE8021-CFM-MIB
- 17-IEEE8021-CFM-V2-MIB
- 18-IEEE8023-LAG-MIB
- 19-LLDP-EXT-MED-MIB
- 20-LLDP-EXT-DOT1-MIB
- 21-LLDP-EXT-DOT1-V2-MIB
- 22-LLDP-EXT-DOT3-MIB
- 23-LLDP-EXT-DOT3-V2-MIB
- 24-LLDP-MIB
- 25-LLDP-V2-MIB
- 26-MAU-MIB
- 27-Q-BRIDGE-MIB
- 28-RBRIDGE-MIB
25-LLDP-V2-MIB | 211.81 KB |
LLDP-V2-MIB
About this MIB
This MIB is compliant with IEEE 802.1AB-2009. It defines MIB objects for the following LLDP information:
· LLDP configuration.
· LLDP statistics.
· LLDP local system information.
· LLDP neighbor system information.
· 802.1 extension.
· DCBX extension.
· 802.3 extension.
MIB file name
lldp-v2.mib
Root object
iso(1).org(3).ieee(111).standards-association-numbers-series-standards(2).lan-man-stds(802).ieee802dot1(1).ieee802dot1mibs(1).lldpV2MIB(13)
Scalar objects
lldpV2MessageTxInterval
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2MessageTxInterval (1.3.111.2.802.1.1.13.1.1.1) |
read-write |
Unsigned32 |
Unsigned32 (5..32768) |
LLDP frame transmission interval. |
As per the MIB. |
lldpV2MessageTxHoldMultiplier
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2MessageTxHoldMultiplier (1.3.111.2.802.1.1.13.1.1.2) |
read-write |
Unsigned32 |
Unsigned32 (2..10) |
TTL multiplier. |
As per the MIB. |
lldpV2ReinitDelay
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2ReinitDelay (1.3.111.2.802.1.1.13.1.1.3) |
read-write |
Unsigned32 |
Unsigned32 (1..10) |
LLDP reinitialization delay. |
As per the MIB. |
lldpV2NotificationInterval
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2NotificationInterval (1.3.111.2.802.1.1.13.1.1.4) |
read-write |
Unsigned32 |
Unsigned32 (5..3600) |
Trap transmission interval. |
As per the MIB. |
lldpV2TxCreditMax
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2TxCreditMax (1.3.111.2.802.1.1.13.1.1.5) |
read-write |
Unsigned32 |
Unsigned32 (1..100) |
Token bucket size for sending LLDP frames. |
As per the MIB. |
lldpV2MessageFastTx
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2MessageFastTx (1.3.111.2.802.1.1.13.1.1.6) |
read-write |
Unsigned32 |
Unsigned32 (1..3600) |
Fast LLDP frame transmission interval. |
As per the MIB. |
lldpV2TxFastInit
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2TxFastInit (1.3.111.2.802.1.1.13.1.1.7) |
read-write |
Unsigned32 |
Unsigned32 (1..8) |
Number of LLDP frames sent each time fast LLDP frame transmission is triggered. |
As per the MIB. |
lldpV2StatsRemTablesLastChangeTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2StatsRemTablesLastChangeTime (1.3.111.2.802.1.1.13.1.2.1) |
read-only |
TimeStamp |
Standard MIB values. |
Time when LLDP information about a neighboring device was last updated. |
As per the MIB. |
lldpV2StatsRemTablesInserts
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2StatsRemTablesInserts (1.3.111.2.802.1.1.13.1.2.2) |
read-only |
ZeroBasedCounter32 |
Number of neighbors added by LLDP. |
As per the MIB. |
lldpV2StatsRemTablesDeletes
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2StatsRemTablesDeletes (1.3.111.2.802.1.1.13.1.2.3) |
read-only |
Number of neighbors deleted by LLDP. |
As per the MIB. |
lldpV2StatsRemTablesDrops
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2StatsRemTablesDrops (1.3.111.2.802.1.1.13.1.2.4) |
read-only |
Number of neighbors discarded by LLDP. |
As per the MIB. |
lldpV2StatsRemTablesAgeouts
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2StatsRemTablesAgeouts (1.3.111.2.802.1.1.13.1.2.5) |
read-only |
Neighbor ageout count. |
As per the MIB. |
lldpV2LocChassisIdSubtype
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2LocChassisIdSubtype (1.3.111.2.802.1.1.13.1.3.1) |
read-only |
LldpV2ChassisIdSubtype |
Local chassis ID subtype. |
As per the MIB. |
lldpV2LocChassisId
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2LocChassisId (1.3.111.2.802.1.1.13.1.3.2) |
read-only |
LldpV2ChassisId |
Local chassis ID. |
As per the MIB. |
lldpV2LocSysName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2LocSysName (1.3.111.2.802.1.1.13.1.3.3) |
read-only |
SnmpAdminString |
OCTET STRING (0..255) |
Local system name. |
As per the MIB. |
lldpV2LocSysDesc
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2LocSysDesc (1.3.111.2.802.1.1.13.1.3.4) |
read-only |
SnmpAdminString |
Local system description. |
As per the MIB. |
lldpV2LocSysCapSupported
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2LocSysCapSupported (1.3.111.2.802.1.1.13.1.3.5) |
read-only |
LldpV2SystemCapabilitiesMap |
Capabilities supported by the local system. |
As per the MIB. |
lldpV2LocSysCapEnabled
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2LocSysCapEnabled (1.3.111.2.802.1.1.13.1.3.6) |
read-only |
Capabilities enabled on the local system. |
As per the MIB. |
Tabular objects
lldpV2PortConfigTable
About this table
Use this table to configure LLDP on a port.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2PortConfigIfIndex and lldpV2PortConfigDestAddressIndex.
The table OID is 1.3.111.2.802.1.1.13.1.1.8.
Access |
Syntax |
Value range |
Implementation |
lldpV2PortConfigIfIndex (1.3.111.2.802.1.1.13.1.1.8.1.1) |
not-accessible |
InterfaceIndex |
Port number. |
As per the MIB. |
lldpV2PortConfigDestAddressIndex (1.3.111.2.802.1.1.13.1.1.8.1.2) |
not-accessible |
LldpV2DestAddressTableIndex |
Agent index. |
As per the MIB. |
lldpV2PortConfigAdminStatus (1.3.111.2.802.1.1.13.1.1.8.1.3) |
read-write |
INTEGER |
txOnly(1) rxOnly(2) txAndRx(3) disabled(4) |
LLDP operating mode. |
Default: Disabled for the following agents: · The nearest customer bridge agent and nearest non-TPMR bridge agent on a Layer 2 Ethernet interface. · The nearest customer bridge agent and nearest non-TPMR bridge agent on a Layer 2 or Layer 3 aggregate interface. · The nearest non-TPMR bridge agent on a Layer 3 Ethernet interface. |
lldpV2PortConfigNotificationEnable (1.3.111.2.802.1.1.13.1.1.8.1.4) |
read-write |
TruthValue |
Trapping status. |
As per the MIB. |
lldpV2PortConfigTLVsTxEnable (1.3.111.2.802.1.1.13.1.1.8.1.5) |
read-write |
BITS |
BITS { portDesc(0), sysName(1), sysDesc(2), sysCap(3) } |
Optional TLVs that the port can send. |
Default: 0xf0 for the following agents: · The nearest bridge agent and nearest customer bridge agent on a Layer 2 or Layer 3 Ethernet interface. · The nearest customer bridge agent on a Layer 2 aggregate interface. The default is 0x40 for the nearest customer bridge agent on a Layer 3 aggregate interface or S-channel interface. |
lldpV2DestAddressTable
About this table
Use this table to obtain the destination MAC address of LLDP frames.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is lldpV2AddressTableIndex.
The table OID is 1.3.111.2.802.1.1.13.1.1.9.
Access |
Syntax |
Value range |
Implementation |
lldpV2AddressTableIndex (1.3.111.2.802.1.1.13.1.1.9.1.1) |
not-accessible |
Index used to identify the destination MAC address associated with this entry. |
As per the MIB. |
lldpV2DestMacAddress (1.3.111.2.802.1.1.13.1.1.9.1.2) |
read-only |
MacAddress |
Destination MAC address. |
As per the MIB. |
lldpV2ManAddrConfigTxPortsTable
About this table
Use this table to configure a management address for agents on interfaces.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are lldpV2ManAddrConfigIfIndex, lldpV2ManAddrConfigDestAddressIndex, lldpV2ManAddrConfigLocManAddrSubtype, lldpV2ManAddrConfigLocManAddr.
The table OID is 1.3.111.2.802.1.1.13.1.1.10.
Access |
Syntax |
Value range |
Implementation |
lldpV2ManAddrConfigIfIndex (1.3.111.2.802.1.1.13.1.1.10.1.1) |
not-accessible |
InterfaceIndex |
Interface index. |
As per the MIB. |
lldpV2ManAddrConfigDestAddressIndex (1.3.111.2.802.1.1.13.1.1.10.1.2) |
not-accessible |
Agent ID. |
As per the MIB. |
lldpV2ManAddrConfigLocManAddrSubtype (1.3.111.2.802.1.1.13.1.1.10.1.3) |
not-accessible |
AddressFamilyNumbers |
Management address subtype. |
As per the MIB. |
lldpV2ManAddrConfigLocManAddr (1.3.111.2.802.1.1.13.1.1.10.1.4) |
not-accessible |
LldpV2ManAddress |
Management address string. |
The subtypes of the management address TLV are IPv4 and IPv6. |
lldpV2ManAddrConfigTxEnable (1.3.111.2.802.1.1.13.1.1.10.1.5) |
read-create |
TruthValue |
Whether the management address TLV is enabled. |
Default: Disabled for the following agents: · The nearest bridge agent and nearest customer bridge agent on a Layer 2 or Layer 3 Ethernet interface. · The nearest customer bridge agent on a Layer 2 or Layer 3 aggregate interface. |
lldpV2ManAddrConfigRowStatus (1.3.111.2.802.1.1.13.1.1.10.1.6) |
read-create |
RowStatus |
Row status. |
Supports only active(1), createAndGo(4), and destroy(6). |
lldpV2StatsTxPortTable
About this table
Use this table to obtain outgoing LLDP packet statistics about agents.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2StatsTxIfIndex and lldpV2StatsTxDestMACAddress.
The table OID is 1.3.111.2.802.1.1.13.1.2.6.
Access |
Syntax |
Value range |
Implementation |
lldpV2StatsTxIfIndex (1.3.111.2.802.1.1.13.1.2.6.1.1) |
not-accessible |
InterfaceIndex |
Interface index. |
As per the MIB. |
lldpV2StatsTxDestMACAddress (1.3.111.2.802.1.1.13.1.2.6.1.2) |
not-accessible |
Agent ID. |
As per the MIB. |
lldpV2StatsTxPortFramesTotal (1.3.111.2.802.1.1.13.1.2.6.1.3) |
read-only |
Counter32 |
Total outgoing frame count. |
As per the MIB. |
lldpV2StatsTxLLDPDULengthErrors (1.3.111.2.802.1.1.13.1.2.6.1.4) |
read-only |
Counter32 |
Frame length error count. |
As per the MIB. |
lldpV2StatsRxPortTable
About this table
Use this table to obtain incoming LLDP packet statistics about agents.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2StatsRxDestIfIndex and lldpV2StatsRxDestMACAddress.
The table OID is 1.3.111.2.802.1.1.13.1.2.7.
Access |
Syntax |
Value range |
Implementation |
lldpV2StatsRxDestIfIndex (1.3.111.2.802.1.1.13.1.2.7.1.1) |
not-accessible |
InterfaceIndex |
Interface index. |
As per the MIB. |
lldpV2StatsRxDestMACAddress(1.3.111.2.802.1.1.13.1.2.7.1.2) |
not-accessible |
Agent ID. |
As per the MIB. |
lldpV2StatsRxPortFramesDiscardedTotal (1.3.111.2.802.1.1.13.1.2.7.1.3) |
read-only |
Counter32 |
Discarded incoming frame count. |
As per the MIB. |
lldpV2StatsRxPortFramesErrors(1.3.111.2.802.1.1.13.1.2.7.1.4) |
read-only |
Counter32 |
Error incoming frame count. |
As per the MIB. |
lldpV2StatsRxPortFramesTotal (1.3.111.2.802.1.1.13.1.2.7.1.5) |
read-only |
Counter32 |
Total incoming frame count. |
As per the MIB. |
lldpV2StatsRxPortTLVsDiscardedTotal (1.3.111.2.802.1.1.13.1.2.7.1.6) |
read-only |
Counter32 |
Discarded incoming TLV count. |
As per the MIB. |
lldpV2StatsRxPortTLVsUnrecognizedTotal (1.3.111.2.802.1.1.13.1.2.7.1.7) |
read-only |
Counter32 |
Unrecognized incoming TLV count. |
As per the MIB. |
lldpV2StatsRxPortAgeoutsTotal (1.3.111.2.802.1.1.13.1.2.7.1.8) |
read-only |
As per the MIB. |
lldpV2LocPortTable
About this table
Use this table to obtain LLDP information about local ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is lldpV2LocPortIfIndex.
The table OID is 1.3.111.2.802.1.1.13.1.3.7.
Access |
Syntax |
Value range |
Implementation |
lldpV2LocPortIfIndex (1.3.111.2.802.1.1.13.1.3.7.1.1) |
not-accessible |
InterfaceIndex |
Interface index. |
As per the MIB. |
lldpV2LocPortIdSubtype (1.3.111.2.802.1.1.13.1.3.7.1.2) |
read-only |
LldpV2PortIdSubtype
Port ID subtype. |
As per the MIB. |
lldpV2LocPortId (1.3.111.2.802.1.1.13.1.3.7.1.3) |
read-only |
LldpV2PortId |
Port ID. |
As per the MIB. |
lldpV2LocPortDesc (1.3.111.2.802.1.1.13.1.3.7.1.4) |
read-only |
SnmpAdminString |
Port description. |
As per the MIB. |
lldpV2LocManAddrTable
About this table
Use this table to obtain local management address information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2LocManAddrSubtype and lldpV2LocManAddr.
The table OID is 1.3.111.2.802.1.1.13.1.3.8.
Access |
Syntax |
Value range |
Implementation |
lldpV2LocManAddrSubtype (1.3.111.2.802.1.1.13.1.3.8.1.1) |
not-accessible |
As per the MIB. |
lldpV2LocManAddr (1.3.111.2.802.1.1.13.1.3.8.1.2) |
not-accessible |
LldpV2ManAddress |
Management address. |
lldpV2LocManAddrLen (1.3.111.2.802.1.1.13.1.3.8.1.3) |
read-only |
Unsigned32 |
Management address length. |
As per the MIB. |
lldpV2LocManAddrIfSubtype (1.3.111.2.802.1.1.13.1.3.8.1.4) |
read-only |
LldpV2ManAddrIfSubtype |
The enumeration value that identifies the port numbering method used for defining the port number associated with the local system. |
As per the MIB. |
lldpV2LocManAddrIfId (1.3.111.2.802.1.1.13.1.3.8.1.5) |
read-only |
Unsigned32 |
Interface index. |
As per the MIB. |
lldpV2LocManAddrOID (1.3.111.2.802.1.1.13.1.3.8.1.6) |
read-only |
OBJECT IDENTIFIER |
The OID value used to identify the type of hardware component or protocol entity associated with the management address advertised by the local system agent. |
Not supported |
lldpV2RemTable
About this table
Use this table to obtain neighbor configuration.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, and lldpV2RemIndex.
The table OID is 1.3.111.2.802.1.1.13.1.4.1
Access |
Syntax |
Value range |
Implementation |
lldpV2RemTimeMark (1.3.111.2.802.1.1.13.1.4.1.1.1) |
not-accessible |
TimeFilter |
Time mark for a neighbor. |
The time mark is the time when this object is created or the remote system is updated. You can use the time mark to search for remote system records. |
lldpV2RemLocalIfIndex (1.3.111.2.802.1.1.13.1.4.1.1.2) |
not-accessible |
InterfaceIndex |
Local interface receiving the neighbor information. |
As per the MIB. |
lldpV2RemLocalDestMACAddress (1.3.111.2.802.1.1.13.1.4.1.1.3) |
not-accessible |
Neighbor agent ID. |
As per the MIB. |
lldpV2RemIndex (1.3.111.2.802.1.1.13.1.4.1.1.4) |
not-accessible |
Unsigned32 |
Unsigned32 (1..2147483647) |
Neighbor index. |
As per the MIB. |
lldpV2RemChassisIdSubtype (1.3.111.2.802.1.1.13.1.4.1.1.5) |
read-only |
Neighbor chassis ID subtype. |
As per the MIB. |
lldpV2RemChassisId (1.3.111.2.802.1.1.13.1.4.1.1.6) |
read-only |
LldpV2ChassisId |
Neighbor chassis ID. |
As per the MIB. |
lldpV2RemPortIdSubtype (1.3.111.2.802.1.1.13.1.4.1.1.7) |
read-only |
LldpV2PortIdSubtype |
Neighbor port ID subtype. |
As per the MIB. |
lldpV2RemPortId (1.3.111.2.802.1.1.13.1.4.1.1.8) |
read-only |
LldpV2PortId |
Neighbor port ID. |
As per the MIB. |
lldpV2RemPortDesc (1.3.111.2.802.1.1.13.1.4.1.1.9) |
read-only |
SnmpAdminString |
Neighbor port description. |
As per the MIB. |
lldpV2RemSysName (1.3.111.2.802.1.1.13.1.4.1.1.10) |
read-only |
SnmpAdminString |
Neighbor system name. |
As per the MIB. |
lldpV2RemSysDesc (1.3.111.2.802.1.1.13.1.4.1.1.11) |
read-only |
SnmpAdminString |
Neighbor system description. |
As per the MIB. |
lldpV2RemSysCapSupported (1.3.111.2.802.1.1.13.1.4.1.1.12) |
read-only |
Capabilities supported by the neighbor system. |
As per the MIB. |
lldpV2RemSysCapEnabled (1.3.111.2.802.1.1.13.1.4.1.1.13) |
read-only |
Capabilities enabled on the neighbor system. |
As per the MIB. |
lldpV2RemRemoteChanges (1.3.111.2.802.1.1.13.1.4.1.1.14) |
read-only |
TruthValue |
Whether there are changes in the remote system's MIB. |
As per the MIB. |
lldpV2RemTooManyNeighbors (1.3.111.2.802.1.1.13.1.4.1.1.15) |
read-only |
TruthValue |
Whether there are too many neighbors. |
As per the MIB. |
lldpV2RemManAddrTable
About this table
Use this table to obtain neighbor management address information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, lldpV2RemManAddrSubtype, and lldpV2RemManAddr.
The table OID is 1.3.111.2.802.1.1.13.1.4.2.
Access |
Syntax |
Value range |
Implementation |
lldpV2RemManAddrSubtype (1.3.111.2.802.1.1.13.1.4.2.1.1) |
not-accessible |
As per the MIB. |
lldpV2RemManAddr (1.3.111.2.802.1.1.13.1.4.2.1.2) |
not-accessible |
LldpV2ManAddress |
OCTET STRING (1..31) |
As per the MIB. |
lldpV2RemManAddrIfSubtype (1.3.111.2.802.1.1.13.1.4.2.1.3) |
read-only |
The enumeration value that identifies the interface numbering method used for defining the interface number associated with the remote system. |
As per the MIB. |
lldpV2RemManAddrIfId (1.3.111.2.802.1.1.13.1.4.2.1.4) |
read-only |
Unsigned32 |
Index of the interface associated with the management address. |
As per the MIB. |
lldpV2RemManAddrOID (1.3.111.2.802.1.1.13.1.4.2.1.5) |
read-only |
OBJECT IDENTIFIER |
The OID value used to identify the type of hardware component or protocol entity associated with the management address advertised by the remote system agent. |
Not supported |
lldpV2RemUnknownTLVTable
About this table
Use this table to display the unrecognized TLVs received from neighbors.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, and lldpV2RemUnknownTLVType.
The table OID is 1.3.111.2.802.1.1.13.1.4.3.
Access |
Syntax |
Value range |
Implementation |
lldpV2RemUnknownTLVType (1.3.111.2.802.1.1.13.1.4.3.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (9..126) |
TLV type. |
As per the MIB. |
lldpV2RemUnknownTLVInfo (1.3.111.2.802.1.1.13.1.4.3.1.2) |
read-only |
OCTET STRING |
OCTET STRING (0..511) |
TLV string. |
As per the MIB. |
lldpV2RemOrgDefInfoTable
About this table
Use this table to display the neighbor organizationally defined information not recognized by the local system.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, lldpV2RemOrgDefInfoOUI, lldpV2RemOrgDefInfoSubtype, and lldpV2RemOrgDefInfoIndex.
The table OID is 1.3.111.2.802.1.1.13.1.4.4.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2RemOrgDefInfoOUI (1.3.111.2.802.1.1.13.1.4.4.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (3) |
Organizationally Unique Identifier (OUI). |
As per the MIB. |
lldpV2RemOrgDefInfoSubtype (1.3.111.2.802.1.1.13.1.4.4.1.2) |
not-accessible |
Unsigned32 |
Unsigned32 (1..255) |
Subtype of the organizationally defined information. |
As per the MIB. |
lldpV2RemOrgDefInfoIndex (1.3.111.2.802.1.1.13.1.4.4.1.3) |
not-accessible |
Unsigned32 |
Index of the organizationally defined information. |
As per the MIB. |
lldpV2RemOrgDefInfo (1.3.111.2.802.1.1.13.1.4.4.1.4) |
read-only |
OCTET STRING |
OCTET STRING (0..507) |
Organizationally defined information. |
As per the MIB. |
Notifications
lldpV2RemTablesChange
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.111.2.802.1.1.13.0.0.1 |
LLDP polling is triggered. |
Informational |
Warning |
N/A |
OFF |
Notification triggers
This notification is generated when the value of the lldpV2StatsRemTableLastChangeTime object changes. The network management system can use this notification to trigger LLDP polling to facilitate maintaining remote system entries.
You can set the notification transmission interval by configuring the lldpV2NotificationInterval object.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the lldp notification remote-change enable command.
MIB: Set the lldpV2PortConfigNotificationEnable object to true(1).
OFF
CLI: Use the undo lldp notification remote-change enable command.
MIB: Set the lldpV2PortConfigNotificationEnable object to false(2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Neighbor creation. |
N/A |
Neighbor deletion. |
N/A |
Neighbor discard. |
N/A |
Neighbor ageout. |
N/A |
Recommended action
1. Verify that the topology changes are as expected.
2. If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
