08-Layer 3 - IP Services
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R838x-6W10008-Layer 3 - IP Services
21-IPV6-MIB
21-IPV6-MIB 109.62 KB
IPV6-MIB
About this MIB
Use this MIB to implement IPv6.
MIB file name
rfc2465-ipv6.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ipv6MIB(55)
Scalar objects
ipv6Forwarding (1.3.6.1.2.1.55.1.1)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
forwarding(1)
notForwarding(2)
Whether this entity is acting as an IPv6 router for the forwarding of datagrams received by, but not addressed to, this entity.
Read only.
ipv6DefaultHopLimit (1.3.6.1.2.1.55.1.2)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
INTEGER (0..255)
Default value inserted into the Hop Limit field of the IPv6 header of datagrams originated at this entity.
Read only.
ipv6Interfaces (1.3.6.1.2.1.55.1.3)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Standard MIB values.
Number of IPv6 interfaces.
As per the MIB.
ipv6IfTableLastChange (1.3.6.1.2.1.55.1.4)
Object (OID)
Access
Value range
Implementation
read-only
TimeStamp
Time when the last modification of the ipv6IfTable was made.
As per the MIB.
ipv6RouteNumber
(1.3.6.1.2.1.55.1.9)
Object (OID)
Access
Value range
Implementation
ipv6RouteNumber
read-only
Gauge32
Total number of IPv6 unicast routing entries used for packet forwarding to public network destinations.
As per the MIB.
ipv6DiscardedRoutes
(1.3.6.1.2.1.55.1.10)
Object (OID)
Access
Value range
Implementation
ipv6DiscardedRoutes
read-only
Counter32
Number of discarded IPv6 routes.
As per the MIB.
Tabular objects
ipv6IfTable
About this table
Use this table to obtain IPv6 interface information.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is ipv6IfIndex.
Object (OID)
Access
Value range
Implementation
ipv6IfIndex (1.3.6.1.2.1.55.1.5.1.1)
not-accessible
Ipv6IfIndex
(1..2147483647)
Interface index.
As per the MIB.
ipv6IfDescr (1.3.6.1.2.1.55.1.5.1.2)
read-write
DisplayString
(0..255)
Interface description.
Cannot exceed 255 characters.
ipv6IfLowerLayer (1.3.6.1.2.1.55.1.5.1.3)
read-only
VariablePointer
Protocol layer over which the network interface operates.
Not supported
ipv6IfEffectiveMtu (1.3.6.1.2.1.55.1.5.1.4)
read-only
Unsigned32
Interface MTU.
As per the MIB.
ipv6IfReasmMaxSize (1.3.6.1.2.1.55.1.5.1.5)
read-only
Unsigned32
Size of the largest IPv6 datagram that this entity can re-assemble from incoming IPv6 fragmented datagrams received on the interface.
Not supported.
The value is fixed at 65535.
ipv6IfIdentifier (1.3.6.1.2.1.55.1.5.1.6)
read-write
Ipv6AddressIfIdentifier
Interface identifier.
Read only.
ipv6IfIdentifierLength (1.3.6.1.2.1.55.1.5.1.7)
read-write
INTEGER
INTEGER(0..64)
Length of the interface identifier.
Read only.
ipv6IfPhysicalAddress (1.3.6.1.2.1.55.1.5.1.8)
read-only
PhysAddress
Physical address of the interface.
As per the MIB.
ipv6IfAdminStatus (1.3.6.1.2.1.55.1.5.1.9)
read-write
INTEGER
up(1)
down(2)
Desired state of the interface.
Read only.
ipv6IfOperStatus (1.3.6.1.2.1.55.1.5.1.10)
read-only
INTEGER
up(1)
down(2)
noIfIdentifier(3)
unknown(4)
notPresent(5)
Operating state of the interface.
As per the MIB.
ipv6IfLastChange (1.3.6.1.2.1.55.1.5.1.11)
read-only
TimeStamp
During since the interface has entered its current operating state.
As per the MIB.
ipv6IfStatsTable
About this table
Use this table to obtain the IPv6 interface forwarding statistics.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
ipv6IfStatsInReceives (1.3.6.1.2.1.55.1.6.1.1)
read-only
Counter32
Total number of input datagrams received by the interface.
As per the MIB.
ipv6IfStatsInHdrErrors (1.3.6.1.2.1.55.1.6.1.2)
read-only
Counter32
Number of input datagrams discarded due to errors in their IPv6 headers.
As per the MIB.
ipv6IfStatsInTooBigErrors (1.3.6.1.2.1.55.1.6.1.3)
read-only
Counter32
Number of input datagrams that cannot be forwarded because their size exceeds the link MTU of the outgoing interface.
As per the MIB.
ipv6IfStatsInNoRoutes (1.3.6.1.2.1.55.1.6.1.4)
read-only
Counter32
Number of input datagrams discarded because no route can be found to transmit them to their destinations.
As per the MIB.
ipv6IfStatsInAddrErrors (1.3.6.1.2.1.55.1.6.1.5)
read-only
Counter32
Number of input datagrams discarded because the IPv6 address in their IPv6 header's destination field was not a valid address.
As per the MIB.
ipv6IfStatsInUnknownProtos (1.3.6.1.2.1.55.1.6.1.6)
read-only
Counter32
Number of locally-addressed datagrams received successfully but discarded because of an unknown or unsupported protocol.
As per the MIB.
ipv6IfStatsInTruncatedPkts (1.3.6.1.2.1.55.1.6.1.7)
read-only
Counter32
Number of input datagrams discarded because datagram frame did not carry enough data.
As per the MIB.
ipv6IfStatsInDiscards (1.3.6.1.2.1.55.1.6.1.8)
read-only
Counter32
Number of input IPv6 datagrams discarded due to unknown errors.
As per the MIB.
ipv6IfStatsInDelivers (1.3.6.1.2.1.55.1.6.1.9)
read-only
Counter32
Total number of datagrams successfully delivered.
As per the MIB.
ipv6IfStatsOutForwDatagrams (1.3.6.1.2.1.55.1.6.1.10)
read-only
Counter32
Number of output datagrams this entity received and forwarded to their final destinations.
As per the MIB.
ipv6IfStatsOutRequests (1.3.6.1.2.1.55.1.6.1.11)
read-only
Counter32
Total number of IPv6 datagrams that local protocols supplied to IPv6 in requests for transmission.
As per the MIB.
ipv6IfStatsOutDiscards (1.3.6.1.2.1.55.1.6.1.12)
read-only
Counter32
Number of output IPv6 datagrams discarded due to unknown errors.
As per the MIB.
ipv6IfStatsOutFragOKs (1.3.6.1.2.1.55.1.6.1.13)
read-only
Counter32
Number of IPv6 datagrams that have been successfully fragmented at the interface.
As per the MIB.
ipv6IfStatsOutFragFails (1.3.6.1.2.1.55.1.6.1.14)
read-only
Counter32
Number of IPv6 datagrams that have been discarded because they failed to be fragmented as required at the interface.
As per the MIB.
ipv6IfStatsOutFragCreates (1.3.6.1.2.1.55.1.6.1.15)
read-only
Counter32
Number of output datagram fragments that have been generated as a result of fragmentation at the interface.
As per the MIB.
ipv6IfStatsReasmReqds (1.3.6.1.2.1.55.1.6.1.16)
read-only
Counter32
Number of received IPv6 fragments which that needed to be reassembled at the interface.
As per the MIB.
ipv6IfStatsReasmOKs (1.3.6.1.2.1.55.1.6.1.17)
read-only
Counter32
Number of IPv6 datagrams successfully reassembled.
As per the MIB.
ipv6IfStatsReasmFails (1.3.6.1.2.1.55.1.6.1.18)
read-only
Counter32
Number of failures detected by IPv6 re-assembly.
As per the MIB.
ipv6IfStatsInMcastPkts (1.3.6.1.2.1.55.1.6.1.19)
read-only
Counter32
Number of multicast packets received by the interface.
As per the MIB.
ipv6IfStatsOutMcastPkts (1.3.6.1.2.1.55.1.6.1.20)
read-only
Counter32
Number of multicast packets transmitted by the interface.
As per the MIB.
ipv6AddrPrefixTable
About this table
Use this table to obtain the IPv6 address prefix information for an interface.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ipv6IfIndex, ipv6AddrPrefix, and ipv6AddrPrefixLength.
Object (OID)
Access
Value range
Implementation
ipv6AddrPrefix (1.3.6.1.2.1.55.1.7.1.1)
not-accessible
Ipv6AddressPrefix
(0..255)
IPv6 address prefix associated with the interface.
As per the MIB.
ipv6AddrPrefixLength (1.3.6.1.2.1.55.1.7.1.2)
not-accessible
INTEGER
INTEGER (0..128)
Length of the prefix.
As per the MIB.
ipv6AddrPrefixOnLinkFlag (1.3.6.1.2.1.55.1.7.1.3)
read-only
TruthValue
true(1)
false(2)
Whether the prefix can be used for on-link determination.
As per the MIB.
ipv6AddrPrefixAutonomousFlag(1.3.6.1.2.1.55.1.7.1.4)
read-only
TruthValue
true(1)
false(2)
Autonomous address configuration flag to determine if the prefix can be used to form a local interface address.
As per the MIB.
ipv6AddrPrefixAdvPreferredLifetime (1.3.6.1.2.1.55.1.7.1.5)
read-only
Unsigned32
Length of time in seconds that this prefix will remain preferred.
As per the MIB.
ipv6AddrPrefixAdvValidLifetime (1.3.6.1.2.1.55.1.7.1.6)
read-only
Unsigned32
Length of time in seconds that this prefix will remain valid.
As per the MIB.
ipv6AddrTable
About this table
Use this table to obtain the node's IPv6 address information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ipv6IfIndex and ipv6AddrAddress.
Object (OID)
Access
Value range
Implementation
ipv6AddrAddress (1.3.6.1.2.1.55.1.8.1.1)
not-accessible
Ipv6Address
IPv6 address to which the entry's addressing information belongs.
As per the MIB.
ipv6AddrPfxLength (1.3.6.1.2.1.55.1.8.1.2)
read-only
Ipv6Address
(0..128)
Length of the prefix associated with the IPv6 address of the entry.
As per the MIB.
ipv6AddrType (1.3.6.1.2.1.55.1.8.1.3)
read-only
INTEGER
stateless(1)
stateful(2)
unknown(3)
Address type.
Do not support unknown.
ipv6AddrAnycastFlag (1.3.6.1.2.1.55.1.8.1.4)
read-only
TruthValue
true(1)
false(2)
Anycast address flag.
As per the MIB.
ipv6AddrStatus (1.3.6.1.2.1.55.1.8.1.5)
read-only
INTEGER
preferred(1)
deprecated(2)
invalid(3)
inaccessible(4)
unknown(5)
Address status.
As per the MIB.
ipv6RouteTable
About this table
Use this table to obtain IPv6 routing table.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ipv6RouteDest, ipv6RoutePfxLength, and ipv6RouteIndex.
Object (OID)
Access
Value range
Implementation
ipv6RouteDest (1.3.6.1.2.1.55.1.11.1.1)
not-accessible
Ipv6Address
Destination IPv6 address of a route.
As per the MIB.
ipv6RoutePfxLength (1.3.6.1.2.1.55.1.11.1.2)
not-accessible
INTEGER
INTEGER (0..128)
Prefix length of the destination address.
As per the MIB.
ipv6RouteIndex
(1.3.6.1.2.1.55.1.11.1.3)
not-accessible
Unsigned32
Route index, which uniquely identifies the route among the routes to the same network layer destination.
As per the MIB.
ipv6RouteIfIndex
(1.3.6.1.2.1.55.1.11.1.4)
read-only
Ipv6IfIndexOrZero
Output interface index.
As per the MIB.
ipv6RouteNextHop
(1.3.6.1.2.1.55.1.11.1.5)
read-only
Ipv6Address
Nexthop address.
As per the MIB.
ipv6RouteType
(1.3.6.1.2.1.55.1.11.1.6)
read-only
INTEGER
other(1), discard(2), local(3), remote(4)
Type of the route.
As per the MIB.
ipv6RouteProtocol
(1.3.6.1.2.1.55.1.11.1.7)
read-only
INTEGER
other(1),
local(2),
netmgmt(3), ndisc(4), rip(5), ospf(6), bgp(7),
idrp(8),
igrp(9)
Routing protocol type.
As per the MIB.
ipv6RoutePolicy
(1.3.6.1.2.1.55.1.11.1.8)
read-only
Integer32
General set of route information.
As per the MIB.
ipv6RouteAge
(1.3.6.1.2.1.55.1.11.1.9)
read-only
Unsigned32
Lifetime of the route.
As per the MIB.
ipv6RouteNextHopRDI
(1.3.6.1.2.1.55.1.11.1.10)
read-only
Unsigned32
Routing domain ID of the next hop.
As per the MIB.
ipv6RouteMetric
(1.3.6.1.2.1.55.1.11.1.11)
read-only
Unsigned32
Metric of the route.
As per the MIB.
ipv6RouteWeight
(1.3.6.1.2.1.55.1.11.1.12)
read-only
Unsigned32
Weight of the route.
As per the MIB.
ipv6RouteInfo
(1.3.6.1.2.1.55.1.11.1.13)
read-only
RowPointer
Route information.
As per the MIB.
ipv6RouteValid
(1.3.6.1.2.1.55.1.11.1.14)
read-write
TruthValue
true(1),
false(2)
Whether the route is valid.
Read only.
ipv6NetToMediaTable
About this table
Use this table to configure the mapping between an IPv6 address and the physical address for an interface.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are ipv6IfIndex and ipv6NetToMediaNetAddress.
Object (OID)
Access
Value range
Implementation
ipv6NetToMediaNetAddress (1.3.6.1.2.1.55.1.12.1.1)
not-accessible
Ipv6Address
Interface IPv6 address.
As per the MIB.
ipv6NetToMediaPhysAddress (1.3.6.1.2.1.55.1.12.1.2)
read-only
PhysAddress
Interface physical address.
As per the MIB.
ipv6NetToMediaType (1.3.6.1.2.1.55.1.12.1.3)
read-only
INTEGER
other(1)
dynamic(2)
static(3)
local(4)
Mapping type.
As per the MIB.
ipv6IfNetToMediaState (1.3.6.1.2.1.55.1.12.1.4)
read-only
INTEGER
reachable(1)
stale(2)
delay(3)
probe(4)
invalid(5)
unknown(6)
Neighbor Unreachability Detection state for the interface when the address mapping in this entry is used.
As per the MIB.
ipv6IfNetToMediaLastUpdated (1.3.6.1.2.1.55.1.12.1.5)
read-only
TimeStamp
Time since the entry was last updated.
As per the MIB.
ipv6NetToMediaValid (1.3.6.1.2.1.55.1.12.1.6)
read-write
TruthValue
true(1)
false(2)
Whether the entry is invalid.
Read only.
Notifications
ipv6IfStateChange
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.55.2.0.1
IPv6 interface state change
Informational
Warning
ON
Notification triggers
This notification is generated when the state of an interface link changed or the IPv6 address of an interface changed.
System impact
If the notification is generated and the link state is not UP, errors might be present on IPv6 services on the interface.
Status control
ON
CLI: snmp-agent trap enable ipv6 address [ interface-state-change ]
OFF
CLI : undo snmp-agent trap enable ipv6 address [ interface-state-change ]
Object
OID (object name)
Index
Value range
Interface information.
ipv6IfIndex
DisplayString
DisplayString , (0255)
Interface state.
ipv6IfIndex
INTEGER
up(1), down(2), noIfIdentifier(3), unknown(4), notPresent(5)
Recommended action
Check the interface connection and the interface address.
