- 02-Layer 2—LAN Switching Configuration Examples
- 01-MAC Address Table Configuration Examples
- 02-Ethernet Link Aggregation Configuration Examples
- 03-Port Isolation Configuration Examples
- 04-VLAN Configuration Examples
- 05-VLAN Tagging Configuration Examples
- 06-Spanning Tree Configuration Examples
- 07-M-LAG Configuration Examples
- 08-MVRP Configuration Examples
02-Ethernet Link Aggregation Configuration Examples | 185.44 KB |
Example: Configuring Layer 2 link aggregation
Example: Configuring Layer 2 link aggregation load sharing
Example: Configuring Layer 3 link aggregation
Example: Configuring Layer 3 link aggregation load sharing
Introduction
This document provides Ethernet link aggregation configuration examples.
This document assumes that you have basic knowledge of Ethernet link aggregation.
As shown in Figure 1, both Device A and Device B forward traffic from VLAN 10 and VLAN 20.
Configure link aggregation on Device A and Device B to meet the following requirements:
· VLAN 10 on Device A can communicate with VLAN 10 on Device B.
· VLAN 20 on Device A can communicate with VLAN 20 on Device B.
Analysis
To enable traffic from VLAN 10 and VLAN 20 to pass through Layer 2 aggregate interface Bridge-aggregation 1, perform the following tasks:
· Configure Layer 2 aggregate interface Bridge-aggregation 1 as a trunk port.
· Assign the aggregate interface to VLAN 10 and VLAN 20.
Hardware |
Software version |
S6550X-HI switch series |
Release 1116 and later Release 1213P51 and later |
S6880 switch series |
S9820-8M switch |
S9855 switch series |
Release 9126 and later |
S9825 switch series |
S5580X-HI switch series |
Release 1213P50 and later |
S5580X-EI switch series |
S5580S-EI switch series |
When you configure Layer 2 link aggregation, follow these restrictions and guidelines:
· When you assign a port to an aggregation group, the recommended configuration procedure is as follows:
a. Use the display this command in interface view to check the following attribute configurations of the port:
- Port isolation.
- QinQ.
- VLAN.
- VLAN mapping.
b. If any of the above configurations exist, use the undo forms of the corresponding commands to remove these configurations. This enables the port to use the default attribute configurations.
c. Assign the port to the aggregation group.
· In a static aggregation group, the Selected state of a port is not affected by whether the peer port is added to an aggregation group and is Selected. As a result, the Selected state of a port might be different from the Selected state of the peer port. When both ends support static aggregation and dynamic aggregation, HP recommends using dynamic aggregation.
· You cannot assign a port to a Layer 2 aggregation group when MAC authentication, port security mode, or 802.1X is configured or enabled on the port.
Procedures
1. Configure Device A:
# Create VLAN 10, and assign port Twenty-FiveGigE 1/0/4 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port twenty-fivegige 1/0/4
[DeviceA-vlan10] quit
# Create VLAN 20, and assign port Twenty-FiveGigE 1/0/5 to VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] port twenty-fivegige 1/0/5
[DeviceA-vlan20] quit
# Create Layer 2 aggregate interface Bridge-aggregation 1. Use one of the following methods as needed.
¡ Use the static aggregation mode to create Layer 2 aggregate interface Bridge-aggregation 1.
[DeviceA] interface bridge-aggregation 1
[DeviceA-Bridge-Aggregation1] undo shutdown
[DeviceA-Bridge-Aggregation1] quit
¡ Use the dynamic aggregation mode to create Layer 2 aggregate interface Bridge-aggregation 1.
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
# Assign ports Twenty-FiveGigE 1/0/1 through Twenty-FiveGigE 1/0/3 to aggregation group 1.
[DeviceA] interface range twenty-fivegige 1/0/1 to twenty-fivegige 1/0/3
[DeviceA-if-range] port link-aggregation group 1
[DeviceA-if-range] undo shutdown
[DeviceA-if-range] quit
# Configure Layer 2 aggregate interface Bridge-aggregation 1 as a trunk port.
[DeviceA-Bridge-Aggregation1] port link-type trunk
Configuring Twenty-FiveGigE1/0/1 done.
Configuring Twenty-FiveGigE1/0/2 done.
Configuring Twenty-FiveGigE1/0/3 done.
# Assign the aggregate interface to VLANs 10 and 20.
[DeviceA-Bridge-Aggregation1] port trunk permit vlan 10 20
2. Configure Device B in the same way Device A is configured. (Details not shown.)
# Display detailed information about the link aggregation groups on Device A.
· Link aggregation configuration information when the static aggregation mode is used:
[DeviceA] display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
G -- Defaulted, H -- Expired
Aggregation Interface: Bridge-Aggregation1
Aggregation Mode: Static
Management VLANs: None
Port Status Priority Oper-Key
WGE1/0/1(R) S 32768 1
WGE1/0/2 S 32768 1
WGE1/0/3 S 32768 1
The output shows that all member ports in the local aggregation group are in the Selected state. The Selected states of the local member ports are not affected by the Selected states of the peer member ports.
· Link aggregation configuration information when the dynamic aggregation mode is used:
Creation Mode: Manual
Aggregation Mode: Dynamic
System ID: 0x8000, 000f-e234-5678
Local:
Port Status Priority Index Oper-Key Flag
WGE1/0/1 S 32768 2 1 {ACDEF}
WGE1/0/2 S 32768 3 1 {ACDEF}
WGE1/0/3 S 32768 4 1 {ACDEF}
Remote:
Actor Priority Index Oper-Key SystemID Flag
WGE1/0/1(R) 32768 2 1 0x8000, a4e5-c316-0100 {ACDEF}
WGE1/0/2 32768 3 1 0x8000, a4e5-c316-0100 {ACDEF}
WGE1/0/3 32768 4 1 0x8000, a4e5-c316-0100 {ACDEF}
The output shows that the local member ports and the corresponding peer member ports are all Selected. In the dynamic link aggregation mode, each local member port and its peer member port have the same Selected state through exchanging LACPDUs. The user data traffic can be forwarded correctly.
Configuration files
· Device A:
vlan 10
interface Twenty-FiveGigE1/0/4
port link-mode bridge
port access vlan 10
vlan 20
interface Twenty-FiveGigE1/0/5
port access vlan 20
¡ In the static aggregation mode:
interface Bridge-Aggregation1
¡ In the dynamic aggregation mode:
interface Twenty-FiveGigE1/0/1
interface Twenty-FiveGigE1/0/2
interface Twenty-FiveGigE1/0/3
· Device B:
The configuration file on Device B is the same as the configuration file on Device A.
As shown in Figure 2, both Device A and Device B forward traffic from VLAN 10 and VLAN 20.
· VLAN 10 on Device A can communicate with VLAN 10 on Device B. VLAN 20 on Device A can communicate with VLAN 20 on Device B.
· The packets from VLAN 10 are load shared across the Selected ports of link aggregation group 1 by source MAC addresses. The packets from VLAN 20 are load shared across the Selected ports of link aggregation group 2 by source MAC addresses.
Analysis
To enable packets from VLAN 10 to pass through aggregate interface Bridge-aggregation 1, assign the aggregate interface to VLAN 10. To enable packets from VLAN 20 to pass through aggregate interface Bridge-aggregation 2, assign the aggregate interface to VLAN 20.
Hardware |
Software version |
S9820-8M switch |
When you configure Layer 2 load sharing, follow these restrictions and guidelines:
- Port isolation.
- QinQ.
- VLAN.
- VLAN mapping.
Procedures
# Create VLAN 10, and assign port Twenty-FiveGigE 1/0/5 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port twenty-fivegige 1/0/5
# Create VLAN 20, and assign port Twenty-FiveGigE 1/0/6 to VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] port twenty-fivegige 1/0/6
# Assign ports Twenty-FiveGigE 1/0/1 and Twenty-FiveGigE 1/0/2 to aggregation group 1.
[DeviceA] interface twenty-fivegige 1/0/1
[DeviceA-Twenty-FiveGigE1/0/1] port link-aggregation group 1
[DeviceA-Twenty-FiveGigE1/0/1] quit
[DeviceA] interface twenty-fivegige 1/0/2
[DeviceA-Twenty-FiveGigE1/0/2] port link-aggregation group 1
[DeviceA-Twenty-FiveGigE1/0/2] quit
# Assign Layer 2 aggregate interface Bridge-aggregation 1 to VLAN 10.
[DeviceA-Bridge-Aggregation1] port access vlan 10
# Create Layer 2 aggregate interface Bridge-aggregation 2.
[DeviceA] interface bridge-aggregation 2
[DeviceA-Bridge-Aggregation2] quit
# Assign ports Twenty-FiveGigE 1/0/3 and Twenty-FiveGigE 1/0/4 to aggregation group 2.
[DeviceA] interface twenty-fivegige 1/0/3
[DeviceA-Twenty-FiveGigE1/0/3] port link-aggregation group 2
[DeviceA-Twenty-FiveGigE1/0/3] quit
[DeviceA] interface twenty-fivegige 1/0/4
[DeviceA-Twenty-FiveGigE1/0/4] port link-aggregation group 2
[DeviceA-Twenty-FiveGigE1/0/4] quit
# Assign Layer 2 aggregate interface Bridge-aggregation 2 to VLAN 20.
[DeviceA-Bridge-Aggregation2] port access vlan 20
Configuring Twenty-FiveGigE1/0/4 done.
# Set the global load sharing mode to source MAC address.
[DeviceA] link-aggregation global load-sharing mode source-mac
# Display the information about Selected ports in link aggregation groups on Device A.
Port Status: S -- Selected, U -- Unselected , I -- Individual
WGE1/0/2 S 32768 1
Aggregation Interface: Bridge-Aggregation2
WGE1/0/3(R) S 32768 2
WGE1/0/4 S 32768 2
· Link aggregation groups 1 and 2 are both Layer 2 static aggregation groups.
· Each aggregation group has two Selected ports for forwarding traffic.
# Display the global link aggregation load sharing mode.
[DeviceA] display link-aggregation load-sharing mode
Link-aggregation load-sharing algorithm:
4 (default)
Link-aggregation load-sharing offset:
0 (default)
Link-aggregation load-sharing seed:
0x1 (default)
Tunneled traffic load-sharing mode:
Outer (default)
Link-aggregation load-sharing mode:
source-mac address
The output shows that Device A load shares packets based on source MAC addresses.
Configuration files
· Device A:
vlan 10
port access vlan 10
vlan 20
interface Twenty-FiveGigE1/0/6
port access vlan 10
port access vlan 10
port access vlan 10
port access vlan 10
interface Bridge-Aggregation2
port access vlan 20
port access vlan 20
port access vlan 20
· Device B:
On the network as shown in Figure 3, perform the following tasks:
· Configure a Layer 3 dynamic aggregation group on both Device A and Device B.
· Configure IP addresses and subnet masks for the corresponding Layer 3 aggregate interfaces.
Hardware |
Software version |
S9820-8M switch |
Procedures
# Create Layer 3 aggregate interface Route-Aggregation 1. Use one of the following methods as needed.
¡ Use the static aggregation mode to create Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA] interface route-aggregation 1
¡ Use the dynamic aggregation mode to create Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA-Route-Aggregation1] link-aggregation mode dynamic
# Configure an IP address and subnet mask for Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA-Route-Aggregation1] ip address 192.168.1.1 24
[DeviceA-Route-Aggregation1] undo shutdown
[DeviceA-Route-Aggregation1] quit
[DeviceA-if-range] port link-mode route
WGE1/0/1 S 32768 1
WGE1/0/2 S 32768 1
WGE1/0/3 S 32768 1
The output shows that all member ports in the local aggregation group are in Selected state. The Selected states of the local member ports are not affected by the Selected states of the peer member ports.
Local:
WGE1/0/1(R) S 32768 2 1 {ACDEF}
Remote:
WGE1/0/1 32768 2 1 0x8000, 68fa-34f2-0200 {ACDEF}
WGE1/0/2 32768 3 1 0x8000, 68fa-34f2-0200 {ACDEF}
WGE1/0/3 32768 4 1 0x8000, 68fa-34f2-0200 {ACDEF}
Configuration files
· Device A:
interface route-aggregation1
Device B:
The configuration file on Device B is similar as the configuration file on Device A.
On the network as shown in Figure 4, perform the following tasks:
· Configure Layer 3 static aggregation groups 1 and 2 on Device A and Device B.
· Set the global load sharing mode to source IP addresses.
Hardware |
Software version |
S9820-8M switch |
You can configure global or group-specific link aggregation load sharing mode. A link aggregation group preferentially uses the group-specific load sharing mode. This example uses the group-specific load sharing mode.
Procedures
# Create Layer 3 aggregate interface Route-Aggregation 2.
[DeviceA] interface route-aggregation 2
# Configure an IP address and subnet mask for Layer 3 aggregate interface Route-Aggregation 2.
[DeviceA-Route-Aggregation2] ip address 192.168.2.1 24
[DeviceA-Route-Aggregation2] quit
# Assign Layer 3 Ethernet interfaces Twenty-FiveGigE 1/0/1 and Twenty-FiveGigE 1/0/2 to aggregation group 1.
[DeviceA] interface range twenty-fivegige 1/0/1 twenty-fivegige 1/0/2
# Assign Layer 3 Ethernet interfaces Twenty-FiveGigE 1/0/3 and Twenty-FiveGigE 1/0/4 to aggregation group 2.
[DeviceA] interface range twenty-fivegige 1/0/3 twenty-fivegige 1/0/4
[DeviceA-if-range] port link-aggregation group 2
# Set the global load sharing mode to source IP address.
[DeviceA] link-aggregation global load-sharing mode source-ip
# Display detailed information about all aggregation groups on Device A.
WGE1/0/2 S 32768 1
Aggregate Interface: Route-Aggregation2
WGE1/0/4 S 32768 2
The output shows that:
· Link aggregation groups 1 and 2 are both load-shared Layer 3 static aggregation groups.
· Each aggregation group contains two Selected ports.
# Display the global link aggregation load sharing mode on Device A.
4 (default)
0 (default)
0x1 (default)
Outer (default)
source-ip address
The output shows that Device A load shares packets based on source IP addresses.
Configuration files
· Device A:
interface Route-Aggregation1
interface Route-Aggregation2
ip address 192.168.2.1 255.255.255.0
· Device B:
