- H3C UniServer R4900 G6 Ultra Hardware Options Installation and Replacement Videos-6W100
- 01-Install standard, ball-bearing, or short-distance slide rails
- 02-Install the server to a rack
- 03-Remove the server from a rack
- 04-Install and remove a cable management arm (CMA)
- 05-Install a processor
- 06-Replace a processor
- 07-Replace a DIMM
- 08-Replace the system board
- 09-Replace the server management module
- 10-Replace a drive
- 11-Replace the intelligent security bezel
- 12-Replace the OCP adapter
- 13-Replace a front drive backplane
- 14-Install a rear drive cage
- 15-Replace a rear drive cage
- 16-Replace a rear drive backplane
- 17-Replace the mid drive cage
- 18-Replace a mid drive
- 19-Replace a riser card
- 20-Install a riser card on PCIe riser connector 3 or 4
- 21-Replace a standard storage controller and the power fail safeguard module
- 22-Replace a GPU
- 23-Replace a standard PCIe network adapter
- 24-Replace an OCP network adapter
- 25-Replace a SATA M.2 SSD
- 26-Replace a SATA M.2 expander module
- 27-Replace an NVMe M.2 SSD
- 28-Replace an NVMe M.2 SSD expander module
- 29-Replace the serial & DSD module
- 30-Replace an SD card
- 31-Install an LCD smart management module
- 32-Replace the LCD smart management module
- 33-Use the LCD smart management module
- 34-Replace a chassis ear
- 35-Replace a fan module
- 36-Install a TPM or TCM
- 37-Replace a power supply
- 38-Connect power cords
- 39-Replace the NVMe VROC module
- 40-Replace the system battery
- 41-Replace the 4GPU module
- 42-Replace a GPU on the 4GPU module
- 43-Replace a PCIe module on the 4GPU module
- 44-Install a GPU on the 4GPU module
- 45-Replace a mid GPU adapter
- 46-Install or remove blanks
| 03-Remove the server from a rack | 77.66 MB |
Watch online
