17-User Access and Authentication
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R838x-6W10017-User Access and Authentication
06-HH3C-PORTAL-MIB
06-HH3C-PORTAL-MIB 75.67 KB
HH3C-PORTAL-MIB
About this MIB
Use this MIB to configure portal authentication and obtain portal authentication information.
MIB file name
hh3c-portal.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cPortal(99)
Tabular objects
hh3cPortalExtSrvTable
About this table
Use this table to configure a portal authentication server and obtain portal configuration and portal running state information.
Support for operations
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table index is hh3cPortalExtSrvName.
Object (OID)
Access
Value range
Implementation
hh3cPortalExtSrvName (1.3.6.1.4.1.25506.2.99.7.1.1.1)
not-accessible
OCTET STRING
OCTET STRING (SIZE (0..32))
Name of the portal authentication server.
As per the MIB.
hh3cPortalExtSrvIPAddrType (1.3.6.1.4.1.25506.2.99.7.1.1.2)
read-create
InetAddressType
Standard MIB values.
IP address type of the portal authentication server.
You must specify hh3cPortalExtSrvIPAddrType and hh3cPortalExtSrvIP in pairs.
hh3cPortalExtSrvIP (1.3.6.1.4.1.25506.2.99.7.1.1.3)
read-create
InetAddress
OCTET STRING (0..255)
IP address of the portal authentication server.
hh3cPortalExtSrvPort (1.3.6.1.4.1.25506.2.99.7.1.1.4)
read-write
Integer32
Integer32 (1..65534)
Port number of the portal authentication server.
As per the MIB.
hh3cPortalExtSrvRowStatus (1.3.6.1.4.1.25506.2.99.7.1.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
As per the MIB.
hh3cPortalExtSrvVpnName (1.3.6.1.4.1.25506.2.99.7.1.1.6)
read-create
OCTET STRING
OCTET STRING (SIZE (0..31))
VPN instance name.
You must specify hh3cPortalExtSrvVpnName together with hh3cPortalExtSrvIPAddrType and hh3cPortalExtSrvIP.
hh3cPortalExtSrvKey (1.3.6.1.4.1.25506.2.99.7.1.1.7)
read-create
OCTET STRING
OCTET STRING (SIZE (0..64))
Shared key for communication with the portal authentication server.
You must specify hh3cPortalExtSrvKey together with hh3cPortalExtSrvIPAddrType and hh3cPortalExtSrvIP.
A string of 0 to 64 characters. When read, this object returns a zero-length string.
Notifications
hh3cPortalServerLost
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.99.3.0.1
Portal authentication server is unreachable.
Error
Major
1.3.6.1.4.1.25506.2.99.3.0.2 (hh3cPortalServerGet)
OFF
Notification triggers
This notification is generated when the device receives no portal packets sent by the portal authentication server within the specified detection period.
This notification might be generated when the following events occur:
The device and the portal authentication server cannot reach each other.
The server heartbeat feature is disabled on the portal authentication server.
System impact
Portal users cannot log in.
Status control
ON
CLI: Use the server-detect trap command in portal authentication server view.
OFF
CLI: Use the undo server-detect command in portal authentication server view.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.99.2.1.1.1 (hh3cPortalServerName)
OCTET STRING
OCTET STRING (1..32)
1.3.6.1.4.1.25506.2.99.3.1.1 (hh3cPortalFirstTrapTime)
Time when this notification is triggered.
N/A
Timeticks
1.3.6.1.4.1.25506.2.99.3.1.2 (hh3cPortalServerIP)
InetAddress
1.3.6.1.4.1.25506.2.99.2.1.1.3 (hh3cPortalServerPort)
Integer32
Recommended action
To resolve this issue:
1.Use the ping or ping ipv6 command to check whether the portal authentication server is reachable:
  - If no, troubleshoot the reachability between the device and the portal authentication server.
  - If yes, go to step 2.
2.Check whether the server heartbeat feature is enabled on the portal authentication server. If the heartbeat feature is enabled, make sure the server heartbeat interval configured on the portal authentication server is smaller than the detection timeout configured on the device.
  - If no, enable the server heartbeat feature on the portal authentication server and configure the server heartbeat interval as required.
  - If yes, go to step 3.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cPortalServerGet
Basic information
OID
Event
Severity
Default status
Portal authentication server is reachable.
Recovery
Warning
N/A (N/A)
OFF
This notification is generated when the device receives portal packets sent by the portal authentication server within the specified detection period.
The device receives portal packets sent by the portal authentication server within the specified detection period.
The server detection feature is disabled for the portal authentication server.
System impact
No negative impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
OCTET STRING
N/A
Timeticks
InetAddress
Integer32
Recommended action
No action is required.
