| 02-Appendix | 6.17 MB |
Appendix A Server specifications
Server models and chassis view
Front panel view of the server
Processor mezzanine board components
Appendix B Component specifications
DRAM DIMM rank classification label
Front 8SFF SAS/SATA drive backplane
Front 8SFF UniBay drive backplane
Front 17SAS/SATA+8UniBay drive backplane
Rear 2SFF UniBay drive backplane
Appendix C Managed removal of OCP network adapters
Appendix D Environment requirements
About environment requirements
General environment requirements
Operating temperature requirements
The information in this document might differ from your product if it contains custom configuration options or features.
Figures in this document are for illustration only.
H3C UniServer R6700 G6 servers are 2U four-processor servers independently developed by H3C based on the new-generation Eagle Stream platform of Intel. The servers can be widely used in general computing scenarios, including cloud computing, virtualization, distributed storage, and enterprise resource allocation. They are suitable for typical applications in industries such as Internet, service providers, enterprises, and government. The servers provide balanced computing performance, storage capacity, power efficiency, scalability, and reliability, and are easy to deploy and manage.
Figure 1 Chassis view
The servers come in the model listed in Table 1. For more information about drive configuration and compatible storage controller configuration, see H3C UniServer R6700 G6 Server Drive Configurations and Cabling Solutions.
Table 1 R6700 G6 server models
Model |
Maximum drive configuration |
SFF |
25SFF drives at the front + 2SFF/8E1.S drives at the rear |
Technical specifications
Item |
Specifications |
Dimensions (H × W × D) |
· Without a security bezel: 87.5 × 445.4 × 748 mm (3.44 × 17.54 × 29.45 in) · With a security bezel: 87.5 × 445.4 × 776 mm (3.44 × 17.54 × 30.55 in) |
Max. weight |
44.34 kg (97.75 lb) |
Processors |
4 × Intel Eagle Stream processors, maximum 350 W power consumption per processor |
Memory |
Up to 64 DIMMs (DDR5 supported) |
Storage controllers |
· Standard storage controller · NVMe VROC module · Serial & DSD module (supports RAID 1) |
Chipset |
Intel C741 Emmitsburg |
Integrated graphics |
The graphics chip (model AST2600) is integrated in the BMC management chip to provide a maximum resolution of 1920 × 1200@60Hz (32bpp), where: · 1920 × 1200: 1920 horizontal pixels and 1200 vertical pixels. · 60Hz: Screen refresh rate, 60 times per second. · 32bpp: Color depts. The higher the value, the more colors that can be displayed. If you attach monitors to both the front and rear VGA connectors, only the monitor connected to the front VGA connector is available. |
Network connectors |
· 1 × embedded 1 Gbps HDM dedicated management port · Up to three OCP 3.0 network adapter connectors for OCP 3.0 network adapters (support NCSI) |
I/O connectors |
· 6 × USB connectors ¡ 3 × USB3.0 connectors (one on the right chassis ear, and two on the rear panel) ¡ 3 × USB2.0 connectors (two on the system board, and one available on the left chassis ear only when the multifunctional rack mount kit is used) · 10 × built-in SATA connectors (displayed as 2 × x4 SlimSAS connectors and 1 × M.2 connector) · 32 × MCIO connectors (PCIe5.0 x8) · 1 × RJ-45 HDM dedicated network port (at the server rear) · 2 × VGA connectors (one on the front panel, and one available on the left chassis ear only when the multifunctional rack mount kit is used) · 1 × serial port (available only when the Serial & DSD module is used) · 1 × dedicated management port (on the front panel) |
Expansion slots |
10 × PCIe standard slots |
Optical drives |
External USB optical drives |
Power supplies |
Up to 4 × hot-swappable power supplies, N + N redundancy |
Standards |
CCC, UL, CE |
Components
Figure 2 R6700 G6 server components
Item |
(1) Chassis access panel |
N/A |
(2) Processor mezzanine board |
Provides extension slots for processors and memory modules. |
(3) CPU heatsink |
Cools the processor. |
(4) System battery |
Supplies power to the system clock to ensure system time correctness. |
(5) Storage controller |
Provides RAID capability to SAS/SATA drives, including RAID configuration and RAID scale-up. It supports online upgrade of the controller firmware and remote configuration. |
(6) NVMe VROC module |
Works with Intel VMD to provide RAID capability for the server to virtualize storage resources of NVMe drives. |
(7) Memory |
Stores computing data and data exchanged with external storage temporarily. |
(8) GPU module |
Provides computing services such as graphics processing and AI. |
(9) Standard PCIe network adapter |
Installed in a standard PCIe slot to provide network ports. |
(10) Riser card |
Provides PCIe slots. |
(11) Serial & DSD module |
Provides one serial port and two SD card slots. |
(12) Power expander module |
Provides power connectors for another two power supplies. |
(13) Rear drive backplane |
Provides power and data channels for drives at the server rear. |
(14) Rear drive cage |
Installed at the server rear to accommodate drives. |
(15) OCP riser card |
Provide OCP network adapter slots and support rear drives to expand OCP network adapters. 2SFF drive configuration does not support the OCP riser card. |
(16) Riser card blank |
Installed on an empty PCIe riser connector to ensure good ventilation. |
(17) Server management module |
Provides I/O connectors and HDM out-of-band management features. |
(18) OCP network adapter |
Network adapter installed onto the OCP network adapter connector on the system board. |
(19) Power supply |
Supplies power to the server. The power supplies support hot swapping and N+N redundancy. |
(20) Chassis |
Accommodate all components. |
(21) Right chassis ear |
Attach the server to the rack. This ear is integrated with the front I/O component. |
(22) Front drive backplane |
Provides power and data channels for drives at the server front. This document installs an 8SFF front drive backplane as an example. |
(23) LCD smart management module |
Displays basic server information, operating status, and fault information. Together with HDM event logs, users can fast locate faulty components and troubleshoot the server, ensuring server operation. |
(24) Drive |
Provides data storage space. Drives support hot swapping. |
(25) Left chassis ear |
Attach the server to the rack. If this ear is multifunctional, it is integrated with VGA connector, dedicated management connector, and USB 3.0 connector. |
(26) SATA M.2 SSD expander module |
Provides M.2 SSD slots. |
(27) SATA M.2 SSD |
Provides data storage space for the server. |
(28) Encryption module |
Provides encryption services for the server to enhance data security. |
(29) Fan cage |
Accommodates fan modules. |
(30) Chassis open-alarm module |
Detects if the access panel is removed. The detection result can be displayed from the HDM Web interface. |
(31) Air baffle |
Provides ventilation aisles for processor heatsinks and memory modules and provides support for the supercapacitor. |
(32) Supercapacitor holder |
Secures a supercapacitor in the chassis. |
(33) Supercapacitor |
Supplies power to the flash card on the power fail safeguard module, which enables the storage controller to back up data to the flash card for protection when power outage occurs. |
(34) Fan |
Helps server ventilation. Fans support hot swapping and N+1 redundancy. |
(35) Processor retaining bracket |
Attaches a processor to the heatsink. |
(36) Processor |
Integrates memory and PCIe controllers to provide data processing capabilities for the server. |
(37) Processor socket cover |
Installed over an empty processor socket to protect pins in the socket. |
(38) System board |
One of the most important parts of a server, on which multiple components are installed, such as processor, memory, and fan. It is integrated with basic server components, including the BIOS chip and PCIe connectors. |
Front panel
Figure 3 8SFF front panel
Table 2 8SFF front panel description
Item |
1 |
Bay 1: 8SFF drives (optional)* |
2 |
Bay 2: 8SFF drives (optional)* |
3 |
Bay 3: 8SFF drives (optional)* |
4 |
USB 3.0 connector |
5 |
LCD smart management module (optional) |
6 |
Serial label pull tab |
7 |
Dedicated management connector |
8 |
USB 2.0 connector |
9 |
VGA connector |
*: Drive types supported by the server vary by drive backplane configuration. For more information, see "Drive backplanes." |
Figure 4 25SFF front panel
Table 3 25SFF front panel description
Item |
1 |
25SFF drives* |
2 |
USB 3.0 connector |
3 |
Drive or LCD mart management module (optional) |
4 |
5 |
6 |
USB 2.0 connector |
7 |
VGA connector |
LEDs and buttons
Figure 5 Front panel LEDs and buttons
Table 4 LEDs and buttons on the front panel
Button/LED |
Status |
Power on/standby button and system power LED |
· Steady green—The system has started. · Flashing green (1 Hz)—The system is starting. · Steady amber—The system is in standby state. · Off—No power is present. Possible reasons: ¡ No power source is connected. ¡ No power supplies are present. ¡ The installed power supplies are faulty. ¡ The system power cords are not connected correctly. |
OCP 3.0 network adapter Ethernet port LED |
· Steady green—A link is present on a port of an OCP 3.0 network adapter. · Flashing green—A port on an OCP 3.0 network adapter is receiving or sending data. · Off—No link is present on any port of either OCP 3.0 network adapter. NOTE: The server supports a maximum of three OCP3.0 network adapters. |
Health LED |
· Steady green—The system is operating correctly or a minor alarm is present. · Flashing green (4 Hz)—HDM is initializing. · Flashing amber (1 Hz)—A major alarm is present. · Flashing red (1 Hz)—A critical alarm is present. If a system alarm is present, log in to HDM to obtain more information about the system running status. |
UID button LED |
· Steady blue—UID LED is activated. The UID LED can be activated by using the following methods: ¡ Press the UID button LED. ¡ Activate the UID LED from HDM. · Flashing blue: ¡ 1 Hz—The firmware is being upgraded or the system is being managed from HDM. Do not power off the server. ¡ 4 Hz—HDM is restarting. To restart HDM, press the UID button LED for eight seconds. · Off—UID LED is not activated. |
Security bezel light
The security bezel provides hardened security and uses effect light to visualize operation and health status to help inspection and fault location. The default effect light is as shown in Figure 6.
Table 5 Security bezel effect light
System status |
Light status |
Standby |
Steady white: The system is in standby state. |
Startup |
· Beads turn on white from middle in turn—POST progress. · Beads turn on white from middle three times—POST has finished. |
Running |
· Breathing white (gradient at 0.2 Hz)—Normal state, indicating the system load by the percentage of beads turning on from the middle to the two sides of the security bezel. ¡ No load—Less than 10%. ¡ Light load—10% to 50%. ¡ Middle load—50% to 80%. ¡ Heavy load—More than 80%. · Breathing white (gradient at 1 Hz )—A pre-alarm is present. · Flashing amber (1 Hz)—A major alarm is present. · Flashing red (1 Hz)—A critical alarm is present. |
UID |
· All beads flash white (1 Hz)—The firmware is being upgraded or the system is being managed from HDM. Do not power off the server. · Some beads flash white (1 Hz)—HDM is restarting. |
Ports
Table 6 Ports on the front panel
Port |
Type |
VGA connector |
DB-15 |
Connects a display terminal, such as a monitor or KVM device. |
USB connector |
USB 2.0/3.0 |
Connects the following devices: · USB flash drive. · USB keyboard or mouse. · USB optical drive for operating system installation. |
Type-C |
Connects a Type-C to USB adapter cable, which connects to a USB Wi-Fi adapter. NOTE: The server supports only Xiaomi USB Wi-Fi adapters. |
Rear panel
Rear panel view
Figure 7 Rear panel components
Table 7 Rear panel description
1 |
PCIe riser bay 1: PCIe slots 1 through 3 |
2 |
PCIe riser bay 2: PCIe slots 4 through 6 |
3 |
PCIe riser bay 3: PCIe slots 7 and 8 (power expander module, optional) |
4 |
PCIe riser bay 4: PCIe slots 9 and 10 (power expander module, optional) |
5 |
Power supply 2 |
6 |
Power supply 1 |
7 |
OCP 3.0 network adapter/Serial & DSD module (in slot 12) (optional) |
8 |
VGA connector |
9 |
Two USB 3.0 connectors |
10 |
HDM dedicated network port (1Gbps, RJ-45, default IP address 192.168.1.2/24) |
11 |
OCP 3.0 network adapter (in slot 11) (optional) |
LEDs
(1) Power supply LED for power supply 2 |
(2) Power supply LED for power supply 1 |
(3) Activity LED of the Ethernet port |
(4) Link LED of the Ethernet port |
(5) UID LED |
Table 8 LEDs on the rear panel
LED |
Status |
Power supply LED |
· Steady green—The power supply is operating correctly. · Flashing green (0.33 Hz)—The power supply is in standby state and does not output power. · Flashing green (2 Hz)—The power supply is updating its firmware. · Steady amber—Either of the following conditions exists: ¡ The power supply is faulty. ¡ The power supply does not have power input, but another power supply has correct power input. · Flashing amber (1 Hz)—An alarm has occurred on the power supply. · Off—No power supplies have power input, which can be caused by an incorrect power cord connection or power source shutdown. |
· Flashing green—The port is receiving or sending data. · Off—The port is not receiving or sending data. |
· Steady green—A link is present on the port. · Off—No link is present on the port. |
UID LED |
· Steady blue—UID LED is activated. The UID LED can be activated by using the following methods: ¡ Press the UID button LED. ¡ Enable UID LED from HDM. · Flashing blue: ¡ 1 Hz—The firmware is being upgraded or the system is being managed from HDM. Do not power off the server. ¡ 4 Hz—HDM is restarting. To restart HDM, press the UID button LED for 8 seconds. · Off—UID LED is not activated. |
Ports
Table 9 Ports on the rear panel
Port |
Type |
VGA connector |
DB-15 |
BIOS serial port |
DB-9 |
The BIOS serial port is used for the following purposes: · Log in to the server when the remote network connection to the server has failed. · Establish a GSM modem or encryption lock connection. |
USB connector |
USB 3.0 |
HDM dedicated network port |
RJ-45 |
Establishes a network connection to manage HDM from its Web interface. |
Power receptacle |
Standard single-phase |
Connects the power supply to the power source. |
System board
System board components
Figure 9 System board components
Table 10 System board components
Item |
Mark |
1 |
OCP network adapter connector 2/Serial & DSD module connector |
OCP2 |
2 |
Fan connector for OCP 3.0 network adapter 2 |
OCP2 FAN |
3 |
TPM/TCM connector |
TPM |
4 |
PFR module connector |
PFRCPLD |
5 |
Server management module connector |
BMC |
6 |
PCIe riser connector 1 (x16 PCIe5.0, for processor 1) |
RISER1 PCIe X16 |
7 |
Fan connector for OCP 3.0 network adapter 1 |
OCP1 FAN |
8 |
OCP 3.0 network adapter connector 1 |
OCP1 |
9 |
SlimSAS connector 2 (x4 SATA) |
SATA PORT2 |
10 |
SlimSAS connector 1 (x4 SATA) |
SATA PORT1 |
11 |
M.2 connector (x2 SATA) |
M.2 PORT |
12 |
NVMe VROC module connector |
NVMe RAID KEY |
13 |
Front I/O connector |
RIGHT EAR |
14 |
Built-in USB 2.0 connector |
INTERNAL USB2.0 |
15 |
System battery |
N/A |
16 |
MCIO connector C1-P1C (x8 PCIe5.0, for processor 1) |
C1-P1C |
17 |
MCIO connector C1-P1A (x8 PCIe5.0, for processor 1) |
C1-P1A |
18 |
MCIO connector C1-P3A (x8 PCIe5.0, for processor 1) |
C1-P3A |
19 |
MCIO connector C1-P3C (x8 PCIe5.0, for processor 1) |
C1-P3C |
20 |
MCIO connector C1-P4C (x8 PCIe5.0, for processor 1) |
C1-P4C |
21 |
MCIO connector C1-P4A (x8 PCIe5.0, for processor 1) |
C1-P4A |
22 |
AUX connector 3 for the front drive backplane |
AUX3 |
23 |
AUX connector 2 for the front drive backplane |
AUX2 |
24 |
Power connector 5 for the front drive backplane |
AUX5 |
25 |
LCD smart management module connector |
DIAG LCD |
26 |
Temperature sensing module connector |
SENSOR1 |
27 |
Power connector 3 for the front drive backplane |
PWR3 |
28 |
Power connector 6 for the front drive backplane |
PWR6 |
29 |
AUX connector 5 for the front drive backplane |
AUX 5 |
30 |
AUX connector 6 for the front drive backplane |
AUX 6 |
31 |
AUX connector 4 for the front drive backplane |
AUX 4 |
32 |
MCIO connector C2-P4A (x8 PCIe5.0, for processor 2) |
C2-P4A |
33 |
MCIO connector C2-P4C (x8 PCIe5.0, for processor 2) |
C2-P4C |
34 |
Power connector 4 for the front drive backplane |
PWR4 |
35 |
MCIO connector C2-P3C (x8 PCIe5.0, for processor 2) |
C2-P3C |
36 |
Power connector 1 for the front drive backplane |
PWR1 |
37 |
MCIO connector C2-P3A (x8 PCIe5.0, for processor 2) |
C2-P3A |
38 |
Power connector 2 for the front drive backplane |
PWR2 |
39 |
AUX connector 1 for the front drive backplane |
AUX1 |
40 |
Chassis-open alarm module connector |
INTRUDER |
41 |
Front VGA and USB2.0 connector |
LEFT EAR |
42 |
Power connector 8 for the rear drive backplane |
PWR8 |
43 |
Signal connector for power supplies 3 and 4 |
PSU34 |
44 |
Power connector 7 for the rear drive backplane |
PWR7 |
45 |
Power expander module connector |
PSU1, PSU2 |
46 |
AUX connector for PCIe riser card 4 |
RISER4 AUX |
47 |
AUX connector 7 for the rear drive backplane |
AUX7 |
48 |
PCIe riser connector 3 (x16 PCIe5.0, for processor 2) |
RISER3 PCIe X16 |
49 |
PCIe riser connector 2 (x16 PCIe5.0, for processor 2) |
RISER2 PCIe X16 |
50 |
NCSI connector for OCP 3.0 network adapter 3 |
OCP3 |
51 |
Power connector for OCP network adapter 3 |
RISER & GPU POWER |
52 |
MCIO connector C2-P2C (x8 PCIe5.0, for processor 2) |
C2-P2C |
53 |
MCIO connector C2-P2A (x8 PCIe5.0, for processor 2) |
C2-P2A |
54 |
INTERNAL USB2.0 |
55 |
AUX connector 8 for the rear drive backplane |
AUX8 |
56 |
Mid module connector |
N/A |
X |
System maintenance switch |
MAINTENANCE SW |
Figure 10 shows the system maintenance switch. Table 11 describes how to use the maintenance switch.
Figure 10 System maintenance switch
Table 11 System maintenance switch description
Item |
Remarks |
1 |
· Off (default)—HDM login requires the username and password of a valid HDM user account. · On—HDM login requires the default username and password. |
For security purposes, turn off the switch after you complete tasks with the default username and password as a best practice. |
5 |
· Off (default)—Normal server startup. · On—Restores the default BIOS settings. |
To restore the default BIOS settings, turn on and then turn off the switch. The server starts up with the default BIOS settings at the next startup. The server cannot start up when the switch is turned on. To avoid service data loss, stop running services and power off the server before turning on the switch. |
6 |
· Off (default)—Normal server startup. · On—Clears all passwords from the BIOS at server startup. |
If this switch is on, the server will clear all the passwords at each startup. Make sure you turn off the switch before the next server startup if you do not need to clear all the passwords. |
2, 3, 4, 7, and 8 |
Reserved for future use. |
N/A |
Figure 11 show the processor mezzanine board layout.
Figure 11 Processor mezzanine board components
Table 12 Processor mezzanine board components
Item |
Mark |
1 |
MCIO connector C4-P2C (x8 PCIe5.0, for processor 4) |
C4-P2C |
2 |
MCIO connector C4-P2A (x8 PCIe5.0, for processor 4) |
C4-P2A |
3 |
MCIO connector C4-P1A (x8 PCIe5.0, for processor 4) |
C4-P1A |
4 |
MCIO connector C4-P1C (x8 PCIe5.0, for processor 4) |
C4-P1C |
5 |
MCIO connector C4-P0C (x8 PCIe5.0, for processor 4) |
C4-P0C |
6 |
MCIO connector C4-P0A (x8 PCIe5.0, for processor 4) |
C4-P0A |
7 |
MCIO connector C3-P2C (x8 PCIe5.0, for processor 3) |
C3-P2C |
8 |
MCIO connector C3-P2A (x8 PCIe5.0, for processor 3) |
C3-P2A |
9 |
MCIO connector C3-P1A (x8 PCIe5.0, for processor 3) |
C3-P1A |
10 |
MCIO connector C3-P1C (x8 PCIe5.0, for processor 3) |
C3-P1C |
11 |
MCIO connector C3-P0C (x8 PCIe5.0, for processor 3) |
C3-P0C |
12 |
MCIO connector C3-P0A (x8 PCIe5.0, for processor 3) |
C3-P0A |
13 |
MCIO connector C3-P4A (x8 PCIe5.0, for processor 3) |
C3-P4A |
14 |
MCIO connector C3-P4C (x8 PCIe5.0, for processor 3) |
C3-P4C |
15 |
MCIO connector C3-P3C (x8 PCIe5.0, for processor 3) |
C3-P3C |
16 |
MCIO connector C3-P3A (x8 PCIe5.0, for processor 3) |
C3-P3A |
17 |
MCIO connector C4-P4A (x8 PCIe5.0, for processor 4) |
C4-P4A |
18 |
MCIO connector C4-P4C (x8 PCIe5.0, for processor 4) |
C4-P4C |
19 |
MCIO connector C4-P3C (x8 PCIe5.0, for processor 4) |
C4-P3C |
20 |
MCIO connector C4-P3A (x8 PCIe5.0, for processor 4) |
C4-P3A |
PCIe5.0 x8 description: · PCIe5.0—Fifth-generation signal speed. · x8—Bus bandwidth. |
DIMM slots
The system board and processor mezzanine board each provide eight DIMM channels per processor, as shown in Figure 12 and Figure 13, respectively. Each channel contains two DIMM slots.
Figure 12 System board DIMM slot layout
Figure 13 Processor mezzanine board DIMM slot layout
For components compatible with the server and detailed component information, use the component compatibility lookup tool at http://www.h3c.com/en/home/qr/default.htm?id=66.
About component model names
The model name of a hardware option in this document might differ slightly from its model name label.
A model name label might add a prefix or suffix to the hardware-coded model name for purposes such as identifying the matching server brand or applicable region. For example, the DDR5-4800-32G-1Rx4 memory model represents memory module labels including UN-DDR5-4800-32G-1Rx4-R, UN-DDR5-4800-32G-1Rx4-F, and UN-DDR5-4800-32G-1Rx4-S, which have different prefixes and suffixes.
DIMMs
The server provides eight DIMM channels per processor and each channel has two DIMM slots. If the server has one processor, the total number of DIMM slots is 16. If the server has two processors, the total number of DIMM slots is 32. If the server has four processors, the total number of DIMM slots is 64. For the physical layout of DIMM slots, see "DIMM slots."
A DIMM rank is a set of memory chips that the system accesses while writing or reading from the memory. On a multi-rank DIMM, only one rank is accessible at a time.
To determine the rank classification of a DIMM, use the label attached to the DIMM, as shown in Figure 14. The meaning of the DDR DIMM rank classification labels is similar and this section uses the label of a DDR5 DIMM as an example.
Figure 14 DDR DIMM rank classification label
Table 13 DIMM rank classification label description
Callout |
Remarks |
1 |
Capacity |
Options include: · 16GB. · 32GB. · 64GB. |
2 |
Number of ranks |
Options include: · 1R—One rank (Single-Rank). · 2R—Two ranks (Dual-Rank). A 2R DIMM is equivalent to two 1R DIMMs. |
3 |
Data width |
Options include: · ×4—4 bits. · ×8—8 bits. |
4 |
DIMM generation |
DDR5 |
5 |
Data rate |
Options include: · 4400—4400 MHz. · 4800—4800 MHz. |
6 |
DIMM type |
Options include: · L—LRDIMM. · R—RDIMM. |
HDDs and SSDs
Drive numbering
The server provides different drive numbering schemes for different drive configurations at the server front and rear.
Figure 15 Drive numbering for front 25SFF drive configuration
Figure 16 Drive numbering for rear 2SFF drive configuration
Figure 17 Drive numbering for rear 8E1.S drive configuration
Drive LEDs
The server supports SAS, SATA, and NVMe drives (including E1.S drives), of which SAS and SATA drives support hot swapping and NVMe drives support hot insertion and managed hot removal. You can use the LEDs on a drive to identify its status after it is connected to a storage controller.
For more information about OSs that support hot insertion and managed hot removal of NVMe drives, contact Technical Support.
Figure 18 and Figure 19 show the locations of LEDs on a drive.
(1) Fault/UID LED |
(2) Present/Active LED |
(1) Fault/UID LED |
To identify the status of a SAS or SATA drive, use Table 14. To identify the status of an NVMe drive, use Table 15. To identify the status of an NVMe drive, use Table 16.
Table 14 SAS/SATA drive LED description
Fault/UID LED status |
Present/Active LED status |
Flashing amber (0.5 Hz) |
Steady green/Flashing green (4.0 Hz) |
A drive failure is predicted. As a best practice, replace the drive before it fails. |
Steady amber |
The drive is faulty. Replace the drive immediately. |
Steady blue |
The drive is operating correctly and is selected by the RAID controller. |
Off |
The drive is performing a RAID migration or rebuilding, or the system is reading or writing data to the drive. |
Off |
Steady green |
The drive is present but no data is being read or written to the drive. |
Off |
Off |
The drive is not securely installed. |
Table 15 NVMe drive LED description
Off |
The managed hot removal process is completed and the drive is ready for removal. |
Flashing amber (4 Hz) |
Off |
The drive is in hot insertion process. |
A drive predictive alarm is present. Replace the drive in time. |
Steady amber |
Steady blue |
The drive is operating correctly and selected by the RAID controller. |
Off |
Off |
Steady green |
Off |
Off |
Table 16 E1.S drive LED description
Off |
The drive has completed the managed hot removal process and can be removed directly. |
Steady green/Flashing green (4 Hz) |
The drive is in hot insertion process or is selected by the RAID controller. |
Steady amber |
A drive error is present. Replace the drive immediately. |
Off |
Off |
Steady green |
Off |
Off |
Drive backplanes
The server supports the following types of drive backplanes:
· SAS/SATA drive backplanes—Support only SAS/SATA drives.
· UniBay drive backplanes—Support both SAS/SATA and NVMe drives. You must connect both SAS/SATA and NVMe data cables. The number of supported drives varies by drive cabling.
· X SAS/SATA+Y UniBay drive backplanes—Support SAS/SATA drives in all slots and support NVMe drives in certain slots.
¡ X: Number of slots supporting only SAS/SATA drives.
¡ Y: Number of slots supporting both SAS/SATA and NVMe drives.
For UniBay drive backplanes and X SAS/SATA+Y UniBay drive backplanes:
· The two drive types are supported only when both SAS/SATA and NVMe data cables are connected.
· The number of supported SAS/SATA drives and the number of supported NVMe drives vary by cable connection.
The PCA-BP-8SFF-2U-G6 8SFF SAS/SATA drive backplane can be installed at the server front to support eight 2.5-inch SAS/SATA drives.
Figure 20 8SFF SAS/SATA drive backplane
(1) x8 SlimSAS connector (SAS PORT1) |
(2) AUX connector (AUX) |
(3) Power connector (PWR) |
The PCA-BP-8UniBay-2U-G6 8SFF UniBay drive backplane can be installed at the server front to support eight 2.5-inch SAS/SATA/NVMe drives.
Figure 21 8SFF UniBay drive backplane
(1) x8 SlimSAS connector (SAS PORT) |
(2) AUX ( AUX) |
(3) MCIO connector B3/B4 (PCIe5.0 x8)(NVMe B3/B4) |
(4) Power connector (POWER) |
(5) MCIO connector B1/B2 (PCIe5.0 x8)(NVMe B1/B2) |
(6) MCIO connector A3/A4 (PCIe5.0 x8)(NVMe A3/A4) |
(7) MCIO connector A1/A2 (PCIe5.0 x8)(NVMe A1/A2) |
PCIe5.0 x8 description: · PCIe5.0: Fifth-generation signal speed. · x8: Bus bandwidth. |
The PCA-BP-25SFF-2U-G6 25SFF drive backplane can be installed at the server front to support twenty-five 2.5-inch SAS/SATA/NVMe drives, including 17 SAS/SATA drives and 8 SAS/SATA/NVMe drives. The drive backplane can use an x8 SlimSAS connector to manage 25 SAS/SATA drives. The drive backplane also integrates an Expander chip and three downlink interfaces to connect to other drive backplanes and support more drives.
Figure 22 17SAS/SATA+8UniBay drive backplane
(1) x4 SlimSAS downlink interface 3 (SAS EXP 3) |
(2) x8 SlimSAS uplink interface (SAS PORT), managing all drives on the backplane |
(3) x8 SlimSAS downlink interface 2 (SAS EXP 2) |
(4) x4 SlimSAS downlink interface 1 (SAS EXP 1) |
(5) Power connector 1 (PWR 1) |
(6) Power connector 2 (PWR 2) |
(7) MCIO connector 4 (PCIe5.0 x8)(NVMe 4), supporting NVMe drives 17 and 18 |
(8) AUX connector (AUX) |
(9) MCIO connector 3 (PCIe5.0 x8)(NVMe 3), supporting NVMe drives 19 and 20 |
(10) MCIO connector 2 (PCIe5.0 x8)(NVMe 2), supporting NVMe drives 21 and 22 |
(11) Power connector 3 (PWR 3) |
(12) MCIO connector 1 (PCIe5.0 x8)(NVMe 1), supporting NVMe drives 23 and 24 |
For more information about drive numbering, see "Drive numbering." PCIe5.0 x8 description: · PCIe5.0: Fifth-generation signal speed. · x8: Bus bandwidth. |
The PCA-BP-2SFF-2UniBay-2U-G6 2SFF UniBay drive backplane is installed at the server rear to support two 2.5-inch SAS/SATA/NVMe drives.
Figure 23 2SFF UniBay drive backplane
(1) Power connector (PWR) |
(2) x4 Mini-SAS-HD connector (SAS PORT) |
(3) SlimSAS connector (PCIe4.0 x8)(NVME) |
(4) AUX connector (AUX) |
PCIe4.0 x8 description: · PCIe4.0: Fifth-generation signal speed. · x8: Bus bandwidth. |
Rear 8E1.S drive backplane
The PCA-BP-8E1S-2U-G6 8E1.S drive backplane is installed at the server rear to support eight 15 mm E1.S drives.
Figure 24 E1.S drive backplane
(1) AUX connector (AUX) |
(2) MCIO connector A1/A2 (PCIe5.0 x8)( EDSFF-A1/A2) |
(3) Power connector (PWR 1) |
(4) MCIO connector A3/A4 (PCIe5.0 x8)( EDSFF-A3/A4) |
(5) MCIO connector B1/B2 (PCIe5.0 x8)(EDSFF-B1/B2) |
(6) MCIO connector B3/B4 (PCIe5.0 x8)(EDSFF-B3/B4) |
Riser cards
To expand the server with PCIe modules, install riser cards on the PCIe riser connectors.
For detailed information about riser cards and their installation guidelines, see "Riser cards and PCIe modules."
RC-3FHFL-2U-G6
Figure 25 RC-3FHFL-2U-G6 (1)
(1) PCIe5.0 x16 (16,8,4,2,1) slot 2/5 |
(2) PCIe5.0 x16 (16,8,4,2,1) slot 3/6 |
(3) GPU module power connector |
(4) PCIe5.0 x16 (16,8,4,2,1) slot 1/4* |
PCIe5.0 x16 (16,8,4,2,1) description: · PCIe5.0: Fifth-generation signal speed. · x16: Connector bandwidth. · (16,8,4,2,1): Compatible bus bandwidth, including x16, x8, x4, x2, and x1. |
NOTE: slot 1/4: When the riser card is installed in PCIe riser card slot 1, this slot corresponds to PCIe slot 1. When the riser card is installed in PCIe riser card slot 2, this slot corresponds to PCIe slot 4. This rule applies to all the other PCIe riser card slots. For information about PCIe slots, see "Rear panel view." |
Figure 26 RC-3FHFL-2U-G6 (2)
(5) MCIO connector 2-C |
(6) MCIO connector 2-A |
(7) MCIO connector 1-A |
(8) MCIO connector 1-C |
RC-3FHHL-2U-G6
Figure 27 RC-3FHHL-2U-G6 (1)
(1) PCIe5.0 x16 (8,4,21) slot 2/5 |
(2) PCIe5.0 x16 (8,4,2,1) slot 3/6 |
(3) PCIe5.0 x16 (16,8,4,2,1) slot 1/4* |
NOTE: slot 1/4: When the riser card is installed in PCIe riser connector 1, this slot corresponds to PCIe slot 1. When the riser card is installed in PCIe riser connector 2, this slot corresponds to PCIe slot 4. This rule applies to all the other PCIe riser card slots. For information about PCIe slots, see "Rear panel view." |
Figure 28 RC-3FHHL-2U-G6 (2)
(4) MCIO connector 1-A |
(5) MCIO connector 1-C |
RC-2HHHL-R3-2U-G6-1
Figure 29 RC-2HHHL-R3-2U-G6-1
(1) PCIe5.0 x16 (8,4,2,1) slot 8 |
(2) PCIe5.0 x16 (8,4,2,1) slot 7 |
(3) MCIO connector SLOT 1 |
PCIe5.0 x16 (8,4,2,1) description: · PCIe5.0: Fifth-generation signal speed. · x16: Connector bandwidth. · (8,4,2,1): Compatible bus bandwidth, including x8, x4, x2, and x1. |
RC-2HHHL-R3-2U-G6-2
Figure 30 RC-2HHHL-R3-2U-G6-2
(1) PCIe5.0 x16 (16,8,4,2,1) slot 8 |
(2) PCIe5.0 x16 (16,8,4,2,1) slot 7 |
(3) MCIO connector SLOT 1-A |
(4) MCIO connector SLOT 1-C |
RC-2HHHL-R4-2U-G6
Figure 31 RC-2HHHL-R4-2U-G6
(1) SLOT 2 cable |
(2) AUX connector |
(3) PCIe5.0 x16 (8,4,2,1) slot 8/10 |
(4) PCIe5.0 x16 (8,4,2,1) slot 7/9* |
(5) Power connector |
(6) SLOT 1 cable |
NOTE: slot 7/9: When the riser card is installed in PCIe riser connector 3, this slot corresponds to PCIe slot 7. When the riser card is installed in PCIe riser connector 4, this slot corresponds to PCIe slot 9. This rule applies to all the other PCIe riser card slots. For information about PCIe slots, see "Rear panel view." |
OCP riser card
Figure 32 OCP riser card
Figure 33 OCP riser card description
Item |
1 |
MCIO connector 4 |
2 |
MCIO connector 3 |
3 |
Power connector |
4 |
AUX connector |
5 |
MCIO connector 2 |
6 |
MCIO connector 1 |
Figure 34 Power expander module
Figure 35 Component description
Item |
1 |
Signal connector |
2 |
The power expander module is installed on top of power supplies 1 and 2 at the server rear, as shown by the blue box in Figure 36.
Figure 36 Installation location of the power expander module
UPI Mezz module
If the server is not installed with the processor mezzanine board, install the UPI Mezz module for interconnection of two processors. When you install the UPI Mezz module, align the connectors marked by the blue frames with the midplane module connector. For more information, see "System board components."
An LCD smart management module displays basic server information, operating status, and fault information, and provides diagnostics and troubleshooting capabilities. You can locate and troubleshoot component failures by using the LCD module in conjunction with the event logs generated in HDM.
Figure 39 LCD smart management module
Table 17 LCD smart management module description
No. |
Item |
1 |
Mini-USB connector |
Used for upgrading the firmware of the LCD module. |
2 |
LCD module cable |
Connects the LCD module to the system board of the server. For information about the LCD smart management module connector on the system board, see "System board." |
3 |
LCD module shell |
Protects and secures the LCD screen. |
4 |
LCD screen |
Displays basic server information, operating status, and fault information. |
Fan modules
The server supports four hot swappable fan modules. The server supports N+1 fan module redundancy. Figure 40 shows the layout of the fan modules in the chassis.
The server uses intelligent fan energy-saving and noise-reduction technology, which integrates multiple AI algorithms. It can monitor the temperature, power, and other status information of the device in real-time to obtain the optimal fan adjustment policy. Then, it dynamically adjusts the fan duty cycle configuration to meet the device's energy-saving and noise-reduction requirements.
PCIe slots
The server supports installing riser cards and rear GPU modules. The PCIe slot numbers vary by configuration.
Figure 41 PCIe slot numbering when riser cards are installed at the server rear
Figure 42 PCIe slot numbering when the OCP riser card is installed
B/D/F information
You can obtain B/D/F information by using one of the following methods:
· BIOS log—Search the dumpiio keyword in the BIOS log.
· UEFI shell—Execute the pci command. For information about how to execute the command, execute the help pci command.
· Operating system—The obtaining method varies by OS.
¡ For Linux, execute the lspci command.
If Linux does not support the lspci command by default, use the software package manager supported by the operating system to obtain and install the pci-utils package.
¡ For Windows, install the pciutils package, and then execute the lspci command.
¡ For VMware, execute the lspci command.
Before you begin
Before you perform a managed removal of an OCP network adapter, perform the following tasks:
· Use the OS compatibility query tool at http://www.h3c.com/en/home/qr/default.htm?id=66 to obtain operating systems that support managed removal of OCP network adapters.
· Make sure the BIOS version is 6.00.15 or higher, the HDM2 version is 1.13 or higher, and the CPLD version is V001 or higher.
Performing a hot removal
This section uses an OCP network adapter in slot 11 as an example.
To perform a hot removal:
1. Access the operating system.
2. Execute the dmidecode -t 9 command to search for the bus address of the OCP network adapter. As shown in Figure 43, the bus address of the OCP network adapter in slot 11 is 0000:31:00.0.
Figure 43 Searching for the bus address of an OCP network adapter by slot number
3. Execute the echo 0 > /sys/bus/pci/slots/slot number/power command, where slot number represents the number of the slot where the OCP network adapter resides.
Figure 44 Executing the echo 0 > /sys/bus/pci/slots/slot number/power command
4. Identify whether the OCP network adapter has been disconnected:
¡ Observe the OCP network adapter LED. If the LED is off, the OCP network adapter has been disconnected.
¡ Execute the lspci –vvv –s 0000:31:00.0 command. If no output is displayed, the OCP network adapter has been disconnected.
Figure 45 Identifying OCP network adapter status
5. Replace the OCP network adapter.
6. Identify whether the OCP network adapter has been connected:
¡ Observe the OCP network adapter LED. If the LED is on, the OCP network adapter has been connected.
¡ Execute the lspci –vvv –s 0000:31:00.0 command. If an output is displayed, the OCP network adapter has been connected.
Figure 46 Identifying OCP network adapter status
7. Identify whether any exception exists. If any exception occurred, contact H3C Support.
The operating temperature requirements for the server vary depending on the server model and hardware configuration. When the general and component-based requirements conflict, use the component-based requirement.
Be aware that the actual maximum operating temperature of the server might be lower than what is stated because of poor site cooling performance. In a real data center, the server cooling performance might decrease because of adverse external factors, including poor cabinet cooling performance, high power density inside the cabinet, or insufficient spacing between devices.
Item |
Specifications |
Operating temperature |
Minimum: 5°C (41°F) Maximum: 45°C (113°F) The maximum temperature varies by hardware option presence. For more information, see "Operating temperature requirements." |
Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
Operating humidity |
8% to 90%, noncondensing |
Storage humidity |
5% to 95%, noncondensing |
Operating altitude |
–60 m to +3000 m (–196.85 ft to +9842.52 ft) The allowed maximum temperature decreases by 0.33°C (32.59°F) as the altitude increases by 100 m (328.08 ft) from 900 m (2952.76 ft) |
Storage altitude |
–60 m to +5000 m (–196.85 ft to +16404.20 ft) |
General guidelines
When a fan fails, the maximum server operating temperature decreases by 5°C (41°F). The performance of GPU modules and processors that support frequency reduction might decrease.
When UN-PS-2202-11L Platinum AC power supplies are installed, the maximum operating temperatures are 3°C (37.4°F) lower than those described in the table.
Drive configuration |
Maximum operating temperature |
30°C |
35°C |
40°C |
8SFF |
All hardware options are supported. |
· When GPU modules are configured, the processor power consumption cannot be greater than 300W. · BF2 smart network adapters are not supported. |
Not supported. |
16SFF |
When BF2 smart network adapters are installed, the processor power consumption cannot be greater than 200W. |
· When GPU modules are configured, the processor power consumption cannot be greater than 270W. · BF2 smart network adapters are not supported. · Processors of more than 330W are not supported. · When 8038 fan modules and 1U heat pipe heatsink module are installed, the power consumption of processors cannot be greater than 195W, and A2 GPU modules and BF2 smart network adapters are not supported. |
25SFF/16SFF+8NVMe/8SFF+16NVME/17SFF+8NVMe/24NVMe |
· Processors with power consumption greater than 300W are not supported. · BF2 smart network adapters are not supported. |
· 24 NVMe drive configuration does not support processors of more than 270W. · 25 HDD configuration does not support processors of more than 330W. · When GPU modules are configured, the power consumption of processors cannot be greater than 200W. · BF2 smart network adapters are not supported. · Delta DPS-1600AB-13 R 1600W Platinum AC power supplies are not supported. · When rear HDDs are installed, the server does not support processors of more than 270W. · When rear NVMe drives are installed, the server does not support processors of more than 200W. · When rear E1.S drives are installed, the server does not support processors of more than 330W. · Rear M.2 drives are not supported. |
Appendix E Product recycling
New H3C Technologies Co., Ltd. provides product recycling services for its customers to ensure that hardware at the end of its life is recycled. Vendors with product recycling qualification are contracted to New H3C to process the recycled hardware in an environmentally responsible way.
For product recycling services, contact New H3C at
· Tel: 400-810-0504
· E-mail: [email protected]
· Website: http://www.h3c.com
Appendix F Glossary
B |
BIOS |
Basic input/output system is non-volatile firmware pre-installed in a ROM chip on a server's management module. The BIOS stores basic input/output, power-on self-test, and auto startup programs to provide the most basic hardware initialization, setup and control functionality. |
C |
CPLD |
Complex programmable logic device is an integrated circuit used to build reconfigurable digital circuits. |
G |
GPU module |
Graphics processing unit module converts digital signals to analog signals for output to a display device and assists processors with image processing to improve overall system performance. |
H |
HDM |
Hardware Device Management is the server management control unit with which administrators can configure server settings, view component information, monitor server health status, and remotely manage the server. |
A module that supports hot swapping (a hot-swappable module) can be installed or removed while the server is running without affecting the system operation. |
K |
KVM |
KVM is a management method that allows remote users to use their local video display, keyboard, and mouse to monitor and control the server. |
N |
NVMe VROC module |
A module that works with Intel VMD to provide RAID capability for the server to virtualize storage resources of NVMe drives. |
R |
RAID |
Redundant array of independent disks (RAID) is a data storage virtualization technology that combines multiple physical hard drives into a single logical unit to improve storage and security performance. |
Redundancy |
A mechanism that ensures high availability and business continuity by providing backup modules. In redundancy mode, a backup or standby module takes over when the primary module fails. |
S |
Security bezel |
A locking bezel mounted to the front of a server to prevent unauthorized access to modules such as hard drives. |
U |
A unit of measure defined as 44.45 mm (1.75 in) in IEC 60297-1. It is used as a measurement of the overall height of racks, as well as equipment mounted in the racks. |
UniBay drive backplane |
A UniBay drive backplane supports both SAS/SATA and NVMe drives. |
UniSystem |
UniSystem provided by H3C for easy and extensible server management. It can guide users to configure a server quickly with ease and provide an API interface to allow users to develop their own management tools. |
V |
VMD |
VMD provides hot removal, management and fault-tolerance functions for NVMe drives to increase availability, reliability, and serviceability. |
Appendix G Acronyms
Acronym |
Full name |
B |
BIOS |
C |
CMA |
Cable Management Arm |
CPLD |
D |
DCPMM |
Data Center Persistent Memory Module |
DDR |
Double Data Rate |
DIMM |
Dual In-Line Memory Module |
DRAM |
Dynamic Random Access Memory |
DVD |
Digital Versatile Disc |
G |
GPU |
H |
HBA |
Host Bus Adapter |
HDD |
Hard Disk Drive |
HDM |
I |
IDC |
Internet Data Center |
iFIST |
integrated Fast Intelligent Scalable Toolkit |
K |
KVM |
Keyboard, Video, Mouse |
L |
LRDIMM |
Load Reduced Dual Inline Memory Module |
N |
NCSI |
Network Controller Sideband Interface |
NVMe |
Non-Volatile Memory Express |
P |
PCIe |
Peripheral Component Interconnect Express |
POST |
Power-On Self-Test |
R |
RDIMM |
Registered Dual Inline Memory Module |
S |
SAS |
Serial Attached Small Computer System Interface |
SATA |
Serial ATA |
SD |
Secure Digital |
SDS |
Secure Diagnosis System |
SFF |
Small Form Factor |
sLOM |
Small form factor Local Area Network on Motherboard |
SSD |
Solid State Drive |
T |
TCM |
Trusted Cryptography Module |
TDP |
Thermal Design Power |
TPM |
Trusted Platform Module |
U |
UID |
Unit Identification |
UPI |
Ultra Path Interconnect |
UPS |
Uninterruptible Power Supply |
USB |
Universal Serial Bus |
V |
VROC |
Virtual RAID on CPU |
VMD |
Volume Management Device |
