04-Layer 2 - LAN Switching
HomeSupportSwitchesS9820 SeriesReference GuidesMIB CompanionH3C S9820-8C MIB Companion-Release 6715-6W10004-Layer 2 - LAN Switching
20-LLDP-EXT-DOT1-MIB
20-LLDP-EXT-DOT1-MIB 108.90 KB
LLDP-EXT-DOT1-MIB
About this MIB
For network managers to discover inconsistent or incorrect VLAN configurations and different supported protocols on interconnected ports, LLDP must implement the IEEE 802.1 organizationally specific extended features.
LLDP-EXT-DOT1-MIB is one of the four MIBs available for LLDP, which also include LLDP-MIB, LLDP-EXT-DOT3-MIB, and LLDP-MED-MIB. This MIB is a standard public MIB, which contains LDDP configuration, local and neighboring LLDP information.
MIB file name
lldp-ext-dot1.mib
Root object
iso(1).std(0).iso8802(8802).ieee802dot1(1).ieee802dot1mibs(1).lldpMIB(2).lldpObjects(1).lldpExtnesions(5).lldpXdot1MIB(32962)
This MIB is the LLDP Management Information Base extension module for IEEE 802.1 organizationally defined discovery information.
Tabular objects
lldpXdot1ConfigPortVlanTable
About this table
This table controls selection of LLDP Port VLAN-ID TLVs to be transmitted on individual ports.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is lldpPortConfigPortNum.
The table OID is 1.0.8802.1.1.2.1.5.32962.1.1.1.
Object (OID)
Access
Value range
Implementation
lldpXdot1ConfigPortVlanTxEnable (1.0.8802.1.1.2.1.5.32962.1.1.1.1.1)
read-write
TruthValue
true(1),
false(2)
Selects whether to enable port VLAN TLV transmission on a given LLDP transmission capable port.
Default: true.
lldpXdot1ConfigVlanNameTable
About this table
This table controls selection of LLDP VLAN name TLV instances to be transmitted on individual ports.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Not supported
Columns
The table indexes are lldpLocPortNum and lldpXdot1LocVlanId.
The table OID is 1.0.8802.1.1.2.1.5.32962.1.1.2.
Object (OID)
Access
Value range
Implementation
lldpXdot1ConfigVlanNameTxEnable (1.0.8802.1.1.2.1.5.32962.1.1.2.1.1)
read-write
TruthValue
true(1),
false(2)
Selects whether to enable VLAN name TLV transmission on a given LLDP transmission capable port.
Default: false.
As a best practice, do not perform the walk operation from the MIB browser, because it takes a long time to walk through all ports and VLANs.
lldpXdot1ConfigProtoVlanTable
About this table
This table controls selection of LLDP port and protocol VLAN ID TLV instances to be transmitted on individual ports.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are lldpLocPortNum and lldpXdot1LocProtoVlanId.
The table OID is 1.0.8802.1.1.2.1.5.32962.1.1.3.
Object (OID)
Access
Value range
Implementation
lldpXdot1ConfigProtoVlanTxEnable (1.0.8802.1.1.2.1.5.32962.1.1.3.1.1)
read-write
TruthValue
true(1),
false(2)
Selects whether to enable Port and Protocol VLAN ID TLV transmission on a given LLDP transmission capable port.
Default: false.
lldpXdot1ConfigProtocolTable
About this table
This table controls selection of LLDP Protocol TLV instances to be transmitted on individual ports.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table indexes are lldpLocPortNum and lldpXdot1LocProtocolIndex.
The table OID is 1.0.8802.1.1.2.1.5.32962.1.1.4.
Object (OID)
Access
Value range
Implementation
lldpXdot1ConfigProtocolTxEnable (1.0.8802.1.1.2.1.5.32962.1.1.4.1.1)
read-write
TruthValue
true(1),
false(2)
Selects whether to enable Protocol Identity TLV transmission on a given LLDP transmission capable port.
Not supported. The default is false if the port is operating in bridge mode.
lldpXdot1LocTable
About this table
This table contains one row per port for IEEE 802.1 organizationally defined LLDP extension on the local system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is lldpLocPortNum.
The table OID is 1.0.8802.1.1.2.1.5.32962.1.2.1.
Object (OID)
Access
Value range
Implementation
lldpXdot1LocPortVlanId (1.0.8802.1.1.2.1.5.32962.1.2.1.1.1)
read-only
Integer32
Integer32(0|1..4094)
PPVID.
As per the MIB.
lldpXdot1LocProtoVlanTable
About this table
This table contains one or more rows per Port and Protocol VLAN information about the local system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.0.8802.1.1.2.1.5.32962.1.2.2.
Object (OID)
Access
Value range
Implementation
lldpXdot1LocProtoVlanId (1.0.8802.1.1.2.1.5.32962.1.2.2.1.1)
not-accessible
Integer32
Port and protocol VLAN ID.
As per the MIB.
lldpXdot1LocProtoVlanSupported (1.0.8802.1.1.2.1.5.32962.1.2.2.1.2)
read-only
TruthValue
true(1),
false(2)
Indicates whether the given port (associated with the local system) supports port and protocol VLANs.
As per the MIB.
lldpXdot1LocProtoVlanEnabled (1.0.8802.1.1.2.1.5.32962.1.2.2.1.3)
read-only
TruthValue
true(1),
false(2)
Indicates whether the port and protocol VLANs are enabled on the given port associated with the local system.
As per the MIB.
lldpXdot1LocVlanNameTable
About this table
This table contains one or more rows of VLAN name information on the local system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.0.8802.1.1.2.1.5.32962.1.2.3.
Object (OID)
Access
Value range
Implementation
lldpXdot1LocVlanId (1.0.8802.1.1.2.1.5.32962.1.2.3.1.1)
not-accessible
VlanId
Standard MIB values.
ID of the VLAN to which the port belongs.
As per the MIB.
lldpXdot1LocVlanName (1.0.8802.1.1.2.1.5.32962.1.2.3.1.2)
read-only
SnmpAdminString
OCTET STRING (1..32)
VLAN name identified by the VLAN ID associated with the given port on the local system.
As per the MIB.
lldpXdot1LocProtocolTable
About this table
This table contains one or more rows per protocol identity information on the local system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table OID is 1.0.8802.1.1.2.1.5.32962.1.2.4.
Object (OID)
Access
Value range
Implementation
lldpXdot1LocProtocolIndex (1.0.8802.1.1.2.1.5.32962.1.2.4.1.1)
not-accessible
Integer32
Integer32(1..2147483647)
Protocol index.
Not supported. The value is 1 if the port is operating in bridge mode.
lldpXdot1RemTable
About this table
This table contains one or more rows per physical network connection.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, and lldpRemIndex.
The table OID is 1.0.8802.1.1.2.1.5.32962.1.3.1.
Object (OID)
Access
Value range
Implementation
lldpXdot1RemPortVlanId (1.0.8802.1.1.2.1.5.32962.1.3.1.1.1)
read-only
Integer32
PVID of the given port on a neighboring device.
As per the MIB.
lldpXdot1RemProtoVlanTable
About this table
This table contains one or more rows per port and protocol VLAN information about the neighboring devices received on the given port.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, and lldpXdot1RemProtoVlanId.
The table OID is 1.0.8802.1.1.2.1.5.32962.1.3.2.
Object (OID)
Access
Value range
Implementation
lldpXdot1RemProtoVlanId (1.0.8802.1.1.2.1.5.32962.1.3.2.1.1)
not-accessible
Integer32
Port and protocol VLAN ID of the given port on a neighboring device.
As per the MIB.
lldpXdot1RemProtoVlanSupported (1.0.8802.1.1.2.1.5.32962.1.3.2.1.2)
read-only
TruthValue
true(1),
false(2)
Indicates whether the given port on the neighboring device supports port and protocol VLANs.
As per the MIB.
lldpXdot1RemProtoVlanEnabled (1.0.8802.1.1.2.1.5.32962.1.3.2.1.3)
read-only
TruthValue
true(1),
false(2)
Indicates whether the port and protocol VLANs are enabled for the given port on the neighboring device.
As per the MIB.
lldpXdot1RemVlanNameTable
About this table
This table contains one or more rows per IEEE 802.1Q VLAN name information about the neighboring devices, received on the given port.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, lldpXdot1RemVlanId.
The table OID is 1.0.8802.1.1.2.1.5.32962.1.3.3.
Object (OID)
Access
Value range
Implementation
lldpXdot1RemVlanId (1.0.8802.1.1.2.1.5.32962.1.3.3.1.1)
not-accessible
VlanId
ID of the VLAN to which the given port on a neighboring device belongs.
As per the MIB.
lldpXdot1RemVlanName (1.0.8802.1.1.2.1.5.32962.1.3.3.1.2)
read-only
SnmpAdminString
VLAN name identified by the VLAN ID on the neighboring device.
As per the MIB.
lldpXdot1RemProtocolTable
About this table
This table contains one or more rows per protocol information about the neighbor, received on the given port.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, lldpXdot1RemProtocolIndex.
The table OID is 1.0.8802.1.1.2.1.5.32962.1.3.4.
Object (OID)
Access
Value range
Implementation
lldpXdot1RemProtocolIndex (1.0.8802.1.1.2.1.5.32962.1.3.4.1.1)
not-accessible
Integer32
Protocol index.
As per the MIB.
lldpXdot1RemProtocolId (1.0.8802.1.1.2.1.5.32962.1.3.4.1.2)
read-only
OCTET STRING
OCTET STRING (1..255)
ID of the protocol associated with the given port of a neighboring device.
As per the MIB.
