14-Basic network configuration
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Configuration Examples(V7)-6W10414-Basic network configuration
02-Layer 2 Static Aggregation Configuration Examples
Introduction
The following information provides Layer 2 static aggregation configuration examples.
This document applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of H3C Ethernet link aggregation.
Example: Configuring a Layer 2 static aggregation group
On the network shown in Figure 1, perform the following tasks:
·     Configure a Layer 2 static aggregation group on the AC and the switch to increase the bandwidth and improve link reliability.
·     Enable VLAN 10 at one end of the aggregate link to communicate with VLAN 10 at the other end.
·     Enable VLAN 20 at one end of the aggregate link to communicate with VLAN 20 at the other end.
Figure 1 Network diagram
Procedures
Configuring the AC
1.     Configure VLANs:
# Create VLAN 10, and assign port GigabitEthernet 1/0/3 to VLAN 10.
<AC> system-view
[AC] vlan 10
[AC-vlan10] port gigabitethernet 1/0/3
[AC-vlan10] quit
# Create VLAN 20, and assign port GigabitEthernet 1/0/4 to VLAN 20.
[AC] vlan 20
[AC-vlan20] port gigabitethernet 1/0/4
[AC-vlan20] quit
2.     Configure a Layer 2 aggregate interface:
# Create Layer 2 aggregate interface Bridge-Aggregation 1.
[AC] interface bridge-aggregation 1
[AC-Bridge-Aggregation1] quit
# Assign port GigabitEthernet 1/0/1 to link aggregation group 1.
[AC-GigabitEthernet1/0/1] port link-aggregation group 1
# Assign port GigabitEthernet 1/0/2 to link aggregation group 1.
[AC] interface gigabitethernet1/0/2
[AC-GigabitEthernet1/0/2] port link-aggregation group 1
[AC-GigabitEthernet1/0/2] quit
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as a trunk port and assign it to VLANs 10 and 20.
[AC-Bridge-Aggregation1] port link-type trunk
[AC-Bridge-Aggregation1] port trunk permit vlan 10 20
Configuring the switch
1.     Configure VLANs:
<Switch> system-view
[Switch] vlan 10
[Switch-vlan10] port gigabitethernet 1/0/3
[Switch-vlan10] quit
[Switch] vlan 20
[Switch-vlan20] port gigabitethernet 1/0/4
[Switch-vlan20] quit
[Switch] interface bridge-aggregation 1
[Switch-Bridge-Aggregation1] quit
[Switch-GigabitEthernet1/0/1] port link-aggregation group 1
[Switch-GigabitEthernet1/0/2] port link-aggregation group 1
[Switch-Bridge-Aggregation1] port link-type trunk
[Switch-Bridge-Aggregation1] port trunk permit vlan 10 20
1.     Verify that GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 on the AC are Selected ports in Layer 2 static aggregation group 1.
<AC> display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H - Expired
Role: P -- Primary, S -- Secondary
Aggregation Mode: Static
Management VLANs: None
  Port            Status  Priority Oper-Key    Role
  GE1/0/1         S       32768     2      None
  GE1/0/2         S       32768     2      None
2.     Verify that the bandwidth for Layer 2 aggregate interface Bridge-Aggregation 1 is the total bandwidth of GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 on the AC.
<AC> display interface bridge-aggregation 1
Bridge-Aggregation1
Current state: UP
Line protocol state: UP
IP packet frame type: Ethernet II, hardware address: 741f-4a05-3db8
Description: Bridge-Aggregation1 Interface
Bandwidth: 2000000 kbps
2Gbps-speed mode, full-duplex mode
PVID: 1
Port link-type: Trunk
 VLAN Passing:   1(default vlan), 10
 VLAN permitted: 1(default vlan), 10, 20
 Trunk port encapsulation: IEEE 802.1q
 Last 300 seconds input:  2 packets/sec 308 bytes/sec 0%
 Last 300 seconds output:  0 packets/sec 0 bytes/sec 0%
 Input (total):  12659 packets, 1290752 bytes
         177 unicasts, 9919 broadcasts, 2563 multicasts, 0 pauses
 Input (normal):  12659 packets, - bytes
 Input:  0 input errors, 0 runts, 0 giants, - throttles
         0 CRC, - frame, 0 overruns, 0 aborts
         - ignored, - parity errors
 Output (total): 316 packets, 295765 bytes
         307 unicasts, 9 broadcasts, 0 multicasts, 0 pauses
 Output (normal): 316 packets, - bytes
 Output: 0 output errors, 0 underruns, - buffer failures
         - lost carrier, - no carrier
Configuration files
·     AC:
vlan 10
vlan20
interface Bridge-Aggregation1
port trunk permit vlan 1 10 20
·     Switch:
vlan 10
vlan 20
Related documentation
·     Network Connectivity Command Reference in H3C Access Controllers Command References
·     Network Connectivity Configuration Guide in H3C Access Controllers Configuration Guides
