| 01-Text | 2.33 MB |
1 About the router
Chassis views
The figures in this section are for illustration only.
MSR1008
Figure1-1 Front view
(1) AC power receptacle |
(2) Console port |
(3) USB port |
(4) Reset button (RESET) |
(5) GE copper ports GE0 and GE1 (combo ports) |
(6) GE fiber ports SFP0 and SFP1 (combo ports) |
(7) 10GE fiber ports SFP+10 and SFP+11 |
(8) GE copper ports GE2 to GE9 |
Figure1-2 Rear view
(1) Grounding screw |
MSR1004-G
Figure1-3 Front view
(1) GE copper ports GE1 to GE4 |
(2) Console port |
(3) GE fiber ports SFP5 and SFP6 |
(4) USB port |
(5) Reset button (RESET) |
(6) Power adapter receptacle |
(7) GE copper port GE0 |
Figure1-4 Rear view
(1) Grounding terminal |
MSR1004S-5G/MSR1004S-5G-GL
Figure1-5 Front view
(1) Power adapter receptacle |
(2) Reset button (RESET) |
(3) Console port |
(4) USB port |
(5) GE copper ports GE1 to GE4 |
(6) GE copper port GE0 |
(7) GE fiber ports SFP5 and SFP6 |
Figure1-6 Left view
(2) Micro SIM card slots SIM0 and SIM1 |
(3) 5G antenna port (ANT3/GNSS) |
(4) 5G antenna ports (ANT0 to ANT2) |
MSR1004S-5G-CN
Figure1-7 Front view
(3) Console port |
(4) USB port |
Figure1-8 Left view
(3) 5G antenna ports (M0 to M3) |
MSR1104S-W
Figure1-9 Front view
(1) GE copper ports GE2 to GE5 |
(2) GE copper port GE0 |
(3) GE fiber port GE1 |
(4) Console port |
(6) USB port |
(7) Power adapter receptacle |
Figure1-10 Rear view
(2) 2.4 GHz and 5 GHz WLAN antennas |
MSR1104S-W-CAT6
Figure1-11 Front view
(4) Micro SIM card slots SIM0 and SIM1 |
(5) Console port |
(6) Reset button (RESET) |
(7) USB port |
(8) Power adapter receptacle |
Figure1-12 Rear view
(2) 4G LTE antenna ports 1 and 2 |
(3) GNSS antenna port (reserved) |
(4) 2.4 GHz and 5 GHz WLAN antennas |
MSR1104S-5G-CN
Figure1-13 Front view
(5) Console port |
(7) USB port |
Figure1-14 Rear view
(2) 5G antenna ports (M0 to M3) |
MSR1104S-W-5G-CN
Figure1-15 Front view
(5) Console port |
(7) USB port |
Figure1-16 Rear view
(3) 2.4 GHz and 5 GHz WLAN antennas |
LEDs
MSR1008
Figure1-17 LEDs on the front panel
(1) GE copper port LEDs (GE2 to GE9) |
(2) 10GE fiber port LEDs (SFP+10 and SFP+11) |
(3) Fiber combo port LEDs (SFP0 and SFP1) |
(4) Copper combo port LEDs (GE0 and GE1) |
(5) System status LED (SYS) |
(6) CTRL LED |
MSR1004-G
Figure1-18 LEDs on the front panel
(1) GE copper port LEDs (GE0 to GE4) |
(2) GE fiber port LEDs (SFP5 and SFP6) |
(3) CTRL LED |
(4) System status LED (SYS) |
Figure1-19 LEDs on the front panel
(1) WWAN LED |
(2) 5G network signal LED |
(3) 3G/4G LTE LED |
(4) GNSS LED |
(5) GE copper port LEDs (GE0 to GE4) |
(6) GE fiber port LEDs (SFP5 and SFP6) |
(7) Micro SIM card status LED |
(8) System status LED (SYS) |
(9) Power status LED (PWR) |
MSR1004S-5G-CN
Figure1-20 LEDs on the front panel
(1) WWAN LED |
(3) 3G/4G LTE LED |
(4) GE copper port LEDs (GE0 to GE4) |
(5) GE fiber port LEDs (SFP5 and SFP6) |
(6) Micro SIM card status LED |
(7) System status LED (SYS) |
(8) Power status LED (PWR) |
MSR1104S-W
Figure1-21 LEDs on the front panel
(1) GE copper port LEDs (GE0, GE2 to GE5) |
(2) GE fiber port LED (GE1) |
(3) 2.4G Wi-Fi status LED |
(4) 5G Wi-Fi status LED |
(5) CTRL LED |
(6) System status LED (SYS) |
MSR1104S-W-CAT6
Figure1-22 LEDs on the front panel
(3) Micro SIM0 card status LED |
(4) Micro SIM1 card status LED |
(5) 2.4G Wi-Fi status LED |
(6) 5G Wi-Fi status LED |
(7) 3G/4G LTE LED |
(8) CTRL LED |
(9) System status LED (SYS) |
MSR1104S-5G-CN
Figure1-23 LEDs on the front panel
(5) 5G network signal LED |
(6) 3G/4G LTE LED |
(7) CTRL LED |
MSR1104S-W-5G-CN
Figure1-24 LEDs on the front panel
(5) 2.4G and 5G Wi-Fi status LED |
(6) 5G network signal LED |
(7) 3G/4G LTE LED |
(8) CTRL LED |
LED descriptions
Table1-1 LED descriptions
LED |
Status |
Fast flashing green |
The BootWare is running. |
Steady green |
The Kernel (including Eshell) is running. |
Slowly flashing green |
Comware is starting or running correctly. |
Slowly flashing yellow |
The memory test has failed (BootWare stage). |
Fast flashing yellow |
The extended BootWare segment does not exist (BootWare stage). |
Steady yellow |
The boot.bin file does not exist (BootWare stage). |
Off |
No power is present, the power system has failed, or a hardware failure has occurred. |
Steady green |
The power system is operating correctly. |
Off |
No power input. |
GE copper port LED Copper combo port LED |
Steady green |
A link is present on the port, and the port is operating at 1000 Mbps. |
Flashing green |
The port is sending or receiving data at 1000 Mbps. |
Steady yellow |
A link is present on the port, and the port is operating at 10/100 Mbps. |
Flashing yellow |
The port is sending or receiving data at 10/100 Mbps. |
Off |
No link is present on the port. |
GE fiber port LED Fiber combo port LED |
Steady green |
Flashing green |
Steady yellow |
A link is present on the port, and the port is operating at 100 Mbps. |
Flashing yellow |
The port is sending or receiving data at 100 Mbps. |
Off |
10GE fiber port LED |
Steady green |
A link is present on the port, and the port is operating at 10 Gbps. |
Flashing green |
The port is sending or receiving data at 10 Gbps. |
Steady yellow |
Flashing yellow |
Off |
CTRL LED (applicable to MSR1008) |
Steady green |
The device has established a WebSocket connection with the AD-WAN controller. |
Flashing yellow |
The device is trying to establishing a connection with the AD-WAN controller. |
Off |
No connection is established between the device and the AD-WAN controller. |
CTRL LED (applicable to MSR1004-G/MSR1104S-W/MSR1104S-W-CAT6/MSR1104S-5G-CN/MSR1104S-W-5G-CN) |
Steady green |
Off |
WWAN LED |
Steady green |
A link is present. |
Flashing green (8 Hz) |
Data is being sent or received. |
Flashing green (1 Hz) |
Searching for networks. |
Off |
No link is present. |
5G network signal LED (applicable to MSR1004S-5G/MSR1004S-5G-GL/MSR1004S-5G-CN) |
Steady green |
Strong 5G network signals in SA mode. |
Fair 5G network signals in SA mode. |
Weak 5G network signals in SA mode. |
Steady yellow |
Strong 5G network signals in NSA mode. |
Flashing yellow (8 Hz) |
Fair 5G network signals in NSA mode. |
Flashing yellow (1 Hz) |
Weak 5G network signals in NSA mode. |
Off |
Poor 5G network signals. 5G services are not available. |
5G network signal LED (applicable to MSR1104S-5G-CN/MSR1104S-W-5G-CN) |
Steady green |
Strong 5G network signals in SA or NSA mode. |
Fair 5G network signals in SA or NSA mode. |
Weak 5G network signals in SA or NSA mode. |
Off |
3G/4G LTE LED (applicable to MSR1004S-5G/MSR1004S-5G-GL/MSR1004S-5G-CN) |
Steady green |
Strong 4G network signals. |
Fair 4G network signals. |
Weak 4G network signals. |
Steady yellow |
Strong 3G network signals |
Fair 3G network signals. |
Weak 3G network signals. |
Off |
Poor network signals. 3G and 4G services are not available. |
3G/4G LTE LED (applicable to MSR1104S-W-CAT6/MSR1104S-5G-CN/MSR1104S-W-5G-CN) |
Steady green |
Steady yellow |
Off |
Steady green |
The 2.4G radio is in standby state and does not have associated clients. |
Flashing green |
The 2.4G radio has associated clients and is sending or receiving data. |
Off |
The 2.4G radio is disabled. |
Steady green |
The 5G radio is in standby state and does not have associated clients. |
Flashing green |
The 5G radio has associated clients and is sending or receiving data. |
Off |
The 5G radio is disabled. |
Steady green |
The radios are in standby state and do not have associated clients. |
Flashing green |
A radio has associated clients and is sending or receiving data. |
Off |
The radios are disabled. |
GNSS LED |
Steady green |
Normal GNSS service. |
Off |
GNSS service is not enabled or is abnormal. |
Steady green |
A card is present in SIM card slot 1. |
Steady yellow |
A card is present in SIM card slot 2. |
Off |
No card is present in both the SIM card slots. |
Micro SIM0/SIM1 card status LED (applicable to MSR1104S-W-CAT6) |
Steady green |
The SIM card is present. |
The SIM card is being used for dial-up. |
The 4G port for the SIM card is sending or receiving data at 2 Gbps, 3 Gbps, or 4 Gbps. |
Steady yellow |
The SIM card is faulty. |
Off |
No SIM card is present, or the 4G module is not present or is being initialized. |
Micro SIM0/SIM1 card status LED (applicable to MSR1104S-5G-CN/MSR1104S-W-5G-CN) |
Steady green |
The 5G port for the SIM card is sending or receiving data at 2 Gbps, 3 Gbps, 4 Gbps, or 5 Gbps. |
Steady yellow |
Off |
No SIM card is present, or the module is not present or is being initialized. |
Interface numbering
Conventions
The interfaces on an MSR1000 router (except for the MSR1008 and MSR1004-G routers) are numbered in the interface-type X/Y format.
· interface-type—Type of the interface such as console, GigabitEthernet, and Ten-GigabitEthernet.
· X—Slot number. For panel interfaces, the number is fixed at 0.
· Y—Number of the interface on the router, starting from 0. The number of an interface is the same as its identifier on the panel.
The interfaces on an MSR1008 or MSR1004-G router are numbered in the interface-type X/Y/Z format.
· Y—Subslot number. The MSR1008 or MSR1004-G router does not support subslots and the number is fixed at 0.
· Z—Number of the interface on the router, starting from 0. The number of an interface is the same as its identifier on the panel.
· On the MSR1004S-5G router, GE fiber ports SFP5 and SFP6 are numbered GigabitEthernet 0/5 and GigabitEthernet 0/6, respectively.
· On the MSR1008 router, GE copper ports GE2 to GE9 are numbered GigabitEthernet 0/0/2 to GigabitEthernet 0/0/9, respectively.
Router specifications
Table1-2 Technical specifications for the MSR1008 and MSR1004-G routers
Item |
MSR1008 |
MSR1004-G |
Dimensions (H × W × D) (excluding rubber feet and mounting brackets) |
43.6 × 266 × 161 mm (1.72 × 10.47 × 6.34 in) |
44 × 210 × 140 mm (1.73 × 8.27 × 5.51 in) |
Dimensions (H × W × D, with package materials) |
85 × 360 × 266 mm (3.35 × 14.17 × 10.47 in) |
95 × 290 × 295 mm (3.74 × 11.42 × 11.61 in) |
Rack height |
1 U |
1 U |
Weight (without package materials) |
1.2 kg (2.65 lb) |
1.1 kg (2.43 lb) |
Weight (with package materials) |
2.04 kg (4.50 lb) |
1.56 kg (3.44 lb) |
Max power consumption |
14.7 W |
11.06 W |
Console port |
1 |
1 |
Console port type |
RJ-45 |
RJ-45 |
USB port |
1 |
1 |
GE copper port |
10, including two combo interfaces |
5 |
GE fiber port |
2, combo interfaces |
2 |
10 GE fiber port |
2 |
N/A |
Memory |
2 GB DDR4 |
2 GB DDR4 |
Flash |
4 GB |
8 GB |
Power supply mode |
AC built-in |
AC external |
Power adapter rated input voltage |
N/A |
100 to 240 VAC @ 50 to 60 Hz |
Power adapter input voltage range |
N/A |
90 to 264 V @ 47 to 63 Hz |
Router power input |
12 V ± 5%/1.5 A |
Router power input voltage range |
N/A |
Max input current |
1 A |
1.5 A |
Fan tray type |
Fanless |
Fanless |
Heat dissipation method |
Passive cooling |
Passive cooling |
Sound pressure level at normal temperature (sound power) |
0 (passive cooling) |
RTC |
Not supported |
Not supported |
Max supported power |
36 W |
18 W |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
–20°C to +55°C (–4°F to +131°F) |
Operating humidity |
5% RH to 95% RH, noncondensing |
Long-term operating altitude |
–60 m to +5000 m (–196.85 ft to +16404.20 ft) |
Table1-3 Technical specifications for the MSR1004S-5G, MSR1004S-5G-GL, and MSR1004S-5G-CN routers
Item |
MSR1004S-5G/MSR1004S-5G-GL |
MSR1004S-5G-CN |
52.4 × 150 × 127 mm (2.06 × 5.91 × 5.00 in) |
90 × 285 × 295 mm (3.54 × 11.22 × 11.61 in) |
Rack height |
1 U |
1 U |
1.1 kg (2.43 lb) |
1.1 kg (2.43 lb) |
1.92 kg (4.23 lb) |
1.92 kg (4.23 lb) |
13.8 W |
17.5 W |
Console port |
1 |
1 |
Console port type |
RJ-45 |
RJ-45 |
USB port |
1 |
1 |
GE copper port |
5 |
5 |
GE fiber port |
2 |
2 |
Built-in 5G module |
5G NSA/SA, LTE, UMTS WCDMA |
5G antenna port |
4 |
4 |
GNSS antenna port |
1 |
N/A |
Memory |
1GB DDR3 |
1GB DDR3 |
Flash |
512 MB |
512 MB |
Power supply mode |
AC external |
AC external |
12 V ± 5%/3 A |
12 V ± 5%/3 A |
Max input current |
3 A |
3 A |
Fan tray type |
Fanless |
Fanless |
Passive cooling |
Passive cooling |
RTC |
Not supported |
Not supported |
48 W |
48 W |
–40°C to +70°C (–40°F to +158°F) |
Table1-4 Technical specifications for the MSR1104S-W and MSR1104S-W-CAT6 routers
Item |
MSR1104S-W |
MSR1104S-W-CAT6 |
77 × 407 × 377 mm (3.03 × 16.02 × 14.84 in) |
Rack height |
1 U |
1 U |
0.95 kg (2.09 lb) |
1.06 kg (2.34 lb) |
2.1 kg (4.63 lb) |
2.2 kg (4.85 lb) |
9.5 W |
14.2 W |
Console port |
1 |
1 |
Console port type |
RJ-45 |
RJ-45 |
USB port |
1 |
1 |
GE copper port |
5 |
5 |
GE fiber port |
1 |
1 |
Built-in 4G module |
N/A |
TDD-LTE, FDD-LTE, WCDMA |
4G LTE antenna port |
N/A |
2 |
GNSS antenna port |
N/A |
1 (reserved) |
WLAN antenna port |
2 (fixed antennas) |
Memory |
1 GB DDR4 |
1 GB DDR4 |
Flash |
256 MB |
256 MB |
Power supply mode |
AC external |
AC external |
12 V ± 5%/2 A |
12 V ± 5%/2 A |
Max input current |
2 A |
2 A |
Fan tray type |
Fanless |
Fanless |
Passive cooling |
Passive cooling |
RTC |
Supported |
Supported |
24 W |
24 W |
Table1-5 Technical specifications for the MSR1104S-5G-CN and MSR1104S-W-5G-CN routers
Item |
MSR1104S-5G-CN |
MSR1104S-W-5G-CN |
Rack height |
1 U |
1 U |
0.95 kg (2.09 lb) |
1.15 kg (2.54 lb) |
2.2 kg (4.85 lb) |
2.2 kg (4.85 lb) |
16.7 W |
12.9 W |
Console port |
1 |
1 |
Console port type |
RJ-45 |
RJ-45 |
USB port |
1 |
1 |
GE copper port |
5 |
5 |
GE fiber port |
1 |
1 |
5G antenna port |
4 |
4 |
WLAN antenna port |
N/A |
Memory |
1 GB DDR4 |
1 GB DDR4 |
Flash |
256 MB |
256 MB |
Power supply |
AC external |
AC external |
12 V ± 5%/2 A |
12 V ± 5%/2 A |
Max input current |
2 A |
2 A |
Fan tray type |
Fanless |
Fanless |
Passive cooling |
Passive cooling |
RTC |
Supported |
Supported |
24 W |
24 W |
Antenna specifications
Table1-6 5G stick antenna specifications for MSR1004S-5G/MSR1004S-5G-GL
Item |
Specification |
Frequency range |
· 617 to 960 MHz/1710 to 2170 MHz · 2300 to 2700 MHz/3300 to 3800 MHz · 4400 to 5000 MHz/5150 to 5850 MHz |
Voltage standing wave ratio (VSWR) |
≤ 4 |
Input impedance |
50 ohms |
Gain |
· 617 to 960 MHz @ 0.59 dBi · 1710 to 2170 MHz @ 3.74 dBi · 2300 to 2700 MHz @ 3.51 dBi · 3300 to 3800 MHz @ 3.7 dBi · 4400 to 5000 MHz @ 4.0 dBi · 5150 to 5850 MHz @ 4.87 dBi |
Max power |
1 W |
Color |
Black |
Weight |
19.63 g (0.69 oz) |
–20°C to +65°C (–4°F to +149°F) |
Table1-7 5G stick antenna specifications for MSR1004S-5G-CN/MSR1104S-5G-CN/MSR1104S-W-5G-CN
Item |
Specification |
Frequency range |
0.6 to 6 GHz |
≤ 6 |
Input impedance |
50 ohms |
Gain |
· 2.74 dBi Max. @ 0.617 to 0.96 GHz · 1.01 dBi Max. @ 1.4 to 1.612 GHz · 4.48 dBi Max. @ 1.71 to 2.17 GHz · 3.98 dBi Max. @ 2.3 to 2.7 GHz · 4.74 dBi Max. @ 3.3 to 4.0 GHz · 5.50 dBi Max. @ 4.0 to 5.0 GHz · 5.82 dBi Max. @ 5.15 to 5.85 GHz |
Polarization |
Vertical |
Max input power |
1 W |
Connector type |
SMA male connector |
Height |
17.6 cm (6.93 in) |
Weight |
20 g (0.71 oz) |
Color |
Black |
Table1-8 4G stick antenna specifications for MSR1104S-W-CAT6
Item |
Specification |
Frequency range |
· 617 to 960 MHz/1420 to 1520 MHz · 1710 to 2690 MHz/3300 to 3800 MHz · 4400 to 5000 MHz/5150 to 5850 MHz |
≤ 3 |
Input impedance |
50 ohms |
Gain |
· 617 to 960 MHz @ 0.5 dBi · 1420 to 1520 MHz @ 1.4 dBi · 1710 to 2690 MHz @ 3.4 dBi · 3300 to 3800 MHz @ 4.0 dBi · 4400 to 5000 MHz @ 4.0 dBi · 5150 to 5850 MHz @ 3 dBi |
Max power |
1 W |
Color |
Black |
Weight |
21.2 g (0.75 oz) |
–20°C to +60°C (–4°F to +140°F) |
4G/5G antenna extension cable specifications
Table1-9 4G/5G antenna extension cable specifications
Cable length |
Applicable router model |
3 m (9.84 ft)/10 m (32.81 ft)/15 m (49.21 ft)/20 m (65.62 ft) |
· MSR1004S-5G · MSR1004S-5G-GL |
5 m (16.40 ft)/10 m (32.81 ft) |
MSR1104S-W-CAT6 |
1 m (3.28 ft)/5 m (16.40 ft)/10 m (32.81 ft)/15 m (49.21 ft) |
· MSR1004S-5G-CN · MSR1104S-5G-CN · MSR1104S-W-5G-CN |
Link mode of interfaces
Table1-10 Interfaces that can operate only as Layer 3 Ethernet interfaces
Device model |
Interfaces |
MSR1008 |
Combo 0 (GE0, SFP0), Combo 1 (GE1, SFP1), SFP+10, SFP+11 |
MSR1004-G |
GE0 |
GE0, SFP5, SFP6 |
MSR1004S-5G-CN |
GE0, SFP5, SFP6 |
MSR1104S-W |
GE0, GE1 |
MSR1104S-W-CAT6 |
GE0, GE1 |
MSR1104S-5G-CN |
GE0, GE1 |
MSR1104S-W-5G-CN |
GE0, GE1 |
Table1-11 Interfaces that can operate only as Layer 2 Ethernet interfaces
Device model |
Interfaces |
MSR1008 |
GE6 to GE9 |
MSR1004-G |
N/A |
N/A |
MSR1004S-5G-CN |
N/A |
MSR1104S-W |
N/A |
MSR1104S-W-CAT6 |
N/A |
MSR1104S-5G-CN |
N/A |
MSR1104S-W-5G-CN |
N/A |
Table1-12 Interfaces that support link mode change
Device model |
Interfaces |
MSR1008 |
GE2 to GE5 |
MSR1004-G |
GE1 to GE4, SFP5, SFP6 |
GE1 to GE4 |
MSR1004S-5G-CN |
GE1 to GE4 |
MSR1104S-W |
GE2 to GE5 |
MSR1104S-W-CAT6 |
GE2 to GE5 |
MSR1104S-5G-CN |
GE2 to GE5 |
MSR1104S-W-5G-CN |
GE2 to GE5 |
