15-ACL and QoS
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R838x-6W10015-ACL and QoS
06-IEEE8021-CN-MIB
06-IEEE8021-CN-MIB 81.70 KB
IEEE8021-CN-MIB
About this MIB
Use this MIB to configure QCN to control congestion on a CP, including CND settings and congestion detection settings
MIB file name
ieee8021-cn.mib
Root object
iso(1).org(3).oid_ieee(111).oid_standards-association-numbered-series-standards(2).oid_lan-man-stds(802). oid_ieee802dot1(1).oid_ieee802dot1mibs(1).ieee8021CnMib(18)
Tabular objects
ieee8021CnGlobalTable
About this table
This table configures global QCN settings.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is ieee8021CnGlobalComponentId.
Object (OID)
Access
Value range
Implementation
ieee8021CnGlobalComponentId (1.3.111.2.802.1.1.18.1.1.1.1)
not-accessible
IEEE8021PbbComponentIdentifier
Standard MIB values.
Component ID.
The value is fixed at 1.
ieee8021CnGlobalMasterEnable (1.3.111.2.802.1.1.18.1.1.1.2)
read-write
TruthValue
true(1)
false(2)
Global QCN state.
As per the MIB.
ieee8021CnGlobalCnmTransmitPriority (1.3.111.2.802.1.1.18.1.1.1.3)
read-write
IEEE8021PriorityValue
Priority of outgoing CNMs.
Not supported..
ieee8021CnGlobalDiscardedFrames (1.3.111.2.802.1.1.18.1.1.1.4)
read-only
Counter64
Number of frames discarded from full CP queues.
Not supported..
ieee8021CnErroredPortTable
About this table
This table obtains the index of the interface on which a CNPV is configured as an alternate priority.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ieee8021CnEpComponentId, ieee8021CnEpPriority, and ieee8021CnEpIfIndex.
Object (OID)
Access
Value range
Implementation
ieee8021CnEpComponentId (1.3.111.2.802.1.1.18.1.2.1.1)
not-accessible
Component ID.
ieee8021CnEpPriority (1.3.111.2.802.1.1.18.1.2.1.2)
not-accessible
Alternate priority.
As per the MIB.
ieee8021CnEpIfIndex (1.3.111.2.802.1.1.18.1.2.1.3)
read-only
InterfaceIndex
Interface index.
As per the MIB.
ieee8021CnCompntPriTable
About this table
This table configures global CND settings.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are ieee8021CnComPriComponentId and ieee8021CnComPriPriority.
Object (OID)
Access
Value range
Implementation
ieee8021CnComPriComponentId (1.3.111.2.802.1.1.18.1.3.1.1)
not-accessible
Component ID.
ieee8021CnComPriPriority (1.3.111.2.802.1.1.18.1.3.1.2)
not-accessible
802.1p priority.
As per the MIB.
ieee8021CnComPriDefModeChoice (1.3.111.2.802.1.1.18.1.3.1.3)
read-create
Ieee8021CnControlChoice
Defense mode choosing mode.
As per the MIB.
ieee8021CnComPriAlternatePriority (1.3.111.2.802.1.1.18.1.3.1.4)
read-create
Alternate priority in Admin mode.
As per the MIB.
ieee8021CnComPriAutoAltPri (1.3.111.2.802.1.1.18.1.3.1.5)
read-only
Alternate priority in Auto mode.
As per the MIB.
ieee8021CnComPriAdminDefenseMode (1.3.111.2.802.1.1.18.1.3.1.6)
read-create
Ieee8021CnDefenseMode
Defense mode in Admin mode.
As per the MIB.
ieee8021CnComPriCreation (1.3.111.2.802.1.1.18.1.3.1.7)
read-create
INTEGER
cncpAutoEnable(1)
cncpAutoDisable(2)
Creation method.
Not supported.
ieee8021CnComPriLldpInstanceChoice (1.3.111.2.802.1.1.18.1.3.1.8)
read-create
Ieee8021CnLldpChoice
LLDP instance choosing mode.
Not supported.
ieee8021CnComPriLldpInstanceSelector (1.3.111.2.802.1.1.18.1.3.1.9)
read-create
LldpV2DestAddressTableIndex
LLDP instance index.
Not supported.
ieee8021CnComPriRowStatus (1.3.111.2.802.1.1.18.1.3.1.10)
read-create
RowStatus
Row status.
active(1)
createAndGo(4)
destroy(6)
ieee8021CnPortPriTable
About this table
This table configures CND settings on an interface.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ieee8021CnPortPriComponentId, ieee8021CnPortPriority, and ieee8021CnPortPriIfIndex.
Object (OID)
Access
Value range
Implementation
ieee8021CnPortPriComponentId (1.3.111.2.802.1.1.18.1.4.1.1)
not-accessible
Component ID.
ieee8021CnPortPriority (1.3.111.2.802.1.1.18.1.4.1.2)
not-accessible
802.1p priority.
As per the MIB.
ieee8021CnPortPriIfIndex (1.3.111.2.802.1.1.18.1.4.1.3)
not-accessible
InterfaceIndex
Interface index.
As per the MIB.
ieee8021CnPortPriDefModeChoice (1.3.111.2.802.1.1.18.1.4.1.4)
read-write
Priority value choosing mode.
As per the MIB.
ieee8021CnPortPriAdminDefenseMode (1.3.111.2.802.1.1.18.1.4.1.5)
read-write
As per the MIB.
ieee8021CnPortPriAutoDefenseMode (1.3.111.2.802.1.1.18.1.4.1.6)
read-only
Negotiated defense mode in Auto mode.
As per the MIB.
ieee8021CnPortPriLldpInstanceChoice (1.3.111.2.802.1.1.18.1.4.1.7)
read-write
Not supported.
ieee8021CnPortPriLldpInstanceSelector (1.3.111.2.802.1.1.18.1.4.1.8)
read-write
Selected LLDP instance.
Not supported.
ieee8021CnPortPriAlternatePriority (1.3.111.2.802.1.1.18.1.4.1.9)
read-write
As per the MIB.
ieee8021CnCpTable
About this table
This table obtains congestion detection settings.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ieee8021CnCpComponentId, ieee8021CnCpIfIndex, and ieee8021CnCpIndex.
Object (OID)
Access
Value range
Implementation
ieee8021CnCpComponentId (1.3.111.2.802.1.1.18.1.5.1.1
not-accessible
Component ID.
ieee8021CnCpIfIndex (1.3.111.2.802.1.1.18.1.5.1.2
not-accessible
InterfaceIndex
Interface index.
As per the MIB.
ieee8021CnCpIndex (1.3.111.2.802.1.1.18.1.5.1.3
not-accessible
Unsigned32
1..4096
CP index.
As per the MIB.
ieee8021CnCpPriority (1.3.111.2.802.1.1.18.1.5.1.4
read-only
802.1p priority.
As per the MIB.
ieee8021CnCpMacAddress (1.3.111.2.802.1.1.18.1.5.1.5
read-only
MacAddress
Source MAC address of outgoing CNMs.
Not supported.
ieee8021CnCpIdentifier (1.3.111.2.802.1.1.18.1.5.1.6
read-only
OCTET STRING
SIZE(8)
CPID in CNMs.
Not supported.
ieee8021CnCpQueueSizeSetPoint (1.3.111.2.802.1.1.18.1.5.1.7
read-write
Unsigned32
100..4294967295
Desired queue length.
Supports only the read operation.
ieee8021CnCpFeedbackWeight (1.3.111.2.802.1.1.18.1.5.1.8)
read-write
Integer32
-10..10
Weight value.
ieee8021CnCpMinSampleBase (1.3.111.2.802.1.1.18.1.5.1.9)
read-write
Unsigned32
10000..4294967295
Minimum number of octets to enqueue in the CP's queue between transmissions of CNMs.
Not supported.
ieee8021CnCpDiscardedFrames (1.3.111.2.802.1.1.18.1.5.1.10)
read-only
Counter64
Number of data frames discarded.
As per the MIB.
ieee8021CnCpTransmittedFrames (1.3.111.2.802.1.1.18.1.5.1.11)
read-only
Counter64
Number of data frames passed on to the queue.
As per the MIB.
ieee8021CnCpTransmittedCnms (1.3.111.2.802.1.1.18.1.5.1.12)
read-only
Counter64
Number of CNMs transmitted.
As per the MIB.
ieee8021CnCpMinHeaderOctets (1.3.111.2.802.1.1.18.1.5.1.13)
read-write
Unsigned32
0..64
Minimum number of octets to be returned in a CNM
Not supported.
