13-Security
HomeSupportRoutersCR16000-M SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-M Routers Alarm Reference-R838x-6W10013-Security
05-HH3C-PORTATK-TRAP-MIB
05-HH3C-PORTATK-TRAP-MIB 75.60 KB
About this MIB
Use this table to configure port attack notifications.
MIB file name
hh3c-portatk-trap.mib
Notifications
hh3cPortAtkTrapPtkAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.250.0.1
A port attack alarm notification was sent to the SNMP module.
Informational
Major
OFF
Notification triggers
This notification is generated when the validity end time of a local certificate is before the current system time of the device.
This notification might be generated when the following events occur:
The system time of the device is not synchronized with that of the CA server.
The validity end time of the local certificate is before the current system time of the device.
System impact
OID
Event
Severity
Default status
Informational
Major
OFF
This notification is generated when a port attack alarm notification is sent to the SNMP module.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable port-attack command.
OFF
CLI: Use the undo snmp-agent trap enable port-attack command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.250.1.1 (hh3cPortAtkTrapPacketIf)
Interface name.
No
OCTET STRING
OCTET STRING  (1..47)
1.3.6.1.4.1.25506.2.250.1.2 (hh3cPortAtkTrapPacketType)
Packet type.
No
INTEGER
isis(1), esis(2), clnp(3), vrrp(4), unknownIpv4Mc(5), unknownIpv6Mc(6), ipv4McastRip(7), ipv4BcastRip(8), mcastNtp(9), bcastNtp(10), ipv4McastOspfDip5(11), ipv4McastOspfDip6(12), ipv4UcastOspf(13), ipv4McastPim(14), ipv4UcastPim(15), ipv4Igmp(16), ucastLdp(17), ipv6McastPim(18), ipv6UcastPim(19), ipv6Mld(20), ipv6Ripng(21), ipv6UcastOspfv3(22), ipv6McastOspfv3Dip5(23), ipv6McastOspfv3Dip6(24), ipv6Ldp(25), ipv6Vrrp(26), rrpp(27), ipv4Autorp(28), dot1x(29), stp(30), lacp(31), gvrp(32), hgmp(33), ucastBgp(34), ucastIcmp(35), ucastTtl(36), ucastIpOption(37), ipv6Bgp(38), ipv6NdPass(39), ipv6NdDest(40), lldp(41), dldp(42), bpduTunnelDmac3(43), bpduTunnelDmac0(44), bpduTunnelDmac1(45), bpduTunnelDmac2(46), msdp(47), telnetSsh(48), httpHttps(49), snmp(50), smlk(51), dot1ag(52), cdp(53), acsei(54), ucastNtp(55), md(56), ipv4UcDhcp(57), ipv4UcOspfTtl(58), ipv4UcPimTtl(59), ipv6Icmp(60), gmrp(61), pvst(62), oam(63), hgmpBc(64), eapolBridgemac(65), wpiBridgemac(66), cfdBridgemac(67), hgmpBridgemac(68), acseiBridgemac(69), ipv6DhcpUcClient(70), ipv6DhcpUcRelay(71), l2Stationmove(72), icmpRdm(73), ipv6CpudstCar(74), ptp(75), fcoeFipUc(76), fcoeToCpu(77), ipv6UcastRtrenum(78), ipv6McastRtrenum(79), ipv6UcastNtp(80), ipv6McastNtp(81), trillAllisis(82), drcp(83), rlinkHigh(84), rlinkMiddle(85), vdp(86), ipv4McastCbt(87), arp(88), arpReply(89), ipv6Ttl(90), ipv6Ping(91), snapCis(92), macBasevlan(93), trillStp(94), routeToCpuMask(95), spbm(96), ipv6IpOption(97), ipv4UcBgpTtl(98), dhcpClient(99), dhcpServer(100), dhcpRelayClient(101), dhcpRelayServer(102), ipv6Dhcp(103), ipv6DhcpClient(104), ipv6DhcpServer(105), ipv6DhcpRelayServer(106), bfdEcho(107), bfdCtrl(108), bfdMultihop(109), bfdIntfCtrl(110), lspPing(111), loopbackDetection(112), loopTest(113), ipv6TelnetSsh(114), mplsRsvp(115), rrppFd(116), ptpUdp(117), ofpMiss(118), ofpMatch(119), ofpDevconfTtl(120), ofpMacipMiss(121), ftpCtrl(122), vxlanUdp(123), capwap(124), rlinkextNormal(125), rlinkextMiddle(126), rlinkextHigh(127), ipv4Siph225(128), ipv4Siph245(129), typeErps(130), esmc(131), rlinkNormal(132), onvifv4(133), onvifv6(134), ipv4Sip(135), twamp(136), pppoe(137), ipv6RaGuard(138), tcpToCpuLow(139), ipv4BcmpServer(140), wlanAcToCpu(141), lwappAcToCpu(142), smartmcUc(143), smartmcBc(144), rlinkLow(145), drniUdp(146), sipSnooping(147), douPsg(148), h323Snooping(149), mdns(150), erps(151), sadp(152), dhcpProtectionClient(153), dhcpProtectionServer(154), bfdMultihopVxlan(155), rarp(156), inof(157), inofMobile(158), ipv6UcBgpTtl(159), ipv4McastOspf5High(160), ipv4McastOspf6High(161), ipv6Drcp(162), l2ptusr(163), rarpReply(164)
Recommended action
No action is required.
hh3cPortAtkTrapPtkResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.250.0.2
A port attack alarm was cleared.
Informational
Major
OFF
System impact
OID
Event
Severity
Default status
Informational
Major
OFF
This notification is generated when a port attack alarm is cleared.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.250.1.1 (hh3cPortPacketIfIndex)
Interface name.
No
OCTET STRING
1.3.6.1.4.1.25506.2.250.1.2 (hh3cPortPacketType)
Packet type.
No
INTEGER
Recommended action
