IPS Signature V7-IPS-1.0.256
Release time:2023-08-22
HomeSupportResource CenterSecuritySignature Database ServicesSignature Database ServicesSoftware DownloadSignature Database Services
Download
Title Size Downloads
V7-IPS-1.0.256.dat 12.62 MB
Version number
V7-IPS-1.0.256
MD5 number
f4cf79536d51d4019f8656f2ecded052
Update time
2023-08-21
Update attack list
Key new rules:
49792   Wanzhong_CMS_SQL_Injection_Vulnerability[2]
---- Category: Vulnerability
---- Description: There is an SQL injection vulnerability in some versions of Peoples CMS,
---- which is due to the problem of username parameter, and the attacker may use this vulnerability
---- to deceive identity, tamper with existing data, leak all data on the system, and destroy data.
49807  eGroupWare_spellchecker.php_Remote_Command_Execution_Vulnerability[2]
---- Description: EGroupWare is a multi user, web based work piece suite developed on
---- a customized set of PHP based APIs, with a command execution vulnerability in the
---- spellchecker.php file.
49809  WiseGiga_Nas_down_data_Path_Traversal_Vulnerability[2]
---- Description: WISEGIGA NAS down_ Data.php has an arbitrary file download vulnerability
---- due to/down_ The filename parameter on the data.php page is not filtered strictly,
---- resulting in the ability to read system sensitive files.
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the IPS rules library file of this version, 20074 predefined rules can be generated in "Intrusion Prevention System"
[4] The device memory is less than or equal to 2GB. After loading the IPS rules library file of this version, 3126 predefined rules can be generated in "Intrusion Prevention System"
  • Become a Partner
  • Partner Resources
