08-Local forwarding
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Configuration Examples(V7)-6W10408-Local forwarding
03-Local Forwarding Mode Direct Portal Authentication (IPv6) Configuration Examples
Introduction
The following information provides examples for configuring direct IPv6 portal authentication in a wireless network where APs directly forward client traffic.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of AAA, portal, and WLAN.
Example: Configuring local forwarding mode direct IPv6 portal authentication
As shown in Figure 1:
·     The AP and the client obtain IPv6 addresses from the DHCPv6 server.
·     The AP and the AC use VLAN 100 to establish CAPWAP tunnels, and the client uses VLAN 200 to access the wireless network.
·     The AP directly forwards traffic of the client.
·     The IMC server acts as the portal authentication server, portal Web server, and RADIUS server.
·     The AC performs direct IPv6 portal authentication on clients. Before passing IPv6 portal authentication, the client can access only the portal Web server. After passing IPv6 portal authentication, the client can access other network resources.
·     The client user can access network resources on any Layer 2 ports in its access VLAN without re-authentication.
·     The IMC server can dynamically change authorization information for the user and can log out the user.
Figure 1 Network diagram
Analysis
To allow an authenticated user to access network resources on any Layer 2 ports in its access VLAN without re-authentication, enable the portal roaming feature.
To allow the RADIUS server to modify user authorization information and log out users, enable the RADIUS session-control feature.
To add GigabitEthernet 1/0/1 of the AP to the local forwarding VLAN (VLAN 200), edit the AP's configuration file and upload it to the AC's storage medium.
To allow portal users to access both IPv4 and IPv6 networks after passing one type (IPv4 or IPv6) of portal authentication, enable portal to support IPv4/IPv6 dual stack.
Configure DNS if necessary. In this example, DNS is not required.
When you configure direct portal authentication, follow these restrictions and guidelines:
·     Use the actual serial ID of an AP to uniquely identify that AP.
·     The portal authentication server type and portal Web server type configured on the AC must be the same as the types of the servers actually used.
·     By default, the portal Web server URL redirected to users does not carry parameters. You can configure the parameters to be carried in the redirection URL as needed.
Procedures
Configuring IMC
This example uses the IMC server to describe the RADIUS server and portal server configuration. The IMC server runs on IMC PLAT 7.1(E0303), IMC EIA 7.1(E0304), and IMC EIP 7.1(E0304).
Configuring the RADIUS server
1.     Add an access device:
a.     Log in to IMC and click the User tab.
b.     From the navigation tree, select User Access Policy > Access Device Management > Access Device.
c.     Click Add.
The Add Access Device page opens.
d.     Configure the shared key as radius.
The shared key must be the same as that configured for the RADIUS server on the AC.
e.     In the Device List area, click Add IPv6 Dev to open the Add Access Device Manually page. Enter the start IPv6 address 2001::1 and click OK.
f.     Use the default settings for other parameters.
g.     Click OK.
Figure 2 Adding an access device
2.     Add an access policy:
a.     From the navigation tree, select User Access Policy > Access Policy.
b.     Click Add to open the Add Access Policy page.
c.     Enter the policy name, select the service group, and use the default settings for other parameters.
d.     Click OK.
Figure 3 Adding an access policy
3.     Add an access service:
a.     From the navigation tree, select User Access Policy > Access Service.
b.     Click Add to open the Add Access Service page.
c.     Enter the service name, select the access policy configured in the previous step as the default access policy, and use the default settings for other parameters.
d.     Click OK.
Figure 4 Adding an access service
4.     Add an access user:
a.     From the navigation tree, select Access User > All Access Users.
b.     Click Add to open the Add Access User page.
c.     Click Select to select an existing user from the User Name list or click Add User to add a new user.
d.     Enter the account name.
e.     Enter and confirm the password.
g.     Click OK.
Figure 5 Adding an access user
Configuring the portal server
1.     Configure the portal authentication service:
b.     From the navigation tree, select User Access Policy > Portal Service > Server.
c.     Configure the portal server parameters.
This example uses the default settings.
d.     Click OK.
Figure 6 Configuring the portal server
2.     Configure an IP group:
a.     From the navigation tree, select User Access Policy > Portal Service > IP Group to open the portal IP group configuration page.
b.     Click Add to open the Add IP Group page.
c.     Enter the IP group name.
d.     Select Yes from the IPv6 field.
e.     Enter the start IP address and end IP address of the IP group.
Make sure the client IP address is in the IP group.
f.     Select a service group.
This example uses the default group Ungrouped.
g.     Click OK.
Figure 7 Adding an IP group
3.     Add a portal device:
a.     Select User Access Policy > Portal Service > Device from the navigation tree to open the portal device configuration page.
b.     Click Add to open the Add Device page.
c.     Enter the device name.
d.     Select Portal 3.0 from the Version list.
e.     Enter the IP address of the AC's interface connected to the client.
f.     Select whether to support server heartbeat and user heartbeat functions.
In this example, select No for both Support Server Heartbeat and Support User Heartbeat.
g.     Enter the key, which must be the same as that configured on the AC.
h.     Select Directly Connected from the Access Method list.
i.     Use the default settings for other parameters.
j.     Click OK.
Figure 8 Adding a portal device
4.     Associate the portal device with the IP group:
a.     In the device list on the portal device configuration page, click the Port Group icon in the Operation field of device NAS, as shown in Figure 9.
Figure 9 Device list
The port group configuration page opens.
Figure 10 Adding a port group
b.     Click Add to open the Add Port Group page as shown in Figure 11.
c.     Enter the port group name.
d.     Select the configured IP group.
The IP address used by the user to access the network must be within this IP group.
e.     Use the default settings for other parameters.
f.     Click OK.
Figure 11 Adding a port group
5.     From the navigation tree, select User Access Policy > Service Parameters > Validate to commit the configuration changes.
Editing the AP configuration file
# Use a text editor to edit the AP's configuration file. Name the configuration file map.txt, and then upload the file to the storage medium of the AC.
The content of the configuration file is as follows:
System-view
vlan 200
interface gigabitethernet1/0/1
port link-type trunk
port trunk permit vlan 200
Configuring the AC
1.     Configuring VLANs and interfaces:
# Create VLAN 100 and VLAN-interface 100. Assign the VLAN interface an IPv6 address. The AC will establish CAPWAP tunnels with APs in this VLAN.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ipv6 address 2001::1 64
# Disable RA message suppression.
[AC-Vlan-interface100] undo ipv6 nd ra halt
# Set the M flag to 1 and the O flag to 1 in RA advertisements to be sent on VLAN-interface 100.
[AC-Vlan-interface100] ipv6 nd autoconfig managed-address-flag
[AC-Vlan-interface100] ipv6 nd autoconfig other-flag
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200. Assign the VLAN interface an IPv6 address. This VLAN will be used for wireless client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ipv6 address 2004::1 64
[AC-Vlan-interface200] undo ipv6 nd ra halt
# Set the M flag to 1 and the O flag to 1 in RA advertisements to be sent on VLAN-interface 200.
[AC-Vlan-interface200] ipv6 nd autoconfig managed-address-flag
[AC-Vlan-interface200] ipv6 nd autoconfig other-flag
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 (the port connected to the switch) as a trunk port, and assign the port to VLAN 100 and VLAN 200.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2.     Configure a static route to reach the IMC:
[AC] ipv6 route-static 2003:: 64 2004::2
3.     Configure the wireless service:
# Create a service template named st1 and enter its view.
[AC] wlan service-template st1
# Configure the SSID of the service template as service.
[AC-wlan-st-st1] ssid service
# Assign clients coming online through the service template to VLAN 200.
[AC-wlan-st-st1] vlan 200
# Enable snooping DHCPv6 and ND packets.
[AC-wlan-st-st1] client ipv6-snooping dhcpv6-learning enable
[AC-wlan-st-st1] client ipv6-snooping nd-learning enable
# Configure APs to forward client data traffic from all VLANs. (Skip this step if the client data forwarder is APs by default.)
[AC–wlan-st-st1] client forwarding-location ap
# Configure the AKM mode as PSK, and set the preshared key to 12345678 in plain text.
[AC-wlan-st-st1] akm mode psk
[AC-wlan-st-st1] preshared-key pass-phrase simple 12345678
# Configure the cipher suite as CCMP and security IE as RSN.
[AC-wlan-st-st1] cipher-suite ccmp
[AC-wlan-st-st1] security-ie rsn
[AC-wlan-st-st1] quit
4.     Configure the AP:
In large-scale networks, configure AP groups instead of single APs as a best practice.
# Create an AP named ap1 with model WA6320 and set its serial ID to 219801A28N819CE0002T.
[AC] wlan ap ap1 model WA6320
[AC-wlan-ap-ap1] serial-id 219801A28N819CE0002T
# Create an AP group named group1 and add AP ap1 to the AP group.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap ap1
# Create an AP model named WA6320 in AP group group1 and then deploy configuration file map.txt to the AP.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] map-configuration map.txt
# Enter the AP group's radio 2 view, and bind service template st1 to radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template st1
# Enable radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] return
5.     Configure the RADIUS scheme:
# Create a RADIUS scheme named rs1 and enter its view.
<AC> system-view
[AC] radius scheme rs1
# Configure the primary authentication and accounting servers and shared keys used for secure communication with the servers.
[AC-radius-rs1] primary authentication ipv6 2003::2
[AC-radius-rs1] primary accounting ipv6 2003::2
[AC-radius-rs1] key authentication simple radius
[AC-radius-rs1] key accounting simple radius
# Configure the AC to remove the domain name from the usernames sent to the RADIUS servers.
[AC-radius-rs1] user-name-format without-domain
# Specify 2001::1 as the source IPv6 address of outgoing RADIUS packets.
[AC-radius-rs1] nas-ip ipv6 2001::1
[AC-radius-rs1] quit
# Enable the RADIUS session-control feature.
[AC] radius session-control enable
# Enable the RADIUS DAE server feature and enter RADIUS DAE server view.
[AC] radius dynamic-author server
# Specify a RADIUS DAE client at IPv6 address 2003::2 and configure the shared key for secure communication with the client as radius.
[AC-radius-da-server] client ipv6 2003::2 key simple radius
[AC-radius-da-server] quit
6.     Configure the authentication domain:
# Create an ISP domain named dm1 and enter its view.
[AC] domain dm1
# Configure the authentication and authorization methods as RADIUS and the accounting method as none for portal users.
[AC-isp-dm1] authentication portal radius-scheme rs1
[AC-isp-dm1] authorization portal radius-scheme rs1
[AC-isp-dm1] accounting portal none
# Configure the idle cut feature for users. Log out a user if the user's traffic is less than 1024 bytes in 15 minutes.
[AC-isp-dm1] authorization-attribute idle-cut 15 1024
[AC-isp-dm1] quit
7.     Configure portal authentication:
# Create a portal authentication server named newpt and specify the server's IPv6 address as 2003::2.
[AC] portal server newpt
[AC-portal-server-newpt] ipv6 2003::2 key simple 123456
[AC-portal-server-newpt] quit
# Create a portal Web server named newpt and specify the server's URL as http://[2003::2]:8080/portal.
[AC] portal web-server newpt
[AC-portal-websvr-newpt] url http://[2003::2]:8080/portal
# Configure the portal redirection URL to carry the ssid, wlanuserip, and wlanacname parameters, and their values are the AP's SSID, the user's IPv6 address, and the AC's name.
[AC-portal-websvr-newpt] url-parameter ssid ssid
[AC-portal-websvr-newpt] url-parameter wlanuserip source-address
[AC-portal-websvr-newpt] url-parameter wlanacname value AC
# Enable the portal roaming feature.
[AC] portal roaming enable
# Configure two portal-free rules to allow users to access the DNS server without authentication.
[AC] portal free-rule 1 destination ip any udp 53
[AC] portal free-rule 2 destination ip any tcp 53
# Configure a portal-free rule. Set the rule number to 3 and the source interface to aggregate interface 1. This rule allows users on the aggregate interface to access the network resources without authentication.
[AC] portal free-rule 3 source interface Bridge-Aggregation1
# Enable direct IPv6 portal authentication on service template st1.
[AC-wlan-st-st1] portal ipv6 enable method direct
# Configure the authentication domain for portal users as dm1.
[AC-wlan-st-st1] portal ipv6 domain dm1
# Specify portal Web server newpt on service template st1.
[AC-wlan-st-st1] portal ipv6 apply web-server newpt
# Enable portal to support IPv4/IPv6 dual stack on service template st1.
[AC-wlan-st-st1] portal dual-stack enable
# Configure the BAS-IPv6 attribute as 2001::1.
[AC-wlan-st-st1] portal bas-ipv6 2001::1
# Enable service template st1.
[AC–wlan-st-st1] service-template enable
Configuring the switch
# Create VLAN 100. The switch will use this VLAN to forward traffic on the CAPWAP tunnel between the AC and AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN 200. The switch will use this VLAN to forward traffic of wireless clients.
[Switch] vlan 200
[Switch-vlan200] quit
# Create VLAN 2. This VLAN is used for communication with the IMC server.
[Switch] vlan 2
[Switch-vlan2] quit
# Add the port connected to the IMC server to VLAN 2. (Details not shown.)
# Configure GigabitEthernet 1/0/1 (the port connected to the AC) as a trunk port. Assign the trunk port to VLAN 100 and VLAN 200.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/2 (the port connected to the AP) as a trunk port. Assign the trunk port to VLAN 100 and VLAN 200. Set the PVID of the trunk port to 100.
# Enable PoE on the port.
# Create VLAN-interface 200 and assign it an IPv6 address.
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ipv6 address 2004::2 64
[Switch-Vlan-interface200] quit
# Create VLAN-interface 2 and assign it an IPv6 address.
[Switch-Vlan-interface2] ipv6 address 2003::1 64
[Switch-Vlan-interface2] quit
Configuring the DHCPv6 server
Configure required settings on the DHCPv6 server. (Details not shown.)
# Use the configured username and password to perform portal authentication through a Web browser on the client. Before passing authentication, all Web accesses are redirected to the portal authentication page (http://[2003::2]:8080/portal). After passing authentication, you can access other network resources.
# Display the online portal user information on the AC.
[AC] display portal user all
Total portal users: 1
Username: Client
  AP name: ap1
  Radio ID: 2
  SSID: service
  Portal server: newpt
  State: Online
  VPN instance: N/A
  MAC             IP                    VLAN    Interface
  0021-6330-0933  2004::2               200     WLAN-BSS1/0/16
  Authorization information:
    DHCP IP pool: N/A
    User profile: N/A
    Session group profile: N/A
    ACL number: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
The output shows that the client successfully passes portal authentication and comes online.
# Display portal filtering rules on the AC and the AP.
[AC] display portal rule all ap ap1
Slot 1:
[AP] display portal rule all
IPv6 portal rules on WLAN-BSS1/0/16:
Rule 1:
 Type                : Static
 Action              : Permit
 Protocol            : Any
 Status              : Active
 Source:
    IP             : ::
    Prefix length  : 0
    Port           : Any
    MAC            : 0000-0000-0000
    Interface      : WLAN-BSS1/0/16
    VLAN           : Any
 Destination:
    IP             : 2003::2
    Prefix length  : 128
    Port           : Any
Rule 2:
 Type                : Dynamic
 Action              : Permit
 Status              : Active
 Source:
    IP             : 2004::2
    MAC            : 0021-6330-0933
    VLAN           : Any
The output shows that the AC does not have portal filtering rules for the AP and the AP has the portal filtering rules. This is because the local forwarding mode is used.
Configuration files
·     AC:
vlan 100
vlan 200
 ssid service
 vlan 200
akm mode psk
 cipher-suite ccmp
 security-ie rsn
interface Vlan-interface100
 ipv6 address 2001::1/64
interface Vlan-interface200
 ipv6 address 2004::1/64
 port trunk permit vlan 1 100 200
radius scheme rs1
 key authentication cipher $c$3$Sqgqz7lDs4XPnethmAgyAKVlke7qwEkYbQ==
 key accounting cipher $c$3$4J/JBRGwqB4F213furJMkB6JWYXBFjWE6g==
 nas-ip ipv6 2001::1
 client ip ipv6 2003::2 key cipher $c$3$AkTEB7OgMYnCqsfDeplhoAgXUek/rVrLZw==
domain dm1
portal server newpt
 ipv6 2003::2 key cipher $c$3$wu1Cg6I4PTcPTgPeKRF/7w9jIqIEq2xlTw==
ap ap1
ap-model WA6320
 map-configuration flash:/map.txt
 radio 1
 radio 2
  radio enable
·     Switch:
vlan 2
vlan 100
vlan 200
 port trunk pvid vlan 100
 poe enable
Related documentation
·     User Access and Authentication Command Reference in H3C Access Controllers Command References
·     User Access and Authentication Configuration Guide in H3C Access Controllers Configuration Guides
·     WLAN Access Command Reference in H3C Access Controllers Command References
·     WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
