14-Basic network configuration
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Configuration Examples(V7)-6W10414-Basic network configuration
01-Internal-to-External Access Through NAT Configuration Examples
Introduction
The following information provides examples for configuring NAT to allow internal users to access the external network.
This document applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of NAT and WLAN.
Example: Configuring NAT to allow internal users to access the external network
As shown in Figure 1, the AP and the clients obtain IP addresses through DHCP. Configure dynamic NAT on the AC's interface that connect to the external network to allow only the clients at the 192.168.1.0/24 to access the Internet.
Figure 1 Network diagram
When you configure NAT to allow internal users to access the external network, follow these restrictions and guidelines:
·     If you configure NAT on VLAN interfaces, use the address group as a best practice for dynamic NAT.
·     Do not include the public IP address of the VLAN interface in the nat address-group.
·     If the AC uses only one public IP address of the VLAN interface for dynamic NAT, use the port-range command to specify a proper port range. As a best practice, use the port range from 10000 to 65535 to ensure that the service ports on the AC are not used by NAT.
·     Make sure the devices can reach each other. In this example, the routing configuration is not shown.
Procedures
Configuring the AC
Configuring the interfaces on the AC
# Create VLAN 100 and configure VLAN-interface 100. The AC will use this IP address to establish CAPWAP tunnels with APs.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.168.0.1 24
[AC-Vlan-interface100] quit
# Create VLAN 200 and configure VLAN-interface 200. The clients will access the WLAN network through this VLAN.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.168.1.1 24
[AC-Vlan-interface200] quit
# Create VLAN 300 and configure VLAN-interface 300. The AC will use this VLAN for dynamic address translation.
[AC] vlan 300
[AC-vlan300] quit
[AC] interface vlan-interface 300
[AC-Vlan-interface300] ip address 202.38.1.1 24
[AC-Vlan-interface300] quit
# Configure GigabitEthernet 1/0/1, the interface that connects to the switch, as a trunk port, and assign it to VLAN 100 and VLAN 200.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/2, the interface that connects to the Internet, as an access port, and assign it to VLAN 300.
[AC] interface gigabitethernet 1/0/2
[AC-GigabitEthernet1/0/2] port access vlan 300
[AC-GigabitEthernet1/0/2] quit
Configuring WLAN services
# Create service template 1 and enter its view.
[AC] wlan service-template 1
# Set the SSID to service for the service template.
[AC-wlan-st-1] ssid service
# Set the authentication and key management mode to PSK, and configure simple string 12345678 as the PSK.
[AC-wlan-st-1] akm mode psk
[AC-wlan-st-1] preshared-key pass-phrase simple 12345678
# Set the CCMP cipher suite and enable the RSN IE in the beacon and probe responses.
[AC-wlan-st-1] cipher-suite ccmp
[AC-wlan-st-1] security-ie rsn
# Configure the AC to forward client data traffic. (Skip this step if the client data traffic forwarder is the AC by default.)
[AC-wlan-st-1] client forwarding-location ac
# Enable the service template.
[AC-wlan-st-1] quit
Configuring the AP
In large-scale networks, configure AP groups instead of single APs as a best practice.
# Create AP officeap with model WA6320, and set the serial ID to 219801A28N819CE0002T.
[AC] wlan ap officeap model WA6320
[AC-wlan-ap-officeap] serial-id 219801A28N819CE0002T
# Create AP group group1 and add AP officeap to AP group group1.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap officeap
# Bind service template 1 to radio 2 in AP group group1.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template 1 vlan 200
# Enable radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] quit
[AC-wlan-ap-group-group1-ap-model-WA6320] quit
[AC-wlan-ap-group-group1] quit
Configuring dynamic NAT
# Configure address group 0. Add two public IP addresses 202.38.1.2 and 202.38.1.3 to the address range.
[AC] nat address-group 0
[AC-address-group-1] address 202.38.1.2 202.38.1.3
[AC-address-group-1] quit
# Configure ACL 2000 to identify packets sourced from 192.168.1.0/24.
[AC] acl basic 2000
[AC-acl-ipv4-adv-2000] rule permit source 192.168.1.0 0.0.0.255
[AC-acl-ipv4-adv-3000] quit
# Configure outbound dynamic IP and port translation on VLAN-interface 3000 to translate the source IP address of outgoing packets permitted by ACL 2000 into addresses in the address group 0.
[AC-Vlan-interface300] nat outbound 2000 address-group 0
Configuring the switch
# Create VLAN 100. The switch will use this VLAN to forward traffic on the CAPWAP tunnel between the AC and AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN 200. This VLAN is used to forward packets from the client.
[Switch] vlan 200
[Switch-vlan200] quit
# Configure GigabitEthernet 1/0/1, the interface that connects to the AC, as a trunk port, and assign it to VLAN 100 and VLAN 200.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/1, the interface that connects to the AP, as an access port, and assign it to VLAN 100.
# Enable PoE.
# Verify that when a user on the subnet 192.168.1.0/24 accesses the Internet, dynamic NAT is performed on the packets from the user. Execute the display nat session verbose command to display the NAT session information.
[AC] display nat session verbose
Slot 1:
Initiator:
  Source      IP/port: 192.168.1.2/1628
  Destination IP/port: 202.38.1.100/21
  DS-Lite tunnel peer: -
  Protocol: TCP(6)
  Inbound interface: Vlan-interface200
Responder:
  Source      IP/port: 202.38.1.100/21
  Destination IP/port: 202.38.1.2/1024
  Protocol: TCP(6)
  Inbound interface: Vlan-interface300
State: TCP_ESTABLISHED
Application: FTP
Start time: 2015-11-28 16:54:35  TTL: 2699s
Initiator->Responder:            1 packets          84 bytes
Responder->Initiator:            1 packets          84 bytes
Total sessions found: 1 s
Configuration files
·     AC:
vlan 100
vlan 200
vlan 300
 ssid service
akm mode psk
 preshared-key pass-phrase cipher $c$3$N//5BVbsOqdBTxi+7MJZKT6Zqh5MAmYs2ZzM
 cipher-suite ccmp
 security-ie rsn
interface Vlan-interface100
 ip address 192.168.0.1 255.255.255.0
interface Vlan-interface200
interface Vlan-interface300
 ip address 202.38.1.1 255.255.255.0
 nat outbound 2000 address-group 1
acl basic 2000
 rule 0 permit source 192.168.1.0 0.0.0.255
nat address-group 0
 ap officeap
 ap-model WA6320
  radio 2
   radio enable
·     Switch:
vlan 100
vlan 200
 poe enable
Related documentation
·     Network Connectivity Command Reference in H3C Access Controllers Command References
·     Network Connectivity Configuration Guide in H3C Access Controllers Configuration Guides
·     WLAN Access Command Reference in H3C Access Controllers Command References
·     WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
