08-Layer 3 - IP Services
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R838x-6W10008-Layer 3 - IP Services
20-IPV6-ICMP-MIB
20-IPV6-ICMP-MIB 68.78 KB
IPV6-ICMP-MIB
About this MIB
Use this MIB to manage ICMPv6.
MIB file name
rfc2466-ipv6-icmp.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ipv6IcmpMIB(56)
Tabular objects
ipv6IfIcmpTable
About this table
Use this table to obtain IPv6 ICMP statistics.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
This table does not contain indexes.
Object (OID)
Access
Value range
Implementation
ipv6IfIcmpInMsgs (1.3.6.1.2.1.56.1.1.1.1)
read-only
Counter32
Standard MIB values.
Total number of ICMP messages received by the interface, including those counted by ipv6IfIcmpInErrors.
As per the MIB.
ipv6IfIcmpInErrors (1.3.6.1.2.1.56.1.1.1.2)
read-only
Counter32
Number of ICMP messages that the interface received and determined as having ICMP-specific errors.
As per the MIB.
ipv6IfIcmpInDestUnreachs (1.3.6.1.2.1.56.1.1.1.3)
read-only
Counter32
Number of ICMP Destination Unreachable messages received by the interface.
As per the MIB.
ipv6IfIcmpInAdminProhibs (1.3.6.1.2.1.56.1.1.1.4)
read-only
Counter32
Number of ICMP destination unreachable/communication administratively prohibited messages received by the interface.
The value is fixed at 0.
ipv6IfIcmpInTimeExcds (1.3.6.1.2.1.56.1.1.1.5)
read-only
Counter32
Number of ICMP Time Exceeded messages received by the interface.
As per the MIB.
ipv6IfIcmpInParmProblems (1.3.6.1.2.1.56.1.1.1.6)
read-only
Counter32
Number of ICMP Parameter Problem messages received by the interface.
As per the MIB.
ipv6IfIcmpInPktTooBigs (1.3.6.1.2.1.56.1.1.1.7)
read-only
Counter32
Number of ICMP Packet Too Big messages received by the interface.
As per the MIB.
ipv6IfIcmpInEchos (1.3.6.1.2.1.56.1.1.1.8)
read-only
Counter32
Number of ICMP Echo (request) messages received by the interface.
As per the MIB.
ipv6IfIcmpInEchoReplies (1.3.6.1.2.1.56.1.1.1.9)
read-only
Counter32
Number of ICMP Echo Reply messages received by the interface.
As per the MIB.
ipv6IfIcmpInRouterSolicits (1.3.6.1.2.1.56.1.1.1.10)
read-only
Counter32
Number of ICMP Router Solicit messages received by the interface.
As per the MIB.
ipv6IfIcmpInRouterAdvertisements (1.3.6.1.2.1.56.1.1.1.11)
read-only
Counter32
Number of ICMP Router Advertisement messages received by the interface.
As per the MIB.
ipv6IfIcmpInNeighborSolicits (1.3.6.1.2.1.56.1.1.1.12)
read-only
Counter32
Number of ICMP Neighbor Solicit messages received by the interface.
As per the MIB.
ipv6IfIcmpInNeighborAdvertisements (1.3.6.1.2.1.56.1.1.1.13)
read-only
Counter32
Number of ICMP Neighbor Advertisement messages received by the interface.
As per the MIB.
ipv6IfIcmpInRedirects (1.3.6.1.2.1.56.1.1.1.14)
read-only
Counter32
Number of Redirect messages received by the interface.
As per the MIB.
ipv6IfIcmpInGroupMembQueries (1.3.6.1.2.1.56.1.1.1.15)
read-only
Counter32
Number of ICMPv6 Group Membership Query messages received by the interface.
As per the MIB.
ipv6IfIcmpInGroupMembResponses (1.3.6.1.2.1.56.1.1.1.16)
read-only
Counter32
Number of ICMPv6 Group Membership Response messages received by the interface.
As per the MIB.
ipv6IfIcmpInGroupMembReductions (1.3.6.1.2.1.56.1.1.1.17)
read-only
Counter32
Number of ICMPv6 Group Membership Reduction messages received by the interface.
As per the MIB.
ipv6IfIcmpOutMsgs (1.3.6.1.2.1.56.1.1.1.18)
read-only
Counter32
Total number of ICMP messages that interface attempted to send.
As per the MIB.
ipv6IfIcmpOutErrors (1.3.6.1.2.1.56.1.1.1.19)
read-only
Counter32
Number of ICMP messages the interface did not send due to problems discovered within ICMP.
ipv6IfIcmpOutDestUnreachs (1.3.6.1.2.1.56.1.1.1.20)
read-only
Counter32
Number of ICMP Destination Unreachable messages sent by the interface.
As per the MIB.
ipv6IfIcmpOutAdminProhibs (1.3.6.1.2.1.56.1.1.1.21)
read-only
Counter32
Number of ICMP destination unreachable/communication administratively prohibited messages sent by the interface.
ipv6IfIcmpOutTimeExcds (1.3.6.1.2.1.56.1.1.1.22)
read-only
Counter32
Number of ICMP Time Exceeded messages sent by the interface.
As per the MIB.
ipv6IfIcmpOutParmProblems (1.3.6.1.2.1.56.1.1.1.23)
read-only
Counter32
Number of ICMP Parameter Problem messages sent by the interface.
As per the MIB.
ipv6IfIcmpOutPktTooBigs (1.3.6.1.2.1.56.1.1.1.24)
read-only
Counter32
Number of ICMP Packet Too Big messages sent by the interface.
As per the MIB.
ipv6IfIcmpOutEchos (1.3.6.1.2.1.56.1.1.1.25)
read-only
Counter32
Number of ICMP Echo (request) messages sent by the interface.
As per the MIB.
ipv6IfIcmpOutEchoReplies (1.3.6.1.2.1.56.1.1.1.26)
read-only
Counter32
Number of ICMP Echo Reply messages sent by the interface.
As per the MIB.
ipv6IfIcmpOutRouterSolicits (1.3.6.1.2.1.56.1.1.1.27)
read-only
Counter32
Number of ICMP Router Solicitation messages sent by the interface.
As per the MIB.
ipv6IfIcmpOutRouterAdvertisements (1.3.6.1.2.1.56.1.1.1.28)
read-only
Counter32
Number of ICMP Router Advertisement messages sent by the interface.
As per the MIB.
ipv6IfIcmpOutNeighborSolicits (1.3.6.1.2.1.56.1.1.1.29)
read-only
Counter32
Number of ICMP Neighbor Solicitation messages sent by the interface.
As per the MIB.
ipv6IfIcmpOutNeighborAdvertisements (1.3.6.1.2.1.56.1.1.1.30)
read-only
Counter32
Number of ICMP Neighbor Advertisement messages sent by the interface.
As per the MIB.
ipv6IfIcmpOutRedirects (1.3.6.1.2.1.56.1.1.1.31)
read-only
Counter32
Number of Redirect messages sent by the interface.
As per the MIB.
ipv6IfIcmpOutGroupMembQueries (1.3.6.1.2.1.56.1.1.1.32)
read-only
Counter32
Number of ICMPv6 Group Membership Query messages sent by the interface.
As per the MIB.
ipv6IfIcmpOutGroupMembResponses (1.3.6.1.2.1.56.1.1.1.33)
read-only
Counter32
Number of ICMPv6 Group Membership Response messages sent by the interface.
As per the MIB.
ipv6IfIcmpOutGroupMembReductions (1.3.6.1.2.1.56.1.1.1.34)
read-only
Counter32
Number of ICMPv6 Group Membership Reduction messages sent by the interface.
As per the MIB.
