03-Device Management
HomeSupportReference GuidesMIB CompanionH3C S5590-EI S5130S-G FS5500-EI FS5500V2-EI S6530X Switch Series MIB Reference-6W10103-Device Management
04-HH3C-LswTRAP-MIB
04-HH3C-LswTRAP-MIB 285.11 KB
HH3C-LswTRAP-MIB
About this MIB
This MIB contains information about notifications for state change of cards and resources on the device.
MIB file name
hh3c-splat-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswTrapMib(12)
Scalar objects
hh3csLswTrapCpuCoreInfo
Object (OID)
Access
Value range
Implementation
hh3csLswTrapCpuCoreInfo (1.3.6.1.4.1.25506.8.35.12.2.1)
accessible-for-notify
SnmpAdminString
OCTET STRING (0..255)
CPU core information in CPU notifications.
As per the MIB.
hh3csLswTrapProcessCpuInfo
Object (OID)
Access
Value range
Implementation
hh3csLswTrapProcessCpuInfo (1.3.6.1.4.1.25506.8.35.12.2.1)
SnmpAdminString
Process information in CPU notifications.
As per the MIB.
hh3csLswTrapProcessMemoryInfo
Object (OID)
Access
Value range
Implementation
hh3csLswTrapProcessMemoryInfo (1.3.6.1.4.1.25506.8.35.12.2.3)
SnmpAdminString
Memory information in CPU notifications.
As per the MIB.
hh3csLswTrapSlubInfo
Object (OID)
Access
Value range
Implementation
hh3csLswTrapSlubInfo (1.3.6.1.4.1.25506.8.35.12.2.4)
SnmpAdminString
Slub information in CPU notifications.
As per the MIB.
hh3cLswTrapCpuUsage
Object (OID)
Access
Value range
Implementation
hh3cLswTrapCpuUsage (1.3.6.1.4.1.25506.8.35.12.2.5)
SnmpAdminString
CPU usage information in CPU notifications.
As per the MIB.
hh3cLswTrapCoreProcessInfo
Object (OID)
Access
Value range
Implementation
hh3cLswTrapCoreProcessInfo (1.3.6.1.4.1.25506.8.35.12.2.6)
SnmpAdminString
Core process information in CPU notifications.
As per the MIB.
hh3cLswCoreTrapUsage
Object (OID)
Access
Value range
Implementation
hh3cLswCoreTrapUsage (1.3.6.1.4.1.25506.8.35.12.2.7)
Unsigned32
Standard MIB values.
CPU usage in the most recent 30 minutes.
As per the MIB.
hh3cBoardAvailablePower
Object (OID)
Access
Value range
Implementation
hh3cBoardAvailablePower (1.3.6.1.4.1.25506.8.35.12.2.8)
Integer32
Available power.
As per the MIB.
hh3cBoardRequiredPower
Object (OID)
Access
Value range
Implementation
hh3cBoardRequiredPower (1.3.6.1.4.1.25506.8.35.12.2.9)
Integer32
Required power.
As per the MIB.
hh3cLswAlarmInPortInNum
Object (OID)
Access
Value range
Implementation
hh3cLswAlarmInPortInNum (1.3.6.1.4.1.25506.8.35.12.2.10)
Unsigned32
Number of alarm in ports.
As per the MIB.
Notifications
This section contains the HH3C-LswTRAP-MIB notifications.
hh3cpowerfailure
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.8.35.12.1.1
Failure of a power supply
Error
Major
1.3.6.1.4.1.25506.8.35.12.1.2(hh3cPowerNormal)
ON
This notification is generated when a power supply fails or a new power supply is inserted into the device.
Status control
The notification cannot be disabled.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.35.9.1.2.1.1 (hh3cDevMPowerNum)
Power supply ID.
Y
Integer32
1.3.6.1.4.1.25506.8.35.9.1.13 (hh3cDevMFirstTrapTime)
Timestamp of the notification.
N
TimeTicks
Recommended action
To resolve the issue:
1.     Verify that the power supply is installed correctly.
2.     If the issue persists, contact H3C Support.
hh3cPowerNormal
Basic information
OID
Event
Severity
Default status
Recovery of a power supply from a fault
Recovery
N/A
N/A
ON
This notification is generated when a power supply recovers from an abnormal state.
Status control
Objects
OID (object name)
Index
Value range
Power supply ID.
Y
Integer32
N
TimeTicks
Recommended action
No action is required.
hh3cPowerRemoved
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.5
Removal of a power supply
Error
Minor
1.3.6.1.4.1.25506.8.35.12.1.23 (hh3cPowerInserted)
ON
This notification is generated when a power supply is removed from the device.
Status control
Objects
OID (object name)
Index
Value range
Power supply ID.
Y
Integer32
Recommended action
1.     Verify that a power supply is removed from the device.
¡     If the power supply is removed from the device, no action is required.
¡     If the power supply is not removed from the device, verify that the power supply is installed correctly.
hh3cfanfailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.6
Failure of a fan tray
Error
Major
1.3.6.1.4.1.25506.8.35.12.1.7(hh3cFanNormal)
ON
This notification is generated when a fan tray fails.
Status control
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.35.9.1.1.1.1 (hh3cDevMFanNum)
Fan tray ID.
Y
Integer32
Recommended action
1.     Verify that the fan tray is installed correctly.
hh3cFanNormal
Basic information
OID
Event
Severity
Default status
Recovery of a fan tray from a fault.
Recovery
N/A
N/A
ON
This notification is generated when a fan tray recovers from a fault.
Status control
Objects
OID (object name)
Index
Value range
Fan tray ID.
Y
Integer32
Recommended action
hh3cBoardRemoved
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.8
Removal of a card
Error
Minor
1.3.6.1.4.1.25506.8.35.12.1.9(hh3cBoardInserted)
ON
This notification is generated when a card is removed from the device.
Status control
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.35.18.4.2.1.1 (hh3cLswFrameIndex)
Member ID of the device.
Y
Integer32
1.3.6.1.4.1.25506.8.35.18.4.3.1.1 (hh3cLswSlotIndex)
Slot ID.
Y
Integer32
Recommended action
1.     Verify that the card is removed from the device.
¡     If the card is removed from the device, no action is required.
¡     If the card is not removed from the device, verify that the card is installed correctly.
hh3cBoardInserted
Basic information
OID
Event
Severity
Default status
Insertion of a card
Recovery
N/A
N/A
ON
This notification is generated when a card is inserted into the device.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
Recommended action
hh3cBoardFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.10
Failure or startup of a card
Error
Major
1.3.6.1.4.1.25506.8.35.12.1.11(hh3cBoardNormal)
ON
This notification is generated when a card is starting up or a fault occurs on the card.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID
Y
Integer32
Recommended action
1.     Verify that the card is installed correctly.
2.     If the issue persists after 24 hours, contact H3C Support.
hh3cBoardNormal
Basic information
OID
Event
Severity
Default status
Initialization completion of a card
Recovery
N/A
N/A
ON
This notification is generated when a card completes initialization.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
Recommended action
hh3cSubcardRemove
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.12
Removal of a subcard
Error
Minor
1.3.6.1.4.1.25506.8.35.12.1.13(hh3cSubcardInsert)
ON
This notification is generated when a subcard is removed from the device.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID
Y
Integer32
1.3.6.1.4.1.25506.8.35.18.4.4.1.1 (hh3cLswSubslotIndex)
Subslot ID
Y
Integer32
Recommended action
1.     Verify that the subcard is removed from the device.
¡     If the subcard is removed from the device, no action is required.
¡     If the subcard is not removed from the device, verify that the subcard is installed correctly.
hh3cSubcardInsert
Basic information
OID
Event
Severity
Default status
Insertion of a subcard
Recovery
N/A
N/A
ON
This notification is generated when a subcard is inserted into the device.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
Subslot ID.
Y
Integer32
Recommended action
hh3cPowerInserted
Basic information
OID
Event
Severity
Default status
Insertion of a power supply
Recovery
N/A
N/A
ON
This notification is generated when a power supply is inserted into the device.
Status control
Objects
OID (object name)
Index
Value range
Power supply ID.
Y
Integer32
Recommended action
hh3cCpuRemoved
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.25
Removal of a non-default CPU
Error
Minor
N/A
ON
This notification is generated when a non-default CPU subcard is removed from the device.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
1.3.6.1.4.1.25506.8.35.18.4.10.1.1 (hh3cLswCpuIndex)
CPU ID.
Y
Integer32
Recommended action
1.     Verify that the non-default CPU is removed from the device.
¡     If the non-default CPU is removed from the device, no action is required.
¡     If the non-default CPU is not removed from the device, verify that the non-default CPU is installed correctly.
hh3cCpuFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.26
Failure or startup of a non-default CPU
Error
Major
1.3.6.1.4.1.25506.8.35.12.1.27(hh3cCpuNormal)
ON
This notification is generated when a non-default CPU is starting up or a fault occurs on it.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
CPU ID.
Y
Integer32
Recommended action
1.     Verify that the non-default CPU is installed correctly.
hh3cCpuNormal
Basic information
OID
Event
Severity
Default status
Initialization completion of a non-default CPU
Recovery
N/A
N/A
ON
This notification is generated when a non-default CPU completes initialization.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
CPU ID.
Y
Integer32
Recommended action
hh3cPowerIncompatible
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.28
Incompatibility of a power supply with the device
Error
Major
ON
This notification is generated when a power supply is not compatible with the device.
Status control
Objects
OID (object name)
Index
Value range
Power supply ID.
Y
Integer32
Recommended action
hh3cCpuUsageSevereNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.29
Severe CPU usage alarm
Error
Major
1.3.6.1.4.1.25506.8.35.12.1.30(hh3cCpuUsageSevereRecoverNotification)
ON
This notification is generated when the CPU usage increases to or above the hh3cLswCpuUsageSevereThreshold.  This notification is sent at intervals of 60 seconds until the alarm is cleared.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
CPU ID.
Y
Integer32
1.3.6.1.4.1.25506.8.35.18.4.10.1.3
(hh3cLswCpuRatio)
CPU usage.
N
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.10.1.11
(hh3cLswCpuUsageMinorThreshold)
Minor CPU usage threshold.
N
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.10.1.12
(hh3cLswCpuUsageSevereThreshold)
Severe CPU usage threshold.
N
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.10.1.13
(hh3cLswCpuUsageRecoverThreshold)
CPU usage recovery threshold.
N
Unsigned32
(hh3csLswTrapCpuCoreInfo)
CPU core usage (top1).
N
SnmpAdminString
(hh3cLswCpuCoreUsage-top1)
CPU core usage (top2).
N
SnmpAdminString
(hh3cLswCpuCoreUsage-top2)
CPU core usage (top3).
N
SnmpAdminString
(hh3cLswCpuCoreUsage-top3)
CPU core usage (top4).
N
SnmpAdminString
(hh3cLswCpuCoreUsage-top4)
CPU core usage (top5).
N
SnmpAdminString
(hh3cLswCpuCoreUsage-top5)
1.3.6.1.4.1.25506.8.35.12.2.2
(hh3csLswTrapProcessCpuInfo)
Process usage (top1).
N
SnmpAdminString
(hh3cLswProcessCpuRatio -top1)
Process usage (top2).
N
SnmpAdminString
(hh3cLswProcessCpuRatio -top2)
Process usage (top3).
N
SnmpAdminString
(hh3cLswProcessCpuRatio-top3)
Process usage (top4).
N
SnmpAdminString
(hh3cLswProcessCpuRatio -top4)
Process usage (top5).
N
SnmpAdminString
(hh3cLswProcessCpuRatio -top5)
Recommended action
Basic information
OID
Event
Severity
Default status
Clearance of a severe CPU usage alarm
Recovery
N/A
N/A
ON
This notification is generated when the CPU usage decreases to or below the hh3cLswCpuUsageSevereThreshold.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
CPU ID.
Y
Integer32
(hh3cLswCpuRatio)
CPU usage.
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
Recommended action
hh3cCpuUsageMinorNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.31
Minor CPU usage alarm
Error
Warning
1.3.6.1.4.1.25506.8.35.12.1.32(hh3cCpuUsageMinorRecoverNotification)
ON
This notification is generated when the CPU usage increases to or above the hh3cLswCpuUsageMinorThreshold. This notification is sent at intervals of 300 seconds until the alarm is cleared.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
CPU ID.
Y
Integer32
(hh3cLswCpuRatio)
CPU usage.
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
Recommended action
Potential risks exist. It is necessary to assess whether to take appropriate measures.
Basic information
OID
Event
Severity
Default status
Minor CPU usage alarm clearance
Recovery
N/A
N/A
ON
This notification is generated when the CPU usage decreases to or below the hh3cLswCpuUsageMinorThreshold.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
CPU ID.
Y
Integer32
(hh3cLswCpuRatio)
CPU usage.
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
Recommended action
hh3cMemoryUsageEarlyWarningNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.33
Memory usage early warning alarm
Informational
N/A
1.3.6.1.4.1.25506.8.35.12.1.34(hh3cMemoryUsageEarlyWarningRecoverNotification)
ON
This notification is generated when the amount of free memory decreases to or below the hh3cMemoryUsageEarlyWarningThreshold. This notification is sent at intervals of 1 hours until the alarm is cleared or a higher severity alarm is generated.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
CPU ID.
Y
Integer32
1.3.6.1.4.1.25506.8.35.18.4.10.1.8
(hh3cLswCpuMemory)
Total memory size.
N
CounterBasedGauge64
1.3.6.1.4.1.25506.8.35.18.4.10.1.14
(hh3cLswCpuMemoryFree)
Free memory size.
N
CounterBasedGauge64
1.3.6.1.4.1.25506.8.35.18.4.10.1.15
(hh3cLswCpuMemoryFreeRadio)
Free memory ratio.
N
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.10.1.16
(hh3cLswCpuMemoryHighTotal)
Total high memory size
N
CounterBasedGauge64
1.3.6.1.4.1.25506.8.35.18.4.10.1.17
(hh3cLswCpuMemoryHighFree)
Free high memory size.
N
CounterBasedGauge64
1.3.6.1.4.1.25506.8.35.18.4.10.1.18
(hh3cLswCpuMemoryLowTotal)
Total low memory size.
N
CounterBasedGauge64
1.3.6.1.4.1.25506.8.35.18.4.10.1.19
(hh3cLswCpuMemoryLowFree)
Free low memory size.
N
CounterBasedGauge64
1.3.6.1.4.1.25506.8.35.18.4.10.1.26
(hh3cLswCpuMemorySecureThreshold)
Sufficient memory threshold.
N
Unsigned32
1 to 100, in percentage
1.3.6.1.4.1.25506.8.35.18.4.10.1.27
(hh3cLswCpuMemoryEarlyWarningThreshold)
Early-warning memory threshold.
N
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.10.1.28
(hh3cLswCpuMemoryNormalThreshold)
Normal state memory threshold.
N
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.10.1.29
(hh3cLswCpuMemoryMinorThreshold)
Minor memory threshold.
N
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.10.1.30
(hh3cLswCpuMemorySevereThreshold)
Severe memory threshold.
N
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.10.1.31
(hh3cLswCpuMemoryCriticalThreshold)
Critical memory threshold.
N
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.10.1.32
(hh3cLswCpuMemoryCurrentState)
Current memory state.
N
INTEGER
secure(1), earlywarning(2),
normal(3), minor(4), severe(5), critical(6)
1.3.6.1.4.1.25506.8.35.18.4.10.1.33
(hh3cLswCpuMemoryUsageThreshold)
Memory usage threshold.
N
CounterBasedGauge64
(hh3csLswTrapProcessMemoryInfo)
N
SnmpAdminString
(hh3cLswProcessMemoryUsed-top1)
N
SnmpAdminString
(hh3cLswProcessMemoryUsed-top2)
N
SnmpAdminString
(hh3cLswProcessMemoryUsed-top3)
N
SnmpAdminString
(hh3cLswProcessMemoryUsed-top4)
N
SnmpAdminString
(hh3cLswProcessMemoryUsed-top5)
(hh3csLswTrapSlubInfo)
Slub information (top 1).
N
SnmpAdminString
(hh3cLswSlubInfoUsed-top1)
Slub information (top 2).
N
SnmpAdminString
(hh3cLswSlubInfoUsed-top2)
Slub information (top 3).
N
SnmpAdminString
(hh3cLswSlubInfoUsed-top3)
Slub information (top 4).
N
SnmpAdminString
(hh3cLswSlubInfoUsed-top4)
Slub information (top 5).
N
SnmpAdminString
(hh3cLswSlubInfoUsed-top5)
Recommended action
Potentical risks exist. It is necessary to assess whether to take appropriate measures.
Basic information
OID
Event
Severity
Default status
Memory usage early warning alarm clearance
Recovery
N/A
N/A
ON
This notification is generated when the amount of free memory usage increases to or above the hh3cMemoryUsageSecureThreshold.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
CPU ID.
Y
Integer32
(hh3cLswCpuMemory)
Total memory size.
N
CounterBasedGauge64
Free memory size.
N
CounterBasedGauge64
Free memory ratio.
N
Unsigned32
Total high memory size.
N
CounterBasedGauge64
N
CounterBasedGauge64
N
CounterBasedGauge64
N
CounterBasedGauge64
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
INTEGER
secure(1), earlywarning(2), normal(3), minor(4), severe(5), critical(6)
N
CounterBasedGauge64
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
Recommended action
hh3cMemoryUsageMinorNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.35
Minor memory usage alarm
Error
Minor
1.3.6.1.4.1.25506.8.35.12.1.36(hh3cMemoryUsageMinorRecoverNotification)
ON
This notification is generated when the amount of free memory decreases to or below the hh3cLswCpuMemoryMinorThreshold.  The notification is sent at intervals of 12 hours until the alarm condition is cleared or a higher severity alarm is generated.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
CPU ID.
Y
Integer32
(hh3cLswCpuMemory)
Total memory size.
N
CounterBasedGauge64
Free memory size.
N
CounterBasedGauge64
Free memory ratio.
N
Unsigned32
N
CounterBasedGauge64
N
CounterBasedGauge64
N
CounterBasedGauge64
N
CounterBasedGauge64
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
INTEGER
N
CounterBasedGauge64
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
Recommended action
The issue needs to be reviewed to determine whether action is necessary.
Basic information
OID
Event
Severity
Default status
Minor memory usage notification clearance
Recovery
N/A
N/A
ON
This notification is generated when the amount of free memory usage increases to or above the hh3cLswCpuMemoryNormalThreshold.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
CPU ID.
Y
Integer32
(hh3cLswCpuMemory)
Total memory size.
N
CounterBasedGauge64
Free memory size.
N
CounterBasedGauge64
Free memory ratio.
N
Unsigned32
N
CounterBasedGauge64
N
CounterBasedGauge64
N
CounterBasedGauge64
N
CounterBasedGauge64
N
CounterBasedGauge64
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
INTEGER
N
CounterBasedGauge64
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
Recommended action
hh3cMemoryUsageSevereNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.37
Severe memory usage alarm
Error
Major
1.3.6.1.4.1.25506.8.35.12.1.38(hh3cMemoryUsageSevereRecoverNotification)
ON
This notification is generated when the amount of free memory decreases to or below the hh3cMemoryUsageSevereThreshold.  This notification is sent at intervals of 3 hours until the alarm is cleared or a higher severity alarm is generated.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
CPU ID.
Y
Integer32
(hh3cLswCpuMemory)
Total memory size.
N
CounterBasedGauge64
Free memory size.
N
CounterBasedGauge64
Free memory ratio.
N
Unsigned32
N
CounterBasedGauge64
N
CounterBasedGauge64
N
CounterBasedGauge64
N
CounterBasedGauge64
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
INTEGER
N
CounterBasedGauge64
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
Recommended action
The issue has significant impact on services. Immediate action is required.
Basic information
OID
Event
Severity
Default status
Severe memory usage alarm clearance
Recovery
N/A
N/A
ON
This notification is generated when the amount of free memory usage increases to or above the hh3cMemoryUsageMinorThreshold.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
CPU ID.
Y
Integer32
(hh3cLswCpuMemory)
Total memory size.
N
CounterBasedGauge64
Free memory size.
N
CounterBasedGauge64
Free memory ratio.
N
Unsigned32
N
CounterBasedGauge64
N
CounterBasedGauge64
N
CounterBasedGauge64
N
CounterBasedGauge64
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
INTEGER
N
CounterBasedGauge64
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
Recommended action
hh3cMemoryUsageCriticalNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.1.39
Critical memory usage alarm
Error
Critical
1.3.6.1.4.1.25506.8.35.12.1.40(hh3cMemoryUsageCriticalRecoverNotification)
ON
This notification is generated when the amount of free memory decreases to or below the hh3cMemoryUsageCriticalThreshold. This notification is sent at intervals of 1 hours until the alarm is cleared.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
CPU ID.
Y
Integer32
(hh3cLswCpuMemory)
Total memory size.
N
CounterBasedGauge64
Free memory size.
N
CounterBasedGauge64
Free memory ratio.
N
Unsigned32
N
CounterBasedGauge64
N
CounterBasedGauge64
N
CounterBasedGauge64
N
CounterBasedGauge64
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
INTEGER
N
CounterBasedGauge64
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
Recommended action
The issue puts the system assets and services at risk. Immediate action is required.
Basic information
OID
Event
Severity
Default status
Critical memory usage alarm clearance
Recovery
N/A
N/A
ON
This notification is generated when the amount of free memory usage increases to or above the hh3cMemoryUsageSevereThreshold.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
CPU ID.
Y
Integer32
(hh3cLswCpuMemory)
Total memory size.
N
CounterBasedGauge64
Free memory size.
N
CounterBasedGauge64
Free memory ratio.
N
Unsigned32
N
CounterBasedGauge64
N
CounterBasedGauge64
N
CounterBasedGauge64
N
CounterBasedGauge64
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
Unsigned32
N
INTEGER
N
CounterBasedGauge64
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
Recommended action
hh3cCoreUsageNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.3.0.1
CPU core usage alarm
Error
Warning
1.3.6.1.4.1.25506.8.35.12.3.0.10(hh3cCoreUsageSevereRecoveryNotification)
ON
This notification is generated when the amount of core usage increases to or above the hh3cLswCoreThreshold.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
CPU ID.
Y
Integer32
1.3.6.1.4.1.25506.8.35.18.4.15.1.1 (hh3cLswCoreIndex)
CPU core ID.
Y
Integer32
(hh3cLswCoreTrapUsage)
CPU core usage in the most recent 30 minutes.
N
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.15.1.5 (hh3cLswCoreThreshold)
CPU core usage threshold.
N
Unsigned32
1.3.6.1.4.1.25506.8.35.12.2.5 (hh3cLswTrapCpuUsage)
CPU usage during the most recent 5 seconds, 1 minute, 5 minutes.
N
SnmpAdminString
1.3.6.1.4.1.25506.8.35.12.2.6 (hh3cLswTrapCoreProcessInfo)
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
N
SnmpAdminString
1.3.6.1.4.1.25506.8.35.18.4.15.1.7 (hh3cLswCoreMinorThreshold)
Minor CPU core usage threshold.
N
Unsigned32
1.3.6.1.4.1.25506.8.35.18.4.15.1.8 (hh3cLswCoreRecoveryThreshold)
CPU core normal state threshold.
N
Unsigned32
Recommended action
hh3cBoardPowerNotEnough
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.3.0.2
Power insufficiency for a card
Error
Major
N/A
ON
This notification is generated when the power provided for a card is not enough.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
 (hh3cBoardAvailablePower)
Available power.
N
Integer32
 (hh3cBoardRequiredPower)
Required power.
N
Integer32
Recommended action
Replace the power supplies with high-power ones.
hh3cAlarmInPortIn
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.35.12.3.0.3
Electrical level state received on an alarm input port inconsistent with that configured for the port.
Informational
N/A
1.3.6.1.4.1.25506.8.35.12.3.0.4(hh3cAlarmInPortRecover)
ON
This notification is generated when the electrical level state received on an alarm input port is inconsistent with that configured for the port.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
1.3.6.1.4.1.25506.8.35.12.2.10 (hh3cLswAlarmInPortInNum)
Alarm input port number.
N
Integer32
Recommended action
Basic information
OID
Event
Severity
Default status
Electrical level state received on an alarm input port become consistent with that configured for the port
Recovery
N/A
N/A
ON
This notification is generated when the electrical level state received on an alarm input port becomes consistent with that configured for the port.
Status control
Objects
OID (object name)
Index
Value range
Y
Integer32
Slot ID.
Y
Integer32
N
Integer32
Recommended action
