Application Signature V7-APR-1.0.162
Release time:2023-09-07
HomeSupportResource CenterSecuritySignature Database ServicesSignature Database ServicesSoftware DownloadSignature Database Services
Download
Title Size Downloads
V7-APR-1.0.162.dat 2.67 MB
Version number
V7-APR-1.0.162
MD5 number
e15596adab6cd16f97e113e62cee6f54
Update time
2023-09-06
New protocol list
Modified protocols:    [1]
----QUIC
Modified protocols:    [2]
----YunZhiJia
----YunKe
----YouMo
----YongZhongRuanJian
----ZeYuanRuanJian
----YongYou
----ZhiYuanHuLian
----YuQue
Update protocol list
----TikTok
----Facebook
----Sunflower
----TeamViewer
----ToDesk
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the APR feature library file of this version, 9554 predefined applications can be generated
[4] The device memory is less than or equal to 2GB. After loading the APR feature library file of this version, 1529 predefined applications can be generated
  • Become a Partner
  • Partner Resources
