04-PIM-STD-MIB | 66.34 KB |
PIM-STD-MIB
About this MIB
Use this MIB to manage PIM routers.
MIB file name
rfc5060-pim-std.mib
Notifications
pimNeighborLoss
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.157.0.1 |
PIM neighbor loss. |
Informational |
Minor |
N/A (N/A) |
ON |
Notification triggers
Notification Triggers
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.157.0.1
PIM neighbor loss.
Informational
Minor
N/A
ON
This notification indicates the loss of a PIM neighbor. This notification is generated when the PIM neighbor timer expires and the router does not have another neighbor on the same interface with the same IP version and a lower IP address than itself.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable { pim | pim6 } neighbor-loss command.
OFF
CLI: Use the undo snmp-agent trap enable { pim | pim6 } neighbor-loss command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.157.1.2.1.6 (pimNeighborUpTime) |
Time since the neighbor has come up. |
No |
TimeTicks |
Standard MIB values. |
Recommended action
To resolve the issue:
1.Verify that whether this notification is generated because of PIM neighbor configuration change.
2.Verify that PIM is correctly configured on the interface.
3.Verify that the lost PIM neighbor can operate correctly.
4.Verify that this router has sufficient memory.
5.Verify that this router does not have link failures.
6.If the issue persists, contact H3C Support.
