17-User Access and Authentication
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R838x-6W10017-User Access and Authentication
13-RADIUS-AUTH-CLIENT-MIB
13-RADIUS-AUTH-CLIENT-MIB 68.50 KB
About this MIB
Use this MIB to collect statistics about authentication packets of different types that a RADIUS client receives from RADIUS servers.
MIB file name
radius-auth-client.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).radiusMIB(67).radiusAuthentication(1).radiusAuthClientMIB(2)
Scalar objects
radiusAuthClientInvalidServerAddresses (1.3.6.1.2.1.67.1.2.1.1.1)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Standard MIB values.
Number of unrecognizable IP addresses of authentication servers.
As per the MIB.
radiusAuthClientIdentifier (1.3.6.1.2.1.67.1.2.1.1.2)
Object (OID)
Access
Value range
Implementation
read-only
SnmpAdminString
OCTET STRING (SIZE (0..255))
ID of a client.
As per the MIB.
Tabular objects
radiusAuthServerTable
About this table
This table contains the statistics about authentication packets that a RADIUS client receives from a RADIUS server.
Support for operations
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table index is radiusAuthServerIndex.
Object (OID)
Access
Value range
Implementation
radiusAuthServerIndex (1.3.6.1.2.1.67.1.2.1.1.3.1.1)
not-accessible
Integer32
1..2147483647
Index of an authentication server.
As per the MIB.
radiusAuthServerAddress (1.3.6.1.2.1.67.1.2.1.1.3.1.2)
read-only
IpAddress
IP address of the authentication server.
As per the MIB.
radiusAuthClientServerPortNumber (1.3.6.1.2.1.67.1.2.1.1.3.1.3)
read-only
Integer32
0..65535
Port number of the authentication server.
As per the MIB.
radiusAuthClientRoundTripTime (1.3.6.1.2.1.67.1.2.1.1.3.1.4)
read-only
TimeTicks
TimeTick
Round trip time.
As per the MIB.
radiusAuthClientAccessRequests (1.3.6.1.2.1.67.1.2.1.1.3.1.5)
read-only
Counter32
Number of access requests sent to the server.
As per the MIB.
radiusAuthClientAccessRetransmissions (1.3.6.1.2.1.67.1.2.1.1.3.1.6)
read-only
Counter32
Number of access requests retransmitted.
As per the MIB.
radiusAuthClientAccessAccepts (1.3.6.1.2.1.67.1.2.1.1.3.1.7)
read-only
Counter32
Number of Access-Accept packets received.
As per the MIB.
radiusAuthClientAccessRejects (1.3.6.1.2.1.67.1.2.1.1.3.1.8)
read-only
Counter32
Number of Access-Reject packets received.
As per the MIB.
radiusAuthClientAccessChallenges (1.3.6.1.2.1.67.1.2.1.1.3.1.9)
read-only
Counter32
Number of Access-Challenge packets received.
As per the MIB.
radiusAuthClientMalformedAccessResponses (1.3.6.1.2.1.67.1.2.1.1.3.1.10)
read-only
Counter32
Number of malformed access responses received.
As per the MIB.
radiusAuthClientBadAuthenticators (1.3.6.1.2.1.67.1.2.1.1.3.1.11)
read-only
Counter32
Number of bad authenticators.
As per the MIB.
radiusAuthClientPendingRequests (1.3.6.1.2.1.67.1.2.1.1.3.1.12)
read-only
Gauge32
Number of pending authentication requests.
As per the MIB.
radiusAuthClientTimeouts (1.3.6.1.2.1.67.1.2.1.1.3.1.13)
read-only
Counter32
Number of timed out access requests.
As per the MIB.
radiusAuthClientUnknownTypes (1.3.6.1.2.1.67.1.2.1.1.3.1.14)
read-only
Counter32
Number of packets with unknown types.
As per the MIB.
radiusAuthClientPacketsDropped (1.3.6.1.2.1.67.1.2.1.1.3.1.15)
read-only
Counter32
Number of packets discarded.
As per the MIB.
