17-User Access and Authentication
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R838x-6W10017-User Access and Authentication
10-IEEE8021-SECY-MIB
10-IEEE8021-SECY-MIB 80.85 KB
IEEE8021-SECY-MIB
About this MIB
Use this MIB to manage MACsec.
MIB file name
ieee8021-secy.mib
Root object
iso(1).std(0).iso8802(8802).ieee802dot1(1).ieee802dot1mibs(1).ieee8021SecyMIB(3)
Tabular objects
secyIFTable
About this table
Use this table to configure or obtain information about MACsec-enabled interfaces.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is secyIfInterfaceIndex.
Object (OID)
Access
Value range
Implementation
secyIfInterfaceIndex (1.0.8802.1.1.3.1.1.1.1.1)
not-accessible
InterfaceIndex
Integer32 (1..2147483647)
An interface index for a port with SecY management ability.
As per the MIB.
secyIfMaxPeerSCs (1.0.8802.1.1.3.1.1.1.1.2)
read-only
Unsigned32
Standard MIB values.
Maximum number of peer SCs that this SecY can support.
Not supported.
secyIfRxMaxKeys (1.0.8802.1.1.3.1.1.1.1.3)
read-only
Unsigned32
Maximum number of keys in simultaneous use for reception that this SecY can support.
Not supported.
secyIfTxMaxKeys (1.0.8802.1.1.3.1.1.1.1.4)
read-only
Unsigned32
Maximum number of keys in simultaneous use for transmission that this SecY can support.
Not supported.
secyIfValidateFrames (1.0.8802.1.1.3.1.1.1.1.6)
read-write
INTEGER
disabled(1),
check(2),
strict(3)
An object to control the validation function for ingress frames.
Default: strict.
secyIfReplayProtectEnable (1.0.8802.1.1.3.1.1.1.1.7)
read-write
TruthValue
true(1),
false(2)
An object to enable or disable the replay protection function.
Supports only the read operation.
secyIfReplayProtectWindow (1.0.8802.1.1.3.1.1.1.1.8)
read-write
Unsigned32
Replay protection window size, in frames.
secyIfCurrentCipherSuite (1.0.8802.1.1.3.1.1.1.1.9)
read-write
Unsigned32
An object that points to an entry of the secyCipherSuiteTable with active row status to indicate the cipher suite that this SecY is currently using.
Not supported.
secyIfAdminPt2PtMAC (1.0.8802.1.1.3.1.1.1.1.10)
read-write
INTEGER
forceTrue(1),
forceFalse(2),
auto(3)
An object to control the service connectivity to at most one other system.
Not supported.
secyIfOperPt2PtMAC
(1.0.8802.1.1.3.1.1.1.1.11)
read-only
TruthValue
true(1),
false(2)
An object to reflect the current service connectivity status.
Not supported.
secyIfIncludeSCIEnable (1.0.8802.1.1.3.1.1.1.1.12)
read-write
TruthValue
true(1),
false(2)
An object indicates whether to include the SCI information in security TAG (SecTAG) field while transmitting MACsec frames.
Not supported.
secyIfUseESEnable (1.0.8802.1.1.3.1.1.1.1.13)
read-write
TruthValue
true(1),
false(2)
An object indicates whether to enable the ES bit in security TAG (SecTAG) field while transmitting MACsec frames.
Not supported.
secyIfUseSCBEnable (1.0.8802.1.1.3.1.1.1.1.14)
read-write
TruthValue
true(1),
false(2)
An object indicates whether to enable the SCB bit in security TAG (SecTAG) field while transmitting MACsec frames.
Not supported.
secyTxSCTable
About this table
Use this table to obtain information about transmitting SCs.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
secyTxSCI (1.0.8802.1.1.3.1.1.2.1.1)
read-only
SecySCI
OCTET STRING (0..65535)
SCI for transmitting MACsec frames of a transmitting SC in a SecY.
The read operation is returned a value only when MACsec is enabled on the port that holds the transmitting SC.
secyTxSCState (1.0.8802.1.1.3.1.1.2.1.2)
read-only
INTEGER
inUse(1),
notInUse(2)
State of the current transmitting SC in the SecY.
Not supported.
secyTxSCEncodingSA (1.0.8802.1.1.3.1.1.2.1.3)
read-only
RowPointer
Current transmitting SA in use.
secyTxSCEncipheringSA (1.0.8802.1.1.3.1.1.2.1.4)
read-only
RowPointer
Previous transmitting SA in use.
secyTxSCCreatedTime (1.0.8802.1.1.3.1.1.2.1.5)
read-only
TimeStamp
System time when the transmitting SC was created.
Not supported.
secyTxSCStartedTime (1.0.8802.1.1.3.1.1.2.1.6)
read-only
TimeStamp
System time when the transmitting SC last started transmitting MACsec frames.
Not supported.
secyTxSCStoppedTime (1.0.8802.1.1.3.1.1.2.1.7)
read-only
TimeStamp
System time when the transmitting SC last stopped transmitting MACsec frames.
Not supported.
secyTXSATable
About this table
Use this table to obtain information about transmitting SAs.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are secyIfInterfaceIndex and secyTxSA.
Object (OID)
Access
Value range
Implementation
secyTxSA (1.0.8802.1.1.3.1.1.3.1.1)
not-accessible
SecyAN
Unsigned32(0..4294967295)
Association number (AN) for identifying a transmitting SA.
As per the MIB.
secyTxSAState (1.0.8802.1.1.3.1.1.3.1.2)
read-only
INTEGER
inUse(1),
notInUse(2)
Current status of the transmitting SA.
Not supported.
secyTxSANextPN (1.0.8802.1.1.3.1.1.3.1.3)
read-only
Unsigned32
Unsigned32 (0..4294967295)
Next packet number (PN) that will be used in transmitting MACsec frames in the SA.
The read operation is returned a value only when MACsec is enabled on the port that holds the transmitting SA.
secyTxSAConfidentiality (1.0.8802.1.1.3.1.1.3.1.4)
read-only
TruthValue
true(1),
false(2)
Whether the SA supports the confidentiality as well as integrity function in transmitting frames.
Not supported.
secyTxSASAKUnchanged (1.0.8802.1.1.3.1.1.3.1.5)
read-only
TruthValue
true(1),
false(2)
A reference to an SAK that is unchanged for the life of the transmitting SA.
Not supported.
secyTxSACreatedTime (1.0.8802.1.1.3.1.1.3.1.6)
read-only
TimeStamp
System time when the transmitting SA was created.
Not supported.
secyTxSAStartedTime (1.0.8802.1.1.3.1.1.3.1.7)
read-only
TimeStamp
System time when the transmitting SA last started transmitting MACsec frames.
Not supported.
SecyTxSAStoppedTime
(1.0.8802.1.1.3.1.1.3.1.8)
read-only
TimeStamp
System time when the transmitting SA last stopped transmitting MACsec frames.
Not supported.
secyRxSCTable
About this table
Use this table to obtain information about receiving SCs.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are secyIfInterfaceIndex and secyRxSCI.
Object (OID)
Access
Value range
Implementation
secyRxSA (1.0.8802.1.1.3.1.1.5.1.1)
not-accessible
SecyAN
Association number (AN) for identifying a receiving SA.
As per the MIB.
secyRxSAState (1.0.8802.1.1.3.1.1.5.1.2)
read-only
INTEGER
inUse(1), notInUse(2)
Current state for the receiving SA.
Not supported.
secyRxSANextPN (1.0.8802.1.1.3.1.1.5.1.3)
read-write
Unsigned32
Stored packet number (PN) for replay protection in the SA.
The read operation is returned a value only when MACsec is enabled on the port that holds the receiving SA.
secyRxSASAKUnchanged (1.0.8802.1.1.3.1.1.5.1.4)
read-only
TruthValue
true(1),
false(2)
A reference to an SAK that is unchanged for the life of the receiving SA.
Not supported.
secyRxSACreatedTime (1.0.8802.1.1.3.1.1.5.1.5)
read-only
TimeStamp
System time when the receiving SA was created.
Not supported.
secyRxSAStartedTime (1.0.8802.1.1.3.1.1.5.1.6)
read-only
TimeStamp
System time when the receiving SA last started receiving MACsec frames.
Not supported.
SecyRxSAStoppedTime
(1.0.8802.1.1.3.1.1.5.1.7)
read-only
TimeStamp
System time when the receiving SA last stopped  receiving MACsec frames.
Not supported.
