08-Layer 3 - IP Services
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R838x-6W10008-Layer 3 - IP Services
11-HH3C-IPFW-MIB
11-HH3C-IPFW-MIB 50.12 KB
HH3C-IPFW-MIB
About this MIB
Use this MIB to obtain IP forwarding information and configure IP forwarding.
MIB file name
hh3c-ipfw.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIpfw(211)
Scalar objects
hh3cIpfwIfIndex (1.3.6.1.4.1.25506.2.211.2.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
InterfaceIndex
Integer32 (1..2147483647)
Index of the interface from which packets are received.
As per the MIB.
hh3cIpfwPeerAddress (1.3.6.1.4.1.25506.2.211.2.1.2)
Object (OID)
Access
Value range
Implementation
OCTET STRING
OCTET STRING  (0..255)
Destination IP address of received packets.
As per the MIB.
hh3cIpfwInterfaceName (1.3.6.1.4.1.25506.2.211.2.1.3)
Object (OID)
Access
Value range
Implementation
OCTET STRING
Name of the interface from which packets are received.
As per the MIB.
Notifications
hh3cIpfwPktNumExcAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.211.2.0.1
Disordered packets detected.
Error
Warning
1.3.6.1.4.1.25506.2.211.2.0.2 (hh3cIpfwPktNumExcAlarmResume)
ON
Notification triggers
This notification is generated when the length of the buffered packet queue exceeds the alarm threshold because the device receives a large number of fragments that require reassembly.
System impact
The device received too many fragments, some of which are disordered, and the device cannot complete fragment reassembly in time. This might cause packet loss and affect service operation.
Status control
ON
CLI: Use the snmp-agent trap enable ip-forwarding command.
OFF
CLI: Use the undo snmp-agent trap enable ip-forwarding command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.211.2.1.1 (hh3cIpfwIfIndex)
Index of the interface from which the packets are received.
N/A
InterfaceIndex
1.3.6.1.4.1.25506.2.211.2.1.2 (hh3cIpfwPeerAddress)
IP address of the interface from which the packets are received.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.211.2.1.3 (hh3cIpfwInterfaceName)
Name of the interface from which the packets are received.
N/A
OCTET STRING
Recommended action
Use the IP address and interface information in the alarm message to identify the fragment source and verify if the fragments are valid. If the fragments are invalid, enable anti-attack measures against the source as a best practice to avoid effect on service operation.
Basic information
OID
Event
Severity
Default status
Disordered packet alarm removal
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the threshold exceeding alarm (buffered packet queue length threshold) is removed.
System impact
No impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
InterfaceIndex
N/A
OCTET STRING
N/A
OCTET STRING
Recommended action
No action is required.
