H3C WA6022H Access Point Installation Guide-6W100
HomeSupportWirelessWA6022H Access PointInstall & UpgradeInstallation GuidesH3C WA6022H Access Point Installation Guide-6W100
02-Appendix A LEDs and ports
02-Appendix A LEDs and ports 121.24 KB
LEDs and buttons
The LED status varies by AP operating mode. For information about the supported operating modes, see the release notes for the AP.
Table 1 LED descriptions (fit mode)
LED status
Off
No power is present or the LED has been turned off.
Yellow
Steady on
The AP is initializing, or an initialization exception has occurred.
Flashing (twice per second)
The Ethernet interfaces are down and no mesh links are established.
Green
Steady on
The AP has registered to an AC, but does not have any associated clients.
Flashing (once per two seconds)
The AP has started up but has not registered to any AC.
The AP is upgrading the image.
Blue
Flashing (once per second)
The radios have associated clients.
Table 2 LED descriptions (cloud mode)
LED status
Off
Yellow
Steady on
Green
Steady on
The AP is in standby state and has connected to the Cloudnet platform, but does not have any associated clients.
The AP has connected to the Cloudnet platform and has associated clients.
Blue
Steady on
The AP is in standby state, but has not connected to the Cloudnet platform and does not have associated clients.
The AP has not connected to the Cloudnet platform, but has associated clients.
Table 3 RESET button descriptions
Press and hold duration (sec)
Button LED status
0 to 5
Steady green
Reset the AP.
5 to 20
Flashing green (twice per second)
Restore to the factory defaults.
20 to 30
Yellow
The AP is operating in fit mode.
Flashing (four times per second)
The AP is operating in cloud mode.
> 30
Yellow
Green
Change the AP operating mode to cloud.
If you release the button, the AP will restart for the new mode to take effect.
Ports
The AP provides the following ports:One Uplink/PoE In port.
The AP also has a reset button.
Figure 1 Ports on the AP (1)
(1) Reset button
Figure 2 Ports on the AP (2)
(1) Uplink/PoE In port
Table 4 Port descriptions
Port
Standards and protocols
RESET
N/A
For more information, see Table 3.
Uplink/PoE In port
·     IEEE802.3
·     IEEE802.3i
·     IEEE802.3u
·     IEEE802.3ab
·     IEEE802.3af
10/100/1000M Ethernet copper port, used for connecting the AP to an uplink device for Internet or MAN access. It can also receive PoE power from the uplink device.
When the AP operates in fit mode, the port is represented by interface number GE1/0/1 in the MAP file and gigabitethernet 1 for configuration on the AC.
