- 02-Layer 2—LAN Switching Configuration Examples
- 01-MAC Address Table Configuration Examples
- 02-Ethernet Link Aggregation Configuration Examples
- 03-Port Isolation Configuration Examples
- 04-VLAN Configuration Examples
- 05-VLAN Tagging Configuration Examples
- 06-Spanning Tree Configuration Examples
- 07-M-LAG Configuration Examples
- 08-MVRP Configuration Examples
| 03-Port Isolation Configuration Examples | 69.60 KB |
General configuration restrictions and guidelines
Example: Configuring port isolation
Introduction
This document provides port isolation configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of port isolation.
You cannot assign the member ports of a service loopback group to an isolation group. You cannot assign the member ports of an isolation group to a service loopback group.
As shown in Figure 1, the company branches Site 1 and Site 2 transfer service traffic in VLAN 2 and VLAN 3. Device A connects to the Internet through Twenty-FiveGigE 1/0/1.
Configure port isolation on Device A to meet the following requirements:
· All hosts can access the Internet through Device A.
· Host A and Host B are isolated from each other at Layer 2.
· Host C and Host D are isolated from each other at Layer 2.
Hardware |
Software version |
S6550X-HI switch series |
Release 1116 and later Release 1213P51 and later |
S6880 switch series |
S9820-8M switch |
S9855 switch series |
Not supported |
S9825 switch series |
Not supported |
S5580X-HI switch series |
Release 1213P50 and later |
S5580X-EI switch series |
S5580S-EI switch series |
When you configure port isolation on the device, follow these restrictions and guidelines:
· Before assigning a port to an isolation group, make sure the isolation group already exists.
· You can assign a port to only one isolation group.
Procedures
# Create VLAN 2 and assign ports Twenty-FiveGigE 1/0/2 and Twenty-FiveGigE 1/0/3 to the VLAN.
[DeviceA] vlan 2
[DeviceA-vlan2] port twenty-fivegige 1/0/2
[DeviceA-vlan2] port twenty-fivegige 1/0/3
[DeviceA-vlan2] quit
# Create VLAN 3 and assign ports Twenty-FiveGigE 1/0/4 and Twenty-FiveGigE 1/0/5 to the VLAN.
[DeviceA] vlan 3
[DeviceA-vlan3] port twenty-fivegige 1/0/4
[DeviceA-vlan3] port twenty-fivegige 1/0/5
[DeviceA-vlan3] quit
# Configure port Twenty-FiveGigE 1/0/1 as a trunk port and assign it to VLAN 2 and VLAN 3.
[DeviceA] interface twenty-fivegige 1/0/1
[DeviceA-Twenty-FiveGigE1/0/1] port link-type trunk
[DeviceA-Twenty-FiveGigE1/0/1] port trunk permit vlan 2 3
[DeviceA-Twenty-FiveGigE1/0/1] quit
# Create isolation groups 1 and 2.
[DeviceA] port-isolate group 1
[DeviceA] port-isolate group 2
# Assign ports Twenty-FiveGigE 1/0/2 and Twenty-FiveGigE 1/0/3 to isolation group 1.
[DeviceA] interface twenty-fivegige 1/0/2
[DeviceA-Twenty-FiveGigE1/0/2] port-isolate enable group 1
[DeviceA-Twenty-FiveGigE1/0/2] quit
[DeviceA] interface twenty-fivegige 1/0/3
[DeviceA-Twenty-FiveGigE1/0/3] port-isolate enable group 1
[DeviceA-Twenty-FiveGigE1/0/3] quit
# Assign ports Twenty-FiveGigE 1/0/4 and Twenty-FiveGigE 1/0/5 to isolation group 2.
[DeviceA] interface twenty-fivegige 1/0/4
[DeviceA-Twenty-FiveGigE1/0/4] port-isolate enable group 2
[DeviceA-Twenty-FiveGigE1/0/4] quit
[DeviceA] interface twenty-fivegige 1/0/5
[DeviceA-Twenty-FiveGigE1/0/5] port-isolate enable group 2
[DeviceA-Twenty-FiveGigE1/0/5] quit
# Display information about all isolation groups.
[DeviceA] display port-isolate group
Port isolation group information:
Group ID: 1
Group members:
Group ID: 2
Group members:
The output shows that:
· Ports Twenty-FiveGigE 1/0/2 and Twenty-FiveGigE 1/0/3 are in isolation group 1. As a result, Host A and Host B are isolated from each other at Layer 2.
· Ports Twenty-FiveGigE 1/0/4 and Twenty-FiveGigE 1/0/4 are in isolation group 2. As a result, Host C and Host D are isolated from each other at Layer 2.
Configuration files
vlan 2 to 3
interface Twenty-FiveGigE1/0/1
port link-mode bridge
port trunk permit vlan 1 to 3
interface Twenty-FiveGigE1/0/2
port access vlan 2
interface Twenty-FiveGigE1/0/3
port access vlan 2
interface Twenty-FiveGigE1/0/4
port access vlan 3
interface Twenty-FiveGigE1/0/5
port access vlan 3
