03-Device Management
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R838x-6W10003-Device Management
05-HH3C-LSW-DEV-ADM-MIB
05-HH3C-LSW-DEV-ADM-MIB 121.04 KB
About this MIB
Use this MIB to obtain basic device information about chassis, slots, CPUs, and ports.
MIB file name
hh3c-lsw-dev-adm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswDeviceAdmin(18)
Scalar objects
hh3cLswSysIpAddr (1.3.6.1.4.1.25506.8.35.18.1.1)
Object (OID)
Access
Value range
Implementation
read-only
IpAddress
Standard MIB values.
IP address of a VLAN interface.
As per the MIB.
hh3cLswSysIpMask (1.3.6.1.4.1.25506.8.35.18.1.2)
Object (OID)
Access
Value range
Implementation
read-only
IpAddress
Subnet mask for the system IP address.
As per the MIB.
hh3cLswSysCpuRatio (1.3.6.1.4.1.25506.8.35.18.1.3)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Integer32 (0..100)
Real-time CPU usage on the card in 1-minute intervals.
For distributed devices in IRF mode, this object indicates the real-time CPU usage on the active MPU in the system.
As per the MIB.
hh3cLswSysVersion (1.3.6.1.4.1.25506.8.35.18.1.4)
Object (OID)
Access
Value range
Implementation
read-only
DisplayString
OCTET STRING (1..64)
Version of the system.
For distributed devices in IRF mode, this object indicates the version of the active MPU in the system.
As per the MIB.
hh3cLswSysTime (1.3.6.1.4.1.25506.8.35.18.1.5)
Object (OID)
Access
Value range
Implementation
read-write
DateAndTime
OCTET STRING (8 | 11)
System time of the device.
For distributed devices in IRF mode, this object indicates the system time of the active MPU in the system.
Supports only the read operation on the non-default MDC.
hh3cLswSysPhyMemory (1.3.6.1.4.1.25506.8.35.18.1.13)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Unsigned32 (0..4294967295)
Physical memory space of the device, in bytes.
For distributed devices, this object indicates the physical memory space of the active MPU in the system.
As per the MIB.
hh3cLswSysMemory (1.3.6.1.4.1.25506.8.35.18.1.14)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
System memory space, in bytes.
For distributed devices, this object indicates the system memory space of the active MPU in the system.
As per the MIB.
hh3cLswSysMemoryUsed (1.3.6.1.4.1.25506.8.35.18.1.15)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Used system memory, in bytes.
For distributed devices, this object indicates the used system memory on the active MPU in the system.
As per the MIB.
hh3cLswSysMemoryRatio (1.3.6.1.4.1.25506.8.35.18.1.16)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Unsigned32 (0..100)
Percentage of the used system memory on the device.
For distributed devices, this object indicates the percentage of the used system memory on the active MPU in the system.
As per the MIB.
hh3cLswSysPhyMemRev (1.3.6.1.4.1.25506.8.35.18.1.18)
Object (OID)
Access
Value range
Implementation
read-only
CounterBasedGauge64
As per the MIB.
hh3cLswSysMemRev (1.3.6.1.4.1.25506.8.35.18.1.19)
Object (OID)
Access
Value range
Implementation
read-only
CounterBasedGauge64
As per the MIB.
hh3cLswSysMemUsedRev (1.3.6.1.4.1.25506.8.35.18.1.20)
Object (OID)
Access
Value range
Implementation
read-only
CounterBasedGauge64
As per the MIB.
hh3cLswSysSerialNumber (1.3.6.1.4.1.25506.8.35.18.1.21)
Object (OID)
Access
Value range
Implementation
read-only
SnmpAdminString
OCTET STRING (0..32)
Device serial number.
As per the MIB.
hh3cLswSysTotalPower (1.3.6.1.4.1.25506.8.35.18.1.22)
Object (OID)
Access
Value range
Implementation
read-only
Unsigned32
Total power in the system, in watts. In IRF mode, the total power is the sum of power on all member devices. Value 0 is invalid.
As per the MIB.
Tabular objects
hh3cLswFrameTable
About this table
This table contains chassis-level information about devices.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cLswFrameIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswFrameIndex (1.3.6.1.4.1.25506.8.35.18.4.2.1.1)
read-only
Integer32
Integer32 (-2147483648..2147483647)
Chassis index.
As per the MIB.
hh3cLswFrameType (1.3.6.1.4.1.25506.8.35.18.4.2.1.2)
read-only
Integer32
Chassis type.
Implementation varies by product.
hh3cLswFrameDesc (1.3.6.1.4.1.25506.8.35.18.4.2.1.3)
read-write
DisplayString
OCTET STRING (0..64)
Description of the chassis.
hh3cLswSlotNumber (1.3.6.1.4.1.25506.8.35.18.4.2.1.4)
read-only
Integer32
Number of slots in the current chassis.
As per the MIB.
hh3cLswFrameAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.2.1.5)
read-only
INTEGER
normal(1),
fault(2),
other(3)
Chassis status.
As per the MIB.
hh3cLswFrameTotalPower (1.3.6.1.4.1.25506.8.35.18.4.2.1.10)
read-only
Unsigned32
Total power in the chassis.
As per the MIB.
hh3cLswSlotTable
About this table
This table contains card information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cLswFrameIndex and hh3cLswSlotIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswSlotIndex (1.3.6.1.4.1.25506.8.35.18.4.3.1.1)
read-only
Integer32
Card index.
As per the MIB.
hh3cLswSlotType (1.3.6.1.4.1.25506.8.35.18.4.3.1.2)
read-only
Integer32
Card type.
hh3cLswSlotDesc (1.3.6.1.4.1.25506.8.35.18.4.3.1.3)
read-write
DisplayString
Description of the card.
hh3cLswSlotCpuRatio (1.3.6.1.4.1.25506.8.35.18.4.3.1.4)
read-only
Integer32
CPU usage on the card.
As per the MIB.
hh3cLswSlotPcbVersion (1.3.6.1.4.1.25506.8.35.18.4.3.1.5)
read-only
DisplayString
Hardware version of the card.
As per the MIB.
hh3cLswSlotSoftwareVersion (1.3.6.1.4.1.25506.8.35.18.4.3.1.6)
read-only
DisplayString
Software version of the card.
As per the MIB.
hh3cLswSubslotNumber (1.3.6.1.4.1.25506.8.35.18.4.3.1.7)
read-only
Integer32
Number of subcards.
As per the MIB.
hh3cLswSlotAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.3.1.8)
read-only
INTEGER
not-install(1), normal(2), fault(3), forbidden(4)
Administrative status of the card.
As per the MIB.
hh3cLswSlotOperStatus (1.3.6.1.4.1.25506.8.35.18.4.3.1.9)
read-write
INTEGER
disable(1), enable(2), reset(3), test(4)
Operation status of the card.
Supports only reset.
hh3cLswSlotPhyMemory (1.3.6.1.4.1.25506.8.35.18.4.3.1.10)
read-only
Unsigned32
Physical memory space of the card, in bytes.
The memory is a 32-bit wide memory.
As per the MIB.
hh3cLswSlotMemory (1.3.6.1.4.1.25506.8.35.18.4.3.1.11)
read-only
Unsigned32
System memory space of the card, in bytes.
As per the MIB.
hh3cLswSlotMemoryUsed (1.3.6.1.4.1.25506.8.35.18.4.3.1.12)
read-only
Unsigned32
Used system memory on the card, in bytes.
As per the MIB.
hh3cLswSlotMemoryRatio (1.3.6.1.4.1.25506.8.35.18.4.3.1.13)
read-only
Unsigned32
Unsigned32 (0..100)
Percentage of the system used memory on the card, in bytes.
As per the MIB.
hh3cLswSlotTemperature (1.3.6.1.4.1.25506.8.35.18.4.3.1.14)
read-only
Integer32
Temperature of the card.
Not supported
hh3cLswSlotPktBufMiss (1.3.6.1.4.1.25506.8.35.18.4.3.1.18)
read-only
Counter64
Counter64 (0..18446744073709551615)
Packet loss counting in packet buffers on the card.
As per the MIB.
hh3cLswSlotRunTime (1.3.6.1.4.1.25506.8.35.18.4.3.1.19)
read-only
DisplayString
Running time of the card.
As per the MIB.
hh3cLswSlotPhyMemRev (1.3.6.1.4.1.25506.8.35.18.4.3.1.20)
read-only
Counter64
The memory is a 64-bit wide memory.
As per the MIB.
hh3cLswSlotMemRev
 (1.3.6.1.4.1.25506.8.35.18.4.3.1.21)
read-only
Counter64
As per the MIB.
hh3cLswSlotMemUsedRev (1.3.6.1.4.1.25506.8.35.18.4.3.1.22)
read-only
Counter64
As per the MIB.
hh3cLswSlotModelDesc (1.3.6.1.4.1.25506.8.35.18.4.3.1.23)
read-only
DisplayString
OCTET STRING (0..255)
Description of the extended module in the slot.
As per the MIB.
hh3cLswSubslotTable
About this table
This table contains subcard information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswSubslotIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswSubslotIndex (1.3.6.1.4.1.25506.8.35.18.4.4.1.1)
read-only
Integer32
Subcard index.
As per the MIB.
hh3cLswSubslotType (1.3.6.1.4.1.25506.8.35.18.4.4.1.2)
read-only
Integer32
Subcard type.
hh3cLswSubslotPortNum (1.3.6.1.4.1.25506.8.35.18.4.4.1.3)
read-only
Integer32
Port number of the subcard.
As per the MIB.
hh3cLswSubslotAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.4.1.4)
read-only
INTEGER
not-install(1),
normal(2),
fault(3),
forbidden(4)
Status of the subacard.
As per the MIB.
hh3cLswSubslotFirstIfIndex (1.3.6.1.4.1.25506.8.35.18.4.4.1.5)
read-only
Integer32
Index of the first physical port on the subcard.
Supports only Ethernet ports.
hh3cLswPortTable
About this table
This table contains port information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, hh3cLswSubslotIndex, and hh3cLswPortIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswPortIndex (1.3.6.1.4.1.25506.8.35.18.4.5.1.1)
read-only
Integer32
Port index.
As per the MIB.
hh3cLswPortType (1.3.6.1.4.1.25506.8.35.18.4.5.1.2)
read-only
Integer32
Port type.
hh3cLswPortIfIndex (1.3.6.1.4.1.25506.8.35.18.4.5.1.3)
read-only
Integer32
Index of the interface attached to the port.
As per the MIB.
Hh3cLswPortIsPlugged (1.3.6.1.4.1.25506.8.35.18.4.5.1.4)
read-only
INTEGER
unplugged(0),
plugged(1)
Connection status of the port.
As per the MIB.
hh3cLswExtendModelTable
About this table
This table contains extended module information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cLswExtendModelIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswExtendModelIndex (1.3.6.1.4.1.25506.8.35.18.4.9.1.1)
not-accessible
Integer32
Integer32 (1..2147483647)
Extended module index.
As per the MIB.
hh3cLswCpuTable
About this table
This table contains CPU information.
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswCpuIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswCpuIndex (1.3.6.1.4.1.25506.8.35.18.4.10.1.1)
not-accessible
PhysicalIndex
Integer32 (0..2147483647)
CPU index.
As per the MIB.
hh3cLswCpuEntityIndex (1.3.6.1.4.1.25506.8.35.18.4.10.1.2)
read-only
Integer32
Index of the CPU entity.
As per the MIB.
hh3cLswCpuRatio (1.3.6.1.4.1.25506.8.35.18.4.10.1.3)
read-only
Unsigned32
Unsigned32 (0..100)
Real-time CPU usage on the host.
As per the MIB.
hh3cLswCpuSoftwareVersion (1.3.6.1.4.1.25506.8.35.18.4.10.1.4)
read-only
DisplayString
CPU software version.
As per the MIB.
hh3cLswCpuAdminStatus (1.3.6.1.4.1.25506.8.35.18.4.10.1.5)
read-only
INTEGER
notInstall(1),
normal(2),
fault(3),
forbidden(4)
CPU status.
As per the MIB.
hh3cLswCpuOperStatus (1.3.6.1.4.1.25506.8.35.18.4.10.1.6)
read-write
INTEGER
disable(1),
enable(2),
reset(3),
test(4)
Operation status of the CPU.
Supports reset only on the active CPU.
Supports the read operation only on the non-default MDC.
hh3cLswCpuPhyMemory (1.3.6.1.4.1.25506.8.35.18.4.10.1.7)
read-only
Counter64
Physical memory space of the node, in bytes.
As per the MIB.
hh3cLswCpuMemory (1.3.6.1.4.1.25506.8.35.18.4.10.1.8)
read-only
Counter64
System memory space of the node, in bytes.
As per the MIB.
hh3cLswCpuMemoryUsed (1.3.6.1.4.1.25506.8.35.18.4.10.1.9)
read-only
Counter64
Used memory on the node, in bytes.
As per the MIB.
hh3cLswCpuMemoryRatio (1.3.6.1.4.1.25506.8.35.18.4.10.1.10)
read-only
Unsigned32
Unsigned32 (0..100)
Percentage of the used memory on the node.
As per the MIB.
hh3cLswCpuGroupTable
About this table
This table contains CPU group information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, hh3cLswCpuIndex, and hh3cLswCpuGroupIndex.
Object (OID)
Access
Value range
Implementation
hh3cLswCpuGroupIndex (1.3.6.1.4.1.25506.8.35.18.4.14.1.1)
read-only
Integer32
CPU group index.
As per the MIB.
hh3cLswCpuGroupName (1.3.6.1.4.1.25506.8.35.18.4.14.1.2)
read-only
OCTET STRING
Name of the CPU group.
As per the MIB.
hh3cLswCurrentCpuUsage (1.3.6.1.4.1.25506.8.35.18.4.14.1.3)
read-only
Unsigned32
CPU group usage in the most recent 5-second interval.
As per the MIB.
hh3cLswLast1mCpuUsage (1.3.6.1.4.1.25506.8.35.18.4.14.1.4)
read-only
Unsigned32
CPU group usage in the most recent 1-minute interval.
As per the MIB.
hh3cLswLast5mCpuUsage (1.3.6.1.4.1.25506.8.35.18.4.14.1.5)
read-only
Unsigned32
CPU group usage in the most recent 5-minute interval.
As per the MIB.
hh3cLswOutputPowerTable
About this table
This table contains power port status information.
CreateNo
Edit/ModifyNo
DeleteNo
ReadYes
Columns
The table indexes are hh3cLswFrameIndex, hh3cLswSlotIndex, and hh3cLswOutputPowerPortID.
Object (OID)
Access
Value range
Implementation
hh3cLswOutputPowerPortID (1.3.6.1.4.1.25506.8.35.18.4.16.1.1)
read-only
Integer32
Integer32(1.. 2147483647)
Power port index.
As per the MIB.
hh3cLswOutputPowerStatus (1.3.6.1.4.1.25506.8.35.18.4.16.1.2)
read-only
INTEGER
disable(1),
normal(2)
open(3),
overvol(4)
undervol(5),
overcur(6)
overpower(7),
Power port status.
As per the MIB.
