| Title | Size | Downloads |
| V7-IPS-1.0.264.dat | 12.90 MB |
Version number
V7-IPS-1.0.264
MD5 number
eb411964a8d9b589864533443e336b0c
Update time
2023-10-11
Update attack list
Key new rules:
50162 CVE-2023-42819_Jumpserver_Key_Argument_Directory_Traversal_Vulnerability[2]
---- Category: Vulnerability
---- Description: Jumpserver is an open source fortress aircraft from China's Hangzhou Feizhiyun
---- Information Technology Co., LTD. JumpServer has a path traversal vulnerability that results from
---- logged-in users being able to access and modify the contents of any file on the system.
50145 Kingdee_EAS_myUploadFile.do_arbitrary_file_upload_vulnerability[2]
---- Description: Kingdee is a global provider of enterprise management software and cloud services.
---- Its products and services mainly cover enterprise financial management (Kingdee EAS, Kingdee K/3, etc.),
---- human resource management (Kingdee HRP), supply chain management (Kingdee MES, etc.),
---- marketing services (Kingdee CRM, etc.) and Cloud computing services (Kingdee Cloud, etc.).Kingdee EAS
---- has any file upload vulnerability. Attackers can use this vulnerability to upload any file or execute any code.
50158 CVE-2023-29452_Zabbix_Geomap_Stored_Cross-Site_Scripting_Vulnerability[2]
---- Description: Zabbix is an open-source monitoring system from Zabbix company. The system supports network
---- monitoring, server monitoring, cloud monitoring, and application monitoring. Zabbix has a security vulnerability.
---- There is currently no relevant information about this vulnerability. Please stay tuned to
---- CNNVD or manufacturer announcements at any time.
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the IPS rules library file of this version, 20443 predefined rules can be generated in "Intrusion Prevention System"
[4] The device memory is less than or equal to 2GB. After loading the IPS rules library file of this version, 3146 predefined rules can be generated in "Intrusion Prevention System"
