- 04-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-MAC-INFORMATION-MIB
- 08-HH3C-MAC-TRAP-MIB
- 09-HH3C-PROTOCOL-VLAN-MIB
- 10-HH3C-QINQV2-MIB
- 11-HH3C-SUBNET-VLAN-MIB
- 12-HH3C-VMAP-MIB
- 13-HH3C-VOICE-VLAN-MIB
- 14-HH3C-LswMSTP-MIB
- 15-HH3C-LswVLAN-MIB
- 16-IEEE8021-CFM-MIB
- 17-IEEE8021-CFM-V2-MIB
- 18-IEEE8023-LAG-MIB
- 19-LLDP-EXT-MED-MIB
- 20-LLDP-EXT-DOT1-MIB
- 21-LLDP-EXT-DOT1-V2-MIB
- 22-LLDP-EXT-DOT3-MIB
- 23-LLDP-EXT-DOT3-V2-MIB
- 24-LLDP-MIB
- 25-LLDP-V2-MIB
- 26-MAU-MIB
- 27-Q-BRIDGE-MIB
- 28-RBRIDGE-MIB
07-HH3C-MAC-INFORMATION-MIB | 216.20 KB |
hh3cMACInformationcSendInterval
hh3cMACInformationLearntMACNum
hh3cMACInformationRemovedMACNum
hh3cMACInformationSyslogSendNum
hh3cMACInfoTrapMsgMovedAddress
hh3cMACInfoTrapMsgMovedFmIfName
hh3cMACInfoTrapMsgMovedToIfName
hh3cMACInformationChangedTrapExt
hh3cMACInformationMovedRsmTrap
About this MIB
Use this MIB to configure MAC Information.
MIB file name
hh3c-mac-information.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMACInformation(87)
Scalar objects
hh3cMACInformationEnabled
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInformationEnabled (1.3.6.1.4.1.25506.2.87.1.1.1) |
read-write |
INTEGER |
enabled(1) disabled(2) |
Status of the MAC Information feature. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInformationcSendInterval(1.3.6.1.4.1.25506.2.87.1.1.2) |
read-write |
Integer32 |
Integer32 (1..20000) |
MAC change notification interval. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInformationLearntMACNum(1.3.6.1.4.1.25506.2.87.1.1.3) |
read-only |
Counter32 |
Standard MIB values. |
Total number of the MAC addresses learned since MAC information is enabled. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInformationRemovedMACNum (1.3.6.1.4.1.25506.2.87.1.1.4) |
read-only |
Counter32 |
Total number of the MAC addresses deleted or aged since MAC information is enabled. |
As per the MIB. |
hh3cMACInformationTrapSendNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInformationTrapSendNum (1.3.6.1.4.1.25506.2.87.1.1.5) |
read-only |
Counter32 |
Number of sent SNMP notifications. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInformationSyslogSendNum (1.3.6.1.4.1.25506.2.87.1.1.6) |
read-only |
Counter32 |
Number of sent syslog messages. |
As per the MIB. |
hh3cMACInformationCacheLen
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInformationCacheLen (1.3.6.1.4.1.25506.2.87.1.1.7) |
read-write |
Integer32 |
Integer32 (0..1000) |
MAC Information queue length. |
As per the MIB. |
hh3cMACInfomationWorkMode
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfomationWorkMode (1.3.6.1.4.1.25506.2.87.1.1.8) |
read-write |
Hh3cMACInfoWorkMode |
trap(1) syslog(2) |
MAC Information mode |
As per the MIB. |
hh3cMACInfoTrapIndex
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapIndex(1.3.6.1.4.1.25506.2.87.1.3.2.1) |
accessible-for-notify |
Integer32 |
Integer32 (1..2147483647) |
Notification index. |
As per the MIB. |
hh3cMACInfoTrapCount
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapCount (1.3.6.1.4.1.25506.2.87.1.3.2.2) |
Integer32 |
Notification count. |
As per the MIB. |
hh3cMACInfoTrapMsg
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapMsg(1.3.6.1.4.1.25506.2.87.1.3.2.2) |
OCTET STRING |
OCTET STRING (1..254) |
Notification contents. |
As per the MIB. |
hh3cMACInfoTrapVerExt
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapVerExt (1.3.6.1.4.1.25506.2.87.1.4.2.1) |
Integer32 |
SNMP version. |
As per the MIB. |
hh3cMACInfoTrapIndexExt
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapIndexExt (1.3.6.1.4.1.25506.2.87.1.4.2.2) |
Integer32 |
As per the MIB. |
hh3cMACInfoTrapCountExt
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapCountExt (1.3.6.1.4.1.25506.2.87.1.4.2.3) |
Integer32 |
As per the MIB. |
hh3cMACInfoTrapMsgExt
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapMsgExt (1.3.6.1.4.1.25506.2.87.1.4.2.4) |
OCTET STRING |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapMsgMovedAddress (1.3.6.1.4.1.25506.2.87.1.4.2.5) |
OCTET STRING |
MAC address. |
As per the MIB. |
hh3cMACInfoTrapMsgMovedVlan
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapMsgMovedVlan (1.3.6.1.4.1.25506.2.87.1.4.2.6) |
Unsigned32 |
Unsigned32 (1..4094) |
VLAN ID. |
As per the MIB. |
hh3cMACInfoTrapMsgMovedFromIf
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapMsgMovedFromIf (1.3.6.1.4.1.25506.2.87.1.4.2.7) |
Unsigned32 |
Unsigned32(1..2147483647) |
Source port for the MAC address move. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapMsgMovedToIf (1.3.6.1.4.1.25506.2.87.1.4.2.8) |
Unsigned32 |
Destination port for the MAC address move. |
As per the MIB. |
hh3cMACInfoTrapMsgMovedCount
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapMsgMovedCount (1.3.6.1.4.1.25506.2.87.1.4.2.9) |
Counter32 |
MAC address move count. |
As per the MIB. |
hh3cMACInfoTrapMsgMovedVsi
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapMsgMovedVsi (1.3.6.1.4.1.25506.2.87.1.4.2.10) |
OCTET STRING |
OCTET STRING (1..31) |
A MAC address moves on a VSI. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapMsgMovedFmIfName (1.3.6.1.4.1.25506.2.87.1.4.2.11) |
OCTET STRING |
OCTET STRING (0..255) |
Source interface name for the MAC address move or interface + service instance or link identifier. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapMsgMovedToIfName (1.3.6.1.4.1.25506.2.87.1.4.2.12) |
OCTET STRING |
Destination interface name for the MAC address move or interface + service instance or link identifier. |
As per the MIB. |
hh3cMACInfoTrapMsgChassis
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapMsgChassis (1.3.6.1.4.1.25506.2.87.1.4.2.13) |
Unsigned32 |
Chassis ID. |
As per the MIB. |
hh3cMACInfoTrapMsgSlot
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapMsgSlot (1.3.6.1.4.1.25506.2.87.1.4.2.14) |
Unsigned32 |
Slot ID. |
As per the MIB. |
hh3cMACInfoTrapMsgBlockIfName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapMsgBlockIfName (1.3.6.1.4.1.25506.2.87.1.4.2.15) |
OCTET STRING |
Interface name. |
As per the MIB. |
hh3cMACInfoTrapMsgBlockTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACInfoTrapMsgBlockTime (1.3.6.1.4.1.25506.2.87.1.4.2.16) |
Unsigned32 |
Unsigned32(30..86400) |
Suppression interval (seconds). |
As per the MIB. |
Tabular objects
hh3cMACInfomationIfTable
About this table
Use this table to configure MAC Information on ports.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMACLearntEnable (1.3.6.1.4.1.25506.2.87.1.2.1.1.1) |
read-write |
INTEGER |
MAC learning event reporting. |
As per the MIB. |
hh3cMACRemovedEnable (1.3.6.1.4.1.25506.2.87.1.2.1.1.2) |
read-write |
INTEGER |
MAC aging or deletion event reporting. |
As per the MIB. |
Notifications
This table contains notifications output by HH3C-MAC-INFORMATION-MIB.
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.87.1.3.0.1 |
MAC changes. |
Informational |
Warning |
ON |
Notification triggers
This notification is generated when MAC addresses change.
System impact
Status control
This notification cannot be disabled.
Objects
OID (Object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.87.1.3.2.1 (hh3cMACInfoTrapIndex) |
N/A |
Unsigned32 |
Unsigned32 (1..2147483647) |
1.3.6.1.4.1.25506.2.87.1.3.2.2 (hh3cMACInfoTrapCount) |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.87.1.3.2.3 (hh3cMACInfoTrapMsg) |
N/A |
OCTET STRING |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.87.1.4.0.1 |
MAC changes. |
Informational |
Warning |
N/A |
ON |
System impact
Status control
Objects
OID (Object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.87.1.4.2.1 (hh3cMACInfoTrapVerExt) |
SNMP version. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.87.1.4.2.2 (hh3cMACInfoTrapIndexExt) |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.87.1.4.2.3 (hh3cMACInfoTrapCountExt) |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.87.1.4.2.4 (hh3cMACInfoTrapMsgExt) |
N/A |
OCTET STRING |
Recommended action
hh3cMACInformationMovedTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.87.1.4.0.2 |
A MAC address moves. |
Error |
Minor |
1.3.6.1.4.1.25506.2.87.1.4.0.3 (hh3cMACInformationMovedRsmTrap) |
OFF |
This notification is generated when a MAC address moves.
System impact
The MAC address move might cause transient interruption of traffic.
Status control
ON
CLI: Use the snmp-agent trap enable mac-address [ mac-move ] command.
OFF
CLI: Use the undo snmp-agent trap enable mac-address [ mac-move ] command.
Objects
OID (Object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.87.1.4.2.5.0 (hh3cMACInfoTrapMsgMovedAddress) |
MAC address. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.87.1.4.2.6.0 (hh3cMACInfoTrapMsgMovedVlan) |
VLAN ID. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.87.1.4.2.7.0 (hh3cMACInfoTrapMsgMovedFromIf) |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.87.1.4.2.8.0 (hh3cMACInfoTrapMsgMovedToIf) |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.87.1.4.2.9.0 (hh3cMACInfoTrapMsgMovedCount) |
N/A |
Counter32 |
1.3.6.1.4.1.25506.2.87.1.4.2.13.0 (hh3cMACInfoTrapMsgChassis) |
Chassis ID. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.87.1.4.2.14.0 (hh3cMACInfoTrapMsgSlot) |
Slot ID. |
N/A |
Unsigned32 |
Recommended action
To resolve this issue:
1. Execute the display mac-address mac-move command to view the MAC address move records, and check whether physical Layer 2 loops exist on interfaces.
¡ If physical Layer 2 loops exist, remove these loops. If MAC address moves occur frequently after you remove the loops, perform step 2.
¡ If no Layer 2 loop exists, perform step 2.
2. Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.87.1.4.0.3 |
MAC address moves stop. |
Recovery |
Minor |
N/A |
ON |
This notification is generated when MAC address moves stop in a VLAN within a specific time period.
System impact
No negative impact on services.
Status control
ON
OFF
Objects
OID (Object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.87.1.4.2.6 (hh3cMACInfoTrapMsgMovedVlan) |
VLAN ID. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.87.1.4.2.13 (hh3cMACInfoTrapMsgChassis) |
Chassis ID. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.87.1.4.2.14 (hh3cMACInfoTrapMsgSlot) |
Slot ID. |
N/A |
Unsigned32 |
Recommended action
hh3cMACInfoVsiMovedTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.87.1.4.0.4 |
Error |
Minor |
1.3.6.1.4.1.25506.2.87.1.4.0.5 (hh3cMACInfoVsiMovedRsmTrap) |
ON |
This notification is generated when a MAC address moves on a VSI.
System impact
Status control
ON
OFF
Objects
OID (Object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.87.1.4.2.5 (hh3cMACInfoTrapMsgMovedAddress) |
MAC address. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.87.1.4.2.10 (hh3cMACInfoTrapMsgMovedVsi) |
VSI name. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.87.1.4.2.11 (hh3cMACInfoTrapMsgMovedFmIfName) |
Source interface name for the MAC address move or interface + service instance or link identifier |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.87.1.4.2.12 (hh3cMACInfoTrapMsgMovedToIfName) |
Destination interface name for the MAC address move or interface + service instance or link identifier |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.87.1.4.2.9 (hh3cMACInfoTrapMsgMovedCount) |
N/A |
Counter32 |
Chassis ID. |
N/A |
Unsigned32 |
Slot ID. |
N/A |
Unsigned32 |
Recommended action
1. Execute the display l2vpn mac-address mac-move command to view the MAC address move records, and check whether physical Layer 2 loops exist on the VSI.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.87.1.4.0.5 |
MAC address moves stop on a VSI. |
Recovery |
Minor |
N/A |
ON |
This notification is generated when MAC address moves stop on a VSI within a specific time period.
System impact
Status control
ON
OFF
Objects
OID (Object name) |
Index nodes |
Type |
Value range |
VSI name. |
N/A |
OCTET STRING |
Chassis ID. |
N/A |
Unsigned32 |
Slot ID. |
N/A |
Unsigned32 |
Recommended action
hh3cMACInfoMovedIfBlockTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.87.1.4.0.6 |
MAC address move suppression is triggered on an interface due to frequent MAC address moves. |
Error |
Critical |
1.3.6.1.4.1.25506.2.87.1.4.0.7 (hh3cMACInfoMovedIfResumeTrap) |
ON |
This notification is generated when MAC address move suppression is triggered on an interface due to frequent MAC address moves, and this interface will be shut down for a suppression interval.
System impact
MAC address move suppression might cause service interruption on the shutdown interface.
Status control
ON
OFF
Objects
OID (Object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.87.1.4.2.15 (hh3cMACInfoTrapMsgBlockIfName) |
Interface name. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.87.1.4.2.16 (hh3cMACInfoTrapMsgBlockTime) |
N/A |
Unsigned32 |
MAC address. |
N/A |
OCTET STRING |
VLAN ID. |
N/A |
Unsigned32 |
Recommended action
1. Check whether physical Layer 2 loops exist in the VLAN.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.87.1.4.0.7 |
An interface recovers from MAC address move suppression. |
Recovery |
Minor |
N/A |
ON |
This notification is generated when an interface goes up after a suppression interval elapses.
System impact
Services interrupted due to MAC address move suppression are restored.
Status control
ON
OFF
Objects
OID (Object name) |
Index nodes |
Type |
Value range |
Interface name. |
N/A |
OCTET STRING |
N/A |
Unsigned32 |
VLAN ID. |
N/A |
Unsigned32 |
Recommended action
