03-Device Management
HomeSupportReference GuidesMIB CompanionH3C S5590-EI S5130S-G FS5500-EI FS5500V2-EI S6530X Switch Series MIB Reference-6W10103-Device Management
06-HH3C-RES-MON-MIB
06-HH3C-RES-MON-MIB 78.29 KB
HH3C-RES-MON-MIB
About this MIB
Use this MIB to monitor and manage state changes of cards and hardware resources on the device and enable the device to send notifications.
MIB file name
hh3c-res-mon.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cResMon(169)
Scalar objects
hh3cResMonMinorResendEnable
Object (OID)
Access
Value range
Implementation
hh3cResMonMinorResendEnable(1.3.6.1.4.1.25506.2.169.1.1)
read-write
TruthValue
true(1), false(2)
Enabling status of the minor resource depletion alarm resending feature.
As per the MIB.
hh3cResMonOutputEnable
Object (OID)
Access
Value range
Implementation
hh3cResMonOutputEnable (1.3.6.1.4.1.25506.2.169.1.2)
read-write
BITS
BITS {syslog(0), snmpNotification(1), netconfEvent(2)}
Destinations for resource depletion alarms.
As per the MIB.
Tabular objects
hh3cResMonConfigTable
About this table
Use this table to configure resource monitoring settings.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are hh3cResMonChassisIndex, hh3cResMonSlotIndex, hh3cResMonCpuIndex, and hh3cResMonResourceName.
Object (OID)
Access
Value range
Implementation
hh3cResMonChassisIndex (1.3.6.1.4.1.25506.2.169.2.1.1.1)
read-only
Unsigned32
Standard MIB values.
Member ID of the device.
As per the MIB.
hh3cResMonSlotIndex (1.3.6.1.4.1.25506.2.169.2.1.1.2)
read-only
Unsigned32
Slot number.
As per the MIB.
hh3cResMonCpuIndex (1.3.6.1.4.1.25506.2.169.2.1.1.3)
read-only
Unsigned32
CPU ID.
As per the MIB.
hh3cResMonResourceName (1.3.6.1.4.1.25506.2.169.2.1.1.4)
read-only
OCTET STRING
OCTET STRING (1..31)
Resource name.
As per the MIB.
hh3cResMonThresholdUnit (1.3.6.1.4.1.25506.2.169.2.1.1.5)
read-write
INTEGER
absolute(1),
percentage(2)
Method for specifying resource depletion thresholds.
As per the MIB.
hh3cResMonMinorThreshold (1.3.6.1.4.1.25506.2.169.2.1.1.6)
read-write
Unsigned32
Minor resource depletion threshold.
As per the MIB.
hh3cResMonSevereThreshold (1.3.6.1.4.1.25506.2.169.2.1.1.7)
read-write
Unsigned32
Severe resource depletion threshold.
As per the MIB.
hh3cResMonInfoTable
About this table
Use this table to obtain information about hardware resources.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cResMonUnit
(1.3.6.1.4.1.25506.2.169.2.2.1.1)
read-only
INTEGER
absolute(1), percentage(2)
Expression method for the resource thresholds
As per the MIB.
hh3cResMonCurrent
(1.3.6.1.4.1.25506.2.169.2.2.1.2)
read-only
Unsigned32
Amount of the used resource.
As per the MIB.
hh3cResMonFree
(1.3.6.1.4.1.25506.2.169.2.2.1.3)
read-only
Unsigned32
Amount of the free resource.
As per the MIB.
hh3cResMonTotal
(1.3.6.1.4.1.25506.2.169.2.2.1.4)
read-only
Unsigned32
Total size of resource.
As per the MIB.
Notifications
hh3cResMonMinorNotification
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.169.3.0.1
Minor resource depletion alarm occurred
Error
Minor
1.3.6.1.4.1.25506.2.169.3.0.2(hh3cResMonMinorRecoverNotification)
ON
This notification is generated when the amount of the free resource decreased to or below the hh3cResMonMinorThreshold.
Status control
The notification cannot be disabled.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.169.2.1.1.1 (hh3cResMonChassisIndex)
Y
Unsigned32
1.3.6.1.4.1.25506.2.169.2.1.1.2 (hh3cResMonSlotIndex)
Slot number
Y
Unsigned32
1.3.6.1.4.1.25506.2.169.2.1.1.3 (hh3cResMonCpuIndex)
CPU ID
Y
Unsigned32
1.3.6.1.4.1.25506.2.169.2.1.1.4 (hh3cResMonResourceName)
Resource name
Y
OCTET STRING
(hh3cResMonThresholdUnit)
Expression method for resource depletion thresholds
N
INTEGER
absolute(1),
percentage(2)
(hh3cResMonMinorThreshold)
N
Unsigned32
(hh3cResMonSevereThreshold)
N
Unsigned32
(hh3cResMonCurrent)
N
Unsigned32
(hh3cResMonFree)
N
Unsigned32
1.3.6.1.4.1.25506.2.169.2.2.1.3 (hh3cResMonTotal)
N
Unsigned32
1.3.6.1.4.1.25506.2.169.3.1.1 (hh3cResMonAdditionalInfo)
Additional information
N
OCTET STRING
Recommended action
This issue has minor impact on the current services. To avoid more serious issues, take actions at an appropriate time or perform further observation.
Basic information
OID
Event
Severity
Default status
Minor resource depletion alarm cleared
Recovery
N/A
N/A
ON
This notification is generated when the amount of the free resource increased to or above the hh3cResMonMinorThreshold.
Status control
Objects
OID (object name)
Index
Value range
Y
Unsigned32
Slot number
Y
Unsigned32
CPU ID
Y
Unsigned32
Resource name
Y
OCTET STRING
N
INTEGER
N
Unsigned32
N
Unsigned32
(hh3cResMonCurrent)
N
Unsigned32
(hh3cResMonFree)
N
Unsigned32
N
Unsigned32
N
OCTET STRING
Recommended action
No action is required.
hh3cResMonSevereNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.169.3.0.3
Severe resource depletion alarm occurred
Error
Major
1.3.6.1.4.1.25506.2.169.3.0.4(hh3cResMonSevereRecoverNotification)
ON
This notification is generated when the amount of the free resource increased to or above the hh3cResMonSevereThreshold.
Status control
Objects
OID (object name)
Index
Value range
Y
Unsigned32
Slot number
Y
Unsigned32
CPU ID
Y
Unsigned32
Resource name
Y
OCTET STRING
N
INTEGER
absolute(1),
percentage(2)
N
Unsigned32
N
Unsigned32
(hh3cResMonCurrent)
N
Unsigned32
(hh3cResMonFree)
N
Unsigned32
N
Unsigned32
N
OCTET STRING
Recommended action
The issue has significant impact on current services. Immediate action is required.
Basic information
OID
Event
Severity
Default status
Severe resource depletion alarm cleared
Recovery
N/A
N/A
ON
This notification is generated when the amount of the free resource is increased to or above hh3cResMonSevereThreshold.
Status control
Objects
OID (object name)
Index
Value range
Y
Unsigned32
Slot number
Y
Unsigned32
CPU ID
Y
Unsigned32
Resource name
Y
OCTET STRING
N
INTEGER
absolute(1),
percentage(2)
N
Unsigned32
N
Unsigned32
(hh3cResMonCurrent)
N
Unsigned32
(hh3cResMonFree)
N
Unsigned32
N
Unsigned32
N
OCTET STRING
Recommended action
hh3cResMonUsedUpNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.169.3.0.5
Resource used up alarm occurred
Error
Critical
1.3.6.1.4.1.25506.2.169.3.0.6(hh3cResMonUsedUpRecoverNotification)
ON
This notification is generated when the resource is used up.
Status control
Objects
OID (object name)
Index
Value range
Y
Unsigned32
Slot number
Y
Unsigned32
CPU ID
Y
Unsigned32
Resource name
Y
OCTET STRING
N
INTEGER
absolute(1),
percentage(2)
N
Unsigned32
N
Unsigned32
(hh3cResMonCurrent)
N
Unsigned32
(hh3cResMonFree)
N
Unsigned32
N
Unsigned32
N
OCTET STRING
Recommended action
The issue puts system assets and services at risk. Immediate action is required.
Basic information
OID
Event
Severity
Default status
Resource used up alarm cleared
Recovery
N/A
N/A
ON
This notification is generated when the free resource increases from zero up.
Status control
Objects
OID (object name)
Index
Value range
Y
Unsigned32
Slot number
Y
Unsigned32
CPU ID
Y
Unsigned32
Resource name
Y
OCTET STRING
N
INTEGER
absolute(1),
percentage(2)
N
Unsigned32
N
Unsigned32
(hh3cResMonCurrent)
N
Unsigned32
(hh3cResMonFree)
N
Unsigned32
N
Unsigned32
N
OCTET STRING
Recommended action
