15-ACL and QoS
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R838x-6W10015-ACL and QoS
03-HH3C-IFQOS2-MIB
03-HH3C-IFQOS2-MIB 271.53 KB
HH3C-IFQOS2-MIB
About this MIB
Use this MIB to configure or obtain settings for the following modules:
   Hardware queuing.
   Software queuing.
   Rate limit.
   CAR.
   GTS.
   WRED.
   Port priority and priority trust mode.
   Priority map.
CAR includes aggregate CAR and three-color CAR. WRED includes table-based WRED and interface WRED.
WRED
WRED avoids global TCP synchronization by randomly dropping packets before a queue is full. WRED sets an upper threshold and lower threshold for each queue, and processes the packets in a queue as follows:
When the queue size is shorter than the lower threshold, no packet is dropped.
When the queue size reaches the upper threshold, all subsequent packets are dropped.
When the queue size is between the lower threshold and the upper threshold, the received packets are dropped at random. The drop probability in a queue increases along with the queue size under the maximum drop probability.
WRED can discard packets based on the IP precedence, DSCP, or MPLS EXP value and selectively discard low-priority packets.
Through combining WRED with WFQ, the flow-based WRED can be realized.
WRED has the following types:
Port-based WRED: Applies WRED to all packets on a port.
Queue-based WRED: Applies WRED to only packets on WRED-enabled queues.
Drop level-based WRED: Applies different WRED parameters to packets with different WRED parameters.
ACL-based WRED: Applies different WRED parameters to packets matching different ACLs.
802.1p-based WRED: Applies different WRED parameters to packets with different 802.1p priorities.
EXP-based WRED: Applies different WRED parameters to packets with different EXP priorities.
ATM CLP-based WRED: Applies different WRED parameters to packets with different CLP priorities.
DSCP-based WRED: Applies different WRED parameters to packets with different DSCP values.
IP precedence-based WRED: Applies different WRED parameters to packets with different IP precedences.
FR DE-based WRED: Applies different WRED parameters to packets with different DE bit settings.
ComwareV500R002 supports two WRED configuration approaches:
Interface configurationConfigure WRED parameters on an interface or PVC and enable WRED.
WRED table configurationConfigure a WRED table in system view and then apply the WRED table to an interface. A maximum number of 64 WRED tables is supported.
Aggregate CAR
Some switch models support aggregate CAR.
An aggregate CAR action is created globally. It can be directly applied to interfaces or used in the traffic behaviors associated with different traffic classes to police multiple traffic flows as a whole. The total rate of the traffic flows must conform to the traffic policing specifications set in the aggregate CAR action.
MIB file name
hh3c-ifqos2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).huawei(2011).hh3c(10).hh3cCommon(2).hh3cQos2(65).hh3cIfQos2(1)
Tabular objects
hh3cIfQoSQSWeightTable
About this table
This table configures attributes for non-SP queues. This table and hh3cIfQoSQSModeTable together configure the queuing settings.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table indexes are ifIndex and hh3cIfQoSQueueID.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSQueueID (1.3.6.1.4.1.25506.2.65.1.1.1.2.1.1)
not-accessible
Integer32
Standard MIB values.
Queue ID.
As per the MIB.
hh3cIfQoSHardwareQueueRunInfoTable
About this table
This table contains queue-based traffic statistics.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cIfQoSPassPackets (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.1)
read-only
Counter64
Number of forwarded packets.
As per the MIB.
hh3cIfQoSDropPackets (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.2)
read-only
Counter64
Number of dropped packets.
As per the MIB.
hh3cIfQoSPassBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.3)
read-only
Counter64
Number of forwarded bytes.
As per the MIB.
hh3cIfQoSPassPPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.4)
read-only
Unsigned32
Packet forwarding rate in packets per second.
As per the MIB.
hh3cIfQoSPassBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.5)
read-only
Unsigned32
Packet forwarding rate in bytes per second.
As per the MIB.
hh3cIfQoSDropBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.6)
read-only
Counter64
Number of dropped bytes.
As per the MIB.
hh3cIfQoSQueueLengthInPkts (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.7)
read-only
Unsigned32
Maximum queue length in packets.
As per the MIB.
hh3cIfQoSQueueLengthInBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.8)
read-only
Unsigned32
Maximum queue length in bytes.
Not supported
hh3cIfQoSCurQueuePkts (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.9)
read-only
Unsigned32
Current queue length in packets.
Not supported
hh3cIfQoSCurQueueBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.10)
read-only
Unsigned32
Current queue length in bytes.
Not supported
hh3cIfQoSCurQueuePPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.11)
read-only
Unsigned32
Number of packets enqueued per second.
Not supported
hh3cIfQoSCurQueueBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.12)
read-only
Unsigned32
Number of bytes enqueued per second.
Not supported
hh3cIfQoSTailDropPkts (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.13)
read-only
Counter64
Number of packets dropped by tail drop.
Not supported
hh3cIfQoSTailDropBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.14)
read-only
Counter64
Number of bytes dropped by tail drop.
Not supported
hh3cIfQoSTailDropPPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.15)
read-only
Unsigned32
Number of packets dropped per second by tail drop.
Not supported
hh3cIfQoSTailDropBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.16)
read-only
Unsigned32
Number of bytes dropped per second by tail drop.
Not supported
hh3cIfQoSWredDropPkts (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.17)
read-only
Counter64
Number of packets dropped by WRED.
Not supported
hh3cIfQoSWredDropBytes (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.18)
read-only
Counter64
Number of bytes dropped by WRED.
Not supported
hh3cIfQoSWredDropPPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.19)
read-only
Unsigned32
Number of packets dropped per second by WRED.
Not supported
hh3cIfQoSWredDropBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.20)
read-only
Unsigned32
Number of bytes dropped per second by WRED.
Not supported
hh3cIfQoSDropPPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.22)
read-only
Unsigned32
Number of packets dropped per second.
As per the MIB.
hh3cIfQoSDropBPS (1.3.6.1.4.1.25506.2.65.1.1.2.1.1.23)
read-only
Unsigned32
Number of bytes dropped per second.
As per the MIB.
hh3cIfQoSLRConfigTable
About this table
This table configures the inbound or outbound rate limit on an interface.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are ifIndex and hh3cIfQoSLRDirection.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSLRDirection (1.3.6.1.4.1.25506.2.65.1.3.1.1.1)
not-accessible
Direction
Rate limit direction.
Implementation varies by product.
hh3cIfQoSLRCir (1.3.6.1.4.1.25506.2.65.1.3.1.1.2)
read-create
Unsigned32
CIR.
hh3cIfQoSLRCbs (1.3.6.1.4.1.25506.2.65.1.3.1.1.3)
read-create
Unsigned32
CBS.
hh3cIfQoSLRUnit (1.3.6.1.4.1.25506.2.65.1.3.1.1.7)
read-create
INTEGER
unitAbsolute(1)
unitPercent(2)
Rate limit unit.
hh3cIfQoSAggregativeCarConfigTable
About this table
This table contains aggregate CAR configuration, which can police the traffic on multiple ports.  Routers do not support aggregate CAR. Some switch models support aggregate CAR.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table index is hh3cIfQoSAggregativeCarIndex.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSAggregativeCarIndex (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.1)
not-accessible
Integer32
1..65534
Aggregate CAR index.
As per the MIB.
hh3cIfQoSAggregativeCarName (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.2)
read-create
OCTET STRING
SIZE (1..31)
Aggregate CAR name.
As per the MIB.
hh3cIfQoSAggregativeCarCir (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.3)
read-create
Unsigned32
CIR.
As per the MIB.
hh3cIfQoSAggregativeCarCbs (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.4)
read-create
Unsigned32
CBS.
hh3cIfQoSAggregativeCarEbs (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.5)
read-create
Unsigned32
EBS.
hh3cIfQoSAggregativeCarPir (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.6)
read-create
Unsigned32
PIR.
hh3cIfQoSAggregativeCarType (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.13)
read-create
INTEGER
aggregative(1)
NotAggregative(2)
hierarchy(3)
Aggregate CAR type.
hh3cIfQoSAggregativeCarRowStatus (1.3.6.1.4.1.25506.2.65.1.4.1.2.1.14)
read-create
RowStatus
Row status.
As per the MIB.
hh3cIfQoSAggregativeCarApplyTable
About this table
This table contains aggregate CAR application information for an interface.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are ifIndex, hh3cIfQoSAggregativeCarApplyDirection, hh3cIfQoSAggregativeCarApplyRuleType, and hh3cIfQoSAggregativeCarApplyRuleValue.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSAggregativeCarApplyDirection (1.3.6.1.4.1.25506.2.65.1.4.1.3.1.1)
not-accessible
Direction
CAR direction.
hh3cIfQoSAggregativeCarApplyRuleType (1.3.6.1.4.1.25506.2.65.1.4.1.3.1.2)
read-create
INTEGER
ipv4acl(1)
ipv6acl(2)
carl(3)
any(4)
CAR type.
hh3cIfQoSAggregativeCarApplyRuleValue (1.3.6.1.4.1.25506.2.65.1.4.1.3.1.3)
read-create
Integer32
0..2147483647
CAR type value.
.Implementation varies by product.
hh3cIfQoSAggregativeCarRunInfoTable
About this table
This table contains aggregate CAR statistics.
CreateNot supported
DeleteNot supported
ReadNot supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cIfQoSAggregativeCarGreenBytes (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.2)
read-only
Counter64
Number of green bytes.
hh3cIfQoSAggregativeCarYellowBytes (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.4)
read-only
Counter64
Number of yellow bytes.
hh3cIfQoSAggregativeCarRedBytes (1.3.6.1.4.1.25506.2.65.1.4.1.4.1.6)
read-only
Counter64
Number of red bytes.
hh3cIfQoSGTSConfigTable
About this table
This table contains GTS configuration information.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are ifIndex, hh3cIfQoSGTSClassRuleType, and hh3cIfQoSGTSClassRuleValue.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.65.1.5.1.1.1)
not-accessible
INTEGER
any(1)
ipv4acl(2)
ipv6acl(3)
queue(4)
GTS type.
Supports only queue(4).
hh3cIfQoSGTSClassRuleValue (1.3.6.1.4.1.25506.2.65.1.5.1.1.2)
not-accessible
Integer32
0..2147483647
GTS type value.
The value range is 0 to 7.
hh3cIfQoSGTSCir (1.3.6.1.4.1.25506.2.65.1.5.1.1.3)
read-create
Unsigned32
CIR.
The value range is 300 to 1000000 for GE interfaces.
The value range is 300 to 10000000 for 10-GE interfaces.
The value range is 300 to 40000000 for 40-GE interfaces.
The value range is 300 to 100000000 for 100-GE interfaces.
hh3cIfQoSGTSCbs (1.3.6.1.4.1.25506.2.65.1.5.1.1.4)
read-create
Unsigned32
CBS.
The value range is 4096 to 133169152 for GE interfaces.
The value range is 4096 to 133169152 for 10-GE interfaces.
The value range is 4096 to 535822336 for 40-GE interfaces.
The value range is 4096 to 1341128704 for 100-GE interfaces.
hh3cIfQoSGTSEbs (1.3.6.1.4.1.25506.2.65.1.5.1.1.5)
read-create
Unsigned32
EBS in bytes.
Not supported.
hh3cIfQoSGTSQueueLength (1.3.6.1.4.1.25506.2.65.1.5.1.1.6)
read-create
Integer32
Queue length.
Not supported.
hh3cIfQoSGTSConfigRowStatus (1.3.6.1.4.1.25506.2.65.1.5.1.1.7)
read-create
RowStatus
Row status.
active(1)
createAndGo(4)
destroy(6)
hh3cIfQoSGTSPir (1.3.6.1.4.1.25506.2.65.1.5.1.1.8)
read-create
Unsigned32
PIR.
Not supported.
hh3cIfQoSGTSUnitType (1.3.6.1.4.1.25506.2.65.1.5.1.1.9)
read-create
INTEGER
unitAbsolute (1)
unitPercent(2)
GTS unit.
Supports only unitAbsolute(1).
hh3cIfQoSWredGroupTable
About this table
This table creates a WRED table.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table index is hh3cIfQoSWredGroupIndex.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSWredGroupIndex (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.1)
not-accessible
Integer32
0..256
WRED table index.
hh3cIfQoSWredGroupName (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.2)
read-create
OCTET STRING
SIZE (1..32)
WRED table name.
As per the MIB.
hh3cIfQoSWredGroupWeightingConstant (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.4)
read-create
Integer32
1..15
WRED exponent for average queue size calculation.
The default value is 9.
hh3cIfQoSWredGroupRowStatus (1.3.6.1.4.1.25506.2.65.1.6.1.2.1.6)
read-create
RowStatus
Row status.
As per the MIB.
hh3cIfQoSWredGroupContentTable
About this table
This table configures a WRED table.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cIfQoSWredGroupIndex, hh3cIfQoSWredGroupContentIndex, and hh3cIfQoSWredGroupContentSubIndex.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSWredGroupContentIndex (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.1)
not-accessible
Integer32
0..63
Second index.
hh3cIfQoSWredGroupContentSubIndex (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.2)
not-accessible
Integer32
0..63
Third index.
hh3cIfQoSWredLowLimit (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.3)
read-create
Integer32
Lower limit.
hh3cIfQoSWredHighLimit (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.4)
read-create
Integer32
Higher limit.
hh3cIfQoSWredDiscardProb (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.5)
read-create
Integer32
Drop probability.
hh3cIfQoSWredGroupExponent (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.6)
read-create
Integer32
0..15
hh3cIfQoSWredRowStatus (1.3.6.1.4.1.25506.2.65.1.6.1.3.1.7)
read-create
RowStatus
Row status.
As per the MIB.
hh3cIfQoSWredGroupApplyIfTable
About this table
This table contains WRED table application information for an interface.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSWredGroupApplyIndex (1.3.6.1.4.1.25506.2.65.1.6.1.4.1.1)
read-create
Integer32
0..256
WRED table index.
As per the MIB.
hh3cIfQoSWredGroupApplyName (1.3.6.1.4.1.25506.2.65.1.6.1.4.1.2)
read-only
OCTET STRING
SIZE (1..32)
WRED table name.
As per the MIB.
hh3cIfQoSWredGroupIfRowStatus (1.3.6.1.4.1.25506.2.65.1.6.1.4.1.3)
read-create
RowStatus
Row status.
As per the MIB.
hh3cIfQoSPortPriorityTable
About this table
This table contains the port priority. After the switch receives a packet, it performs priority mapping according to the configured priority trust mode. If no local precedence is successfully assigned or no packet priority is trusted, the switch uses the priority of the input interface as the local precedence or 802.1p priority for priority mapping. Routers do not support this table.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cIfQoSPortPriorityValue (1.3.6.1.4.1.25506.2.65.1.7.1.1.1.1)
read-write
Integer32
0..7
Port priority.
hh3cIfQoSPortPirorityTrustTable
About this table
This table contains the priority trust mode.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cIfQoSPortPriorityTrustOvercastType (1.3.6.1.4.1.25506.2.65.1.7.1.2.1.2)
read-write
INTEGER
noOvercast(1)
overcastDSCP(2)
overcastCOS(3)
overcast(4)
Overwrite mode.
hh3cIfQoSPrePriMapTable
About this table
This table configures a priority map.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cIfQoSPrePriMapTableType, hh3cIfQoSPrePriMapTableColor, hh3cIfQoSPrePriMapTableDirection, and hh3cIfQoSPrePriMapTableImportValue.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSPrePriMapTableType (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.1)
not-accessible
INTEGER
dot1pToLp(1)
dot1pToDp(2)
expToLp(3)
dscpToLp(4)
expToDp(5)
dscpToDp(6)
dscpToDot1p(7)
dot1pToDscp(8)
dscpToDscp(9)
dscpToExp(10)
expToDscp(11)
expToDot1p(12)
expToExp(13)
lpToDot1p(14)
dot1pToRpr(15)
dscpToRpr(16)
expToRpr(17)
ippreToRpr(18)
upToDot1p(19)
upToDscp(20)
upToExp(21)
upToDp(22)
upToLp(23)
upToRpr(24)
upToFc(25)
lpTodscp(26)
dot11eToLp(27)
lpToDot11e(28)
lpToLp(29)
dot1pToExp(30)
lpToExp(31)
lpToDp(32)
upToUp(33)
dot1pToDot1p(34)
Priority map type.
hh3cIfQoSPrePriMapTableColor (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.2)
not-accessible
INTEGER
nocolor(1)
green(2)
yellow(3)
red(4)
Priority map color.
hh3cIfQoSPrePriMapTableDirection (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.3)
not-accessible
INTEGER
nodirection(1)
inbound(2)
outbound(3)
Priority map direction.
hh3cIfQoSPrePriMapTableImportValue (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.4)
not-accessible
Integer32
0..63
Input values of the priority map.
As per the MIB.
hh3cIfQoSPrePriMapTableExportValue (1.3.6.1.4.1.25506.2.65.1.9.1.4.1.5)
read-write
Integer32
0..63
Output values of the priority map.
As per the MIB.
hh3cIfQoSCoppFlowStatTable
About this table
This table contains protocol traffic statistics for a control plane.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cIfQoSCoppFlowStatChassis, hh3cIfQoSCoppFlowStatSlot, and hh3cIfQoSCoppFlowStatProType.
Object (OID)
Access
Value range
Implementation
hh3cIfQoSCoppFlowStatChassis (1.3.6.1.4.1.25506.2.65.1.14.1.1.1)
not-accessible
Unsigned32
Chassis number for the control plane.
As per the MIB.
hh3cIfQoSCoppFlowStatSlot (1.3.6.1.4.1.25506.2.65.1.14.1.1.2)
not-accessible
Unsigned32
Slot number for the control plane.
As per the MIB.
hh3cIfQoSCoppFlowStatProType (1.3.6.1.4.1.25506.2.65.1.14.1.1.3)
not-accessible
Unsigned32
1..65
Protocol type.
As per the MIB.
hh3cIfQoSCoppFlowPassPackets (1.3.6.1.4.1.25506.2.65.1.14.1.1.4)
read-only
Counter64
As per the MIB.
hh3cIfQoSCoppFlowPassBytes (1.3.6.1.4.1.25506.2.65.1.14.1.1.5)
read-only
Counter64
As per the MIB.
hh3cIfQoSCoppFlowDropPackets (1.3.6.1.4.1.25506.2.65.1.14.1.1.6)
read-only
Counter64
As per the MIB.
hh3cIfQoSCoppFlowDropBytes (1.3.6.1.4.1.25506.2.65.1.14.1.1.7)
read-only
Counter64
As per the MIB.
Notifications
hh3cIfQoS8QueueResouceOverAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.1
The downlink resources of an 8-queue scheduling profile are insufficient.
Error
Major
hh3cIfQoS8QueueResouceOverRecover (hh3cIfQoS8QueueResouceOverRecover)
OFF
Notification triggers
The notification is generated when the downlink (network side to user side) resources of an 8-queue scheduling profile are insufficient.
System impact
The qos user-queue command might not take effect.
Status control
ON
CLI: Use the snmp-agent trap enable qos command.
OFF
CLI: Use the undo snmp-agent trap enable qos command.
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
 (1.3.6.1.4.1.25506.2.65.1.15.1)
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
 (1.3.6.1.4.1.25506.2.65.1.15.2)
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
 (1.3.6.1.4.1.25506.2.65.1.15.3)
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSChip
 (1.3.6.1.4.1.25506.2.65.1.15.4)
Chip number
N/A
Integer32
0 to 65534
hh3cIfQoSDirection (1.3.6.1.4.1.25506.2.65.1.15.6)
Direction
N/A
Direction
As per the MIB
Recommended action
To resolve the issue:
1.Delete or optimized related configuration.
2.If you cannot identify the configuration to be deleted or optimized, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.2
The resources of an 8-queue user-queue profile are sufficient.
Recovery
Major
N/A (N/A)
OFF
The notification is generated when the resources of an 8-queue user-queue profile are sufficient.
System impact
No negative impact on the system.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSChip
Chip number
N/A
Integer32
0 to 65534
Direction
N/A
Direction
As per the MIB
Recommended action
No action is required.
hh3cIfQoS8QueueResoucePreAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.3
The resource usage of an 8-queue scheduling profile exceeds 90%.
Error
Minor
hh3cIfQoS8QueueResoucePreRecover (hh3cIfQoS8QueueResoucePreRecover)
OFF
The notification is generated when the resource usage of an 8-queue scheduling profile exceeds 90%.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSChip
Chip number
N/A
Integer32
0 to 65534
Direction
N/A
Direction
As per the MIB
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.4
The resource usage of an 8-queue scheduling profile fell below 90%.
Recovery
Minor
N/A (N/A)
OFF
The notification is generated when the resource usage of an 8-queue scheduling profile falls below 90%.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSChip
Chip number
N/A
Integer32
0 to 65534
Direction
N/A
Direction
As per the MIB
Recommended action
hh3cIfQoSBufferOverAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.5
Queue buffer usage alarm.
Error
Minor
hh3cIfQoSBufferOverRecover (hh3cIfQoSBufferOverRecover)
OFF
An alarm is generated when the queue buffer usage reaches or exceeds 90%.
System impact
Packet loss occurs on high-priority queues.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSChip
Chip number
N/A
Integer32
0 to 65534
Direction
N/A
Direction
As per the MIB
Recommended action
1.Reduce deployed services.
2.If the issue persists, collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.6
Queue buffer usage alarm recovery.
Recovery
Minor
N/A (N/A)
OFF
The notification is generated when the queue buffer usage alarm recovers.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSChip (1.3.6.1.4.1.25506.2.65.1.15.4)
Chip number
N/A
Integer32
0 to 65534
Recommended action
hh3cIfQoSModeChannelOverPortShapAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.7
The channelized bandwidth exceeds the interface rate limit.
Error
Major
hh3cIfQoSModeChannelOverPortShapRecover (hh3cIfQoSModeChannelOverPortShapRecover)
OFF
The notification is generated when the channelized bandwidth exceeds the interface rate limit.
System impact
The channelized bandwidth does not take effect.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
hh3cIfQoSIfName (1.3.6.1.4.1.25506.2.65.1.15.5)
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Recommended action
1.Use the mode channel-bandwidth command to set a smaller channelized bandwidth.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.8
The channelized bandwidth is smaller than the interface rate limit.
Recovery
Major
N/A (N/A)
OFF
The notification is generated when the channelized bandwidth is smaller than the interface rate limit.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Recommended action
hh3cIfQoSExclusiveBandApplyFailAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.9
Exclusive bandwidth application failure alarm.
Error
Major
hh3cIfQoSExclusiveBandApplyFailRecover (hh3cIfQoSExclusiveBandApplyFailRecover)
OFF
The notification is generated when the exclusive bandwidth fails to be applied.
System impact
The exclusive bandwidth does not take effect.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Recommended action
Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.10
Exclusive bandwidth application failure alarm recovery.
Recovery
Major
N/A (N/A)
OFF
The notification is generated when the exclusive bandwidth application failure alarm recovers.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Recommended action
None.
hh3cIfQoSExclusiveBandOverAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.11
Exclusive bandwidth exceeding maximum interface bandwidth.
Recovery
Major
hh3cIfQoSExclusiveBandOverRecover (hh3cIfQoSExclusiveBandOverRecover)
OFF
The notification is generated when the exclusive bandwidth value exceeds the maximum interface bandwidth. The configuration will also become ineffective.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Recommended action
Configure an exclusive bandwidth value that is smaller than the maximum interface bandwidth.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.12
Exclusive bandwidth exceeding maximum interface bandwidth alarm recovery.
Recovery
Major
N/A (N/A)
OFF
The notification is generated when the alarm that the configured exclusive bandwidth value exceeds the maximum interface bandwidth recovers.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cIfQoSChassis
Chassis number
N/A
Integer32
0 to 65534
hh3cIfQoSSlot
Slot number
N/A
Integer32
0 to 65534
hh3cIfQoSCPU
CPU number
N/A
Integer32
0 to 65534
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Recommended action
hh3cIfQoSLRDiscardAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.13
The outgoing traffic of an interface exceeds the configured CIR
Recovery
Major
hh3cIfQoSLRDiscardAlarmRecover (hh3cIfQoSLRDiscardAlarmRecover)
OFF
The notification is generated when the outgoing traffic of an interface exceeds the configured CIR.
System impact
The outgoing traffic of an interface might be dropped.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.65.1.15.5 (hh3cIfQoSIfName)
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
1.3.6.1.4.1.25506.2.65.1.3.1.1.2 (hh3cIfQoSLRCir)
CIR
N/A
Unsigned32
1.3.6.1.4.1.25506.2.65.1.15.7 (hh3cIfQoSPassPacketRate)
Outgoing traffic rate of the interface
N/A
Unsigned32
Recommended action
Increase the CIR on the interface.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.14
The outgoing traffic rate of an interface drops below the configured CIR
Recovery
Major
N/A (N/A)
OFF
The notification is generated when the outgoing traffic rate of an interface drops below the configured CIR.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
CIR
N/A
Unsigned32
N/A
Unsigned32
Recommended action
hh3cIfQoSCarDiscardAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.15
Packets are dropped by CAR on an interface
Recovery
Major
hh3cIfQoSCarDiscardAlarmRecover (hh3cIfQoSCarDiscardAlarmRecover)
OFF
The notification is generated when packets are dropped by CAR on an interface.
System impact
Traffic might be dropped.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.65.1.15.1 (hh3cIfQoSChassis)
Chassis number
N/A
Integer32
0 to 65534
1.3.6.1.4.1.25506.2.65.1.15.2 (hh3cIfQoSSlot)
Slot number
N/A
Integer32
0 to 65534
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
1.3.6.1.4.1.25506.2.65.1.15.6 (hh3cIfQoSDirection)
Direction
N/A
Direction
Recommended action
Cancel the CAR settings or increase the CIR.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.16
Packets dropped by CAR on an interface have been recovered
Recovery
Major
N/A (N/A)
OFF
The notification is generated when packets dropped by CAR on an interface have been recovered.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Interface name
N/A
OCTET STRING
SIZE (1 to 47)
Direction
N/A
Direction
Recommended action
hh3cIfQoSCoppDropPktAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.17
Packets are dropped by CAR on the control plane
Recovery
Major
hh3cIfQoSCoppDropPktAlarmRecover (hh3cIfQoSCoppDropPktAlarmRecover)
OFF
The notification is generated when packets are dropped by CAR on the control plane.
System impact
Packets are dropped by CAR on the control plane, and services or internal control information might not be able to be processed.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
1.3.6.1.4.1.25506.2.65.1.15.8 (hh3cIfQoSCoppProtocol)
Protocol type
N/A
OCTET STRING
SIZE (1 to 31)
1.3.6.1.4.1.25506.2.65.1.15.9 (hh3cIfQoSBandwidth)
Bandwidth
N/A
Unsigned32
1.3.6.1.4.1.25506.2.65.1.15.13 (hh3cIfQoSBandwidthUnit)
Bandwidth unit
N/A
INTEGER
unitUnavailable (0), unitAbsolute (1), unitAbsolutePPS (4)
Recommended action
Cancel the CAR settings for the control plane.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.18
Packets dropped by CAR on the control plane have been recovered
Recovery
Major
N/A (N/A)
OFF
The notification is generated when packets dropped by CAR on the control plane have been recovered.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Protocol type
N/A
OCTET STRING
SIZE (1 to 31)
Bandwidth
N/A
Unsigned32
Bandwidth unit
N/A
INTEGER
Recommended action
hh3cIfQoSQueExcpAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.19
Packets fail to be forwarded due to queue exceptions.
Recovery
Major
hh3cIfQoSQueExcpAlarmRecover (hh3cIfQoSQueExcpAlarmRecover)
OFF
The notification is generated when packets fail to be forwarded due to queue exceptions.
System impact
Packets cannot be forwarded.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Protocol type
N/A
OCTET STRING
SIZE (1 to 31)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.20
Packets failing to be forwarded due to queue exceptions have been recovered.
Recovery
Major
N/A (N/A)
OFF
The notification is generated when packets failing to be forwarded due to queue exceptions have been recovered.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Protocol type
N/A
OCTET STRING
SIZE (1 to 31)
Recommended action
hh3cIfQoSBoardL3AclResLack
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.21
Layer 3 ACL resources are insufficient.
Recovery
Major
N/A (N/A)
OFF
The notification is generated when Layer 3 ACL resources are insufficient.
System impact
ACL rules do not take effect or fail to be matched.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
1.3.6.1.4.1.25506.2.65.1.15.10 (hh3cIfQoSServiceName)
Service name
N/A
OCTET STRING
SIZE (1 to 63)
1.3.6.1.4.1.25506.2.65.1.15.12 (hh3cIfQoSFailReason)
Failure reason
N/A
OCTET STRING
SIZE (1 to 127)
Recommended action
hh3cIfQoSAclResAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.22
Recovery
Major
hh3cIfQoSAclResAlarmRecover (hh3cIfQoSAclResAlarmRecover)
OFF
The notification is generated when ACL resources are insufficient.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Service name
N/A
OCTET STRING
SIZE (1 to 63)
1.3.6.1.4.1.25506.2.65.1.15.11 (hh3cIfQoSApplyObject)
Application object
N/A
OCTET STRING
SIZE (1 to 127)
Direction
N/A
Direction
Failure reason
N/A
OCTET STRING
SIZE (1 to 127)
Recommended action
Basic information
OID
Event
Severity
Default status
The ACL resource alarm is cleared.
Recovery
Major
N/A (N/A)
OFF
The notification is generated when the ACL resource alarm is cleared.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Service name
N/A
OCTET STRING
SIZE (1 to 63)
Application object
N/A
OCTET STRING
SIZE (1 to 127)
Direction
N/A
Direction
Failure reason
N/A
OCTET STRING
SIZE (1 to 127)
Recommended action
hh3cIfQoSAclMemFullAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.24
The ACL forwarding engine memory is exhausted.
Recovery
Major
hh3cIfQoSAclMemFullAlarmRecover (hh3cIfQoSAclMemFullAlarmRecover)
OFF
The notification is generated when the ACL forwarding engine memory is exhausted.
System impact
ACL rules fail to be matched.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.65.1.16.0.25
The ACL forwarding engine memory is recovered.
Recovery
Major
N/A (N/A)
OFF
The notification is generated when the ACL forwarding engine memory is recovered.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number
N/A
Integer32
0 to 65534
Slot number
N/A
Integer32
0 to 65534
Recommended action
