03-Device Management
HomeSupportReference GuidesMIB CompanionH3C S5590-EI S5130S-G FS5500-EI FS5500V2-EI S6530X Switch Series MIB Reference-6W10103-Device Management
03-HH3C-LswDEVM-MIB
03-HH3C-LswDEVM-MIB 50.41 KB
HH3C-LswDEVM-MIB
About this MIB
Use this MIB to obtain information the resources on the device. For example, access this MIB to obtain power supply or fan information, including their number or status.
MIB file name
hh3c-splat-devm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswdevMMib(9)
Scalar objects
hh3cdot1qTpFdbLearnStatus
Object (OID)
Access
Value range
Implementation
hh3cdot1qTpFdbLearnStatus (1.3.6.1.4.1.25506.8.35.9.1.10)
read-write
INTEGER
enabled(1),
disabled(2)
Enablement status of MAC address learning.
Supported.
hh3cDevMFirstTrapTime
Object (OID)
Access
Value range
Implementation
hh3cDevMFirstTrapTime (1.3.6.1.4.1.25506.8.35.9.1.13)
accessible-for-notify
TimeTicks
Standard MIB values.
Time when the first trap is sent.
Supported.
Tabular objects
hh3cdevMFanStatusTable
About this table
This table contains basic fan information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cDevMFanNum.
Object (OID)
Access
Value range
Implementation
hh3cDevMFanNum (1.3.6.1.4.1.25506.8.35.9.1.1.1.1)
read-only
Integer32
Fan index.
Supported.
hh3cDevMFanStatus (1.3.6.1.4.1.25506.8.35.9.1.1.1.2)
read-only
INTEGER
active(1),
deactive(2),
not-install(3),
unsupport(4)
Fan status.
Supported.
hh3cDevMFanPosFrame
read-only
Integer32
ID of the chassis where the fan resides.
Not supported.
hh3cDevMFanPosSlot
read-only
Integer32
Slot number of the fan.
Supported
hh3cDevMFanPosIndex
read-only
Integer32
Fan number.
Supported.
hh3cDevMFanMaxSpeed
read-only
Integer32
Maximum fan speed.
Not supported.
hh3cDevMFanCurrentSpeed
read-only
Integer32
Current fan speed.
Not supported.
hh3cdevMPowerStatusTable
About this table
This table contains basic power supply information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cDevMPowerNum.
Object (OID)
Access
Value range
Implementation
hh3cDevMPowerNum (1.3.6.1.4.1.25506.8.35.9.1.2.1.1)
read-only
Integer32
Power supply index.
Supported.
hh3cDevMPowerStatus (1.3.6.1.4.1.25506.8.35.9.1.2.1.2)
read-only
INTEGER
active(1),
deactive(2),
not-install(3),
unsupport(4)
Power supply status.
Supported.
hh3cDevMPowerEntIndex (1.3.6.1.4.1.25506.8.35.9.1.2.1.3)
read-only
Integer32
Entity index of the power supply.
Supported.
hh3cdevMSlotEnvironmentTable
About this table
This table contains environment information for a card.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cdevMSlotEnvironmentType.
Object (OID)
Access
Value range
Implementation
hh3cdevMSlotEnvironmentType (1.3.6.1.4.1.25506.8.35.9.1.3.1.1)
not-accessible
INTEGER
temperature(1),
humidity(2),
fog(3)
Type of the environment elements.
Not supported.
hh3cDevMSlotEnvironmentStatus (1.3.6.1.4.1.25506.8.35.9.1.3.1.2)
read-only
INTEGER
normal(1),
upper(2),
lower(3)
Status of the environment where the card resides.
Not supported.
hh3cDevMSlotEnvironmentValue (1.3.6.1.4.1.25506.8.35.9.1.3.1.3)
read-only
Integer32
Environment data for the card.
Supported.
hh3cDevMSlotEnvironmentUpperLimit (1.3.6.1.4.1.25506.8.35.9.1.3.1.4)
read-write
Integer32
Upper limit for the environment requirements.
Not supported.
hh3cDevMSlotEnvironmentLowerLimit (1.3.6.1.4.1.25506.8.35.9.1.3.1.5)
read-write
Integer32
Lower limit for the environment requirements.
Not supported.
