HomeSupportSwitchesS5570S-EI SeriesConfigure & DeployConfiguration GuidesH3C S5570S-EI & S5500V3-SI Configuration Guides-R11xx-6W10209-Security Configuration Guide
23-Crypto engine configuration
23-Crypto engine configuration 40.38 KB
Configuring crypto engines
About crypto engines
Crypto engines encrypt and decrypt data for service modules.
The device supports only one software crypto engine, which is a set of software encryption algorithms. The software crypto engine is always enabled.
When a service module requires data encryption/decryption, it sends the desired data to the crypto engine. After the crypto engine completes data encryption/decryption, it sends the data back to the service module.
Display and maintenance commands for crypto engines
Display crypto engine information.
display crypto-engine
Display crypto engine statistics.
display crypto-engine statistics [ engine-id engine-id slot slot-number ]
Clear crypto engine statistics.
reset crypto-engine statistics [ engine-id engine-id slot slot-number ]
