02-Layer 2—LAN Switching Configuration Examples
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-11xx[R1213Pxx][R9126Pxx]-6W10102-Layer 2—LAN Switching Configuration Examples
05-VLAN Tagging Configuration Examples
05-VLAN Tagging Configuration Examples 821.13 KB
Introduction· 1
Prerequisites· 1
General configuration restrictions and guidelines· 1
Example: Configuring QoS policies for SVLAN tagging· 2
Network configuration· 2
Analysis· 3
Applicable hardware and software versions· 4
Restrictions and guidelines· 4
Procedures· 4
Configuring PE A· 4
Configuring PE B· 7
Configuring devices between PE A and PE B· 9
Verifying the configuration· 9
Configuration files· 10
Example: Configuring QinQ·· 13
Network configuration· 13
Applicable hardware and software versions· 14
Restrictions and guidelines· 14
Procedures· 15
Configuring PE A· 15
Configuring PE B· 16
Configuring devices between PE A and PE B· 16
Verifying the configuration· 16
Configuration files· 17
Example: Configuring one-to-two VLAN mapping· 18
Network configuration· 18
Analysis· 19
Applicable hardware and software versions· 20
Restrictions and guidelines· 20
Procedures· 20
Configuring PE A· 20
Configuring PE B· 21
Configuring devices between PE A and PE B· 23
Verifying the configuration· 23
Configuration files· 24
Example: Configuring one-to-one VLAN mapping· 25
Network configuration· 25
Applicable hardware and software versions· 26
Procedures· 27
Configuring Switch A· 27
Configuring Switch B· 28
Verifying the configuration· 28
Configuration files· 28
Example: Configuring many-to-one VLAN mapping· 29
Applicable hardware and software versions· 30
Procedures· 30
Configuring Switch A· 30
Configuring Switch B and Switch C· 31
Configuring Switch D·· 31
Configuring Switch E· 31
Verifying the configuration· 31
Configuration files· 32
Example: Configuring two-to-two VLAN mapping· 33
Network configuration· 33
Applicable hardware and software versions· 34
Restrictions and guidelines· 34
Procedures· 35
Configuring Switch A· 35
Configuring Switch B· 35
Configuring Switch C· 36
Configuring Switch D·· 37
Verifying the configuration· 37
Configuration files· 38
Introduction
This document provides examples for using VLAN tagging features to extend customer VLANs (CVLANs) across an Ethernet service provider network.
VLAN tagging features enable service providers to separate or aggregate customer traffic in the service provider network. The following are available VLAN tagging operations:
·     Adding a layer of service provider VLAN (SVLAN) tag.
·     Modifying the SVLAN tag, CVLAN tag, or both.
To add an SVLAN tag, use one of the following VLAN tagging features:
·     QinQ—Tags all incoming frames (tagged or untagged) on the customer-side port with the PVID of the port.
·     One-to-two VLAN mapping—Adds different SVLANs for traffic with different CVLAN tags.
·     Zero-to-two VLAN mapping—Adds double VLAN tags to untagged packets.
·     Two-to-three VLAN mapping—Adds an outermost VLAN tag to double-tagged packets.
·     Policy-based VLAN manipulation—Uses QoS nest actions in a QoS policy to tag different classes of frames with different SVLAN tags. Traffic classifiers include CVLAN ID, IP address, and MAC address. In addition, you can use QoS priority marking to set the 802.1p priority in SVLAN tags.
To modify VLAN tags, use one of the following VLAN tagging features:
·     VLAN mapping—Includes the following features:
¡     One-to-one VLAN mapping—Replaces one VLAN tag with another.
¡     Many-to-one VLAN mapping—Replaces multiple VLAN tags with the same VLAN tag.
¡     Two-to-two VLAN mapping—Replaces the SVLAN ID, CVLAN ID, or both IDs for an incoming double-tagged frame.
·     Policy-based VLAN manipulation—Uses a QoS policy to modify the CVLAN or SVLAN ID by using the remark customer-vlan-id or remark service-vlan-id action.
The devices in the service provider network learn MAC addresses of CVLANs into the MAC address table of the SVLAN.
This document assumes that you have basic knowledge of QinQ, VLAN mapping, QoS nesting, and QoS priority and CVLAN marking.
EVB and the VLAN tagging features are mutually exclusive. Do not use EVB with any VLAN tagging features on a port.
As shown in Figure 1:
·     Customer A and Customer B each have two branches that require Layer 2 connectivity over the service provider network.
·     The three types of traffic require separate transmission through three VLANs provided by the service provider. The service provider network configures different transmission policies for each type of traffic.
Apply a QoS policy to each customer-side port on PE A and PE B to separate the traffic by customer and traffic type.
Figure 1 Network diagram
Table 1 shows the VLAN assignment. For each customer, the service provider assigns one SVLAN by traffic type. Figure 2 shows the expected traffic transmission pattern after the QoS policies are applied to customer-side ports.
Table 1 VLAN assignment
Traffic type
CVLANs
SVLAN
Customer A:
Video
31 to 40
1003
Voice
21 to 30
1002
Data
10 to 20
1001
Customer B:
Storage
36 to 40
2003
Voice
26 to 35
2002
Data
15 to 25
2001
Figure 2 Expected traffic pattern in the service provider network
Analysis
For the customer-side ports to support multiple SVLANs and send traffic to the customer site with the SVLAN tag removed, you must perform the following tasks:
1.     Configure the link type as hybrid on the customer-side ports.
2.     Assign the ports to the SVLANs as untagged VLAN members.
By default, the 802.1p priority in the SVLAN tag added by a port depends on the priority trust mode on the port.
·     If the 802.1p priority in frames is trusted, the device copies the 802.1p priority in the CVLAN tag to the SVLAN tag.
·     If port priority is trusted, the port priority is used as the 802.1p priority in the SVLAN tag. For untagged incoming frames, the port encapsulates the port priority as the 802.1p priority in the SVLAN tag.
To add SVLAN tags for traffic of different types, configure an SVLAN tagging QoS policy.
Hardware
Software version
S6550X-HI switch series
Release 1116 and later
Release 1213P51 and later
S6880 switch series
S9820-8M
S5580X-HI switch series
Release 1213P50 and later
S5580X-EI switch series
For frames to travel across the service provider network, follow these restrictions and guidelines:
·     Set the MTU to a minimum of 1504 bytes for each port on the path of frames. This value is the sum of the default Ethernet interface MTU (1500 bytes) and the length (4 bytes) of a CVLAN tag. The CVLAN tag of frames is treated as part of the payload during transmission.
·     Configure all the ports on the forwarding path to allow frames from VLANs 1001 through 1003 and VLANs 2001 through 2003 to pass through without modifying or removing the VLAN tag.
Procedures
Configuring PE A
1.     Create SVLANs 1001 through 1003 and SVLANs 2001 through 2003.
<PE_A> system-view
[PE_A] vlan 1001 to 1003
[PE_A] vlan 2001 to 2003
2.     Configure the customer-side port Twenty-FiveGigE 1/0/1:
# Configure the port as a hybrid port.
[PE_A] interface twenty-fivegige 1/0/1
[PE_A-Twenty-FiveGigE1/0/1] port link-type hybrid
# Remove the port from VLAN 1.
[PE_A-Twenty-FiveGigE1/0/1] undo port hybrid vlan 1
# Assign the port to SVLANs 1001 through 1003 as an untagged VLAN member.
[PE_A-Twenty-FiveGigE1/0/1] port hybrid vlan 1001 to 1003 untagged
# Configure the port to trust the 802.1p priority of frames.
[PE_A-Twenty-FiveGigE1/0/1] qos trust dot1p
[PE_A-Twenty-FiveGigE1/0/1] quit
3.     Configure the customer-side port Twenty-FiveGigE 1/0/2:
[PE_A] interface twenty-fivegige 1/0/2
[PE_A-Twenty-FiveGigE1/0/2] port link-type hybrid
[PE_A-Twenty-FiveGigE1/0/2] undo port hybrid vlan 1
# Assign the port to SVLANs 2001 through 2003 as an untagged VLAN member.
[PE_A-Twenty-FiveGigE1/0/2] port hybrid vlan 2001 to 2003 untagged
[PE_A-Twenty-FiveGigE1/0/2] qos trust dot1p
[PE_A-Twenty-FiveGigE1/0/2] quit
3.     Configure the service provider-side port Twenty-FiveGigE 1/0/3:
# Configure the port as a trunk port.
[PE_A] interface twenty-fivegige 1/0/3
[PE_A-Twenty-FiveGigE1/0/3] port link-type trunk
[PE_A-Twenty-FiveGigE1/0/3] undo port trunk permit vlan 1
# Assign the port to SVLANs 1001 through 1003 and SVLANs 2001 through 2003.
[PE_A-Twenty-FiveGigE1/0/3] port trunk permit vlan 1001 to 1003 2001 to 2003
[PE_A-Twenty-FiveGigE1/0/3] quit
4.     Configure QoS policies for SVLAN tagging and 802.1p priority marking:
# Create the class customer_A_pc to match traffic from CVLANs 10 through 20 (data traffic) for Customer A.
[PE_A] traffic classifier customer_A_pc
[PE_A-classifier-customer_A_pc] if-match customer-vlan-id 10 to 20
[PE_A-classifier-customer_A_pc] quit
# Create the classes customer_A_voice and customer_A_video to match Customer A's voice traffic and video traffic, respectively.
[PE_A] traffic classifier customer_A_voice
[PE_A-classifier-customer_A_voice] if-match customer-vlan-id 21 to 30
[PE_A-classifier-customer_A_voice] quit
[PE_A] traffic classifier customer_A_video
[PE_A-classifier-customer_A_video] if-match customer-vlan-id 31 to 40
[PE_A-classifier-customer_A_video] quit
# Configure SVLAN tagging actions for Customer A's three traffic types.
[PE_A] traffic behavior customer_A_pc
[PE_A-behavior-customer_A_pc] nest top-most vlan 1001
[PE_A-behavior-customer_A_pc] quit
[PE_A] traffic behavior customer_A_voice
[PE_A-behavior-customer_A_voice] nest top-most vlan 1002
[PE_A-behavior-customer_A_voice] quit
[PE_A] traffic behavior customer_A_video
[PE_A-behavior-customer_A_video] nest top-most vlan 1003
[PE_A-behavior-customer_A_video] quit
# Create the QoS policy customer_A for Customer A, and associate the classes with their respective behaviors in the QoS policy.
[PE_A] qos policy customer_A
[PE_A-qospolicy-customer_A] classifier customer_A_pc behavior customer_A_pc
[PE_A-qospolicy-customer_A] classifier customer_A_voice behavior customer_A_voice
[PE_A-qospolicy-customer_A] classifier customer_A_video behavior customer_A_video
[PE_A-qospolicy-customer_A] quit
# Apply the QoS policy customer_A to the inbound direction of Twenty-FiveGigE 1/0/1.
[PE_A-Twenty-FiveGigE1/0/1] qos apply policy customer_A inbound
# Create traffic classes for matching Customer B's three traffic types.
[PE_A] traffic classifier customer_B_pc
[PE_A-classifier-customer_B_pc] if-match customer-vlan-id 15 to 25
[PE_A-classifier-customer_B_pc] quit
[PE_A] traffic classifier customer_B_voice
[PE_A-classifier-customer_B_voice] if-match customer-vlan-id 26 to 35
[PE_A-classifier-customer_B_voice] quit
[PE_A] traffic classifier customer_B_storage
[PE_A-classifier-customer_B_storage] if-match customer-vlan-id 36 to 40
[PE_A-classifier-customer_B_storage] quit
# Configure SVLAN tagging behaviors for Customer B's traffic types.
[PE_A] traffic behavior customer_B_pc
[PE_A-behavior-customer_B_pc] nest top-most vlan 2001
[PE_A-behavior-customer_B_pc] quit
[PE_A] traffic behavior customer_B_voice
[PE_A-behavior-customer_B_voice] nest top-most vlan 2002
[PE_A-behavior-customer_B_voice] quit
[PE_A] traffic behavior customer_B_storage
[PE_A-behavior-customer_B_storage] nest top-most vlan 2003
[PE_A-behavior-customer_B_storage] quit
# Create the QoS policy customer_B for Customer B, and associate the classes with their respective behaviors in the QoS policy.
[PE_A] qos policy customer_B
[PE_A-qospolicy-customer_B] classifier customer_B_pc behavior customer_B_pc
[PE_A-qospolicy-customer_B] classifier customer_B_voice behavior customer_B_voice
[PE_A-qospolicy-customer_B] classifier customer_B_storage behavior customer_B_storage
[PE_A-qospolicy-customer_B] quit
# Apply the QoS policy customer_B to the inbound direction of Twenty-FiveGigE 1/0/2.
[PE_A-Twenty-FiveGigE1/0/2] qos apply policy customer_B inbound
Configuring PE B
<PE_B> system-view
[PE_B] vlan 1001 to 1003
[PE_B] vlan 2001 to 2003
[PE_B] interface twenty-fivegige 1/0/1
[PE_B-Twenty-FiveGigE1/0/1] port link-type hybrid
[PE_B-Twenty-FiveGigE1/0/1] undo port hybrid vlan 1
[PE_B-Twenty-FiveGigE1/0/1] port hybrid vlan 2001 to 2003 untagged
[PE_B-Twenty-FiveGigE1/0/1] qos trust dot1p
[PE_B-Twenty-FiveGigE1/0/1] quit
[PE_B] interface twenty-fivegige 1/0/2
[PE_B-Twenty-FiveGigE1/0/2] port link-type hybrid
[PE_B-Twenty-FiveGigE1/0/2] undo port hybrid vlan 1
[PE_B-Twenty-FiveGigE1/0/2] port hybrid vlan 1001 to 1003 untagged
[PE_B-Twenty-FiveGigE1/0/2] qos trust dot1p
[PE_B-Twenty-FiveGigE1/0/2] quit
4.     Configure the service provider-side port Twenty-FiveGigE 1/0/3:
[PE_B] interface twenty-fivegige 1/0/3
[PE_B-Twenty-FiveGigE1/0/3] port link-type trunk
[PE_B-Twenty-FiveGigE1/0/3] undo port trunk permit vlan 1
[PE_B-Twenty-FiveGigE1/0/3] port trunk permit vlan 1001 to 1003 2001 to 2003
[PE_B-Twenty-FiveGigE1/0/3] quit
5.     Configure QoS policies for SVLAN tagging and 802.1p priority marking:
# Create traffic classes for matching Customer A's traffic types.
[PE_B] traffic classifier customer_A_pc
[PE_B-classifier-customer_A_pc] if-match customer-vlan-id 10 to 20
[PE_B-classifier-customer_A_pc] quit
[PE_B] traffic classifier customer_A_voice
[PE_B-classifier-customer_A_voice] if-match customer-vlan-id 21 to 30
[PE_B-classifier-customer_A_voice] quit
[PE_B] traffic classifier customer_A_video
[PE_B-classifier-customer_A_video] if-match customer-vlan-id 31 to 40
[PE_B-classifier-customer_A_video] quit
# Configure SVLAN tagging behaviors for Customer A's three traffic types.
[PE_B] traffic behavior customer_A_pc
[PE_B-behavior-customer_A_pc] nest top-most vlan 1001
[PE_B-behavior-customer_A_pc] quit
[PE_B] traffic behavior customer_A_voice
[PE_B-behavior-customer_A_voice] nest top-most vlan 1002
[PE_B-behavior-customer_A_voice] quit
[PE_B] traffic behavior customer_A_video
[PE_B-behavior-customer_A_video] nest top-most vlan 1003
[PE_B-behavior-customer_A_video] quit
[PE_B] qos policy customer_A
[PE_B-qospolicy-customer_A] classifier customer_A_pc behavior customer_A_pc
[PE_B-qospolicy-customer_A] classifier customer_A_voice behavior customer_A_voice
[PE_B-qospolicy-customer_A] classifier customer_A_video behavior customer_A_video
[PE_B-qospolicy-customer_A] quit
# Apply the QoS policy customer_A to the inbound direction of Twenty-FiveGigE 1/0/2.
[PE_B-Twenty-FiveGigE1/0/2] qos apply policy customer_A inbound
[PE_B] traffic classifier customer_B_pc
[PE_B-classifier-customer_B_pc] if-match customer-vlan-id 15 to 25
[PE_B-classifier-customer_B_pc] quit
[PE_B] traffic classifier customer_B_voice
[PE_B-classifier-customer_B_voice] if-match customer-vlan-id 26 to 35
[PE_B-classifier-customer_B_voice] quit
[PE_B] traffic classifier customer_B_storage
[PE_B-classifier-customer_B_storage] if-match customer-vlan-id 36 to 40
[PE_B-classifier-customer_B_storage] quit
# Configure SVLAN tagging behaviors for Customer B's three traffic types.
[PE_B] traffic behavior customer_B_pc
[PE_B-behavior-customer_B_pc] nest top-most vlan 2001
[PE_B-behavior-customer_B_pc] quit
[PE_B] traffic behavior customer_B_voice
[PE_B-behavior-customer_B_voice] nest top-most vlan 2002
[PE_B-behavior-customer_B_voice] quit
[PE_B] traffic behavior customer_B_storage
[PE_B-behavior-customer_B_storage] nest top-most vlan 2003
[PE_B-behavior-customer_B_storage] quit
[PE_B] qos policy customer_B
[PE_B-qospolicy-customer_B] classifier customer_B_pc behavior customer_B_pc
[PE_B-qospolicy-customer_B] classifier customer_B_voice behavior customer_B_voice
[PE_B-qospolicy-customer_B] classifier customer_B_storage behavior customer_B_storage
[PE_B-qospolicy-customer_B] quit
# Apply the QoS policy customer_B to the inbound direction of Twenty-FiveGigE 1/0/1.
[PE_B-Twenty-FiveGigE1/0/1] qos apply policy customer_B inbound
# Set the MTU to a minimum of 1504 bytes for each port on the path of frames. (Details not shown.)
# Configure all ports on the path between PE A and PE B allow frames from VLANs 1001 through 1003 and VLANs 2001 through 2003 to pass through without modifying or removing the VLAN tag. (Details not shown.)
# Verify the configuration on each port. This example uses Twenty-FiveGigE 1/0/1 of PE A.
[PE_A-Twenty-FiveGigE1/0/1] display this
interface Twenty-FiveGigE1/0/1
 port link-mode bridge
 qos trust dot1p
Return
# Verify the QoS configuration on each port. This example uses Twenty-FiveGigE 1/0/1 of PE A.
[PE_A] display qos policy interface twenty-fivegige 1/0/1
Interface: Twenty-FiveGigE1/0/1
  Direction: Inbound
  Policy: customer_A
   Classifier: customer_A_pc
     Operator: AND
     Rule(s) :
      If-match customer-vlan-id 10 to 20
     Behavior: customer_A_pc
      Nesting:
        Nest top-most vlan-id 1001
   Classifier: customer_A_voice
     Operator: AND
     Rule(s) :
      If-match customer-vlan-id 21 to 30
     Behavior: customer_A_voice
      Nesting:
        Nest top-most vlan-id 1002
   Classifier: customer_A_video
     Operator: AND
     Rule(s) :
      If-match customer-vlan-id 31 to 40
     Behavior: customer_A_video
      Nesting:
        Nest top-most vlan-id 1003
Configuration files
·     PE A:
vlan 1001 to 1003
vlan 2001 to 2003
traffic classifier customer_A_pc operator and
traffic classifier customer_A_voice operator and
traffic classifier customer_A_video operator and
traffic classifier customer_B_pc operator and
traffic classifier customer_B_voice operator and
traffic classifier customer_B_storage operator and
 qos trust dot1p
interface Twenty-FiveGigE1/0/2
 qos trust dot1p
interface Twenty-FiveGigE1/0/3
·     PE B:
vlan 1001 to 1003
vlan 2001 to 2003
 qos trust dot1p
 qos trust dot1p
As shown in Figure 3:
·     The service provider assigns VLAN 1000 to Company A's VLANs 100 through 150.
·     The service provider assigns VLAN 2000 to Company B's VLANs 120 through 200.
Configure QinQ on PE A and PE B to transmit traffic in VLANs 1000 and 2000 for Company A and Company B, respectively.
Figure 3 Network diagram
Hardware
Software version
S6880 switch series
S9820-8M
S5580S-EI switch series
When you configure QinQ, follow these restrictions and guidelines:
·     You only need to configure QinQ on customer-side ports of PEs.
·     The link type of the customer-side port can be access, hybrid, or trunk.
¡     If the link type is access, you must assign the port to the SVLAN.
¡     If the link type is trunk, you must assign the port to the SVLAN, and set the SVLAN ID as the PVID of the port.
¡     If the link type is hybrid, you must assign the port to the SVLAN as an untagged VLAN member, and set the SVLAN ID as the PVID of the port. The settings ensure that the port can forward traffic to the customer site with the SVLAN tag removed.
·     For QinQ frames to travel across the service provider network, you must perform the following tasks:
¡     Set the MTU to a minimum of 1504 bytes for each port on the path of QinQ frames. This value is the sum of the default Ethernet interface MTU (1500 bytes) and the length (4 bytes) of a CVLAN tag. The CVLAN tag of QinQ frames is treated as part of the payload during transmission.
¡     Configure all the ports on the forwarding path to allow frames from VLANs 1000 and 2000 to pass through without removing the VLAN tag.
Procedures
Configuring PE A
1.     Create VLANs 1000 and 2000.
<PE_A> system-view
[PE_A] vlan 1000
[PE_A-vlan1000] quit
[PE_A] vlan 2000
[PE_A-vlan2000] quit
2.     Configure Twenty-FiveGigE 1/0/1:
# Configure the port as an access port, and assign the port to VLAN 1000.
[PE_A-Twenty-FiveGigE1/0/1] port access vlan 1000
# Enable QinQ on the port.
[PE_A-Twenty-FiveGigE1/0/1] qinq enable
3.     Configure Twenty-FiveGigE 1/0/2:
# Configure the port as an access port, and assign the port to VLAN 2000.
[PE_A-Twenty-FiveGigE1/0/2] port access vlan 2000
[PE_A-Twenty-FiveGigE1/0/2] qinq enable
4.     Configure Twenty-FiveGigE 1/0/3:
# Assign the port to VLANs 1000 and 2000.
[PE_A-Twenty-FiveGigE1/0/3] port trunk permit vlan 1000 2000
Configuring PE B
<PE_B> system-view
[PE_B] vlan 1000
[PE_B-vlan1000] quit
[PE_B] vlan 2000
[PE_B-vlan2000] quit
[PE_B-Twenty-FiveGigE1/0/1] port access vlan 2000
[PE_B-Twenty-FiveGigE1/0/1] qinq enable
[PE_B-Twenty-FiveGigE1/0/2] port access vlan 1000
[PE_B-Twenty-FiveGigE1/0/2] qinq enable
[PE_B-Twenty-FiveGigE1/0/3] port trunk permit vlan 1000 2000
# Set the MTU to a minimum of 1504 bytes for each port on the path of QinQ frames. (Details not shown.)
# Configure all ports on the forwarding path to allow frames from VLANs 1000 and 2000 to pass through without removing the VLAN tag. (Details not shown.)
# Verify that each company's PCs can ping each other in the same CVLAN across the service provider network. (Details not shown.)
# Verify that the two companies' PCs cannot communicate at Layer 2 even if their CVLAN IDs are the same. The ARP tables on one company's PCs do not contain entries for MAC addresses of the other company's PCs. (Details not shown.)
Configuration files
·     PE A:
vlan 1000
vlan 2000
 qinq enable
 qinq enable
·     PE B:
vlan 1000
vlan 2000
 qinq enable
 qinq enable
As shown in Figure 4:
·     Both customers have three types of traffic. For each customer, the service provider assigns one SVLAN by traffic type.
Configure one-to-two VLAN mapping on each customer-side port of PE A and PE B to meet the following requirements:
·     The service provider adds an SVLAN tag to packets from customer networks based on the traffic type, as described in Table 2 and Figure 5.
·     The SVLAN tag uses the same 802.1p priority as the CVLAN tag.
Figure 4 Network diagram
Table 2 VLAN mapping table
Traffic type
CVLANs
SVLAN
Customer A
Video
31 to 40
1003
Voice
21 to 30
1002
Data
10 to 20
1001
Customer B
Storage
36 to 40
2003
Voice
26 to 35
2002
Data
15 to 25
2001
Figure 5 Required traffic pattern in the service provider network
Analysis
To support multiple SVLANs and send traffic to the customer networks with the SVLAN tag removed, perform the following tasks on the customer-side ports:
1.     Configure the link type of the ports as hybrid.
For the SVLAN tag to use the same 802.1p priority as the CVLAN tag, configure the customer-side port to use the 802.1p priority in incoming packets for priority mapping.
Hardware
Software version
S6880 switch series
S9820-8M
When you configure ports on the forwarding path of double-tagged packets across the service provider network, follow these restrictions and guidelines:
·     Set the MTU to a minimum of 1504 bytes for each port.
·     Configure all ports to allow double-tagged packets to pass through without removing the SVLAN tag.
Procedures
Configuring PE A
1.     Create CVLANs and SVLANs:
# Create CVLANs 10 to 40.
<PE_A> system-view
[PE_A] vlan 10 to 40
# Create SVLANs 1001 through 1003 and SVLANs 2001 through 2003.
# Assign the port to CVLANs 10 through 40 as a tagged VLAN member.
[PE_A-Twenty-FiveGigE1/0/1] port hybrid vlan 10 to 40 tagged
# Configure one-to-two VLAN mapping to add SVLAN tag 1001 to traffic from VLANs 10 through 20.
[PE_A-Twenty-FiveGigE1/0/1] vlan mapping nest range 10 to 20 nested-vlan 1001
# Configure one-to-two VLAN mapping to add SVLAN tag 1002 to traffic from VLANs 21 through 30.
[PE_A-Twenty-FiveGigE1/0/1] vlan mapping nest range 21 to 30 nested-vlan 1002
# Configure one-to-two VLAN mapping to add SVLAN tag 1003 to traffic from VLANs 31 through 40.
[PE_A-Twenty-FiveGigE1/0/1] vlan mapping nest range 31 to 40 nested-vlan 1003
# Configure the port to use the 802.1p priority in incoming packets for priority mapping.
# Assign the port to CVLANs 15 through 40 as a tagged VLAN member.
[PE_A-Twenty-FiveGigE1/0/2] port hybrid vlan 15 to 40 tagged
# Configure one-to-two VLAN mapping to add SVLAN tag 2001 to traffic from VLANs 15 through 25.
[PE_A-Twenty-FiveGigE1/0/2] vlan mapping nest range 15 to 25 nested-vlan 2001
# Configure one-to-two VLAN mapping to add SVLAN tag 2002 to traffic from VLANs 26 through 35.
[PE_A-Twenty-FiveGigE1/0/2] vlan mapping nest range 26 to 35 nested-vlan 2002
# Configure one-to-two VLAN mapping to add SVLAN tag 2003 to traffic from VLANs 36 through 40.
[PE_A-Twenty-FiveGigE1/0/2] vlan mapping nest range 36 to 40 nested-vlan 2003
Configuring PE B
<PE_B> system-view
[PE_B] vlan 10 to 40
[PE_B-Twenty-FiveGigE1/0/1] port hybrid vlan 15 to 40 tagged
[PE_B-Twenty-FiveGigE1/0/1] vlan mapping nest range 15 to 25 nested-vlan 2001
[PE_B-Twenty-FiveGigE1/0/1] vlan mapping nest range 26 to 35 nested-vlan 2002
[PE_B-Twenty-FiveGigE1/0/1] vlan mapping nest range 36 to 40 nested-vlan 2003
[PE_B-Twenty-FiveGigE1/0/2] port hybrid vlan 10 to 40 tagged
[PE_B-Twenty-FiveGigE1/0/2] vlan mapping nest range 10 to 20 nested-vlan 1001
[PE_B-Twenty-FiveGigE1/0/2] vlan mapping nest range 21 to 30 nested-vlan 1002
[PE_B-Twenty-FiveGigE1/0/2] vlan mapping nest range 31 to 40 nested-vlan 1003
# Set the MTU to a minimum of 1504 bytes for each port on the path of double-tagged packets. (Details not shown.)
# Configure all ports on the forwarding path to allow packets from VLANs 1001 through 1003 and VLANs 2001 through 2003 to pass through without removing the SVLAN tag. (Details not shown.)
1.     Verify VLAN mapping information:
# Verify VLAN mapping information on PE A.
[PE_A] display vlan mapping
Interface Twenty-FiveGigE1/0/1:
  Outer VLAN    Inner VLAN    Translated Outer VLAN    Translated Inner VLAN
  10-20         N/A           1001                     10-20
  21-30         N/A           1002                     21-30
  31-40         N/A           1003                     31-40
Interface Twenty-FiveGigE1/0/2:
  15-25         N/A           2001                     15-25
  26-35         N/A           2002                     26-35
  36-40         N/A           2003                     36-40
# Verify VLAN mapping information on PE B.
[PE_B] display vlan mapping
2.     Verify that PCs of the same customer in a CVLAN can ping each other across the service provider network. (Details not shown.)
3.     Verify that PCs of different customers in a CVLAN cannot communicate at Layer 2. The ARP tables on one customer's PCs do not contain entries for MAC addresses of the other customer's PCs. (Details not shown.)
Configuration files
·     PE A:
vlan 10 to 40
vlan 1001 to 1003
vlan 2001 to 2003
 qos trust dot1p
 qos trust dot1p
·     PE B:
vlan 10 to 40
vlan 1001 to 1003
vlan 2001 to 2003
 qos trust dot1p
 qos trust dot1p
As shown in Figure 6:
·     Each household subscribes to PC, VoD, and VoIP services, and obtains the IP address through DHCP.
·     On the home gateways, PC, VoD, and VoIP service traffic is assigned to VLANs 1, 2, and 3, respectively.
To isolate traffic of the same service type from different households, configure one-to-one VLAN mapping on the wiring-closet switches. This feature assigns one VLAN to each type of traffic from each household.
Figure 6 Network diagram
Hardware
Software version
S6880 switch series
S9820-8M
Procedures
# Create the original VLANs 2 and 3. (VLAN 1 is the system default VLAN and already exists.)
[SwitchA] vlan 2 to 3
# Create the translated VLANs 101 through 102, 201 through 202, and 301 through 302.
[SwitchA] vlan 101 to 102
[SwitchA] vlan 201 to 202
[SwitchA] vlan 301 to 302
# Configure the customer-side port Twenty-FiveGigE 1/0/1 as a trunk port.
[SwitchA] interface twenty-fivegige 1/0/1
[SwitchA-Twenty-FiveGigE1/0/1] port link-type trunk
# Assign Twenty-FiveGigE 1/0/1 to the original VLANs and translated VLANs.
[SwitchA-Twenty-FiveGigE1/0/1] port trunk permit vlan 1 2 3 101 201 301
# Configure one-to-one VLAN mapping on Twenty-FiveGigE 1/0/1 to map VLANs 1, 2, and 3 to VLANs 101, 201, and 301, respectively.
[SwitchA-Twenty-FiveGigE1/0/1] vlan mapping 1 translated-vlan 101
[SwitchA-Twenty-FiveGigE1/0/1] vlan mapping 2 translated-vlan 201
[SwitchA-Twenty-FiveGigE1/0/1] vlan mapping 3 translated-vlan 301
[SwitchA-Twenty-FiveGigE1/0/1] quit
# Configure the customer-side port Twenty-FiveGigE 1/0/2 as a trunk port.
[SwitchA] interface twenty-fivegige 1/0/2
[SwitchA-Twenty-FiveGigE1/0/2] port link-type trunk
# Assign Twenty-FiveGigE 1/0/2 to the original VLANs and translated VLANs.
[SwitchA-Twenty-FiveGigE1/0/2] port trunk permit vlan 1 2 3 102 202 302
# Configure one-to-one VLAN mapping on Twenty-FiveGigE 1/0/2 to map VLANs 1, 2, and 3 to VLANs 102, 202, and 302, respectively.
[SwitchA-Twenty-FiveGigE1/0/2] vlan mapping 1 translated-vlan 102
[SwitchA-Twenty-FiveGigE1/0/2] vlan mapping 2 translated-vlan 202
[SwitchA-Twenty-FiveGigE1/0/2] vlan mapping 3 translated-vlan 302
[SwitchA-Twenty-FiveGigE1/0/2] quit
# Configure the network-side port Twenty-FiveGigE 1/0/3 as a trunk port.
[SwitchA] interface twenty-fivegige 1/0/3
[SwitchA-Twenty-FiveGigE1/0/3] port link-type trunk
# Assign Twenty-FiveGigE 1/0/3 to the translated VLANs.
[SwitchA-Twenty-FiveGigE1/0/3] undo port trunk permit vlan 1
[SwitchA-Twenty-FiveGigE1/0/3] port trunk permit vlan 101 201 301 102 202 302
[SwitchA-Twenty-FiveGigE1/0/3] quit
# Configure Switch B in the same way Switch A is configured. (Details not shown.)
# Verify VLAN mapping information on Switch A.
[SwitchA] display vlan mapping
  1             N/A           101                      N/A
  2             N/A           201                      N/A
  3             N/A           301                      N/A
  1             N/A           102                      N/A
  2             N/A           202                      N/A
  3             N/A           302                      N/A
# Verify VLAN mapping information on Switch B in the same way as Switch A. (Details not shown.)
Configuration files
·     Switch A:
vlan 1
vlan 2 to 3
vlan 101 to 102
vlan 201 to 202
vlan 301 to 302
 port trunk permit vlan 1 to 3 101 201 301
 port trunk permit vlan 1 to 3 102 202 302
 port trunk permit vlan 1 101 to 102 201 to 202 301 to 302
·     Switch B:
vlan 1
vlan 2 to 3
vlan 103 to 104
vlan 203 to 204
vlan 303 to 304
 port trunk permit vlan 1 to 3 103 203 303
 vlan mapping 1 translated-vlan 103
 vlan mapping 2 translated-vlan 203
 vlan mapping 3 translated-vlan 303
 port trunk permit vlan 1 to 3 104 204 304
 vlan mapping 1 translated-vlan 104
 vlan mapping 2 translated-vlan 204
 vlan mapping 3 translated-vlan 304
 port trunk permit vlan 1 103 to 104 203 to 204 303 to 304
As shown in Figure 7, the wiring-closet switch isolates similar services of different household users by dividing VLAN 2 to 4. On the campus switch, to save VLAN resources, different household users' similar services are mapped to the same VLAN through many-to-one VLAN mapping. All household users' similar services are mapped to VLAN 10 for processing.
Figure 7 Network diagram
Hardware
Software version
S6880 switch series
S9820-8M
Procedures
# Create the original VLAN 2.
[SwitchA] vlan 2
# Assign Twenty-FiveGigE 1/0/1 and Twenty-FiveGigE 1/0/1 to VLAN 2.
[SwitchA] interface range twenty-fivegige 1/0/1 to twenty-fivegige 1/0/2
[SwitchA-if-range] port access vlan 2
# Configure Switch B and Switch C in the same way Switch A is configured. (Details not shown.)
# Create the original VLANs 2 and 4.
[SwitchD] vlan 2 to 4
# Assign Twenty-FiveGigE 1/0/1 to VLAN 2, assign Twenty-FiveGigE 1/0/2 to VLAN 3, and assign Twenty-FiveGigE 1/0/3 to VLAN 4.
[SwitchD] interface ten-twenty-fivegige 1/0/1
[SwitchD-Twenty-FiveGigE1/0/1] port access vlan 2
[SwitchD-Twenty-FiveGigE1/0/1] quit
[SwitchD] interface ten-twenty-fivegige 1/0/2
[SwitchD-Twenty-FiveGigE1/0/2] port access vlan 3
[SwitchD-Twenty-FiveGigE1/0/2] quit
[SwitchD] interface ten-twenty-fivegige 1/0/3
[SwitchD-Twenty-FiveGigE1/0/3] port access vlan 4
[SwitchD-Twenty-FiveGigE1/0/3] quit
# Configure Twenty-FiveGigE 1/0/4 as a trunk port.
[SwitchD] interface ten-twenty-fivegige 1/0/4
[SwitchD-Twenty-FiveGigE1/0/4] port link-type trunk
# Assign Twenty-FiveGigE 1/0/4 to the original VLANs and translated VLANs.
[SwitchD-Twenty-FiveGigE1/0/4] port trunk permit vlan 2 to 4
# Configure Twenty-FiveGigE 1/0/1 as a trunk port.
[SwitchE] interface ten-twenty-fivegige 1/0/1
[SwitchE-Twenty-FiveGigE1/0/1] port link-type trunk
[SwitchE-Twenty-FiveGigE1/0/1] port trunk permit vlan 2 to 4
# Configure many-to-one VLAN mapping on Twenty-FiveGigE 1/0/1 to map VLANs 2, 3, and 4 to VLAN 10.
[SwitchE-Twenty-FiveGigE1/0/1] vlan mapping uni range 2 to 4 translated-vlan 10
# Verify VLAN mapping information on Switch E.
[SwitchE] display vlan mapping
  2-4           N/A           10                       N/A
Configuration files
·     Switch A:
vlan 1
vlan 2
 port access vlan 2
 port access vlan 2
·     Switch B:
vlan 1
vlan 3
 port access vlan 3
 port access vlan 3
·     Switch C:
vlan 1
vlan 4
 port access vlan 4
 port access vlan 4
·     Switch D:
vlan 1
vlan 2 to 4
 port access vlan 2
 port access vlan 3
 port access vlan 4
interface Twenty-FiveGigE1/0/4
 port trunk permit vlan 1 to 4
·     Switch E:
vlan 1
vlan 2 to 4
As shown in Figure 8:
·     A company assigns its branch sites (Site 1 and Site 2) to VLAN 10, and the headquarters provides services in VLAN 30.
·     Service provider A uses SVLAN 100 to transmit VLAN 10 traffic for the branch sites.
·     Service provider B uses SVLAN 200 to transmit VLAN 30 traffic for the headquarters.
Configure two-to-two VLAN mapping to permit the two branch sites to access VLAN 30 of the headquarters without changing their VLAN assignment.
Figure 8 Network diagram
Hardware
Software version
S6880 switch series
S9820-8M
Configure two-to-two VLAN mapping on one of the edge devices between the two service provider networks. This example uses Switch C.
Procedures
# Create CVLAN 10 and SVLAN 100.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
[SwitchA] vlan 100
[SwitchA-vlan100] quit
# Configure a one-to-two VLAN mapping on the customer-side port (Twenty-FiveGigE 1/0/1) to add SVLAN tag 100 to packets from VLAN 10.
[SwitchA-Twenty-FiveGigE1/0/1] vlan mapping nest single 10 nested-vlan 100
# Configure Twenty-FiveGigE 1/0/1 as a hybrid port.
[SwitchA-Twenty-FiveGigE1/0/1] port link-type hybrid
# Assign Twenty-FiveGigE 1/0/1 to VLAN 10 as a tagged member.
[SwitchA-Twenty-FiveGigE1/0/1] port hybrid vlan 10 tagged
# Assign Twenty-FiveGigE 1/0/1 to VLAN 100 as an untagged member.
[SwitchA-Twenty-FiveGigE1/0/1] port hybrid vlan 100 untagged
# Remove Twenty-FiveGigE 1/0/1 from VLAN 1.
[SwitchA-Twenty-FiveGigE1/0/1] undo port hybrid vlan 1
# Configure the network-side port Twenty-FiveGigE 1/0/2 as a trunk port.
# Assign Twenty-FiveGigE 1/0/2 to VLAN 100.
[SwitchA-Twenty-FiveGigE1/0/2] port trunk permit vlan 100
# Remove Twenty-FiveGigE 1/0/2 from VLAN 1.
[SwitchA-Twenty-FiveGigE1/0/2] undo port trunk permit vlan 1
[SwitchB] vlan 10
[SwitchB-vlan10] quit
[SwitchB] vlan 100
[SwitchB-vlan100] quit
# Configure a one-to-two VLAN mapping on the customer-side port (Twenty-FiveGigE 1/0/3) to add SVLAN tag 100 to packets from VLAN 10.
[SwitchB] interface twenty-fivegige 1/0/3
[SwitchB-Twenty-FiveGigE1/0/3] vlan mapping nest single 10 nested-vlan 100
# Configure Twenty-FiveGigE 1/0/3 as a hybrid port.
[SwitchB-Twenty-FiveGigE1/0/3] port link-type hybrid
# Assign Twenty-FiveGigE 1/0/3 to VLAN 10 as a tagged member.
[SwitchB-Twenty-FiveGigE1/0/3] port hybrid vlan 10 tagged
# Assign Twenty-FiveGigE 1/0/3 to VLAN 100 as an untagged member.
[SwitchB-Twenty-FiveGigE1/0/3] port hybrid vlan 100 untagged
# Remove Twenty-FiveGigE 1/0/3 from VLAN 1.
[SwitchB-Twenty-FiveGigE1/0/3] undo port hybrid vlan 1
[SwitchB-Twenty-FiveGigE1/0/3] quit
[SwitchB] interface twenty-fivegige 1/0/1
[SwitchB-Twenty-FiveGigE1/0/1] port link-type trunk
# Assign Twenty-FiveGigE 1/0/1 to VLAN 100.
[SwitchB-Twenty-FiveGigE1/0/1] port trunk permit vlan 100
[SwitchB-Twenty-FiveGigE1/0/1] undo port trunk permit vlan 1
[SwitchB-Twenty-FiveGigE1/0/1] quit
# Configure Twenty-FiveGigE 1/0/2 as a trunk port.
[SwitchB] interface twenty-fivegige 1/0/2
[SwitchB-Twenty-FiveGigE1/0/2] port link-type trunk
[SwitchB-Twenty-FiveGigE1/0/2] port trunk permit vlan 100
[SwitchB-Twenty-FiveGigE1/0/2] undo port trunk permit vlan 1
[SwitchB-Twenty-FiveGigE1/0/2] quit
# Create SVLANs 100 and 200.
[SwitchC] vlan 100
[SwitchC-vlan100] quit
[SwitchC] vlan 200
[SwitchC-vlan200] quit
[SwitchC] interface twenty-fivegige 1/0/1
[SwitchC-Twenty-FiveGigE1/0/1] port link-type trunk
# Assign Twenty-FiveGigE 1/0/1 to VLANs 100 to 200.
[SwitchC-Twenty-FiveGigE1/0/1] port trunk permit vlan 100 200
[SwitchC-Twenty-FiveGigE1/0/1] undo port trunk permit vlan 1
# Configure a two-to-two VLAN mapping on Twenty-FiveGigE 1/0/1 to map SVLAN 100 and CVLAN 10 to SVLAN 200 and CVLAN 30.
[SwitchC-Twenty-FiveGigE1/0/1] vlan mapping tunnel 100 10 translated-vlan 200 30
[SwitchC-Twenty-FiveGigE1/0/1] quit
[SwitchC] interface twenty-fivegige 1/0/2
[SwitchC-Twenty-FiveGigE1/0/2] port link-type trunk
# Assign Twenty-FiveGigE 1/0/2 to VLAN 200.
[SwitchC-Twenty-FiveGigE1/0/2] port trunk permit vlan 200
[SwitchC-Twenty-FiveGigE1/0/2] undo port trunk permit vlan 1
[SwitchC-Twenty-FiveGigE1/0/2] quit
# Create CVLAN 30 and SVLAN 200.
<SwitchD> system-view
[SwitchD] vlan 30
[SwitchD-vlan30] quit
[SwitchD] vlan 200
[SwitchD-vlan200] quit
# Configure the link type of Twenty-FiveGigE 1/0/1 as trunk.
[SwitchD] interface twenty-fivegige 1/0/1
[SwitchD-Twenty-FiveGigE1/0/1] port link-type trunk
# Assign Twenty-FiveGigE 1/0/1 to VLAN 200.
[SwitchD-Twenty-FiveGigE1/0/1] port trunk permit vlan 200
[SwitchD-Twenty-FiveGigE1/0/1] undo port trunk permit vlan 1
# Configure Twenty-FiveGigE 1/0/2 as a hybrid port.
[SwitchD] interface twenty-fivegige 1/0/2
[SwitchD-Twenty-FiveGigE1/0/2] port link-type hybrid
# Assign Twenty-FiveGigE 1/0/2 to VLAN 30 as a tagged member.
[SwitchD-Twenty-FiveGigE1/0/2] port hybrid vlan 30 tagged
# Assign Twenty-FiveGigE 1/0/2 to VLAN 200 as an untagged member.
[SwitchD-Twenty-FiveGigE1/0/2] port hybrid vlan 200 untagged
[SwitchD-Twenty-FiveGigE1/0/2] undo port hybrid vlan 1
# Configure a one-to-two VLAN mapping on the customer-side port (Twenty-FiveGigE 1/0/2) to add SVLAN tag 200 to packets from VLAN 30.
[SwitchD-Twenty-FiveGigE1/0/2] vlan mapping nest single 30 nested-vlan 200
# Verify VLAN mapping information on Switch C.
[SwitchC] display vlan mapping
  100           10            200                      30
Configuration files
·     Switch A:
vlan 10
vlan 100
·     Switch B:
vlan 10
vlan 100
·     Switch C:
vlan 100
vlan 200
·     Switch D:
vlan 30
vlan 200
