| Title | Size | Downloads |
| V7-IPS-1.0.280.dat | 13.78 MB |
Version number
V7-IPS-1.0.280
MD5 number
b706b679d003d18a956bc9d05a68e013
Update time
2024-01-26
Update attack list
Key new rules:
51299 CVE-2024-0305_Ncast_busiFacade_Remote_code_execution_vulnerability[2]
---- Category: Vulnerability
---- Description: Ncast HD Intelligent Recording and Playback system is a new audio and video recording and playback system
---- designed to provide high quality, high-definition customized recording and playback capabilities.
---- There is an information leakage vulnerability (CVE-2024-0305) in the HD intelligent recording and broadcasting system
---- of Guangzhou Yingvisual Electronic Technology Co, through which attackers can use the visitor identity
---- to access /manage/IPSetup.php background function module without authorization, and use the network diagnosis function module
---- to achieve unauthorized remote command execution. Cause the server to crash is charged.
51303 CVE-2023-50038_textpanttern_cms_Any_file_upload_vulnerability[2]
---- Description: Textpattern CMS is a PHP-based content management system from the Textpattern team.
---- Textpattern CMS v4.8.8 has a security vulnerability. This vulnerability is caused by any file upload vulnerability
---- in the background of the system. Attackers can use this vulnerability to obtain server permissions.
51334 CVE-2023-22527_Confluence_Data_Center_and_Server_Remote_Code_Execution_Vulnerability[2]
---- Description: Atlas Confluence is a professional enterprise knowledge management and collaboration software developed
---- by Australian company Atlas, which can also be used to build enterprise WiKi. There is a security vulnerability
---- in the Atlas Confluence Data Center and Server, which arises from a template injection vulnerability
---- that allows unauthorized attackers to execute remote code on affected instances.
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the IPS rules library file of this version, 21609 predefined rules can be generated in "Intrusion Prevention System"
[4] The device memory is less than or equal to 2GB. After loading the IPS rules library file of this version, 3188 predefined rules can be generated in "Intrusion Prevention System"
