03-PIM-BSR-MIB | 77.91 KB |
PIM-BSR-MIB
About this MIB
Use this MIB to manage PIM BSR settings.
MIB file name
rfc5240-pim-bsr.mib
Notifications
pimBsrElectedBSRLostElection
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.172.0.1 |
Lost BSR election to a new E-BSR |
Informational |
Warning |
N/A (N/A) |
ON |
Notification triggers
Notification Triggers
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.172.0.1
Informational
Warning
N/A
ON
This notification is generated when the current E-BSR lost election to a new E-BSR. Only E-BSR will generate this notification.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable { pim | pim6 } elected-bsr-lost-election command.
OFF
CLI: Use the undo snmp-agent trap enable { pim | pim6 } elected-bsr-lost-election command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.172.1.4.1.2 (pimBsrElectedBSRAddressType) |
Address type of a BSR. |
No |
InetAddressType |
ipv4(1), ipv6(2) |
1.3.6.1.2.1.172.1.4.1.3 (pimBsrElectedBSRAddress) |
IP address of the BSR. |
No |
InetAddress |
OCTET STRING (4|16) |
1.3.6.1.2.1.172.1.4.1.4 (pimBsrElectedBSRPriority) |
Priority of the BSR. |
No |
Unsigned32 |
Unsigned32(0..255) |
Recommended action
To resolve the issue:
1.Verify that whether this notification is generated because of BSR or C-BSR configuration change.
2.Verify that other PIM routers are operating correclty.
3.Verify that the local router has sufficient memory.
4.Verify that the local router does not have link failures.
5.If the issue persists, contact H3C Support.
pimBsrCandidateBSRWinElection
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.172.0.2 |
Win of BSR election. |
Informational |
Warning |
N/A (N/A) |
ON |
System impact
OID
Event
Severity
Default status
1.3.6.1.2.1.172.0.2
Informational
Warning
N/A
ON
This notification is generated when a C-BSR was elected as the E-BSR. Only E-BSR will generate this notification.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable { pim | pim6 } candidate-bsr-win-election command.
OFF
CLI: Use the undo snmp-agent trap enable { pim | pim6 } candidate-bsr-win-election command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.172.1.3.1.6 (pimBsrCandidateBSRElectedBSR) |
Whether this routeristhe E-BSR. |
No |
TruthValue |
true(1), false(2) |
Recommended action
