03-Device Management
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R838x-6W10003-Device Management
10-SYSLOG-MSG-MIB
10-SYSLOG-MSG-MIB 79.71 KB
SYSLOG-MSG-MIB
About this MIB
Use this MIB to manage syslog messages as SNMP objects and enable and view syslog message notifications.
MIB file name
rfc5676-syslog-msg.mib
Root object
iso(1).org(3).dod(6).internet(1)..mgmt(2).mib-2(1).syslogMsgMib(192)
Scalar objects
syslogMsgTableMaxSize (1.3.6.1.2.1.192.1.1.1)
Object (OID)
Access
Value range
Implementation
read-write
Unsigned32
Standard MIB values.
Maximum number of syslog messages in syslogMsgTable.
Default value: 1024.
syslogMsgEnableNotifications (1.3.6.1.2.1.192.1.1.2)
Object (OID)
Access
Value range
Implementation
read-write
SyslogFacility
true(1),false(2)
Whether syslog notifications are enabled.
As per the MIB.
Tabular objects
syslogMsgTable
About this table
This table contains recent syslog messages.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is syslogMsgIndex.
Object (OID)
Access
Value range
Implementation
syslogMsgIndex (1.3.6.1.2.1.192.1.2.1.1)
not-accessible
Unsigned32
Standard MIB values
Index of an entry in the syslogMsgTable.
As per the MIB.
syslogMsgFacility (1.3.6.1.2.1.192.1.2.1.2)
read-only
SyslogFacility
kern(0),
user(1),
mail(2),
daemon(3),
auth(4),
syslog(5),
lpr(6),
news(7),
uucp(8),
cron(9),
authpriv(10),
ftp(11),
ntp(12),
audit(13),
console(14),
cron2(15),
local0(16),
local1(17),
local2(18),
local3(19),
local4(20),
local5(21),
local6(22),
local7(23)
Facility of the syslog message.
As per the MIB.
syslogMsgSeverity (1.3.6.1.2.1.192.1.2.1.3)
read-only
SyslogSeverity
emerg(0),
alert(1),
crit(2),
err(3),
warning(4),
notice(5),
info(6),
debug(7)
Severity of the syslog message.
As per the MIB.
syslogMsgVersion (1.3.6.1.2.1.192.1.2.1.4)
read-only
Unsigned32
Unsigned32 (0..999)
Version of the syslog message.
As per the MIB.
syslogMsgTimeStamp (1.3.6.1.2.1.192.1.2.1.5)
read-only
SyslogTimeStamp
OCTET STRING (0 | 10 | 13)
Timestamp of the syslog message.
As per the MIB.
syslogMsgHostName (1.3.6.1.2.1.192.1.2.1.6)
read-only
DisplayString
OCTET STRING (0..255)
Host name of the syslog message.
As per the MIB.
syslogMsgAppName (1.3.6.1.2.1.192.1.2.1.7)
read-only
DisplayString
OCTET STRING (0..48)
Application name of the syslog message.
As per the MIB.
syslogMsgProcID (1.3.6.1.2.1.192.1.2.1.8)
read-only
DisplayString
OCTET STRING (0..128)
Process ID of the syslog message.
A zero-length string indicates an unknown process ID.
syslogMsgMsgID (1.3.6.1.2.1.192.1.2.1.9)
read-only
DisplayString
OCTET STRING (0..32)
Message ID of the syslog message.
A zero-length string indicates an unknown message ID.
syslogMsgSDParams (1.3.6.1.2.1.192.1.2.1.10)
read-only
Unsigned32
Standard MIB values
Total number of structured data element parameters carried in the syslog message.
As per the MIB.
syslogMsgMsg (1.3.6.1.2.1.192.1.2.1.11)
read-only
OCTET STRING
OCTET STRING (0..65535)
Message part of the syslog message.
As per the MIB.
syslogMsgSDTable
About this table
This table contains structured data elements of syslog messages.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are syslogMsgIndex, syslogMsgSDParamIndex, syslogMsgSDID, and syslogMsgSDParamName.
Object (OID)
Access
Value range
Implementation
syslogMsgSDParamIndex (1.3.6.1.2.1.192.1.3.1.1)
not-accessible
Unsigned32
Standard MIB values
Index of the structured data element parameters contained in a syslog message.
As per the MIB.
syslogMsgSDID (1.3.6.1.2.1.192.1.3.1.2)
not-accessible
DisplayString
OCTET STRING (1..32)
Name (SD-ID) of a structured data element.
As per the MIB.
syslogMsgSDParamName (1.3.6.1.2.1.192.1.3.1.3)
not-accessible
DisplayString
Name of a parameter of the structured data element.
As per the MIB.
syslogMsgSDParamValue (1.3.6.1.2.1.192.1.3.1.4)
read-only
SyslogParamValueString
Value of the parameter of the syslog message.
As per the MIB.
Notifications
syslogMsgNotification
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.192.0.1
A syslog message generated
Informational
Warning
N/A (N/A)
OFF
Notification triggers
This notification is generated when a new syslog message is received.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable syslog command.
MIB: Set syslogMsgEnableNotifications to true(1).
OFF
CLI: Use the undo snmp-agent trap enable syslog command.
MIB: Set syslogMsgEnableNotifications to false(2).
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.192.1.2.1.2 (syslogMsgFacility)
syslogMsgIndex
SyslogFacility
kern(0), user(1), mail(2), daemon(3), auth(4), syslog(5), lpr(6), news(7), uucp(8), cron(9), authpriv(10), ftp(11), ntp(12), audit(13), console(14), cron2(15), local0(16), local1(17), local2(18), local3(19), local4(20), local5(21), local6(22), local7(23)
1.3.6.1.2.1.192.1.2.1.3 (syslogMsgSeverity)
syslogMsgIndex
SyslogSeverity
emerg(0), alert(1), crit(2), err(3), warning(4), notice(5), info(6), debug(7)
1.3.6.1.2.1.192.1.2.1.4 (syslogMsgVersion)
syslogMsgIndex
Unsigned32
0..999
1.3.6.1.2.1.192.1.2.1.5 (syslogMsgTimeStamp)
syslogMsgIndex
SyslogTimeStamp
OCTET STRING (SIZE (0|10|13))
1.3.6.1.2.1.192.1.2.1.6 (syslogMsgHostName)
syslogMsgIndex
DisplayString
OCTET STRING (SIZE (0..255))
1.3.6.1.2.1.192.1.2.1.7 (syslogMsgAppName)
syslogMsgIndex
DisplayString
OCTET STRING (SIZE (0..48))
1.3.6.1.2.1.192.1.2.1.8 (syslogMsgProcID)
syslogMsgIndex
DisplayString
OCTET STRING (SIZE (0..128))
1.3.6.1.2.1.192.1.2.1.9 (syslogMsgMsgID)
syslogMsgIndex
DisplayString
OCTET STRING (SIZE (0..32))
1.3.6.1.2.1.192.1.2.1.10 (syslogMsgSDParams)
Number of structured data element parameters carried in the syslog message.
syslogMsgIndex
Unsigned32
1.3.6.1.2.1.192.1.2.1.11 (syslogMsgMsg)
syslogMsgIndex
OCTET STRING
Recommended action
No action is required.
