17-User Access and Authentication
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesMIB CompanionH3C SR8800-F Routers MIB Reference-R838x-6W10017-User Access and Authentication
07-HH3C-RADIUS-MIB
07-HH3C-RADIUS-MIB 192.37 KB
HH3C-RADIUS-MIB
About this MIB
Use this MIB to obtain and configure RADIUS server settings.
MIB file name
hh3c-radius.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cRadius(13)
Scalar objects
hh3cRadiusAuthErrThreshold (1.3.6.1.4.1.25506.2.13.1.3.1)
Object (OID)
Access
Value range
Implementation
read-write
Unsigned32
Unsigned32 (1..100)
Authentication failure alarm threshold.
As per the MIB.
hh3cRadiusStatAccAck (1.3.6.1.4.1.25506.2.13.6.2)
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Standard MIB values.
Number of RADIUS accounting responses received from the RADIUS server.
As per the MIB.
hh3cRadiusStatLogoutReq (1.3.6.1.4.1.25506.2.13.6.3)
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Number of logout requests sent to the RADIUS server.
As per the MIB.
hh3cRadiusStatLogoutAck (1.3.6.1.4.1.25506.2.13.6.4)
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Number of logout responses received from the RADIUS server.
As per the MIB.
hh3cRadiusAccCacheMaxPackets (1.3.6.1.4.1.25506.2.13.8.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
Integer32
256..2147483647
Maximum number of buffered accounting packets.
As per the MIB.
hh3cRadiusAccCacheUpperValue (1.3.6.1.4.1.25506.2.13.8.1.2)
Object (OID)
Access
Value range
Implementation
Integer32
1..100
Upper threshold for accounting packet buffering, in percentage.
As per the MIB.
hh3cRadiusAccCacheLowerValue (1.3.6.1.4.1.25506.2.13.8.1.3)
Object (OID)
Access
Value range
Implementation
Integer32
0..99
Lower threshold for accounting packet buffering, in percentage.
As per the MIB.
hh3cRadiusAccCacheMemoryUsage (1.3.6.1.4.1.25506.2.13.8.1.4)
Object (OID)
Access
Value range
Implementation
Integer32
0..100
Current memory usage, in percentage.
As per the MIB.
hh3cRadiusAccCachePackets (1.3.6.1.4.1.25506.2.13.8.1.5)
Object (OID)
Access
Value range
Implementation
Integer32
256..2147483647
Current number of buffered packets.
As per the MIB.
Tabular objects
hh3cRdInfoTable
About this table
Use this table to configure or obtain RADIUS authentication scheme settings. Each RADIUS scheme contains a primary authentication server, a secondary authentication server, and other settings.
Support for operations
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table index is hh3cRdGroupName.
Object (OID)
Access
Value range
Implementation
hh3cRdGroupName (1.3.6.1.4.1.25506.2.13.1.1.1.1)
read-only
DisplayString
OCTET STRING (1..32)
Name of a RADIUS scheme.
As per the MIB.
hh3cRdPrimUdpPort (1.3.6.1.4.1.25506.2.13.1.1.1.3)
read-create
Integer32
Port number of the primary authentication server.
Value range: 1 to 65535.
hh3cRdPrimState (1.3.6.1.4.1.25506.2.13.1.1.1.4)
read-create
INTEGER
active(1),
block(2)
Status of the primary authentication server.
As per the MIB.
hh3cRdSecUdpPort (1.3.6.1.4.1.25506.2.13.1.1.1.6)
read-create
Integer32
Port number of the secondary authentication server.
hh3cRdSecState (1.3.6.1.4.1.25506.2.13.1.1.1.7)
read-create
INTEGER
active(1),
block(2)
Status of the secondary authentication server.
As per the MIB.
hh3cRdKey (1.3.6.1.4.1.25506.2.13.1.1.1.8)
read-create
DisplayString
Shared key for communication with the authentication server.
The shared key is a string of 0 to 64 characters.
When read, this object returns a zero-length string.
In dayou OEM version, the shared key string must be nine characters long or longer and must contain digits, uppercase letters, lowercase letters, and special characters.
hh3cRdRetry (1.3.6.1.4.1.25506.2.13.1.1.1.9)
read-create
Integer32
Maximum number of attempts for transmitting an authentication packet to the authentication server.
Value range: 1 to 20.
hh3cRdTimeout (1.3.6.1.4.1.25506.2.13.1.1.1.10)
read-create
Integer32
Response timeout time for the RADIUS authentication server, in seconds.
Value range: 1 to 10.
hh3cRdPrimAuthIpAddrType (1.3.6.1.4.1.25506.2.13.1.1.1.11)
read-create
InetAddressType
Type of the IP address for the primary authentication server.
You must specify hh3cRdPrimAuthIpAddrType and hh3cRdPrimAuthIpAddr in pairs in an SNMP request.
hh3cRdPrimAuthIpAddr (1.3.6.1.4.1.25506.2.13.1.1.1.12)
read-create
InetAddress
OCTET STRING (0..255)
IP address of the primary authentication server.
As per the MIB.
hh3cRdSecAuthIpAddrType (1.3.6.1.4.1.25506.2.13.1.1.1.13)
read-create
InetAddressType
Type of the IP address for the secondary authentication server.
You must specify hh3cRdSecAuthIpAddrType and hh3cRdSecAuthIpAddr in pairs in an SNMP request.
hh3cRdSecAuthIpAddr (1.3.6.1.4.1.25506.2.13.1.1.1.14)
read-create
InetAddress
IP address of the secondary authentication server.
As per the MIB.
hh3cRdServerType (1.3.6.1.4.1.25506.2.13.1.1.1.15)
read-create
INTEGER
standard(1),
iphotel(2),
portal(3),
extended(4)
Service type of the RADIUS authentication server.
Only standard RADIUS attributes (value 1) are supported.
hh3cRdQuietTime (1.3.6.1.4.1.25506.2.13.1.1.1.16)
read-create
Integer32
Integer32 (0..255)
Quiet time for the authentication server to restore to the active status, in minutes.
Value range: 0 to 255.
hh3cRdUserNameFormat (1.3.6.1.4.1.25506.2.13.1.1.1.17)
read-create
INTEGER
withoutdomain(1),
withdomain(2) ,
keeporignal(3)
Format of usernames sent to the RADIUS server.
As per the MIB.
hh3cRdRowStatus (1.3.6.1.4.1.25506.2.13.1.1.1.18)
read-create
RowStatus
Row status.
The following values are supported:
active(1).
createAndGo(4).
destroy(6).
hh3cRdSecKey (1.3.6.1.4.1.25506.2.13.1.1.1.19)
read-create
DisplayString
OCTET STRING (0..64)
Shared key for communication with the secondary authentication server.
hh3cRdPrimVpnName (1.3.6.1.4.1.25506.2.13.1.1.1.20)
read-create
DisplayString
OCTET STRING (0..31)
Name of the VPN to which the primary authentication server belongs.
As per the MIB.
hh3cRdSecVpnName (1.3.6.1.4.1.25506.2.13.1.1.1.21)
read-create
DisplayString
Name of the VPN to which the secondary authentication server belongs.
As per the MIB.
hh3cRdAuthNasIpAddrType (1.3.6.1.4.1.25506.2.13.1.1.1.22)
read-create
InetAddressType
Type of the NAS IP addresses for RADIUS authentication packets sent to the authentication server.
Not supported.
hh3cRdAuthNasIpAddr (1.3.6.1.4.1.25506.2.13.1.1.1.23)
read-create
IpAddress
NAS IPv4 address.
As per the MIB.
hh3cRdAuthNasIpv6Addr
(1.3.6.1.4.1.25506.2.13.1.1.1.24)
read-create
Ipv6Address
NAS IPv6 address.
As per the MIB.
hh3cRdAccInfoTable
About this table
Use this table to configure or obtain RADIUS accounting scheme settings. Each RADIUS scheme contains a primary accounting server, a secondary accounting server, and other settings.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table index is hh3cRdAccGroupName.
Object (OID)
Access
Value range
Implementation
hh3cRdAccGroupName (1.3.6.1.4.1.25506.2.13.1.2.1.1)
read-only
DisplayString
Name of a RADIUS accounting scheme.
As per the MIB.
hh3cRdPrimAccIpAddrType (1.3.6.1.4.1.25506.2.13.1.2.1.2)
read-create
InetAddressType
Type of the IP address for the primary accounting server.
You must specify hh3cRdPrimAccIpAddrType and hh3cRdPrimAccIpAddr in pairs in an SNMP request.
hh3cRdPrimAccIpAddr (1.3.6.1.4.1.25506.2.13.1.2.1.3)
read-create
InetAddress
IP address of the primary accounting server.
As per the MIB.
hh3cRdPrimAccUdpPort (1.3.6.1.4.1.25506.2.13.1.2.1.4)
read-create
Integer32
Port number of the primary accounting server.
hh3cRdPrimAccState (1.3.6.1.4.1.25506.2.13.1.2.1.5)
read-create
INTEGER
active(1),
block(2)
Status of the primary accounting server.
As per the MIB.
hh3cRdSecAccIpAddrType (1.3.6.1.4.1.25506.2.13.1.2.1.6)
read-create
InetAddressType
Type of the IP address for the secondary accounting server.
You must specify hh3cRdSecAccIpAddrType and hh3cRdSecAccIpAddr in pairs in an SNMP request.
hh3cRdSecAccIpAddr (1.3.6.1.4.1.25506.2.13.1.2.1.7)
read-create
InetAddress
IP address of the secondary accounting server.
As per the MIB.
hh3cRdSecAccUdpPort (1.3.6.1.4.1.25506.2.13.1.2.1.8)
read-create
Integer32
Port number of the secondary accounting server.
hh3cRdSecAccState (1.3.6.1.4.1.25506.2.13.1.2.1.9)
read-create
INTEGER
active(1),
block(2)
As per the MIB.
hh3cRdAccKey (1.3.6.1.4.1.25506.2.13.1.2.1.10)
read-create
DisplayString
Shared key for communication with the accounting server.
hh3cRdAccRetry (1.3.6.1.4.1.25506.2.13.1.2.1.11)
read-create
Integer32
Maximum number of attempts for transmitting an accounting packet to the accounting server.
hh3cRdAccTimeout (1.3.6.1.4.1.25506.2.13.1.2.1.12)
read-create
Integer32
Response timeout time for the accounting server, in seconds.
hh3cRdAccServerType (1.3.6.1.4.1.25506.2.13.1.2.1.13)
read-create
INTEGER
standard(1),
iphotel(2),
portal(3),
extended(4)
Service type provided by the accounting server.
hh3cRdAccQuietTime (1.3.6.1.4.1.25506.2.13.1.2.1.14)
read-create
Integer32
Integer32 (0..255)
Quiet time for the accounting server to restore to the active status, in minutes.
hh3cRdAccFailureAction (1.3.6.1.4.1.25506.2.13.1.2.1.15)
read-create
INTEGER
ignore (1),
reject(2)
Action to take on accounting failure.
Not supported
hh3cRdAccRealTime (1.3.6.1.4.1.25506.2.13.1.2.1.16)
read-create
Integer32
Integer32 (0..71582)
Interval for sending real-time accounting packets (in minutes by default).
As per the MIB.
hh3cRdAccRealTimeRetry (1.3.6.1.4.1.25506.2.13.1.2.1.17)
read-create
Integer32
Integer32 (1..255)
Maximum number of attempts for transmitting a real-time accounting packet.
As per the MIB.
hh3cRdAccSaveStopPktEnable (1.3.6.1.4.1.25506.2.13.1.2.1.18)
read-create
TruthValue
true(1),
false(2)
Whether to buffer RADIUS stop-accounting requests to which no responses have been received.
Not supported.
hh3cRdAccStopRetry (1.3.6.1.4.1.25506.2.13.1.2.1.19)
read-create
Integer32
Integer32 (10..65535)
Maximum number of transmission attempts for individual RADIUS stop-accounting requests.
Not supported.
hh3cRdAccDataFlowUnit (1.3.6.1.4.1.25506.2.13.1.2.1.20)
read-create
INTEGER
byte(1),
kiloByte(2),
megaByte(3),
gigaByte(4)
Data flow measurement unit for traffic statistics.
As per the MIB.
hh3cRdAccPacketUnit (1.3.6.1.4.1.25506.2.13.1.2.1.21)
read-create
INTEGER
onePacket(1),
kiloPacket (2),
megaPacket (3),
gigaPacket (4)
Packet measurement unit for traffic statistics.
As per the MIB.
hh3cRdAccRowStatus (1.3.6.1.4.1.25506.2.13.1.2.1.22)
read-create
RowStatus
Row status.
active(1).
createAndGo(4).
destroy(6).
hh3cRdAcctOnEnable (1.3.6.1.4.1.25506.2.13.1.2.1.23)
read-create
TruthValue
true(1),
false(2)
Enabling status of the accounting-on feature.
As per the MIB.
hh3cRdAcctOnSendTimes (1.3.6.1.4.1.25506.2.13.1.2.1.24)
read-create
Integer32
Maximum number of accounting-on packet transmission attempts.
As per the MIB.
hh3cRdAcctOnSendInterval (1.3.6.1.4.1.25506.2.13.1.2.1.25)
read-create
Integer32
Interval for retransmitting an accounting-on packet.
As per the MIB.
hh3cRdSecAccKey (1.3.6.1.4.1.25506.2.13.1.2.1.26)
read-create
DisplayString
Shared key for communication with the secondary accounting server.
hh3cRdPrimAccVpnName (1.3.6.1.4.1.25506.2.13.1.2.1.27)
read-create
DisplayString
Name of the VPN to which the primary accounting server belongs.
As per the MIB.
hh3cRdSecAccVpnName
(1.3.6.1.4.1.25506.2.13.1.2.1.28)
read-create
DisplayString
Name of the VPN to which the secondary accounting server belongs.
As per the MIB.
hh3cRdAccNasIpAddrType (1.3.6.1.4.1.25506.2.13.1.2.1.29)
read-create
InetAddressType
Type of the NAS IP addresses for RADIUS accounting packets sent to the RADIUS accounting server.
Not supported.
hh3cRdAccNasIpAddr (1.3.6.1.4.1.25506.2.13.1.2.1.30)
read-create
IpAddress
NAS IPv4 address.
As per the MIB.
hh3cRdAccNasIpv6Addr (1.3.6.1.4.1.25506.2.13.1.2.1.31)
read-create
Ipv6Address
NAS IPv6 address.
As per the MIB.
hh3cRdAccRealTimeUnit
(1.3.6.1.4.1.25506.2.13.1.2.1.32)
read-create
INTEGER
minute(0),
second(1)
Measurement unit for the interval at which real-time accounting packets are sent.
As per the MIB.
hh3cRdAccStopPktTimeResend
(1.3.6.1.4.1.25506.2.13.1.2.1.33)
read-only
Integer32
Interval for resending stop-accounting packets.
Value 0 indicates that this node is not supported.
hh3cRdSecondaryAuthServerTable
About this table
Use this table to configure or obtain secondary RADIUS authentication server settings.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cRdGroupName, hh3cRdSecondaryAuthIpAddrType, hh3cRdSecondaryAuthIpAddr, hh3cRdSecondaryAuthVpnNam, and hh3cRdSecondaryAuthUdpPort.
Object (OID)
Access
Value range
Implementation
hh3cRdSecondaryAuthIpAddrType (1.3.6.1.4.1.25506.2.13.1.4.1.1)
not-accessible
InetAddressType
Type of the IP address for a secondary authentication server.
As per the MIB.
hh3cRdSecondaryAuthIpAddr (1.3.6.1.4.1.25506.2.13.1.4.1.2)
not-accessible
InetAddress
As per the MIB.
hh3cRdSecondaryAuthVpnName (1.3.6.1.4.1.25506.2.13.1.4.1.3)
not-accessible
DisplayString
As per the MIB.
hh3cRdSecondaryAuthUdpPort (1.3.6.1.4.1.25506.2.13.1.4.1.4)
not-accessible
Integer32
Integer32 (1..65535)
As per the MIB.
hh3cRdSecondaryAuthState (1.3.6.1.4.1.25506.2.13.1.4.1.5)
read-create
INTEGER
active(1),
block(2)
As per the MIB.
hh3cRdSecondaryAuthKey (1.3.6.1.4.1.25506.2.13.1.4.1.6)
read-create
DisplayString
hh3cRdSecondaryAuthRowStatus
(1.3.6.1.4.1.25506.2.13.1.4.1.7)
read-create
RowStatus
Row status.
active(1).
createAndGo(4).
destroy(6).
hh3cRdSecondaryAccServerTable
About this table
Use this table to configure or obtain secondary RADIUS accounting server settings.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cRdAccGroupName, hh3cRdSecondaryAccIpAddrType, hh3cRdSecondaryAccIpAddr, hh3cRdSecondaryAccVpnName, and hh3cRdSecondaryAccUdpPort.
Object (OID)
Access
Value range
Implementation
hh3cRdSecondaryAccIpAddrType (1.3.6.1.4.1.25506.2.13.1.5.1.1)
not-accessible
InetAddressType
Type of the IP address for a secondary accounting server.
As per the MIB.
hh3cRdSecondaryAccIpAddr (1.3.6.1.4.1.25506.2.13.1.5.1.2)
not-accessible
InetAddress
As per the MIB.
hh3cRdSecondaryAccVpnName (1.3.6.1.4.1.25506.2.13.1.5.1.3)
not-accessible
DisplayString
As per the MIB.
hh3cRdSecondaryAccUdpPort (1.3.6.1.4.1.25506.2.13.1.5.1.4)
not-accessible
Integer32
As per the MIB.
hh3cRdSecondaryAccState (1.3.6.1.4.1.25506.2.13.1.5.1.5)
read-create
INTEGER
active(1),
block(2)
Status of the secondary accounting server.
As per the MIB.
hh3cRdSecondaryAccKey (1.3.6.1.4.1.25506.2.13.1.5.1.6)
read-create
DisplayString
hh3cRdSecondaryAccRowStatus
(1.3.6.1.4.1.25506.2.13.1.5.1.7)
read-create
RowStatus
Row status.
active(1).
createAndGo(4).
destroy(6).
hh3cRadiusAccServerTable
About this table
This table collects packet statistics by RADIUS accounting server, which is not implemented by standard MIBs.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is radiusAccServerIndex.
Object (OID)
Access
Value range
Implementation
hh3cRadiusAccClientStartRequests (1.3.6.1.4.1.25506.2.13.2.1.1.1.1)
read-only
Counter32
Number of start-accounting requests sent to the RADIUS server.
As per the MIB.
hh3cRadiusAccClientStartResponses (1.3.6.1.4.1.25506.2.13.2.1.1.1.2)
read-only
Counter32
Number of start-accounting requests received from the RADIUS server.
As per the MIB.
hh3cRadiusAccClientInterimRequests (1.3.6.1.4.1.25506.2.13.2.1.1.1.3)
read-only
Counter32
Number of real-time accounting request sent to the RADIUS server.
As per the MIB.
hh3cRadiusAccClientInterimResponses (1.3.6.1.4.1.25506.2.13.2.1.1.1.4)
read-only
Counter32
Number of real-time accounting requests received from the RADIUS server.
As per the MIB.
hh3cRadiusAccClientStopRequests (1.3.6.1.4.1.25506.2.13.2.1.1.1.5)
read-only
Counter32
Number of stop-accounting request sent to the RADIUS server.
As per the MIB.
hh3cRadiusAccClientStopResponses (1.3.6.1.4.1.25506.2.13.2.1.1.1.6)
read-only
Counter32
Number of stop-accounting requests received from the RADIUS server.
As per the MIB.
hh3cRadiusAuthServerTable
About this table
This table collects authentication failure statistics by RADIUS authentication server, which is not implemented by standard MIBs.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is radiusAuthServerIndex.
Object (OID)
Access
Value range
Implementation
hh3cRadiusAuthFailureTimes (1.3.6.1.4.1.25506.2.13.4.1.1.1.1)
read-only
Counter32
Number of authentication failures.
As per the MIB.
hh3cRadiusAuthTimeoutTimes (1.3.6.1.4.1.25506.2.13.4.1.1.1.2)
read-only
Counter32
Number of authentication timeouts.
As per the MIB.
hh3cRadiusAuthRejectTimes (1.3.6.1.4.1.25506.2.13.4.1.1.1.3)
read-only
Counter32
Number of authentication rejections.
As per the MIB.
Notifications
hh3cRadiusAuthServerUpTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.13.3.0.1
Authentication server up
Recovery
Warning
N/A (N/A)
OFF
Notification triggers
This notification is generated when the status of an authentication server changes from blocked to active.
This notification cannot function correctly with SNMPv2 and later versions. It has been replaced with hh3cRadiusAuthenticationServerUpTrap (1.3.6.1.4.1.25506.2.13.3.0.4) in SNMPv2 and later versions.
The notification generated by the device for the RADIUS authentication server up event (if enabled) depends on the SNMP version for the event:
If SNMPv1 is specified for this event by using the radius trap-version v1 command, the device generates the hh3cRadiusAuthServerUpTrap (1.3.6.1.4.1.25506.2.13.3.0.1) notification.
If SNMPv2 is specified for this event by using the radius trap-version v2 command, the device generates the hh3cRadiusAuthenticationServerUpTrap (1.3.6.1.4.1.25506.2.13.3.0.4) notification.
System impact
No negative impact on services.
Status control
ON
CLI: Use both the snmp-agent trap enable radius authentication-server-up and radius trap-version v1 commands.
OFF
CLI: Use either the undo snmp-agent trap enable radius authentication-server-up command or the radius trap-version v2 command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.67.1.2.1.1.3.1.2 (radiusAuthServerAddress)
IP address of an authentication server.
IP Address
1.3.6.1.2.1.67.1.2.1.1.3.1.3 (radiusAuthClientServerPortNumber)
Port number of the authentication server.
INTEGER
1.. 65535
Recommended action
No action is required.
hh3cRadiusAccServerUpTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.13.3.0.2
Accounting server up
Recovery
Warning
N/A (N/A)
OFF
This notification is generated when the status of an accounting server changes from blocked to active.
This notification cannot function correctly with SNMPv2 and later versions. It has been replaced with hh3cRadiusAccountingServerUpTrap (1.3.6.1.4.1.25506.2.13.3.0.5) in SNMPv2 and later versions.
The notification generated by the device for the RADIUS accounting server up event (if enabled) depends on the SNMP version for the event:
If SNMPv1 is specified for this event by using the radius trap-version v1 command, the device generates the hh3cRadiusAccServerUpTrap (1.3.6.1.4.1.25506.2.13.3.0.2) notification.
If SNMPv2 is specified for this event by using the radius trap-version v2 command, the device generates the hh3cRadiusAccountingServerUpTrap (1.3.6.1.4.1.25506.2.13.3.0.5) notification.
System impact
Status control
ON
CLI: Use both the snmp-agent trap enable radius accounting-server-up and radius trap-version v1 commands.
OFF
CLI: Use either the undo snmp-agent trap enable radius accounting-server-up command or the radius trap-version v2 command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.67.2.2.1.1.3.1.2 (radiusAccServerAddress)
IP address of an accounting server.
IP Address
1.3.6.1.2.1.67.2.2.1.1.3.1.3 (radiusAccClientServerPortNumber)
Port number of the accounting server.
INTEGER
1.. 65535
Recommended action
hh3cRadiusAuthErrTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.13.3.0.3
Authentication failure alarm threshold crossing.
Informational
Major
N/A (N/A)
OFF
This notification is generated when the ratio of the authentication failures to the total authentication requests reaches the authentication failure alarm threshold.
System impact
The system is might being attacked.
Status control
ON
CLI: Use the snmp-agent trap enable radius authentication-error-threshold command.
OFF
CLI: Use the undo snmp-agent trap enable radius authentication-error-threshold command.
Object
OID (object name)
Index
Value range
IP Address
INTEGER
1.. 65535
Recommended action
To resolve this issue, contact the administrator for help.
Basic information
OID
Event
Severity
Default status
Recovery
Warning
N/A (N/A)
OFF
This notification replaces hh3cRadiusAuthServerUpTrap (1.3.6.1.4.1.25506.2.13.3.0.1) in SNMPv2 and later versions.
System impact
Status control
ON
CLI: Use both the snmp-agent trap enable radius authentication-server-up and radius trap-version v2 commands.
OFF
CLI: Use either the undo snmp-agent trap enable radius authentication-server-up command or the radius trap-version v1 command.
Object
OID (object name)
Index
Value range
IP Address
INTEGER
1.. 65535
Recommended action
Basic information
OID
Event
Severity
Default status
Recovery
Warning
N/A (N/A)
OFF
This notification replaces hh3cRadiusAccServerUpTrap (1.3.6.1.4.1.25506.2.13.3.0.2) in SNMPv2 and later versions.
System impact
Status control
ON
CLI: Use both the snmp-agent trap enable radius accounting-server-up and radius trap-version v2 commands.
OFF
CLI: Use either the undo snmp-agent trap enable radius accounting-server-up command or the radius trap-version v1 command.
Object
OID (object name)
Index
Value range
IP Address
INTEGER
1.. 65535
Recommended action
hh3cRadiusAuthenticationServerDownTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.13.3.0.6
Authentication server down
Error
Major
1.3.6.1.4.1.25506.2.13.3.0.4 (hh3cRadiusAuthenticationServerUpTrap)
OFF
This notification is generated when the status of an authentication server changes from active to blocked.
This notification replaces hh3cRadiusAuthServerDownTrap (1.3.6.1.4.1.25506.2.13.3.1) in SNMPv2 and later versions.
The notification generated by the device for the RADIUS authentication server down event (if enabled) depends on the SNMP version for the event:
If SNMPv2 is specified for this event by using the radius trap-version v2 command, the device generates the hh3cRadiusAuthenticationServerDownTrap (1.3.6.1.4.1.25506.2.13.3.0.6) notification.
If SNMPv1 is specified for this event by using the radius trap-version v1 command, the device generates the hh3cRadiusAuthServerDownTrap (1.3.6.1.4.1.25506.2.13.3.1) notification.
System impact
If no secondary authentication servers exist, users cannot perform authentication to come online.
Status control
ON
CLI: Use both the snmp-agent trap enable radius authentication-server-down and radius trap-version v2 commands.
OFF
CLI: Use either the undo snmp-agent trap enable radius authentication-server-down command or the radius trap-version v1 command.
Object
OID (object name)
Index
Value range
IP Address
INTEGER
1.. 65535
Recommended action
To resolve this issue:
1.Use the display interface command to view whether the interface connected to the authentication server is up:
  - If no, troubleshoot the physical link.
  - If yes, go to step 2.
2.Use the ping command to check whether the RADIUS server is reachable:
  - If no, first check the network reachability between the device and the RADIUS server, and then check whether firewalls exist in the network. Make sure the RADIUS server is reachable.
  - If yes, go to step 3.
3.Use the display current-configuration command to view whether the RADIUS server's configurations are correct:
  - If no, modify the RADIUS server's configurations. For more information about RADIUS server configurations, see AAA commands in Security Command Reference and AAA configuration in Security Configuration Guide of the device.
  - If yes, go to step 4.
4.Collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
hh3cRadiusAccountingServerDownTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.13.3.0.7
Accounting server down
Error
Major
1.3.6.1.4.1.25506.2.13.3.0.5 (hh3cRadiusAccountingServerUpTrap)
OFF
This notification is generated when the status of an accounting server changes from active to blocked.
This notification replaces hh3cRadiusAccServerDownTrap (1.3.6.1.4.1.25506.2.13.3.2) in SNMPv2 and later versions.
The notification generated by the device for the RADIUS accounting server down event (if enabled) depends on the SNMP version for the event:
If SNMPv2 is specified for this event by using the radius trap-version v2 command, the device generates the hh3cRadiusAccountingServerDownTrap (1.3.6.1.4.1.25506.2.13.3.0.7) notification.
If SNMPv1 is specified for this event by using the radius trap-version v1 command, the device generates the hh3cRadiusAccServerDownTrap (1.3.6.1.4.1.25506.2.13.3.2) notification.
System impact
The server is unreachable and users cannot come online.
Status control
ON
CLI: Use both the snmp-agent trap enable radius accounting-server-down and radius trap-version v2 commands.
OFF
CLI: Use either the undo snmp-agent trap enable radius accounting-server-down command or the radius trap-version v1 command.
Object
OID (object name)
Index
Value range
IP Address
Port number of an accounting server.
INTEGER
1.. 65535
Recommended action
1.Use the display interface command to view whether the interface connected to the accounting server is up:
Basic information
OID
Event
Severity
Default status
Error
Major
1.3.6.1.4.1.25506.2.13.3.0.1 (hh3cRadiusAuthServerUpTrap)
OFF
This notification cannot function correctly with SNMPv2 and later versions. It has been replaced with hh3cRadiusAuthenticationServerDownTrap (1.3.6.1.4.1.25506.2.13.3.0.6) in SNMPv2 and later versions.
System impact
Status control
ON
CLI: Use both the snmp-agent trap enable radius authentication-server-down and radius trap-version v1 commands.
OFF
CLI: Use either the undo snmp-agent trap enable radius authentication-server-down command or the radius trap-version v2 command.
Object
OID (object name)
Index
Value range
IP Address
INTEGER
1.. 65535
Recommended action
Basic information
OID
Event
Severity
Default status
Error
Major
1.3.6.1.4.1.25506.2.13.3.0.2 (hh3cRadiusAccServerUpTrap)
OFF
This notification cannot function correctly with SNMPv2 and later versions. It has been replaced with hh3cRadiusAccountingServerDownTrap (1.3.6.1.4.1.25506.2.13.3.0.7) in SNMPv2 and later versions.
System impact
Status control
ON
CLI: Use both the snmp-agent trap enable radius accounting-server-down and radius trap-version v1 commands.
OFF
CLI: Use either the undo snmp-agent trap enable radius accounting-server-down command or the radius trap-version v2 command.
Object
OID (object name)
Index
Value range
IP Address
INTEGER
1.. 65535
Recommended action
hh3cRadiusAccCacheAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.13.8.0.1
The ratio of the number of buffered stop-accounting packets to the max number allowed reached the upper threshold.
Error
Warning
1.3.6.1.4.1.25506.2.13.8.0.2 (hh3cRadiusAccCacheResume)
OFF
This notification is generated when the ratio of the number of buffered stop-accounting packets to the allowed max number configured by using the radius stop-accounting-buffer cache command reaches the upper threshold.
System impact
No negative impact on services currently. If the number of buffered stop-accounting packets reaches the allowed max number, the device processes new stop-accounting requests according to whether you have configured the radius stop-accounting-buffer overwrite-oldest command in system view for new stop-accounting request overwriting.
If you have configured the command, the device uses a new stop-accounting request to overwrite the oldest one.
If you have not configured the command, the device stops buffering new stop-accounting requests and new stop-accounting requests are dropped.
Status control
ON
CLI: Use the snmp-agent trap enable radius accounting-cache-upper-threshold command.
OFF
CLI: Use the undo snmp-agent trap enable radius accounting-cache-upper-threshold command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.13.8.1.1 (hh3cRadiusAccCacheMaxPackets)
Allowed maximum number of stop-accounting packets that can be buffered.
N/A
Integer32
256..2147483647
1.3.6.1.4.1.25506.2.13.8.1.2 (hh3cRadiusAccCacheUpperValue)
Upper threshold for the ratio of the number of buffered stop-accounting packets to the maximum number allowed, in percentage.
N/A
Integer32
1..100
Recommended action
1.Check whether the set upper threshold for stop-accounting request buffering is appropriate:
  - If no, use the radius stop-accounting-buffer warning-threshold command in system view to set the upper threshold to a higher value as needed, and then go to step 2.
2.Use the test-aaa command in user view to test whether communication failures exist between the device and the RADIUS server:
  - If the test succeeds, it indicates that the RADIUS server is reachable. Go to step 3.
  - If the test fails, troubleshoot the link between the device and the server. If the issue persists when the link is normal, go to step 3.
3.Collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
The ratio of the number of buffered stop-accounting packets to the max number allowed dropped below the lower threshold.
Recovery
Warning
N/A (N/A)
OFF
This notification is generated when the ratio of the number of buffered stop-accounting packets to the allowed max number configured by using the radius stop-accounting-buffer cache command drops below the lower threshold.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable radius accounting-cache-lower-threshold command.
OFF
CLI: Use the undo snmp-agent trap enable radius accounting-cache-lower-threshold command.
Object
OID (object name)
Index
Value range
N/A
Integer32
256..2147483647
1.3.6.1.4.1.25506.2.13.8.1.3 (hh3cRadiusAccCacheLowerValue)
Lower threshold for the ratio of the number of buffered stop-accounting packets to the maximum number allowed, in percentage.
N/A
Integer32
0..99
Recommended action
hh3cRadiusAccCachePacketDiscard
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.13.8.0.3
The system dropped buffered stop-accounting packets or stop-accounting packets to be buffered after the memory usage reached the minor alarm threshold.
Informational
Major
N/A (N/A)
OFF
This notification is generated when the system drops buffered stop-accounting packets or stop-accounting packets to be buffered after the memory usage reaches the minor alarm threshold.
System impact
The device processes stop-accounting packets according to whether you have configured the radius stop-accounting-buffer memory-minor-threshold overwrite-oldest command. If you have configured this command, the device uses a new stop-accounting request to overwrite the oldest one. Otherwise, the device stops buffering new stop-accounting requests. After the link between the device and the server recovers, some users might fail to go offline in time.
Status control
ON
CLI: Use the snmp-agent trap enable radius accounting-cache-discard command.
OFF
CLI: Use the undo snmp-agent trap enable radius accounting-cache-discard command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.13.8.1.4 (hh3cRadiusAccCacheMemoryUsage)
N/A
Integer32
0..100
1.3.6.1.4.1.25506.2.13.8.1.5 (hh3cRadiusAccCachePackets)
Number of stop-accounting packets that have been buffered.
N/A
Integer32
256..2147483647
Recommended action
1.Use the display memory-threshold command in any view to check whether the memory usage of the MPU reaches the minor memory alarm threshold:
  - If no, go to step 5.
2.Check whether the configured minor memory alarm threshold is low:
  - If yes, use the memory-threshold command in system view to set the minor memory alarm threshold to a higher value as needed.
  - If no, go to step 3.
3.Use the radius stop-accounting-buffer cache command in system view to set the maximum number of stop-accounting requests allowed to a smaller value so as to reduce resource consumption caused by buffered RADIUS stop-accounting requests. Then go to step 4.
4.Use the test-aaa command in user view to test whether communication failures exist between the device and the RADIUS server:
  - If the test succeeds, it indicates that the RADIUS server is reachable. Go to step 5.
  - If the test fails, troubleshoot the link between the device and the server. If the issue persists when the link is normal, go to step 5.
5.Collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
