08-Local forwarding
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Configuration Examples(V7)-6W10408-Local forwarding
01-Local Forwarding Mode and Local Portal Authentication Configuration Examples
Introduction
The following information provides an example of configuring local portal authentication on a wireless network where APs forward client traffic locally.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of AAA, portal authentication, WLAN access, and WLAN high availability.
Example: Configuring local forwarding mode and local portal authentication
As shown in Figure 1:
·     The AP and the client obtain IP addresses from the DHCP server.
·     The AP and the AC use VLAN 100 to establish CAPWAP tunnels, and the client uses VLAN 200 to access the wireless network.
·     The AC acts as the portal authentication server and portal Web server.
Configure the devices to meet the following requirements:
·     The AC uses a service template to provide direct portal authentication for the client. Before passing the authentication, the client can access only the portal Web server. After passing the authentication, the client can access other network resources.
·     The AP forwards the client traffic locally.
·     The client can access network resources through any Layer 2 ports in its access VLAN without re-authentication.
Figure 1 Network diagram
Analysis
To allow a client to access network resources through any Layer 2 ports in its access VLAN without re-authentication, enable portal roaming.
In local forwarding mode, to ensure that valid clients can perform portal authentication, enable validity check on wireless clients.
To avoid portal authentication failure caused by frequent logins and logouts in a short time, disable the Rule ARP entry feature.
To use GigabitEthernet 1/0/1 on the AP to forward client traffic, edit a .txt configuration file and upload the file to the AC.
Use the actual serial ID of an AP to uniquely identify that AP.
By default, the portal Web server URL redirected to users does carry parameters. You can configure the parameters to be carried in the redirection URL as needed.
Procedures
Editing the AP configuration file
# Use a text editor to edit the AP's configuration file. Name the configuration file map.txt, and then upload the file to the storage medium of the AC.
The content of the configuration file is as follows:
vlan 200
interface gigabitethernet1/0/1
port link-type trunk
port trunk permit vlan 200
Configuring the AC
1.     Configure interfaces:
# Create VLAN 100, create VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish CAPWAP control and data tunnels with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 2.2.1.1 24
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The AC will use VLAN 200 for client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 2.2.2.1 24
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 (the port connected to the switch) as a trunk port, and assign the port to VLAN 100 and VLAN 200.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2.     Configure the wireless service:
# Create a service template named st1.
[AC] wlan service-template st1
# Set the SSID of the service template.
[AC-wlan-st-st1] ssid service
# Specify VLAN 200 for the service template.
[AC-wlan-st-st1] vlan 200
# Configure APs to forward client data traffic from all VLANs.
[AC–wlan-st-st1] client forwarding-location ap
[AC-wlan-st-st1] quit
# Configure the AKM mode as PSK, and set the preshared key to 12345678 in plain text.
[AC-wlan-st-st1] akm mode psk
[AC-wlan-st-st1] preshared-key pass-phrase simple 12345678
# Configure the cipher suite as CCMP and security IE as RSN.
[AC-wlan-st-st1] cipher-suite ccmp
[AC-wlan-st-st1] security-ie rsn
3.     Configure the AP:
In large-scale networks, configure AP groups instead of single APs as a best practice.
# Create an AP named ap1 with model WA6320 and set its serial ID to 219801A28N819CE0002T.
[AC] wlan ap ap1 model WA6320
[AC-wlan-ap-ap1] serial-id 219801A28N819CE0002T
# Create an AP group named group1 and add AP ap1 to AP group group1.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap ap1
# Create an AP model named WA6320 in AP group group1 and then deploy configuration file map.txt to the AP.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] map-configuration map.txt
# Enter the AP group's radio 2 view, and bind service template st1 to radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template st1
# Enable radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] return
4.     Configure an ISP domain:
# Create an ISP domain named dm1.
<AC> system-view
[AC] domain dm1
# Configure the AC to perform local authentication and not to perform authorization or accounting on portal users in the ISP domain.
[AC-isp-dm1] authentication portal local
[AC-isp-dm1] authorization portal none
[AC-isp-dm1] accounting portal none
# Configure the idle cut feature so that the AC will log out a user if the user's total traffic in the idle timeout period is less than 1024 bytes.
[AC-isp-dm1] authorization-attribute idle-cut 15 1024
[AC-isp-dm1] quit
5.     Configure portal authentication:
# Create a portal Web server named newpt, and specify http://2.2.2.1/portal as the server's URL
[AC] portal web-server newpt
[AC-portal-websvr-newpt] url http://2.2.2.1/portal
# Add parameter wlanuserip to the URL of the portal Web server and specify the user IP address as the value of the parameter.
[AC-portal-websvr-newpt] url-parameter wlanuserip source-address
[AC-portal-websvr-newpt] quit
# Create an HTTP-based local portal Web service.
[AC] portal local-web-server http
# Specify file abc.zip as the default authentication page file for the local portal Web service.
[AC–portal-local-websvr-http] default-logon-page abc.zip
[AC–portal-local-websvr-http] quit
# Create two destination-based portal-free rules to permit traffic to the DNS server.
[AC] portal free-rule 1 destination ip any udp 53
[AC] portal free-rule 2 destination ip any tcp 53
# Add a network access user named 123, set the password of the user, and assign the portal service to the user.
[AC] local-user 123 class network
[AC-luser-network-123] password simple 123
[AC-luser-network-123] service-type portal
[AC-luser-network-123] quit
# Enable roaming for portal users.
[AC] portal roaming enable
# Disable the Rule ARP entry feature.
[AC] undo portal refresh arp enable
# Enable validity check on wireless portal clients.
[AC] portal host-check enable
# Enable direct portal authentication on service template st1.
[AC-wlan-st-st1] portal enable method direct
# Specify ISP domain dm1 as the portal authentication domain on service template st1.
[AC-wlan-st-st1] portal domain dm1
# Specify portal Web server newpt on service template st1.
[AC-wlan-st-st1] portal apply web-server newpt
# Enable service template st1.
[AC–wlan-st-st1] service-template enable
Configuring the switch
# Create VLAN 100. The switch will use this VLAN to forward traffic on CAPWAP tunnels between the AC and the AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN 200, create VLAN-interface 200, and assign an IP address to the VLAN interface. The switch will use this VLAN to forward packets for wireless clients.
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 2.2.2.100 255.255.255.0
[Switch-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 (the port connected to the AC) as a trunk port, and assign the port to VLAN 100 and VLAN 200.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/2 (the port connected to the AP) as a trunk port, and assign the port to VLAN 100 and VLAN 200.
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] port trunk permit vlan 100 200
[Switch-GigabitEthernet1/0/2] port trunk pvid vlan 100
# Enable PoE on GigabitEthernet 1/0/2.
Configuring the DHCP server
Configure required settings on the DHCP server. (Details not shown.)
Verifying local portal authentication
# Use the configured username and password to perform portal authentication through a Web browser on the client. Before passing authentication, all Web accesses are redirected to the portal authentication page (http://2.2.2.1/portal). After passing authentication, you can access other network resources. (Details not shown.)
# Display online portal user information on the AC.
[AC] display portal user all
Total portal users: 1
Username: Client
  Portal server: newpt
  State: Online
  VPN instance: N/A
  MAC             IP                    VLAN    Interface
  0021-6330-0933  2.2.2.2               200     WLAN-BSS1/0/16
  Authorization information:
    DHCP IP pool: N/A
    User profile: N/A
    Session group profile: N/A
    ACL number: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
The output shows that the user has passed portal authentication.
Verifying local forwarding mode
# Display portal filtering rules on the AC.
[AC] display portal rule all ap ap1
Slot 1:
The output shows that the AC does not have portal filtering rules, indicating that the AC does not forward client data traffic.
# Display portal filtering rules on the AP.
[AP] display portal rule all
IPv4 portal rules on WLAN-BSS1/0/16:
Rule 1:
 Type                : Static
 Action              : Permit
 Protocol            : Any
 Status              : Active
 Source:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    Port           : Any
    MAC            : 0000-0000-0000
    Interface      : WLAN-BSS1/0/16
    VLAN           : Any
 Destination:
    IP             : 2.2.2.1
    Mask           : 255.255.255.255
    Port           : Any
Rule 2:
 Type                : Dynamic
 Action              : Permit
 Status              : Active
 Source:
    IP             : 2.2.2.2
    MAC            : 0021-6330-0933
    VLAN           : Any
Rule 3:
 Type                : Static
 Action              : Redirect
 Status              : Active
 Source:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    VLAN           : Any
    Protocol       : TCP
 Destination:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    Port           : 443
Rule 4:
 Type                : Static
 Action              : Redirect
 Status              : Active
 Source:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    VLAN           : Any
    Protocol       : TCP
 Destination:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    Port           : 80
Rule 5:
 Type                : Static
 Action              : Deny
 Status              : Active
 Source:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    VLAN           : Any
 Destination:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
The output shows that the AP has portal filtering rules, indicating that the AP forwards client data traffic.
Configuration files
·     AC:
vlan 100
vlan 200
 ssid service
 vlan 200
akm mode psk
 cipher-suite ccmp
 security-ie rsn
portal domain dm1
interface Vlan-interface100
 ip address 2.2.1.1 255.255.255.0
interface Vlan-interface200
 ip address 2.2.2.1 255.255.255.0
 port trunk permit vlan 1 100 200
domain dm1
ap ap1
ap-model WA6320
 map-configuration flash:/map.txt
 radio 1
 radio 2
  radio enable
·     Switch:
vlan 100
vlan 200
poe enable
Related documentation
·     User Access and Authentication Command Reference in H3C Access Controllers Command Reference
·     User Access and Authentication Configuration Guide in H3C Access Controllers Configuration Guide
·     WLAN Access Command Reference in H3C Access Controllers Command Reference
·     WLAN Access Configuration Guide in H3C Access Controllers Configuration Guide
