15-ACL and QoS
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R838x-6W10015-ACL and QoS
01-HH3C-ACL-MIB
01-HH3C-ACL-MIB 207.34 KB
HH3C-ACL-MIB
About this MIB
This MIB provides some basic table for managing ACLs on a switch.
MIB file name
hh3c-acl.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cAcl(8)
Tabular objects
hh3cAclMib2CapabilityTable
About this table
ACL capability set. Use this table to obtain product-supported ACL information for only user-defined ACLs.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cAclMib2EntityType, hh3cAclMib2EntityIndex, hh3cAclMib2ModuleIndex, and hh3cAclMib2CharacteristicsIndex.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.8.2.1.2.1.1)
not-accessible
INTEGER
system(1)
interface(2)
Type of the entity where the ACL is configured and applied.
As per the MIB.
(1.3.6.1.4.1.25506.2.8.2.1.2.1.2)
not-accessible
Integer32
0..2147483647
Index of the entity type.
As per the MIB.
(1.3.6.1.4.1.25506.2.8.2.1.2.1.3)
not-accessible
INTEGER
layer3(1)
layer2(2)
userDefined(3)
Index of the ACL type.
As per the MIB.
(1.3.6.1.4.1.25506.2.8.2.1.2.1.4)
not-accessible
Integer32
0..2147483647
Index of the ACL attribute.
As per the MIB.
hh3cAclMib2CharacteristicsDesc
(1.3.6.1.4.1.25506.2.8.2.1.2.1.5)
read-only
OCTET STRING
SIZE (0..255)
Description of the ACL attribute.
Not supported.
hh3cAclMib2CharacteristicsValue
(1.3.6.1.4.1.25506.2.8.2.1.2.1.6)
read-only
Unsigned32
Standard MIB values.
Value of the ACL attribute.
Not supported.
hh3cAclNumberGroupTable
About this table
This table records numbered ACL configuration information.
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cAclNumberGroupType and hh3cAclNumberGroupIndex.
Object (OID)
Access
Value range
Implementation
hh3cAclNumberGroupType (1.3.6.1.4.1.25506.2.8.2.1.3.1.1)
not-accessible
INTEGER
ipv4(1)
ipv6(2)
mac(3)
user(4)
ACL type.
Implementation varies by product
hh3cAclNumberGroupIndex (1.3.6.1.4.1.25506.2.8.2.1.3.1.2)
not-accessible
Integer32
2000..5999
10000..42767
ACL number index.
hh3cAclNumberGroupRowStatus (1.3.6.1.4.1.25506.2.8.2.1.3.1.3)
read-create
RowStatus
Row status.
active(1)
createAndGo(4)
destroy(6)
hh3cAclNumberGroupMatchOrder (1.3.6.1.4.1.25506.2.8.2.1.3.1.4)
read-create
INTEGER
config(1)
auto(2)
Rule match order.
As per the MIB.
hh3cAclNumberGroupStep (1.3.6.1.4.1.25506.2.8.2.1.3.1.5)
read-create
Integerd32
1..20
Rule numbering step.
As per the MIB.
hh3cAclNumberGroupDescription (1.3.6.1.4.1.25506.2.8.2.1.3.1.6)
read-create
OCTET STRING
SIZE (0..127)
ACL description.
As per the MIB.
hh3cAclNumberGroupCountClear (1.3.6.1.4.1.25506.2.8.2.1.3.1.7)
read-write
CounterClear
Clear rule statistics for the ACL.
As per the MIB.
hh3cAclNumberGroupRuleCounter (1.3.6.1.4.1.25506.2.8.2.1.3.1.8)
read-only
Counter32
Number of rules in the ACL.
As per the MIB.
hh3cAclNamedGroupTable
About this table
This table records named ACL configuration information. Use this table to add or delete a named ACL.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cAclNumberGroupType, hh3cAclNamedGroupCategory, and hh3cAclNamedGroupName.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.8.2.1.4.1.1)
not-accessible
INTEGER
invalid(0)
basic(1)
advanced(2)
ACL category.
As per the MIB.
hh3cAclNamedGroupName (1.3.6.1.4.1.25506.2.8.2.1.4.1.2)
not-accessible
OCTET STRING
SIZE (1..63)
ACL name.
As per the MIB.
hh3cAclNamedGroupRowStatus (1.3.6.1.4.1.25506.2.8.2.1.4.1.3)
read-create
RowStatus
Row status.
active(1)
createAndGo(4)
destroy(6)
hh3cAclNamedGroupMatchOrder (1.3.6.1.4.1.25506.2.8.2.1.4.1.4)
read-create
INTERGER
config(1)
auto(2)
Rule match order.
As per the MIB.
hh3cAclNamedGroupStep (1.3.6.1.4.1.25506.2.8.2.1.4.1.5)
read-create
Integer32
1..20
As per the MIB.
hh3cAclNamedGroupDescription (1.3.6.1.4.1.25506.2.8.2.1.4.1.6)
read-create
OCTET STRING
SIZE (0..127)
ACL description.
As per the MIB.
hh3cAclNamedGroupCountClear (1.3.6.1.4.1.25506.2.8.2.1.4.1.7)
read-write
CounterClear
As per the MIB.
hh3cAclNamedGroupRuleCounter (1.3.6.1.4.1.25506.2.8.2.1.4.1.8)
read-only
Counter32
As per the MIB.
hh3cAclIPAclBasicTable
About this table
This table records basic ACL configuration information. Use this table to add or delete a basic ACL rule.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cAclNumberGroupType, hh3cAclNumberGroupIndex, and hh3cAclIPAclBasicRuleIndex.
Object (OID)
Access
Value range
Implementation
hh3cAclIPAclBasicRuleIndex (1.3.6.1.4.1.25506.2.8.2.2.2.1.1)
not-accessible
Integer32
0..65534
ACL rule ID.
As per the MIB.
hh3cAclIPAclBasicRowStatus (1.3.6.1.4.1.25506.2.8.2.2.2.1.2)
read-create
RowStatus
Row status.
active(1)
createAndGo(4)
destroy(6)
hh3cAclIPAclBasicAct (1.3.6.1.4.1.25506.2.8.2.2.2.1.3)
read-create
RuleAction
Action type.
permit(2)
deny(3)
hh3cAclIPAclBasicSrcAddrType (1.3.6.1.4.1.25506.2.8.2.2.2.1.4)
read-create
InetAddressType
Source address type.
As per the MIB.
hh3cAclIPAclBasicSrcAddr (1.3.6.1.4.1.25506.2.8.2.2.2.1.5)
read-create
InetAddress
Source IP address.
As per the MIB.
hh3cAclIPAclBasicSrcPrefix (1.3.6.1.4.1.25506.2.8.2.2.2.1.6)
read-create
InetAddressPrefixLength
Source IP address prefix.
As per the MIB.
hh3cAclIPAclBasicSrcAny (1.3.6.1.4.1.25506.2.8.2.2.2.1.7)
read-create
TruthValue
true(1)
false(2)
Whether the source IP address can be any.
Default: true(1).
hh3cAclIPAclBasicSrcWild (1.3.6.1.4.1.25506.2.8.2.2.2.1.8)
read-create
IpAddress
Source IP address wildcard mask.
As per the MIB.
hh3cAclIPAclBasicTimeRangeName (1.3.6.1.4.1.25506.2.8.2.2.2.1.9)
read-create
OCTET STRING
SIZE (0..32)
Time range name.
As per the MIB.
hh3cAclIPAclBasicFragmentFlag (1.3.6.1.4.1.25506.2.8.2.2.2.1.10)
read-create
FragmentFlag
Fragment flag.
Support 0 and 2.
hh3cAclIPAclBasicLog (1.3.6.1.4.1.25506.2.8.2.2.2.1.11)
read-create
TruthValue
true(1)
false(2)
Enabling status of the logging feature.
As per the MIB.
hh3cAclIPAclBasicCount (1.3.6.1.4.1.25506.2.8.2.2.2.1.12)
read-only
Unsigned32
Number of packets matching the ACL rule.
As per the MIB.
hh3cAclIPAclBasicCountClear (1.3.6.1.4.1.25506.2.8.2.2.2.1.13)
read-write
INTEGER
Clear the rule match count.
Not supported
hh3cAclIPAclBasicEnable (1.3.6.1.4.1.25506.2.8.2.2.2.1.14)
read-only
TruthValue
true(1)
false(2)
Enabling status of the rule.
As per the MIB.
hh3cAclIPAclBasicVpnInstanceName (1.3.6.1.4.1.25506.2.8.2.2.2.1.15)
read-create
OCTET STRING
SIZE (0..32)
VPN instance name.
hh3cAclIPAclBasicComment (1.3.6.1.4.1.25506.2.8.2.2.2.1.16)
read-create
OCTET STRING
SIZE (0..127)
Rule description.
Read and write.
hh3cAclIPAclBasicCounting (1.3.6.1.4.1.25506.2.8.2.2.2.1.17)
read-create
TruthValue
true(1)
false(2)
Enabling status of counting packets matching the rule.
As per the MIB.
hh3cAclIPAclBasicRouteTypeAny (1.3.6.1.4.1.25506.2.8.2.2.2.1.18)
read-create
TruthValue
true(1)
false(2)
Whether the rule matches all types of IPv6 routing headers.
As per the MIB.
hh3cAclIPAclAdvancedTable
About this table
This table records advanced ACL configuration information. Use this table to add or delete an advanced ACL rule.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cAclNumberGroupType, hh3cAclNumberGroupIndex, and hh3cAclIPAclAdvancedRuleIndex.
Object (OID)
Access
Value range
Implementation
hh3cAclIPAclAdvancedRuleIndex (1.3.6.1.4.1.25506.2.8.2.2.3.1.1)
not-accessible
Integer32
0..65534
ACL rule ID.
As per the MIB.
hh3cAclIPAclAdvancedRowStatus (1.3.6.1.4.1.25506.2.8.2.2.3.1.2)
read-create
RowStatus
Row status.
active(1)
createAndGo(4)
destroy(6)
hh3cAclIPAclAdvancedAct (1.3.6.1.4.1.25506.2.8.2.2.3.1.3)
read-create
RuleAction
Action type.
permit(2)
deny(3)
hh3cAclIPAclAdvancedProtocol (1.3.6.1.4.1.25506.2.8.2.2.3.1.4)
read-create
INTEGER
0..255
Number of a Layer 3 protocol or a protocol above Layer 3.
As per the MIB.
hh3cAclIPAclAdvancedAddrFlag (1.3.6.1.4.1.25506.2.8.2.2.3.1.5)
read-create
AddressFlag
Address flag for the IPv6 source address and destination address.
Not supported
hh3cAclIPAclAdvancedSrcAddrType (1.3.6.1.4.1.25506.2.8.2.2.3.1.6)
read-create
InetAddressType
Source IP address type.
As per the MIB.
hh3cAclIPAclAdvancedSrcAddr (1.3.6.1.4.1.25506.2.8.2.2.3.1.7)
read-create
InetAddress
Source IP address.
As per the MIB.
hh3cAclIPAclAdvancedSrcPrefix (1.3.6.1.4.1.25506.2.8.2.2.3.1.8)
read-create
As per the MIB.
hh3cAclIPAclAdvancedSrcAny (1.3.6.1.4.1.25506.2.8.2.2.3.1.9)
read-create
TruthValue
true(1)
false(2)
Whether the source IP address can be any value.
Default: true(1).
hh3cAclIPAclAdvancedSrcWild (1.3.6.1.4.1.25506.2.8.2.2.3.1.10)
read-create
IpAddress
As per the MIB.
hh3cAclIPAclAdvancedSrcOp (1.3.6.1.4.1.25506.2.8.2.2.3.1.11)
read-create
PortOp
Port operator.
As per the MIB.
hh3cAclIPAclAdvancedSrcPort1 (1.3.6.1.4.1.25506.2.8.2.2.3.1.12)
read-create
Integer32
0..65535
Source UDP or TCP port 1.
As per the MIB.
hh3cAclIPAclAdvancedSrcPort2 (1.3.6.1.4.1.25506.2.8.2.2.3.1.13)
read-create
Integer32
0..65535
Source UDP or TCP port 2.
As per the MIB.
hh3cAclIPAclAdvancedDestAddrType (1.3.6.1.4.1.25506.2.8.2.2.3.1.14)
read-create
InetAddressType
Destination address type.
As per the MIB.
hh3cAclIPAclAdvancedDestAddr (1.3.6.1.4.1.25506.2.8.2.2.3.1.15)
read-create
InetAddress
Destination IP address.
As per the MIB.
hh3cAclIPAclAdvancedDestPrefix (1.3.6.1.4.1.25506.2.8.2.2.3.1.16)
read-create
Destination address prefix.
As per the MIB.
hh3cAclIPAclAdvancedDestAny (1.3.6.1.4.1.25506.2.8.2.2.3.1.17)
read-create
TruthValue
true(1)
false(2)
Whether the destination IP address can be any value.
Default: true(1).
hh3cAclIPAclAdvancedDestWild (1.3.6.1.4.1.25506.2.8.2.2.3.1.18)
read-create
IpAddress
Destination IP address wildcard mask.
As per the MIB.
hh3cAclIPAclAdvancedDestOp (1.3.6.1.4.1.25506.2.8.2.2.3.1.19)
read-create
PortOp
Port operator.
As per the MIB.
hh3cAclIPAclAdvancedDestPort1 (1.3.6.1.4.1.25506.2.8.2.2.3.1.20)
read-create
Integer32
0..65535
Destination UDP or TCP port 1.
As per the MIB.
hh3cAclIPAclAdvancedDestPort2 (1.3.6.1.4.1.25506.2.8.2.2.3.1.21)
read-create
Integer32
0..65535
Destination UDP or TCP port 2.
As per the MIB.
hh3cAclIPAclAdvancedIcmpType (1.3.6.1.4.1.25506.2.8.2.2.3.1.22)
read-create
Integer32
0..255
65535
ICMP message type.
As per the MIB.
hh3cAclIPAclAdvancedIcmpCode (1.3.6.1.4.1.25506.2.8.2.2.3.1.23)
read-create
Integer32
0..255
65535
ICMP message code.
As per the MIB.
hh3cAclIPAclAdvancedPrecedence (1.3.6.1.4.1.25506.2.8.2.2.3.1.24)
read-create
Integer32
0..7
255
IP precedence.
As per the MIB.
hh3cAclIPAclAdvancedTos (1.3.6.1.4.1.25506.2.8.2.2.3.1.25)
read-create
Integer32
0..15
255
ToS type
As per the MIB.
hh3cAclIPAclAdvancedDscp (1.3.6.1.4.1.25506.2.8.2.2.3.1.26)
read-create
DSCPValue
0..63
255
DSCP value.
As per the MIB.
hh3cAclIPAclAdvancedTimeRangeName (1.3.6.1.4.1.25506.2.8.2.2.3.1.27)
read-create
OCTET STRING
SIZE (0..32)
Time range name.
As per the MIB.
hh3cAclIPAclAdvancedTCPFlag (1.3.6.1.4.1.25506.2.8.2.2.3.1.28)
read-create
TCPFlag
TCP flag.
As per the MIB.
hh3cAclIPAclAdvancedFragmentFlag (1.3.6.1.4.1.25506.2.8.2.2.3.1.29)
read-create
FragmentFlag
Fragments flag.
Support 0 and 2.
hh3cAclIPAclAdvancedLog (1.3.6.1.4.1.25506.2.8.2.2.3.1.30)
read-create
TruthValue
true(1)
false(2)
As per the MIB.
hh3cAclIPAclAdvancedCount (1.3.6.1.4.1.25506.2.8.2.2.3.1.31)
read-only
Unsigned32
As per the MIB.
hh3cAclIPAclAdvancedCountClear (1.3.6.1.4.1.25506.2.8.2.2.3.1.32)
read-write
CounterClear
Not supported
hh3cAclIPAclAdvancedEnable (1.3.6.1.4.1.25506.2.8.2.2.3.1.33)
read-only
TruthValue
true(1)
false(2)
As per the MIB.
hh3cAclIPAclAdvancedVpnInstanceName (1.3.6.1.4.1.25506.2.8.2.2.3.1.34)
read-create
OCTET STRING
SIZE (0..32)
VPN instance name.
Implementation varies by product.
hh3cAclIPAclAdvancedComment (1.3.6.1.4.1.25506.2.8.2.2.3.1.35)
read-create
OCTET STRING
SIZE (0..127)
Rule description.
Read and write.
hh3cAclIPAclAdvancedReflective (1.3.6.1.4.1.25506.2.8.2.2.3.1.36)
read-create
TruthValue
true(1)
false(2)
Whether it is a reflective rule.
Not supported
hh3cAclIPAclAdvancedCounting (1.3.6.1.4.1.25506.2.8.2.2.3.1.37)
read-create
TruthValue
true(1)
false(2)
As per the MIB.
hh3cAclIPAclAdvancedTCPFlagMask (1.3.6.1.4.1.25506.2.8.2.2.3.1.38)
read-create
Hh3cAlarmStatus
tcpack(0)
tcpfin(1)
tcppsh(2)
tcprst(3)
tcpsyn(4)
tcpurg(5)
TCP flag bit mask.
As per the MIB.
hh3cAclIPAclAdvancedTCPFlagValue (1.3.6.1.4.1.25506.2.8.2.2.3.1.39)
read-create
Hh3cAlarmStatus
tcpack(0)
tcpfin(1)
tcppsh(2)
tcprst(3)
tcpsyn(4)
tcpurg(5)
TCP flag bit set.
As per the MIB.
hh3cAclIPAclAdvancedRouteTypeAny (1.3.6.1.4.1.25506.2.8.2.2.3.1.40)
read-create
TruthValue
true(1)
false(2)
As per the MIB.
hh3cAclIPAclAdvancedFlowLabel (1.3.6.1.4.1.25506.2.8.2.2.3.1.42)
read-create
Unsigned32
0..1048575
4294967295
Flow label.
Default: 0.
hh3cAclIPAclAdvancedSrcSuffix(1.3.6.1.4.1.25506.2.8.2.2.3.1.43)
read-create
Unsigned32
Source address suffix.
Not supported.
hh3cAclIPAclAdvancedDestSuffix(1.3.6.1.4.1.25506.2.8.2.2.3.1.44)
read-create
Unsigned32
Destination address suffix.
Not supported.
hh3cAclIPAclNamedBscTable
About this table
This table records basic ACL configuration information. Use this table to add or delete a basic named ACL.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cAclNumberGroupType, hh3cAclNamedGroupName, and hh3cAclIPAclBasicRuleIndex.
Object (OID)
Access
Value range
Implementation
hh3cAclIPAclNamedBscRowStatus (1.3.6.1.4.1.25506.2.8.2.2.4.1.1)
read-create
RowStatus
Row status.
active(1)
createAndGo(4)
destroy(6)
hh3cAclIPAclNamedBscAct (1.3.6.1.4.1.25506.2.8.2.2.4.1.2)
read-create
RuleAction
Action type.
permit(2)
deny(3)
hh3cAclIPAclNamedBscSrcAddrType (1.3.6.1.4.1.25506.2.8.2.2.4.1.3)
read-create
InetAddressType
As per the MIB.
hh3cAclIPAclNamedBscSrcAddr (1.3.6.1.4.1.25506.2.8.2.2.4.1.4)
read-create
InetAddress
Source IP address.
As per the MIB.
hh3cAclIPAclNamedBscSrcPrefix (1.3.6.1.4.1.25506.2.8.2.2.4.1.5)
read-create
As per the MIB.
hh3cAclIPAclNamedBscSrcAny (1.3.6.1.4.1.25506.2.8.2.2.4.1.6)
read-create
TruthValue
true(1)
false(2)
Default: true(1)
hh3cAclIPAclNamedBscSrcWild (1.3.6.1.4.1.25506.2.8.2.2.4.1.7)
read-create
IpAddress
As per the MIB.
hh3cAclIPAclNamedBscTimeRangeName (1.3.6.1.4.1.25506.2.8.2.2.4.1.8)
read-create
OCTET STRING
SIZE (0..32)
Time range name.
As per the MIB.
hh3cAclIPAclNamedBscFragmentFlag (1.3.6.1.4.1.25506.2.8.2.2.4.1.9)
read-create
FragmentFlag
Fragments flag.
Support 0 and 2.
hh3cAclIPAclNamedBscLog (1.3.6.1.4.1.25506.2.8.2.2.4.1.10)
read-create
TruthValue
true(1)
false(2)
As per the MIB.
hh3cAclIPAclNamedBscCount (1.3.6.1.4.1.25506.2.8.2.2.4.1.11)
read-only
Unsigned32
As per the MIB.
hh3cAclIPAclNamedBscCountClear (1.3.6.1.4.1.25506.2.8.2.2.4.1.12)
read-write
CounterClear
Not supported
hh3cAclIPAclNamedBscEnable (1.3.6.1.4.1.25506.2.8.2.2.4.1.13)
read-only
TruthValue
true(1)
false(2)
As per the MIB.
hh3cAclIPAclNamedBscVpnInstName (1.3.6.1.4.1.25506.2.8.2.2.4.1.14)
read-create
OCTET STRING
SIZE(0..32)
VPN instance name.
hh3cAclIPAclNamedBscComment (1.3.6.1.4.1.25506.2.8.2.2.4.1.15)
read-create
OCTET STRING
SIZE (0..127)
Rule description.
Read and write.
hh3cAclIPAclNamedBscCounting
(1.3.6.1.4.1.25506.2.8.2.2.4.1.16)
read-create
TruthValue
true(1)
false(2)
As per the MIB.
hh3cAclIPAclNamedBscRouteTypeAny (1.3.6.1.4.1.25506.2.8.2.2.4.1.17)
read-create
TruthValue
true(1)
false(2)
As per the MIB.
hh3cAclIPAclNamedAdvTable
About this table
This table records advanced ACL configuration information. Use this table to add or delete an advanced named ACL.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cAclNumberGroupType, hh3cAclNamedGroupName, and hh3cAclIPAclAdvancedRuleIndex.
Object (OID)
Access
Value range
Implementation
hh3cAclIPAclNamedAdvRowStatus (1.3.6.1.4.1.25506.2.8.2.2.5.1.1)
read-create
RowStatus
Row status.
active(1)
createAndGo(4)
destroy(6)
hh3cAclIPAclNamedAdvAct (1.3.6.1.4.1.25506.2.8.2.2.5.1.2)
read-create
RuleAction
Action type.
permit(2)
deny(3)
hh3cAclIPAclNamedAdvProtocol (1.3.6.1.4.1.25506.2.8.2.2.5.1.3)
read-create
Integer32
0..255
As per the MIB.
hh3cAclIPAclNamedAdvAddrFlag (1.3.6.1.4.1.25506.2.8.2.2.5.1.4)
read-create
AddressFlag
Not supported
hh3cAclIPAclNamedAdvSrcAddrType (1.3.6.1.4.1.25506.2.8.2.2.5.1.5)
read-create
InetAddressType
As per the MIB.
hh3cAclIPAclNamedAdvSrcAddr (1.3.6.1.4.1.25506.2.8.2.2.5.1.6)
read-create
InetAddress
Source IP address.
As per the MIB.
hh3cAclIPAclNamedAdvSrcPrefix (1.3.6.1.4.1.25506.2.8.2.2.5.1.7)
read-create
As per the MIB.
hh3cAclIPAclNamedAdvSrcAny (1.3.6.1.4.1.25506.2.8.2.2.5.1.8)
read-create
TruthValue
true(1)
false(2)
Default: true(1)
hh3cAclIPAclNamedAdvSrcWild (1.3.6.1.4.1.25506.2.8.2.2.5.1.9)
read-create
IpAddress
As per the MIB.
hh3cAclIPAclNamedAdvSrcOp (1.3.6.1.4.1.25506.2.8.2.2.5.1.10)
read-create
PortOp
Port operator.
As per the MIB.
hh3cAclIPAclNamedAdvSrcPort1 (1.3.6.1.4.1.25506.2.8.2.2.5.1.11)
read-create
Integer32
0..65535
As per the MIB.
hh3cAclIPAclNamedAdvSrcPort2 (1.3.6.1.4.1.25506.2.8.2.2.5.1.12)
read-create
Integer32
0..65535
As per the MIB.
hh3cAclIPAclNamedAdvDstAddrType (1.3.6.1.4.1.25506.2.8.2.2.5.1.13)
read-create
InetAddressType
As per the MIB.
hh3cAclIPAclNamedAdvDstAddr (1.3.6.1.4.1.25506.2.8.2.2.5.1.14)
read-create
InetAddress
As per the MIB.
hh3cAclIPAclNamedAdvDstPrefix (1.3.6.1.4.1.25506.2.8.2.2.5.1.15)
read-create
As per the MIB.
hh3cAclIPAclNamedAdvDstAny (1.3.6.1.4.1.25506.2.8.2.2.5.1.16)
read-create
TruthValue
true(1)
false(2)
Default: true(1)
hh3cAclIPAclNamedAdvDstWild (1.3.6.1.4.1.25506.2.8.2.2.5.1.17)
read-create
IpAddress
As per the MIB.
hh3cAclIPAclNamedAdvDstOp (1.3.6.1.4.1.25506.2.8.2.2.5.1.18)
read-create
PortOp
Port operator.
As per the MIB.
hh3cAclIPAclNamedAdvDstPort1 (1.3.6.1.4.1.25506.2.8.2.2.5.1.19)
read-create
Integer32
0..65535
As per the MIB.
hh3cAclIPAclNamedAdvDstPort2 (1.3.6.1.4.1.25506.2.8.2.2.5.1.20)
read-create
Integer32
0..65535
As per the MIB.
hh3cAclIPAclNamedAdvIcmpType (1.3.6.1.4.1.25506.2.8.2.2.5.1.21)
read-create
Integer32
0..255
65535
ICMP message type.
As per the MIB.
hh3cAclIPAclNamedAdvIcmpCode (1.3.6.1.4.1.25506.2.8.2.2.5.1.22)
read-create
Integer32
0..255
65535
ICMP message code.
As per the MIB.
hh3cAclIPAclNamedAdvPrecedence (1.3.6.1.4.1.25506.2.8.2.2.5.1.23)
read-create
Integer32
0..7
255
IP precedence.
As per the MIB.
hh3cAclIPAclNamedAdvTos (1.3.6.1.4.1.25506.2.8.2.2.5.1.24)
read-create
Integer32
0..15
255
ToS.
As per the MIB.
hh3cAclIPAclNamedAdvDscp (1.3.6.1.4.1.25506.2.8.2.2.5.1.25)
read-create
Integer32
0..63
255
DSCP.
As per the MIB.
hh3cAclIPAclNamedAdvTimeRangeName (1.3.6.1.4.1.25506.2.8.2.2.5.1.26)
read-create
OCTET STRING
SIZE (0..32)
Time range name.
As per the MIB.
hh3cAclIPAclNamedAdvTCPFlag (1.3.6.1.4.1.25506.2.8.2.2.5.1.27)
read-create
TCPFlag
TCP flag.
As per the MIB.
hh3cAclIPAclNamedAdvFragmentFlag (1.3.6.1.4.1.25506.2.8.2.2.5.1.28)
read-create
FragmentFlag
Fragments flag.
Support 0 and 2.
hh3cAclIPAclNamedAdvLog (1.3.6.1.4.1.25506.2.8.2.2.5.1.29)
read-create
TruthValue
true(1)
false(2)
As per the MIB.
hh3cAclIPAclNamedAdvCount (1.3.6.1.4.1.25506.2.8.2.2.5.1.30)
read-only
Unsigned32
As per the MIB.
hh3cAclIPAclNamedAdvCountClear (1.3.6.1.4.1.25506.2.8.2.2.5.1.31)
read-write
CounterClear
Not supported
hh3cAclIPAclNamedAdvEnable (1.3.6.1.4.1.25506.2.8.2.2.5.1.32)
read-only
TruthValue
true(1)
false(2)
As per the MIB.
hh3cAclIPAclNamedAdvComment (1.3.6.1.4.1.25506.2.8.2.2.5.1.34)
read-create
OCTET STRING
SIZE (0..127)
Rule description.
Read and write.
hh3cAclIPAclNamedAdvReflective (1.3.6.1.4.1.25506.2.8.2.2.5.1.35)
read-create
TruthValue
true(1)
false(2)
Not supported
hh3cAclIPAclNamedAdvCounting
(1.3.6.1.4.1.25506.2.8.2.2.5.1.36)
read-only
TruthValue
true(1)
false(2)
As per the MIB.
hh3cAclIPAclNamedAdvTCPFlagMask (1.3.6.1.4.1.25506.2.8.2.2.5.1.37)
read-create
Hh3cAlarmStatus
tcpack(0)
tcpfin(1)
tcppsh(2)
tcprst(3)
tcpsyn(4)
tcpurg(5)
TCP flag bit mask.
As per the MIB.
hh3cAclIPAclNamedAdvTCPFlagValue (1.3.6.1.4.1.25506.2.8.2.2.5.1.38)
read-create
Hh3cAlarmStatus
tcpack(0)
tcpfin(1)
tcppsh(2)
tcprst(3)
tcpsyn(4)
tcpurg(5)
TCP flag bit set.
As per the MIB.
hh3cAclIPAclNamedAdvRouteTypeAny (1.3.6.1.4.1.25506.2.8.2.2.5.1.39)
read-create
TruthValue
true(1)
false(2)
As per the MIB.
hh3cAclIPAclNamedAdvFlowLabel (1.3.6.1.4.1.25506.2.8.2.2.5.1.41)
read-create
Unsigned32
0..1048575
4294967295
Flow label.
Default: 0.
hh3cAclIPAclNamedAdvSrcSuffix(1.3.6.1.4.1.25506.2.8.2.2.5.1.42)
read-create
Unsigned32
Not supported.
hh3cAclIPAclNamedAdvDstSuffix(1.3.6.1.4.1.25506.2.8.2.2.5.1.43)
read-create
Unsigned32
Not supported.
hh3cAclMACTable
About this table
This table records MAC ACL (also called Layer 2 ACL) configuration information. Use this table to add or delete a MAC ACL rule.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cAclNumberGroupType, hh3cAclNumberGroupIndex, and hh3cAclMACRuleIndex.
Object (OID)
Access
Value range
Implementation
hh3cAclMACRuleIndex (1.3.6.1.4.1.25506.2.8.2.3.1.1.1)
not-accessible
Integer32
0..65534
ACL rule ID.
As per the MIB.
hh3cAclMACRowStatus (1.3.6.1.4.1.25506.2.8.2.3.1.1.2)
read-create
RowStatus
Row status.
active(1)
createAndGo(4)
destroy(6)
hh3cAclMACAct (1.3.6.1.4.1.25506.2.8.2.3.1.1.3)
read-create
RuleAction
Action type.
permit(2)
deny(3)
hh3cAclMACTypeCode (1.3.6.1.4.1.25506.2.8.2.3.1.1.4)
read-create
OCTET STRING
SIZE (0..32)
Layer 2 protocol type.
As per the MIB.
hh3cAclMACTypeMask (1.3.6.1.4.1.25506.2.8.2.3.1.1.5)
read-create
OCTET STRING
SIZE (0..32)
Mask of the Layer 2 protocol type.
As per the MIB.
hh3cAclMACSrcMac (1.3.6.1.4.1.25506.2.8.2.3.1.1.6)
read-create
MacAddress
Source MAC address.
As per the MIB.
hh3cAclMACSrcMacWild (1.3.6.1.4.1.25506.2.8.2.3.1.1.7)
read-create
MacAddress
Mask of the source MAC address.
As per the MIB.
hh3cAclMACDestMac (1.3.6.1.4.1.25506.2.8.2.3.1.1.8)
read-create
MacAddress
Destination MAC address.
As per the MIB.
hh3cAclMACDestMacWild (1.3.6.1.4.1.25506.2.8.2.3.1.1.9)
read-create
MacAddress
Destination MAC address mask.
As per the MIB.
hh3cAclMACCos (1.3.6.1.4.1.25506.2.8.2.3.1.1.12)
read-create
Integer32
0..7
255
802.1p priority in VLAN tags.
As per the MIB.
hh3cAclMACTimeRangeName (1.3.6.1.4.1.25506.2.8.2.3.1.1.13)
read-create
OCTET STRING
SIZE (0..32)
Time range name.
As per the MIB.
hh3cAclMACCount (1.3.6.1.4.1.25506.2.8.2.3.1.1.14)
read-only
Unsigned32
As per the MIB.
hh3cAclMACCountClear (1.3.6.1.4.1.25506.2.8.2.3.1.1.15)
read-write
CounterClear
Not supported
hh3cAclMACEnable (1.3.6.1.4.1.25506.2.8.2.3.1.1.16)
read-only
TruthValue
true(1)
false(2)
As per the MIB.
hh3cAclMACComment (1.3.6.1.4.1.25506.2.8.2.3.1.1.17)
read-create
OCTET STRING
SIZE (0..127)
Rule description.
Read and write.
hh3cAclMACLog (1.3.6.1.4.1.25506.2.8.2.3.1.1.18)
read-create
TruthValue
true(1)
false(2)
Not supported
hh3cAclMACCounting (1.3.6.1.4.1.25506.2.8.2.3.1.1.19)
read-create
TruthValue
true(1)
false(2)
As per the MIB.
hh3cAclNamedMACTable
About this table
This table records MAC ACL configuration information. Use this table to add or delete a rule for a named MAC ACL.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cAclNumberGroupType, hh3cAclNamedGroupName, and hh3cAclMACRuleIndex.
Object (OID)
Access
Value range
Implementation
hh3cAclNamedMACRowStatus (1.3.6.1.4.1.25506.2.8.2.3.2.1.1)
read-create
RowStatus
Row status.
active(1)
createAndGo(4)
destroy(6)
hh3cAclNamedMACAct (1.3.6.1.4.1.25506.2.8.2.3.2.1.2)
read-create
RuleAction
Action type.
permit(2)
deny(3)
hh3cAclNamedMACTypeCode (1.3.6.1.4.1.25506.2.8.2.3.2.1.3)
read-create
OCTET STRING
SIZE(0..32)
As per the MIB.
hh3cAclNamedMACTypeMask (1.3.6.1.4.1.25506.2.8.2.3.2.1.4)
read-create
OCTET STRING
SIZE (0..32)
As per the MIB.
hh3cAclNamedMACSrcMac (1.3.6.1.4.1.25506.2.8.2.3.2.1.5)
read-create
MacAddress
Source MAC address.
As per the MIB.
hh3cAclNamedMACSrcMacWild (1.3.6.1.4.1.25506.2.8.2.3.2.1.6)
read-create
MacAddress
Source MAC address mask.
As per the MIB.
hh3cAclNamedMACDstMac (1.3.6.1.4.1.25506.2.8.2.3.2.1.7)
read-create
MacAddress
As per the MIB.
hh3cAclNamedMACDstMacWild (1.3.6.1.4.1.25506.2.8.2.3.2.1.8)
read-create
MacAddress
As per the MIB.
hh3cAclNamedMACLsapCode (1.3.6.1.4.1.25506.2.8.2.3.2.1.9)
read-create
OCTET STRING
SIZE (0..32)
Encapsulation format of the frame.
As per the MIB.
hh3cAclNamedMACLsapMask (1.3.6.1.4.1.25506.2.8.2.3.2.1.10)
read-create
OCTET STRING
SIZE (0..32)
LSAP mask.
As per the MIB.
hh3cAclNamedMACCos (1.3.6.1.4.1.25506.2.8.2.3.2.1.11)
read-create
Integer32
0..7
255
As per the MIB.
hh3cAclNamedMACTimeRangeName (1.3.6.1.4.1.25506.2.8.2.3.2.1.12)
read-create
OCTET STRING
SIZE (0..32)
Time range name.
As per the MIB.
hh3cAclNamedMACCount (1.3.6.1.4.1.25506.2.8.2.3.2.1.13)
read-only
Unsigned32
As per the MIB.
hh3cAclNamedMACCountClear (1.3.6.1.4.1.25506.2.8.2.3.2.1.14)
read-write
CounterClear
Not supported
hh3cAclNamedMACEnable (1.3.6.1.4.1.25506.2.8.2.3.2.1.15)
read-only
TruthValue
true(1)
false(2)
As per the MIB.
hh3cAclNamedMACComment (1.3.6.1.4.1.25506.2.8.2.3.2.1.16)
read-create
OCTET STRING
SIZE (0..127)
Rule description.
Read and write.
hh3cAclNamedMACLog (1.3.6.1.4.1.25506.2.8.2.3.2.1.17)
read-create
TruthValue
true(1)
false(2)
Not supported
hh3cAclNamedMACCounting (1.3.6.1.4.1.25506.2.8.2.3.2.1.18)
read-create
TruthValue
true(1)
false(2)
As per the MIB.
hh3cAclEnUserTable
About this table
This table records user-defined ACL configuration information. Use this table to add or delete a user-defined ACL rule.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cAclNumberGroupType, hh3cAclNumberGroupIndex, and hh3cAclEnUserRuleIndex.
Object (OID)
Access
Value range
Implementation
hh3cAclEnUserStartString (1.3.6.1.4.1.25506.2.8.2.4.3.1.4)
read-create
OCTET STRING
SIZE (0..255)
String for packet matching.
Not supported
hh3cAclEnUserMplsString (1.3.6.1.4.1.25506.2.8.2.4.3.1.6)
read-create
OCTET STRING
SIZE (0..255)
String for MPLS packet matching.
Not supported
hh3cAclEnUserIPv4String (1.3.6.1.4.1.25506.2.8.2.4.3.1.7)
read-create
OCTET STRING
SIZE (0..255)
String for IPv4 packet matching.
Default: “0,(null),(null)”
hh3cAclEnUserL5String (1.3.6.1.4.1.25506.2.8.2.4.3.1.10)
read-create
OCTET STRING
SIZE (0..255)
String for Layer 5 packet matching.
Not supported
hh3cAclEnUserCountClear (1.3.6.1.4.1.25506.2.8.2.4.3.1.13)
read-write
CounterClear
Not supported
hh3cAclEnUserLog (1.3.6.1.4.1.25506.2.8.2.4.3.1.16)
read-create
TruthValue
true(1)
false(2)
Not supported
hh3cAclNamedUserTable
About this table
This table records named user-defined ACL configuration information. Use this table to add or delete a rule for a named user-defined ACL rule.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cAclNumberGroupType, hh3cAclNamedGroupName, and hh3cAclEnUserRuleIndex.
Object (OID)
Access
Value range
Implementation
hh3cAclNamedUserStartString (1.3.6.1.4.1.25506.2.8.2.4.4.1.3)
read-create
OCTET STRING
SIZE (0..255)
Not supported
hh3cAclNamedUserMplsString (1.3.6.1.4.1.25506.2.8.2.4.4.1.5)
read-create
OCTET STRING
SIZE (0..255)
Not supported
hh3cAclNamedUserL5String (1.3.6.1.4.1.25506.2.8.2.4.4.1.9)
read-create
OCTET STRING
SIZE (0..255)
Not supported
hh3cAclNamedUserCountClear (1.3.6.1.4.1.25506.2.8.2.4.4.1.12)
read-write
CounterClear
Not supported
hh3cAclNamedUserLog (1.3.6.1.4.1.25506.2.8.2.4.4.1.15)
read-create
TruthValue
true(1)
false(2)
Not supported
hh3cAclResourceUsageTable
About this table
This table obtains the ACL TCAM resource usage information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cAclResourceChassis, hh3cAclResourceSlot, hh3cAclResourceChip, and hhh3cAclResourceType.
Object (OID)
Access
Value range
Implementation
hh3cAclResourceChassis (1.3.6.1.4.1.25506.2.8.2.5.1.1.1)
not-accessible
Unsigned32
Chassis number.
As per the MIB.
hh3cAclResourceSlot (1.3.6.1.4.1.25506.2.8.2.5.1.1.2)
not-accessible
Unsigned32
Slot number.
As per the MIB.
hh3cAclResourceChip (1.3.6.1.4.1.25506.2.8.2.5.1.1.3)
not-accessible
Unsigned32
Chip number that the ACL TCAM resource maps to.
As per the MIB.
hh3cAclResourceType (1.3.6.1.4.1.25506.2.8.2.5.1.1.4)
not-accessible
Integer32
1..255
Type of the ACL TCAM resources.
As per the MIB.
hh3cAclPortRange (1.3.6.1.4.1.25506.2.8.2.5.1.1.5)
read-only
OCTET STRING
SIZE (0..255)
Port range of the ACL TCAM resources.
As per the MIB.
hh3cAclResourceTotal (1.3.6.1.4.1.25506.2.8.2.5.1.1.6)
read-only
Unsigned32
Total number of the resources of the current type.
As per the MIB.
hh3cAclResourceReserved (1.3.6.1.4.1.25506.2.8.2.5.1.1.7)
read-only
Unsigned32
Number of reserved resources of the current type.
As per the MIB.
hh3cAclResourceConfigured (1.3.6.1.4.1.25506.2.8.2.5.1.1.8)
read-only
Unsigned32
Number of allocated resources of the current type.
As per the MIB.
hh3cAclResourceUsagePercent (1.3.6.1.4.1.25506.2.8.2.5.1.1.9)
read-only
Unsigned32
Usage of the resources of the current type.
As per the MIB.
hh3cAclResourceTypeDescription (1.3.6.1.4.1.25506.2.8.2.5.1.1.10)
read-only
OCTET STRING
SIZE (0..31)
Description of the ACL resource type.
As per the MIB.
hh3cAclIntervalTable
About this table
This table records ACL logging and notification configuration.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table index is hh3cAclIntervalType.
Object (OID)
Access
Value range
Implementation
hh3cAclIntervalType (1.3.6.1.4.1.25506.2.8.2.6.1.1.1)
not-accessible
INTEGER
logging(1)
trap(2)
Object type of the interval.
As per the MIB.
hh3cAclIntervalValue (1.3.6.1.4.1.25506.2.8.2.6.1.1.2)
read-create
Integer32
5..1440
Interval value.
As per the MIB.
hh3cAclIntervalRowStatus (1.3.6.1.4.1.25506.2.8.2.6.1.1.3)
read-create
RowStatus
Row status.
As per the MIB.
hh3cPfilterApplyTable
About this table
This MIB records packet filter application configuration. You can apply or cancel the packet filter configuration on a specified entity.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cPfilterApplyObjType, hh3cPfilterApplyObjIndex, hh3cPfilterApplyDirection, hh3cPfilterApplyAclType, and hh3cPfilterApplyAclIndex.
Object (OID)
Access
Value range
Implementation
hh3cPfilterApplyObjType (1.3.6.1.4.1.25506.2.8.3.2.1.1)
not-accessible
INTEGER
interface (1)
vlan(2)
global(3)
Entity type of the packet filter application.
hh3cPfilterApplyObjIndex (1.3.6.1.4.1.25506.2.8.3.2.1.2)
not-accessible
Integer32
0..2147483647
Packet filter application index.
As per the MIB.
hh3cPfilterApplyDirection (1.3.6.1.4.1.25506.2.8.3.2.1.3)
not-accessible
DirectionType
Packet filter application direction.
As per the MIB.
hh3cPfilterApplyAclType (1.3.6.1.4.1.25506.2.8.3.2.1.4)
not-accessible
INTEGER
ipv4(1)
ipv6(2)
default(3)
mac(4)
user(5)
Type of the ACL in the packet filter.
hh3cPfilterApplyAclIndex (1.3.6.1.4.1.25506.2.8.3.2.1.5)
not-accessible
Integer32
0
2000..5999
Number of the ACL in the packet filter.
hh3cPfilterApplyHardCount (1.3.6.1.4.1.25506.2.8.3.2.1.6)
read-create
TruthValue
true(1)
false(2)
Enabling status of hardware counting.
hh3cPfilterApplySequence (1.3.6.1.4.1.25506.2.8.3.2.1.7)
read-only
Unsigned32
Packet filtering application sequence number.
As per the MIB.
hh3cPfilterApplyCountClear (1.3.6.1.4.1.25506.2.8.3.2.1.8)
read-write
CounterClear
Clear statistics for the specified ACL.
As per the MIB.
hh3cPfilterApplyRowStatus (1.3.6.1.4.1.25506.2.8.3.2.1.9)
read-create
RowStatus
Row status.
active(1)
createAndGo(4)
destroy(6)
hh3cPfilterAclGroupRunInfoTable
About this table
This table records ACL running inforamtion in packet filter. Use this table to obtain the packet filter status and statistics from a specified entity.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cPfilterRunApplyObjType, hh3cPfilterRunApplyObjIndex, hh3cPfilterRunApplyDirection, hh3cPfilterRunApplyAclType, and hh3cPfilterRunApplyAclIndex.
Object (OID)
Access
Value range
Implementation
hh3cPfilterRunApplyObjType (1.3.6.1.4.1.25506.2.8.3.3.1.1)
not-accessible
INTEGER
interface (1)
vlan(2)
global(3)
Type of the entity on which the packet filter running information is obtained.
hh3cPfilterRunApplyObjIndex (1.3.6.1.4.1.25506.2.8.3.3.1.2)
not-accessible
Integer32
0..2147483647
As per the MIB.
hh3cPfilterRunApplyDirection (1.3.6.1.4.1.25506.2.8.3.3.1.3)
not-accessible
DirectionType
Direction of the packet filter application.
As per the MIB.
hh3cPfilterRunApplyAclType (1.3.6.1.4.1.25506.2.8.3.3.1.4)
not-accessible
INTEGER
ipv4(1)
ipv6(2)
default(3)
mac(4)
user(5)
Type of the ACL used in the packet filter application.
hh3cPfilterRunApplyAclIndex (1.3.6.1.4.1.25506.2.8.3.3.1.5)
not-accessible
Integer32
1..3
2000..5999
Number of the ACL used in the packet filter application.
hh3cPfilterAclGroupStatus (1.3.6.1.4.1.25506.2.8.3.3.1.6)
read-only
INTEGER
success(1)
failed(2)
partialSuccess(3)
Application status of the ACL for the packet filter.
As per the MIB.
hh3cPfilterAclGroupCountStatus (1.3.6.1.4.1.25506.2.8.3.3.1.7)
read-only
INTEGER
success(1)
failed(2)
partialSuccess(3)
Enabling status of the hardware count for the ACL used by the packet filter.
hh3cPfilterAclGroupPermitPkts (1.3.6.1.4.1.25506.2.8.3.3.1.8)
read-only
Counter64
Number of packets permitted by the ACL.
hh3cPfilterAclGroupPermitBytes (1.3.6.1.4.1.25506.2.8.3.3.1.9)
read-only
Counter64
Number of bytes permitted by the ACL.
hh3cPfilterAclGroupDenyPkts (1.3.6.1.4.1.25506.2.8.3.3.1.10)
read-only
Counter64
Number of packets dropped by the ACL.
hh3cPfilterAclGroupDenyBytes (1.3.6.1.4.1.25506.2.8.3.3.1.11)
read-only
Counter64
Number of bytes dropped by the ACL.
hh3cPfilterAclRuleRunInfoTable
About this table
This table records the ACL rule running information for the packet filter. Use this table to obtain the packet filter status and statistics on an entity.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cPfilterRunApplyObjType, hh3cPfilterRunApplyObjIndex, hh3cPfilterRunApplyDirection, hh3cPfilterRunApplyAclType, hh3cPfilterRunApplyAclIndex, and hh3cPfilterAclRuleIndex.
Object (OID)
Access
Value range
Implementation
hh3cPfilterAclRuleIndex (1.3.6.1.4.1.25506.2.8.3.4.1.1)
not-accessible
Integer32
0..65534
ACL rule ID.
As per the MIB.
hh3cPfilterAclRuleStatus (1.3.6.1.4.1.25506.2.8.3.4.1.2)
read-only
INTEGER
success(1)
failed(2)
partialSuccess(3)
Application status of the ACL rule.
As per the MIB.
hh3cPfilterAclRuleCountStatus (1.3.6.1.4.1.25506.2.8.3.4.1.3)
read-only
INTEGER
success(1)
failed(2)
partialSuccess(3)
Enabling status of the rule match count.
hh3cPfilterAclRuleMatchPackets (1.3.6.1.4.1.25506.2.8.3.4.1.4)
read-only
Counter64
hh3cPfilterAclRuleMatchBytes (1.3.6.1.4.1.25506.2.8.3.4.1.5)
read-only
Counter64
Number of bytes matching the ACL rule.
hh3cPfilterStatisticSumTable
About this table
Use this table to obtain the accumulated packet filter statistics.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cPfilterSumDirection, hh3cPfilterSumAclType, hh3cPfilterSumAclIndex, and hh3cPfilterSumRuleIndex.
Object (OID)
Access
Value range
Implementation
hh3cPfilterSumDirection (1.3.6.1.4.1.25506.2.8.3.5.1.1)
not-accessible
DirectionType
Direction of the application for which the accumulated statistics is obtained.
As per the MIB.
hh3cPfilterSumAclType (1.3.6.1.4.1.25506.2.8.3.5.1.2)
not-accessible
INTEGER
ipv4(1)
ipv6(2)
mac(3)
user(4)
Type of the ACL for which the accumulated statistics is obtained.
hh3cPfilterSumAclIndex (1.3.6.1.4.1.25506.2.8.3.5.1.3)
not-accessible
Integer32
2000..5999
Number of the ACL for which the accumulated statistics is obtained.
hh3cPfilterSumRuleIndex (1.3.6.1.4.1.25506.2.8.3.5.1.4)
not-accessible
Integer32
0..65534
Number of the ACL rule for which the accumulated statistics is obtained.
As per the MIB.
hh3cPfilterSumRuleMatchPackets (1.3.6.1.4.1.25506.2.8.3.5.1.5)
read-only
Counter64
Number of packets matching the rule in the packet filter.
hh3cPfilterSumRuleMatchBytes (1.3.6.1.4.1.25506.2.8.3.5.1.6)
read-only
Counter64
Number of bytes matching the rule in the packet filter.
hh3cPfilter2ApplyTable
About this table
This table records the packet filter application configuration. Use this table to apply or cancel the packet filter configuration on an entity.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cPfilter2ApplyObjType, hh3cPfilter2ApplyObjIndex, hh3cPfilter2ApplyDirection, hh3cPfilter2ApplyAclType, and hh3cPfilter2ApplyAclIndex.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.8.3.6.1.1)
accessible-for-notify
INTEGER
interface (1)
vlan(2)
global(3)
Type of the application object.
hh3cPfilter2ApplyObjIndex (1.3.6.1.4.1.25506.2.8.3.6.1.2)
Integer32
0..2147483647
Index of the application object.
As per the MIB.
hh3cPfilter2ApplyDirection (1.3.6.1.4.1.25506.2.8.3.6.1.3)
DirectionType
As per the MIB.
hh3cPfilter2ApplyAclType (1.3.6.1.4.1.25506.2.8.3.6.1.4)
INTEGER
ipv4(1)
ipv6(2)
default(3)
mac(4)
user(5)
Type of the ACL used by the packet filter.
hh3cPfilter2ApplyAclIndex (1.3.6.1.4.1.25506.2.8.3.6.1.5)
OCTET STRING
SIZE (1..63)
Number or name of the ACL used by the packet filter.
hh3cPfilter2ApplyHardCount
(1.3.6.1.4.1.25506.2.8.3.6.1.6)
read-create
TruthValue
true(1)
false(2)
hh3cPfilter2ApplySequence
(1.3.6.1.4.1.25506.2.8.3.6.1.7)
read-only
Unsigned32
Packet filter application sequence number.
As per the MIB.
hh3cPfilter2ApplyCountClear
(1.3.6.1.4.1.25506.2.8.3.6.1.8)
read-write
CounterClear
As per the MIB.
hh3cPfilterNameApplyRowStatus (1.3.6.1.4.1.25506.2.8.3.6.1.5)
read-create
RowStatus
Row status.
active(1)
createAndGo(4)
destroy(6)
hh3cPfilter2AclGroupRunInfoTable
About this table
This table records the ACL running information for the packet filter. Use this table to obtain the packet filter status and statistics from an entity. Different from h3cPfilterAclGroupRunInfoTable, hh3cPfilter2RunApplyAclIndex in this table supports obtaining statistics for numbered and named ACL.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cPfilter2RunApplyObjType, hh3cPfilter2RunApplyObjIndex, hh3cPfilter2RunApplyDirection, hh3cPfilter2RunApplyAclType, and hh3cPfilter2RunApplyAclIndex.
Object (OID)
Access
Value range
Implementation
hh3cPfilter2RunApplyObjType (1.3.6.1.4.1.25506.2.8.3.7.1.1)
not-accessible
INTEGER
interface (1)
vlan(2)
global(3)
Type of the entity on which the ACL running information is obtained.
hh3cPfilter2RunApplyObjIndex (1.3.6.1.4.1.25506.2.8.3.7.1.2)
not-accessible
Integer32
0..2147483647
As per the MIB.
hh3cPfilter2RunApplyDirection (1.3.6.1.4.1.25506.2.8.3.7.1.3)
not-accessible
DirectionType
As per the MIB.
hh3cPfilter2RunApplyAclType (1.3.6.1.4.1.25506.2.8.3.7.1.4)
not-accessible
INTEGER
ipv4(1)
ipv6(2)
default(3)
mac(4)
user(5)
Type of the ACL used in the packet filter.
hh3cPfilter2RunApplyAclIndex (1.3.6.1.4.1.25506.2.8.3.7.1.5)
not-accessible
OCTET STRING
SIZE (1..63)
Number of name of the ACL.
hh3cPfilter2AclGroupStatus (1.3.6.1.4.1.25506.2.8.3.7.1.6)
read-only
INTEGER
success(1)
failed(2)
partialSuccess(3)
Application status of the ACL.
As per the MIB.
hh3cPfilter2AclGroupCountStatus
(1.3.6.1.4.1.25506.2.8.3.7.1.7)
read-only
INTEGER
success(1)
failed(2)
partialSuccess(3)
hh3cPfilter2AclGroupPermitPkts (1.3.6.1.4.1.25506.2.8.3.7.1.8)
read-only
Counter64
hh3cPfilter2AclGroupPermitBytes (1.3.6.1.4.1.25506.2.8.3.7.1.9)
read-only
Counter64
hh3cPfilter2AclGroupDenyPkts (1.3.6.1.4.1.25506.2.8.3.7.1.10)
read-only
Counter64
hh3cPfilter2AclGroupDenyBytes (1.3.6.1.4.1.25506.2.8.3.7.1.11)
read-only
Counter64
hh3cPfilter2AclRuleRunInfoTable
About this table
This table records the ACL rule running information for the packet filter. Use this table to obtain the packet filter status and statistics from an entity. Different from the table hh3cPfilterAclRuleRunInfoTable, the index in this table supports obtaining statistics for numbered and named ACL.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cPfilter2RunApplyObjType, hh3cPfilter2RunApplyObjIndex, hh3cPfilter2RunApplyDirection, hh3cPfilter2RunApplyAclType, hh3cPfilter2RunApplyAclIndex, and hh3cPfilter2AclRuleIndex.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.8.3.8.1.1)
Integer32
0..65534
ACL rule ID.
As per the MIB.
hh3cPfilter2AclRuleStatus (1.3.6.1.4.1.25506.2.8.3.8.1.2)
read-only
INTEGER
success(1)
failed(2)
partialSuccess(3)
As per the MIB.
hh3cPfilter2AclRuleCountStatus (1.3.6.1.4.1.25506.2.8.3.8.1.3)
read-only
INTEGER
success(1)
failed(2)
partialSuccess(3)
hh3cPfilter2AclRuleMatchPkts (1.3.6.1.4.1.25506.2.8.3.8.1.4)
read-only
Counter64
hh3cPfilterAclNameRuleMatchBytes (1.3.6.1.4.1.25506.2.8.3.8.1.5)
read-only
Counter64
hh3cPfilter2StatisticSumTable
About this table
This table records the accumulated ACL rule statistics for the packet filter. Different from the h3cPfilterStatisticSumTable, the h3cPfilter2SumAclIndex in this table supports numbered and named ACL.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cPfilter2SumDirection, hh3cPfilter2SumAclType, hh3cPfilter2SumAclIndex, and hh3cPfilter2SumRuleIndex.
Object (OID)
Access
Value range
Implementation
hh3cPfilter2SumDirection (1.3.6.1.4.1.25506.2.8.3.9.1.1)
not-accessible
DirectionType
Direction of packet filter.
As per the MIB.
hh3cPfilter2SumAclType (1.3.6.1.4.1.25506.2.8.3.9.1.2)
not-accessible
INTEGER
ipv4(1)
ipv6(2)
mac(3)
user(4)
hh3cPfilter2SumAclIndex (1.3.6.1.4.1.25506.2.8.3.9.1.3)
not-accessible
OCTET STRING
SIZE (1..63)
Number or name of the ACL.
hh3cPfilter2SumRuleIndex (1.3.6.1.4.1.25506.2.8.3.9.1.4)
not-accessible
INTEGER
0..65534
ACL rule ID.
As per the MIB.
hh3cPfilter2SumRuleMatchPackets (1.3.6.1.4.1.25506.2.8.3.9.1.5)
read-only
Counter64
hh3cPfilterNameSumRuleMatchBytes (1.3.6.1.4.1.25506.2.8.3.9.1.6)
read-only
Counter64
Notifications
hh3cAclRuleMatchCount
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.8.5.0.2
Notification for the ACL rule matches.
Informational
Warning
N/A (N/A)
OFF
Notification triggers
When a trap interval is set through the table hh3cAclIntervalTable, notifications will be generated at intervals. The notification information includes the number of rule matches in the interval.
System impact
No negative impact on services.
Status control
ON
CLI: Use the acl trap interval interval command.
MIB: Set hh3cAclIntervalType to trap(2), set the hh3cAclIntervalValue to a value in the range of 5 to 1440, and use the table hh3cAclIntervalTable to perform a create operation.
OFF
MIB: Use the table hh3cAclIntervalTable to perform a destroy operation.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.8.3.6.1.1 (hh3cPfilter2ApplyObjType)
Object to which the ACL is applied.
INTEGER
interface(1), vlan(2), global(3)
1.3.6.1.4.1.25506.2.8.3.6.1.2 (hh3cPfilter2ApplyObjIndex)
Object index.
Integer32
0 to 2147483647
1.3.6.1.4.1.25506.2.8.3.6.1.3 (hh3cPfilter2ApplyDirection)
Direction of the packet filter.
INTEGER
inbound(1), outbound(2)
1.3.6.1.4.1.25506.2.8.3.6.1.4 (hh3cPfilter2ApplyAclType)
Type of the ACL.
INTEGER
ipv4(1), ipv6(2), default(3), mac(4), user(5)
1.3.6.1.4.1.25506.2.8.3.6.1.5 (hh3cPfilter2ApplyAclIndex)
ACL index.
OCTET STRING
SIZE (1 to 63)
1.3.6.1.4.1.25506.2.8.3.8.1.1 (hh3cPfilter2AclRuleIndex)
ACL rule index
Integer32
0 to 65534.
1.3.6.1.4.1.25506.2.8.3.8.1.4 (hh3cPfilter2AclRuleMatchPackets)
ACL rule match count.
N/A
Counter64
0 to 18446744073709551615.
Recommended action
No action is required.
hh3cAclResourceTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.8.7.0.1
TCAM resource usage notification.
Informational
Warning
OFF
Notifications will be generated for violations of threshold set by hh3cAclMib2ResourceThreshold at intervals set by hh3cAclMib2ResourceLogInterval. The notification information includes the Ternary Content Addressable Memory (TCAM) resource usage for each card.
System impact
Status control
ON
CLI: Use the commands:
acl resource threshold percent percent
acl resource log interval interval
MIB: Set hh3cAclMib2ResourceThreshold to a value in the range of 1 to 100, and set hh3cAclMib2ResourceLogInterval to a value in the range of 1 to 60.
OFF
undo acl resource threshold percent
undo acl resource log interval
MIB: Set hh3cAclMib2ResourceThreshold to 0, and set hh3cAclMib2ResourceLogInterval to 0.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.8.6.1 (hh3cAclResourceTypeName)
Resource type.
N/A
OCTET STRING
SIZE (1 to 255)
1.3.6.1.4.1.25506.2.8.6.2 (hh3cAclResourceUsage)
Resource usage.
N/A
Integer32
0 to 100
1.3.6.1.4.1.25506.2.8.6.3 (hh3cAclResourceUsedEntries)
Number of used resources.
N/A
Integer32
1.3.6.1.4.1.25506.2.8.6.4 (hh3cAclResourceTotalEntries)
Total number of resources.
N/A
INTEGER
1.3.6.1.4.1.25506.2.8.2.1.1.5 (hh3cAclMib2ResourceThreshold)
Resource usage alarm threshold.
N/A
Integer32
0 to 100
1.3.6.1.4.1.25506.2.8.6.5 (hh3cAclResourceChassisID)
Chassis number.
N/A
Integer32
1.3.6.1.4.1.25506.2.8.6.6 (hh3cAclResourceSlotID)
Slot number.
N/A
Integer32
Recommended action
