| 01-Text | 1.09 MB |
General safety recommendations
Determining the installation position
Mounting the AP on a Junction box
Connecting the AP to a power source
Connecting the AP to the network
Verifying that the AP has been connected to the network when it operates in fit mode
Verifying that the AP has been connected to the network when it operates in cloud mode
Logging in to the AP from the console port
Connecting the AP to a configuration terminal from the console port
Setting parameters for the configuration terminal
Logging in to the AP through Telnet
Logging in from the Web interface
Configuring the AP from the Cloudnet platform
Downloading and installing Cloudnet App Int
Logging in to the Cloudnet platform
Preparing for installation
Safety recommendations
Safety labels
Safety label |
Hot surface warning label. A device attached with this label might have a hot surface during operation. Install the device in a restricted access location. Only servicing engineers or trained personnel can operate the devices in the access location. • Hot parts: Text that identifies the nature of the class 2 or class 3 energy source or the consequences that can be caused by the energy source, and the location of the energy source. • Burned fingers when handling the parts: Text that describes the possible consequences of energy transfer from the energy source to a body part. • Wait one-half hour after switching off before handling parts: Text that describes the safeguard action necessary to avoid energy transfer to a body part. |
Only professional technical personnel can install and remove the AP and its accessories. You must read all safety instructions carefully before working with the AP.
To avoid possible bodily injury and equipment damage, read the following safety recommendations before installing the AP. Note that the recommendations do not cover every possible hazardous condition.
· To avoid bodily injury and device damage, take adequate safety measures.
· Place the AP in a dry and flat location and take anti-slip measures.
· Keep the AP clean and dust-free.
· Do not place the AP in a moist area and avoid liquid intrusion.
· Keep the AP and installation tools away from walkways.
Site preparation
To make sure the AP will operate in a favorable environment, examine the installation site before installing the AP. Make sure the temperature and humidity at the installation site meet the requirements in Table 1.
Table 1 Temperature and humidity requirements
Item |
Specification |
Operating temperature |
0°C to +40°C (+32°F to +104°F) |
Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
Operating humidity |
5% RH to 95% RH, noncondensing |
Installation accessories
Figure 1 Accessories provided with the AP
Installation tools
When installing the AP, you might need the following tools. Prepare the installation tools yourself as required.
Figure 2 Installation tools
Installing the AP
Installation flowchart
Figure 3 Installation flowchart
Pre-installation tasks
Before installing the AP, perform the following tasks:
· Connect the AP to a power source and the network. Examine the LEDs to verify that the AP is operating correctly. For information about AP LEDs, see "Appendix A LEDs and ports".
· Record the MAC address and serial number at the rear of the AP for future use.
· Make sure you have completed cabling at the installation site.
· Use Cat-5e or above network cables. For information about the supported interface rates, see "Appendix A LEDs and ports".
· The AP is typically installed on a high position. As a best practice, access and configure the AP before installing it.
· If a cable is routed outdoors, make sure a lighting arrester is attached to the AP port. Prepare a lighting arrester yourself as needed.
Determine the installation position by observing the following principles:
· Few obstacles such as wall exist between the AP and clients.
· Reserve clearance around the AP for heat dissipation. Ensure a minimum distance of 2 m (6.56 ft) between the AP and other radiant resources, for example, wireless base station antennas.
· The AP does not hinder people’s daily work and life.
· The place is not water seeping, water soaking, and condensing.
Mounting the AP
The AP can be installed only indoors. You can mount the AP on a wall, a Junction box, or a ceiling.
Mounting bracket
Figure 4 Mounting bracket
Figure 5 Device
Mounting the AP on a wall
1. Place the mounting bracket against the wall and mark the installation holes on the wall.
Figure 6 Marking the installation holes on the wall
2. Drill two holes with a diameter of 7 mm (0.315 in) and a depth of 30 mm (1.18 in) at the marked locations, as shown in Figure 7.
Figure 7 Drilling holes in the wall
3. Use a rubber hammer to tap a screw anchor into each hole until it is all flush with the wall surface, as shown in Figure 8.
Figure 8 Hammering the screw anchor into the wall
4. Remove the U-shaped plastic plate on the wall side for wiring, feed the Ethernet cable through the cable hole, and then secure the wall bracket to the wall using screws, as shown in Figure 9. The wall bracket has side A and side B. Make sure side A faces the wall and determine the direction of the cable hole on the wall bracket based on the wiring direction.
Figure 9 Attaching the mounting bracket to the wall
5. Connect an Ethernet cable to the uplink port on the rear of the AP, as shown in Figure 10.
Figure 10 Connect an Ethernet cable
6. Align the screw holes on two sides of the AP with those on the wall bracket, use the screws to secure the AP to the wall bracket, as shown in Figure 11.
7. Install the AP cover, as shown in Figure 12.
1. Connect an Ethernet cable with an RJ-45 connector to the uplink port on the rear of the AP.
Figure 13 Connect an Ethernet cable
2. Align the screw holes on the two sides of the AP with those on the junction box, use screws to secure the AP to the junction box, as shown in Figure 14.
Figure 14 Connect an Ethernet cable
3. Reinstall the AP cover, as shown in Figure 15.
Figure 15 Reinstall the AP cover
Mounting the AP on a ceiling
CAUTION: When you use the ceiling installation, the M4 screws provided with the AP require that the ceiling must be less than 15 mm (0.59 in) in thickness. If the ceiling is thicker, prepare longer M4 screws yourself. |
To mount the AP on a ceiling:
1. Remove the ceiling, use a handheld cutting machine to cut a groove in the ceiling, as shown in Figure 16.
Figure 16 Cut a groove in the ceiling
2. Push the AP into the ceiling groove.After you have removed the ceiling and cut a groove in the ceiling, make the ceiling face down, and then push the AP into the ceiling groove, as shown in Figure 17.
Figure 17 Push the AP into the ceiling groove
3. Push the mounting bracket into the other side of the ceiling so that both the mounting bracket and the AP are attached to the ceiling. Use the provided M4 screws to secure the AP to the ceiling. The wall bracket has side A and side b. Make sure side B faces the ceiling during installation and determine the direction of the cable hole on the ceiling bracket based on the wiring direction, as shown in Figure 18.
Figure 18 Secure the AP to the ceiling
4. Connect an Ethernet cable to the uplink port on the rear of the AP.
Figure 19 Connect an Ethernet cable
5. Install the cover of the AP.
Figure 20 Install the cover of the AP
You can supply power to the AP through 802.3af-compliant PoE as required. Before powering the AP, make sure the 802.3af-compliant power sourcing equipment (PSE) is grounded reliably.
Connecting a PoE power source
To power the AP through PoE, use an Ethernet cable to connect an Ethernet port on a PoE switch to the GE/PoE port on the AP. Attach the cable cover to the AP securely after connecting all cables.
Check after power-on
Examine the LEDs on the AP after you power on it to verify that the AP is operating correctly.
When the AP operates in fit mode, all AP settings are configured on the AC. To verify the network connectivity of the AP, execute the display wlan ap all command on the AC. If the AP status is R/M, the AP has been connected to the network.
<AC> display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 3072
Remaining APs: 3071
Total AP licenses: 128
Remaining AP licenses: 127
AP information
State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad
C = Config, DC = DataCheck, R = Run M = Master, B = Backup
AP name AP ID State Model Serial ID
ap1 1 R/M WA6022H 219801A3L58224E00031
When the AP operates in cloud mode, use a wireless terminal to search for and access the wireless service provided by the AP. If you can access external networks, the AP has been connected to the network.
Accessing the AP
When the AP operates in cloud mode, you can access and configure the AP from the console port, Web interface, or through Telnet. Accessing the AP from the Web interface or through Telnet requires the IP address of the AP.
Prepare the following items for accessing the device from the console port:
· An 8-core console cable, with a crimped RJ-45 connector at one end, and a DB-9 connector at the other end.
· A configuration terminal. It can be a standard character terminal with an RS-232 port, or a PC.
CAUTION: · To connect a PC to the AP, first connect the PC end. To disconnect a PC from the AP, first disconnect the AP end. · If the PC does not have an RS-232 port but a USB port, use a USB-to-RS-232 converter to connect the USB port to the console cable and install the driver on the PC. |
To connect the AP to a configuration terminal from the console port:
1. Connect the DB-9 connector of the console cable to the serial port on the configuration terminal, for example, a PC.
2. Connect the RJ-45 connector of the console cable to the console port on the AP.
To configure and manage the AP from the console port, you must run a terminal emulator program, such as HyperTerminal or PuTTY, on your configuration terminal. You can use the emulator program to connect a network device, a Telnet site, or an SSH site. For more information about the terminal emulator programs, see the user guides for these programs.
Configure the terminal parameters as follows:
· Bits per second—9,600.
· Data bits—8.
· Stop bits—1.
· Parity—None.
· Flow control—None.
Verify that the AP is connected correctly to the configuration terminal and the configuration terminal parameters are configured correctly. Then, power on the AP. You can see the following information on the configuration terminal:
System is starting...
Booting Normal Extend BootWare.
System application is starting...
Startup configuration file does not exist.
User interface con0 is available.
Press ENTER to get started.
By default, Telnet is enabled and the following login information is defined for your login:
· Username—admin.
· Password—h3capadmin.
Make sure the PC obtains an IP address dynamically.
When the AP operates in cloud mode, it obtains the IP address of VLAN 1 dynamically by default.
Some Intel wireless adapters do not support 802.11ax. For clients to detect Wi-Fi 6 networks, upgrade the driver for the wireless adapter to the most recent version. For more information, see the official statement of Intel.
To log in to the AP through a wireless connection:
1. Enable WLAN on the configuration terminal and access WLAN H3C_xxxxxx, where xxxxxx is the last six bits of the AP's MAC address.
2. Enter telnet wlan.h3c.com from the CLI of the terminal.
3. Enter the default username and password and change the default password as prompted.
By default, HTTP and HTTPS are enabled and the following login information is defined for your login:
· Username—admin.
2. Visit http://wlan.h3c.com from a browser, and then press Enter.
3. Enter the default username and password. For security purposes, change the password as prompted after you access the Web interface, and then click OK.
You can manage the AP remotely from the Cloudnet platform (Web interface or app) only when the AP operates in cloud mode.
Make sure the smartphone uses Android 4.0, iOS7.0, or a higher-version operating system.
Download and install Cloudnet App Int from Google Play Store.
To manage the AP from the Cloudnet platform, make sure the AP uses an IP address that can reach the external network.
To log in to the Cloudnet platform:
1. Open Cloudnet App Int or visit https://oasiscloudnet.h3c.com from a browser.
2. Enter the username and password.
After login, you can add the AP to the platform and manage the AP. For more information about platform login and device management, see H3C Cloudnet Deployment Guide.
