03-Device Management
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R838x-6W10003-Device Management
06-HH3C-LswDEVM-MIB
06-HH3C-LswDEVM-MIB 70.77 KB
HH3C-LswDEVM-MIB
About this MIB
Use this MIB to obtain information the resources on the device. For example, access this MIB to obtain power supply or fan information, including their number or status.
MIB file name
hh3c-splat-devm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswdevMMib(9)
Tabular objects
hh3cdevMFanStatusTable
About this table
This table contains basic fan information.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDevMFanNum.
Object (OID)
Access
Value range
Implementation
hh3cDevMFanNum (1.3.6.1.4.1.25506.8.35.9.1.1.1.1)
read-only
Integer32
Standard MIB values.
Fan index.
Implementation varies by product.
hh3cDevMFanStatus (1.3.6.1.4.1.25506.8.35.9.1.1.1.2)
read-only
INTEGER
active(1),
deactive(2),
not-install(3),
unsupport(4)
Fan status.
hh3cDevMFanPosFrame
(1.3.6.1.4.1.25506.8.35.9.1.1.1.3)
read-only
Integer32
ID of the chassis where the fan resides.
Not supported
hh3cDevMFanMaxSpeed
(1.3.6.1.4.1.25506.8.35.9.1.1.1.6)
read-only
Integer32
Maximum fan speed.
Not supported
hh3cDevMFanCurrentSpeed
(1.3.6.1.4.1.25506.8.35.9.1.1.1.7)
read-only
Integer32
Current fan speed.
Not supported
hh3cdevMPowerStatusTable
About this table
This table contains basic power supply information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDevMPowerNum.
Object (OID)
Access
Value range
Implementation
hh3cDevMPowerNum (1.3.6.1.4.1.25506.8.35.9.1.2.1.1)
read-only
Integer32
Power supply index.
hh3cDevMPowerStatus (1.3.6.1.4.1.25506.8.35.9.1.2.1.2)
read-only
INTEGER
active(1),
deactive(2),
not-install(3),
unsupport(4)
Power supply status.
hh3cDevMPowerEntIndex (1.3.6.1.4.1.25506.8.35.9.1.2.1.3)
read-only
Integer32
Entity index of the power supply.
hh3cDevMPowerRatedVoltage (1.3.6.1.4.1.25506.8.35.9.1.2.1.4)
read-only
Integer32
Rated voltage of the power supply, in mV.
hh3cDevMPowerRatedCurrent (1.3.6.1.4.1.25506.8.35.9.1.2.1.5)
read-only
Integer32
Rated current of the power supply, in mA.
hh3cDevMPowerLoadFactor (1.3.6.1.4.1.25506.8.35.9.1.2.1.6)
read-only
Integer32
Load factor of the power supply.
hh3cDevMPowerUsedPower
(1.3.6.1.4.1.25506.8.35.9.1.2.1.7)
read-only
Integer32
Used power of the power supply, in mW.
hh3cDevMPowerRemainingPower (1.3.6.1.4.1.25506.8.35.9.1.2.1.8)
read-only
Integer32
Remaining power of the power supply, in mW.
hh3cDevMPowerSupplyType
(1.3.6.1.4.1.25506.8.35.9.1.2.1.9)
read-only
Integer32
AC(1),
DC (2),
HVDC(3)
Power supply type.
hh3cdevMSlotEnvironmentTable
About this table
This table contains environment information for a card.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cdevMSlotEnvironmentType.
Object (OID)
Access
Value range
Implementation
hh3cdevMSlotEnvironmentType (1.3.6.1.4.1.25506.8.35.9.1.3.1.1)
not-accessible
INTEGER
temperature(1),
humidity(2),
fog(3)
Type of the environment elements.
hh3cDevMSlotEnvironmentStatus (1.3.6.1.4.1.25506.8.35.9.1.3.1.2)
read-only
INTEGER
normal(1),
upper(2),
lower(3)
Status of the environment where the card resides.
Not supported.
hh3cDevMSlotEnvironmentValue (1.3.6.1.4.1.25506.8.35.9.1.3.1.3)
read-only
Integer32
Environment data for the card.
hh3cDevMSlotEnvironmentUpperLimit (1.3.6.1.4.1.25506.8.35.9.1.3.1.4)
read-write
Integer32
Upper limit for the environment requirements.
Not supported.
hh3cDevMSlotEnvironmentLowerLimit (1.3.6.1.4.1.25506.8.35.9.1.3.1.5)
read-write
Integer32
Lower limit for the environment requirements.
Not supported.
