- 20-Network Management and Monitoring
- 01-DISMAN-PING-MIB
- 02-DISMAN-TRACEROUTE-MIB
- 03-HH3C-HTTP-MIB
- 04-HH3C-INQA-MIB
- 05-HH3C-MIRRORGROUP-MIB
- 06-HH3C-NETCONF-MIB
- 07-HH3C-NQA-MIB
- 08-HH3C-NTP-MIB
- 09-HH3C-PTP-MIB
- 10-HH3C-RMON-EXT2-MIB
- 11-HH3C-SNMP-EXT-MIB
- 12-HH3C-TWAMP-MIB
- 13-RMON-MIB
- 14-RMON2-MIB
- 15-SNMP-FRAMEWORK-MIB
- 16-SNMP-MPD-MIB
- 17-SNMP-NOTIFICATION-MIB
- 18-SNMP-TARGET-MIB
- 19-SNMP-USER-BASED-SM-MIB
- 20-SNMP-VIEW-BASED-ACM-MIB
- 21-SNMPv2-MIB
06-HH3C-NETCONF-MIB | 78.52 KB |
hh3cNetconfSessionId (1.3.6.1.4.1.25506.2.206.1.1.1)
hh3cNetconfSessionUserName (1.3.6.1.4.1.25506.2.206.1.1.2)
hh3cNetconfSessionPeerIPAddressType (1.3.6.1.4.1.25506.2.206.1.1.3)
hh3cNetconfSessionPeerIPAddress (1.3.6.1.4.1.25506.2.206.1.1.4)
hh3cNetconfSessionTerminationReason (1.3.6.1.4.1.25506.2.206.1.1.5)
HH3C-NETCONF-MIB
About this MIB
Use this MIB to notify SNMP NMSs of NETCONF session establishment and disconnection events.
MIB file name
hh3c-netconf.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cNetconf(206)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNetconfSessionId (1.3.6.1.4.1.25506.2.206.1.1.1) |
accessible-for-notify |
Integer32 |
Integer32 (1..2147483647) |
NETCONF session ID. |
Implementation varies by product. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNetconfSessionUserName (1.3.6.1.4.1.25506.2.206.1.1.2) |
DisplayString |
OCTET STRING (1..80) |
NETCONF session username. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNetconfSessionPeerIPAddressType (1.3.6.1.4.1.25506.2.206.1.1.3) |
InetAddress |
Standard MIB values. |
Type of the remote IP address that established the NETCONF session with the device. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNetconfSessionPeerIPAddress (1.3.6.1.4.1.25506.2.206.1.1.4) |
InetAddressType |
Remote IP address that established the NETCONF session with the device. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNetconfSessionTerminationReason (1.3.6.1.4.1.25506.2.206.1.1.5) |
INTEGER |
other(1), closed(2), linkDown(3), idleTimeout(4), |
Reason. for the session to be disconnected by the NETCONF client. |
Options: other(1)—Any other reason than those listed below. closed(2)—Session was closed. linkDown(3)—Link went down. idleTimeout(4)—Session timed out. |
Notifications
hh3cNetconfServerSessionStart
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.206.2.0.1 |
NETCONF server established a session. |
Informational |
Warning |
N/A (N/A) |
ON |
Notification triggers
This notification is generated when the NETCONF server establishes a session with a NETCONF client.
System impact
No negative impact on the system.
Status control
No action is required.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.206.1.1.1 (hh3cNetconfSessionId) |
N/A |
Integer32 |
Integer32 , (1..2147483647) |
1.3.6.1.4.1.25506.2.206.1.1.2 (hh3cNetconfSessionUserName) |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.206.1.1.3 (hh3cNetconfSessionPeerIPAddressType) |
N/A |
InetAddressType |
1.3.6.1.4.1.25506.2.206.1.1.4 (hh3cNetconfSessionPeerIPAddress) |
N/A |
InetAddress |
Recommended action
hh3cNetconfServerSessionEnd
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.206.2.0.2 |
NETCONF server ended a session |
Informational |
Warning |
N/A (N/A) |
ON |
This notification might be generated when the following events occur:
The NETCONF server receives a session termination request.
A persistent session is disconnected because of a network error.
A temporary session is disconnected because the session timeout time expires.
System impact
NETCONF server terminates a session.
Status control
This notification cannot be disabled.
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Integer32 |
N/A |
DisplayString |
N/A |
InetAddressType |
N/A |
InetAddress |
1.3.6.1.4.1.25506.2.206.1.1.5 (hh3cNetconfSessionTerminationReason) |
Reasons for the session to be disconnected by the NETCONF client: |
N/A |
INTEGER |
Options:, other(1)—Any other reason than those listed below., closed(2)—Session was closed., timeout(3)—Session exception occurred., idleTimeout(4)—Session timed out. |
Recommended action
● If the session was closed normally, no action is required.
● If the session was closed abnormally, check the physical link.
