- 20-Network Management and Monitoring
- 01-DISMAN-PING-MIB
- 02-DISMAN-TRACEROUTE-MIB
- 03-HH3C-HTTP-MIB
- 04-HH3C-INQA-MIB
- 05-HH3C-MIRRORGROUP-MIB
- 06-HH3C-NETCONF-MIB
- 07-HH3C-NQA-MIB
- 08-HH3C-NTP-MIB
- 09-HH3C-PTP-MIB
- 10-HH3C-RMON-EXT2-MIB
- 11-HH3C-SNMP-EXT-MIB
- 12-HH3C-TWAMP-MIB
- 13-RMON-MIB
- 14-RMON2-MIB
- 15-SNMP-FRAMEWORK-MIB
- 16-SNMP-MPD-MIB
- 17-SNMP-NOTIFICATION-MIB
- 18-SNMP-TARGET-MIB
- 19-SNMP-USER-BASED-SM-MIB
- 20-SNMP-VIEW-BASED-ACM-MIB
- 21-SNMPv2-MIB
05-HH3C-MIRRORGROUP-MIB | 80.98 KB |
About this MIB
Use this MIB to configure the source port, monitor port, reflector port, remote probe VLAN, and more.
MIB file name
hh3c-mirrorgroup.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMirrGroup(68)
Tabular objects
hh3cMGTable
About this table
This table creates, deletes, or obtains a mirroring group.
Support for operations
Create:Supported
Edit/Modify:Not supported
Delete:Supported
Read:Supported
Columns
The table index is h3cMGID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMGID (1.3.6.1.4.1.25506.2.68.1.1.1.1.1) |
not-accessible |
Integer32 |
0..2147483647 |
Mirroring group ID. |
Implementation varies by product. |
hh3cMGType (1.3.6.1.4.1.25506.2.68.1.1.1.1.2) |
read-create |
INTEGER |
local(1) remote-source(2) remote-destination(3) |
Mirroring group type. |
hh3cMGStatus (1.3.6.1.4.1.25506.2.68.1.1.1.1.3) |
read-only |
INTEGER |
active(1) inactive(2) |
Mirroring group state. |
As per the MIB. |
hh3cMGRowStatus (1.3.6.1.4.1.25506.2.68.1.1.1.1.4) |
read-create |
RowStatus |
Standard MIB values. |
Row status. |
Supports only the following values: active(1). createAndGo(4). destroy(6). |
hh3cMGMirrorIfTable
About this table
This table creates, deletes, or obtains a source port in a mirroring group.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cMGID, h3cMGMirrorIfIndex, and h3cMGMirrorDirection.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMGMirrorIfIndex (1.3.6.1.4.1.25506.2.68.1.2.1.1.1) |
not-accessible |
Integer32 |
Source port index. |
As per the MIB. |
hh3cMGMirrorDirection (1.3.6.1.4.1.25506.2.68.1.2.1.1.2) |
not-accessible |
INTEGER |
inbound(1) outbound(2) both(3) |
Mirroring direction. |
As per the MIB. |
hh3cMGMirrorRowStatus (1.3.6.1.4.1.25506.2.68.1.2.1.1.3) |
read-create |
RowStatus |
Row status. |
hh3cMGMonitorIfTable
About this table
This table creates, deletes, or obtains a monitor port in a mirroring group.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cMGID and h3cMGMonitorIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMGMonitorIfIndex (1.3.6.1.4.1.25506.2.68.1.3.1.1.1) |
not-accessible |
Integer32 |
Monitor port index. |
As per the MIB. |
hh3cMGMonitorRowStatus (1.3.6.1.4.1.25506.2.68.1.3.1.1.2) |
read-create |
RowStatus |
Row status. |
hh3cMGReflectorIfTable
About this table
This table creates, deletes, or obtains a reflector port in a mirroring group.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cMGID and h3cMGReflectorIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMGReflectorIfIndex (1.3.6.1.4.1.25506.2.68.1.4.1.1.1) |
not-accessible |
Integer32 |
Reflector port index. |
As per the MIB. |
hh3cMGReflectorRowStatus (1.3.6.1.4.1.25506.2.68.1.4.1.1.2) |
read-create |
RowStatus |
Row status. |
hh3cMGRprobeVlanTable
About this table
This table creates, deletes, or obtains a remote probe VLAN in a mirroring group.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cMGID and h3cMGRprobeVlanID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMGRprobeVlanID (1.3.6.1.4.1.25506.2.68.1.5.1.1.1) |
not-accessible |
Integer32 |
1..4094 |
Remote probe VLAN ID. |
As per the MIB. |
hh3cMGRprobeVlanRowStatus (1.3.6.1.4.1.25506.2.68.1.5.1.1.2) |
read-create |
RowStatus |
Row status. |
hh3cMGEgressIfTable
About this table
This table creates, deletes, or obtains an egress port in a mirroring group.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cMGID and h3cMGEgressIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMGEgressIfIndex (1.3.6.1.4.1.25506.2.68.1.6.1.1.1) |
not-accessible |
Integer32 |
0..2147483647 |
Egress port index. |
As per the MIB. |
hh3cMGEgressRowStatus (1.3.6.1.4.1.25506.2.68.1.6.1.1.2) |
read-create |
RowStatus |
Row status. |
hh3cMGMirrorCpuTable
About this table
This table creates, deletes, or obtains a source CPU in a mirroring group.
Create:Supported
Edit/Modify:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are h3cMGID, h3cMGMirrorCpuChassis, and h3cMGMirrorCpuSlot.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMGMirrorCpuChassis (1.3.6.1.4.1.25506.2.68.1.8.1.1.1) |
not-accessible |
Unsigned32 |
Chassis number for the source CPU. |
As per the MIB. |
hh3cMGMirrorCpuSlot (1.3.6.1.4.1.25506.2.68.1.8.1.1.2) |
not-accessible |
Unsigned32 |
Slot number for the source CPU. |
As per the MIB. |
hh3cMGMirrorCpuDirection (1.3.6.1.4.1.25506.2.68.1.8.1.1.3) |
read-create |
INTEGER |
inbound(1), outbound(2), both(3) |
As per the MIB. |
hh3cMGMirrorCpuRowStatus (1.3.6.1.4.1.25506.2.68.1.8.1.1.4) |
read-create |
RowStatus |
Row status. |
