17-User Access and Authentication
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesMIB CompanionH3C SR8800-F Routers MIB Reference-R838x-6W10017-User Access and Authentication
08-HH3C-USER-MIB
08-HH3C-USER-MIB 108.53 KB
HH3C-USER-MIB
About this MIB
Use this MIB to manage local users.
MIB file name
hh3c-user.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cUser(12)
Scalar objects
hh3cUserIndexIndicator (1.3.6.1.4.1.25506.2.12.1.5)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Standard MIB values.
Index to be used for the next local user.
As per the MIB.
hh3cUserIPAddressType (1.3.6.1.4.1.25506.2.12.3.1.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
InetAddressType
User IP address type.
As per the MIB.
hh3cUserIPAddress (1.3.6.1.4.1.25506.2.12.3.1.1.2)
Object (OID)
Access
Value range
Implementation
InetAddress
User IP address.
As per the MIB.
hh3cUserGroupUsedNum (1.3.6.1.4.1.25506.2.12.4.1.1)
Object (OID)
Access
Value range
Implementation
Unsigned32
Number of existing user groups.
As per the MIB.
hh3cUserGroupNumThreshold (1.3.6.1.4.1.25506.2.12.4.1.2)
Object (OID)
Access
Value range
Implementation
Integer32
User group quantity threshold.
As per the MIB.
Tabular objects
hh3cUserInfoTable
About this table
Use this table to configure or obtain basic information of a local user.
Support for operations
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table index is hh3cUserIndex.
Object (OID)
Access
Value range
Implementation
hh3cUserName (1.3.6.1.4.1.25506.2.12.1.1.1.1)
read-create
DisplayString
OCTET STRING (1..255)
Name of a local user.
The username cannot contain any of the following characters: backslash (\), forward slash (/), colon (:), asterisk (*), question mark (?), quotation mark ("), left angle bracket (<), right angle bracket (>), or vertical bar (|). It cannot be a, al, or all and cannot begin with or end with at sign (@).
A username that contains a domain name is in the format of localusername@domain. The localusername part in the username cannot contain any of the following characters: backslash (\), forward slash (/), colon (:), asterisk (*), question mark (?), quotation mark ("), left angle bracket (<), right angle bracket (>), or vertical bar (|).. The maximum length of this part varies by device model.
The username of each local user is unique. You cannot edit an existing username.
hh3cUserPassword (1.3.6.1.4.1.25506.2.12.1.1.1.2)
read-create
DisplayString
OCTET STRING (0..255)
Password of the local user.
When read, this object returns a zero-length string.
hh3cAuthMode (1.3.6.1.4.1.25506.2.12.1.1.1.3)
read-create
Integer32
Encrypting type of the user password.
Value range: 0 or 7.
hh3cUserState (1.3.6.1.4.1.25506.2.12.1.1.1.5)
read-create
INTEGER
active(0),
block(1)
Status of the local user.
As per the MIB.
hh3cUserInfoRowStatus (1.3.6.1.4.1.25506.2.12.1.1.1.6)
read-create
RowStatus
active(1),
createAndGo(4),
destroy(6)
Row status.
As per the MIB.
hh3cUserIndex (1.3.6.1.4.1.25506.2.12.1.1.1.7)
not-accessible
Integer32
Integer32 (1..2147483646)
Index of the local user.
Value range: 1 to 1024.
hh3cUserAttributeTable
About this table
This table contains attributes of a local user.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cAccessLimit (1.3.6.1.4.1.25506.2.12.1.2.1.1)
read-write
Integer32
Maximum number of concurrent users that can use a username to access the device.
Default: No limit is placed on the maximum number of concurrent users that can use a username to access the device.
Value range: 0 to 1024.
hh3cIdleCut (1.3.6.1.4.1.25506.2.12.1.2.1.2)
read-write
Integer32
Idle timeout period, in seconds.
This object will round the specified value to the nearest multiple of 60.
hh3cIPAddress (1.3.6.1.4.1.25506.2.12.1.2.1.3)
read-write
IpAddress
IP address of a user.
Default: 0.0.0.0.
hh3cNasIPAddress (1.3.6.1.4.1.25506.2.12.1.2.1.4)
read-write
IpAddress
IP address of the NAS for the user.
Not supported.
hh3cSlotNum (1.3.6.1.4.1.25506.2.12.1.2.1.5)
read-write
Integer32
Slot number of the user.
Not supported.
hh3cSubSlotNum (1.3.6.1.4.1.25506.2.12.1.2.1.6)
read-write
Integer32
Subslot number of the user.
Not supported.
hh3cPortNum (1.3.6.1.4.1.25506.2.12.1.2.1.7)
read-write
Integer32
Port number of the user.
Not supported.
hh3cMacAddress (1.3.6.1.4.1.25506.2.12.1.2.1.8)
read-write
MacAddress
OCTET STRING (6)
MAC address of the user.
As per the MIB.
hh3cVlan (1.3.6.1.4.1.25506.2.12.1.2.1.9)
read-write
Integer32
Integer32 (0..4094)
ID of the VLAN to which the user belongs.
As per the MIB.
hh3cFtpService (1.3.6.1.4.1.25506.2.12.1.2.1.10)
read-write
ServiceType
enable(1),
disable(2)
FTP service.
Not supported.
hh3cFtpDirectory (1.3.6.1.4.1.25506.2.12.1.2.1.11)
read-write
OCTET STRING
FTP directory.
Not supported.
hh3cLanAccessService (1.3.6.1.4.1.25506.2.12.1.2.1.12)
read-write
ServiceType
enable(1),
disable(2)
LAN access service.
As per the MIB.
hh3cSshService (1.3.6.1.4.1.25506.2.12.1.2.1.13)
read-write
ServiceType
enable(1),
disable(2)
SSH service.
Not supported.
hh3cTelnetService (1.3.6.1.4.1.25506.2.12.1.2.1.14)
read-write
ServiceType
enable(1),
disable(2)
Telnet service.
Not supported.
hh3cTerminalService (1.3.6.1.4.1.25506.2.12.1.2.1.15)
read-write
ServiceType
enable(1),
disable(2)
Terminal service.
Not supported.
hh3cExpirationDate (1.3.6.1.4.1.25506.2.12.1.2.1.16)
read-write
DateAndTime
OCTET STRING (8)
Expired date of the user.
Not supported.
hh3cUserGroup (1.3.6.1.4.1.25506.2.12.1.2.1.17)
read-write
DisplayString
User group of the user.
A user group name cannot exceed 32 characters.
hh3cPortalService (1.3.6.1.4.1.25506.2.12.1.2.1.18)
read-write
ServiceType
enable(1),
disable(2)
Portal service.
As per the MIB.
hh3cPPPService (1.3.6.1.4.1.25506.2.12.1.2.1.19)
read-write
ServiceType
enable(1),
disable(2)
PPP service.
As per the MIB.
hh3cHttpService (1.3.6.1.4.1.25506.2.12.1.2.1.20)
read-write
ServiceType
enable(1),
disable(2)
HTTP service.
Not supported
hh3cHttpsService (1.3.6.1.4.1.25506.2.12.1.2.1.21)
read-write
ServiceType
enable(1),
disable(2)
HTTPS service.
Not supported
hh3cUserIfIndex (1.3.6.1.4.1.25506.2.12.1.2.1.22)
read-write
Integer32
Index of the user's access interface.
As per the MIB.
hh3cUserRoleTable
About this table
Use this table to configure or obtain basis information of a local user.
CreateSupported
Edit/ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cUserIndex and hh3cUserRole.
Object (OID)
Access
Value range
Implementation
hh3cUserRole (1.3.6.1.4.1.25506.2.12.1.6.1.1)
not-accessible
DisplayString
OCTET STRING  (1..63))
User role.
In MDCs, the default user role is mdc-operator.
In non-MDCs, the default user role is network-operator.
hh3cUserRoleStatus (1.3.6.1.4.1.25506.2.12.1.6.1.2)
read-create
RowStatus
active(1),
createAndGo(4),
destroy(6)
Row status.
You must specify hh3cUserIndex when you create a local user.
hh3cUserGroupInfoTable
About this table
Use this table to configure or obtain basic information of a user group.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table index is hh3cUserGroupName.
Object (OID)
Access
Value range
Implementation
hh3cUserGroupName (1.3.6.1.4.1.25506.2.12.2.1.1.1)
not-accessible
DisplayString
Name of a user group.
As per the MIB.
hh3cUserGroupInfoRowStatus (1.3.6.1.4.1.25506.2.12.2.1.1.2)
read-create
RowStatus
active(1),
createAndGo(4),
destroy(6)
Row status.
As per the MIB.
Notifications
hh3cUserBlacklistLock
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.12.3.1.0.1
A user was locked to the password control blacklist.
Informational
Warning
N/A (N/A)
OFF
Notification triggers
This notification is generated when the number of login failures of a user reaches the upper limit. The user is added to the password control blacklist.
System impact
The system may be under login attacks.
Status control
ON
CLI: Use the snmp-agent trap enable password-control user-lock command.
OFF
CLI: Use the undo snmp-agent trap enable password-control user-lock command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.12.1.1.1.1 (hh3cUserName)
Username.
hh3cUserIndex
DisplayString
1.3.6.1.4.1.25506.2.12.3.1.1.1 (hh3cUserIPAddressType)
Address type of the user.
hh3cUserIndex
INTEGER
unknown(0),, ipv4(1), , ipv6(2)
1.3.6.1.4.1.25506.2.12.3.1.1.2 (hh3cUserIPAddress)
IP address of the user.
hh3cUserIndex
InetAddress
OCTET STRING(0..255)
Recommended action
Use the display password-control blacklist command to view users in the password control blacklist and analyze whether login user attacks exist. If login user attacks exist, contact the administrator.
hh3cUserBlacklistUnlock
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.12.3.1.0.2
A user was unlocked from the password control blacklist.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when a user blacklisted due to login failures is removed from the blacklist because the administrator executed the reset password-control blacklist command or the user lockout timer expires.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable password-control user-unlock command.
OFF
CLI: Use the undo snmp-agent trap enable password-control user-unlock command.
Object
OID (object name)
Index
Value range
Username.
hh3cUserIndex
DisplayString
OCTET STRING (1.. 255)
User address type.
hh3cUserIndex
INTEGER
User IP address.
hh3cUserIndex
InetAddress
Recommended action
No action is required.
hh3cUserGroupThresholdAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.12.4.0.1
Maximum number of user groups already reached.
Error
Major
1.3.6.1.4.1.25506.2.12.4.0.2 (hh3cUserGroupThresholdResume)
OFF
This notification is generated when the number of user groups configured on the device reaches the upper limit.
System impact
New user groups cannot be created.
Status control
ON
CLI: Use the snmp-agent trap enable user-group max-count-threshold command.
OFF
CLI: Use the undo snmp-agent trap enable user-group max-count-threshold command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.12.4.1.1 (hh3cUserGroupUsedNum)
Current number of user groups.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.12.4.1.2 (hh3cUserGroupNumThreshold)
Maximum number of user groups.
N/A
Integer32
Recommended action
1.Use the display user-group command in any view to view local user group information and analyze whether unused user groups exist.
  - If unused user groups exist, proceed to step 2.
  - If no unused user group exists, proceed to step 3.
2.Use the undo user-group command in system view to deleted unused user groups.
3.Collect alarm, log, and configuration information, and contact Technical Support.
Basic information
OID
Event
Severity
Default status
Number of user groups dropped to 90% of the maximum number.
Recovery
Warning
N/A (N/A)
OFF
This notification is generated when the number of user groups configured on the device drops below 90% of the maximum value.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
Unsigned32
N/A
Integer32
Recommended action
