03-HH3C-IPSGT-MIB | 43.55 KB |
HH3C-IPSGT-MIB
About this MIB
Use this table to obtain the operation status of IP-SGT and report corresponding alarm events.
MIB file name
hh3c-ipsgt.mib
Notifications
hh3cIpsgtCloudConnectionUp
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.247.0.1 |
Cloud connection is established to the EIA server. |
Informational |
Warning |
OFF |
Notification triggers
This notification is generated when the number of packets dropped because of packet mismatching with IPSG bindings drops below the threshold.
System impact
OID
Event
Severity
Default status
Informational
Warning
OFF
This notification is generated when the device establishes a cloud connection to a cloud-based EIA server that supports IP-SGT.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable ipsgt command.
OFF
CLI: Use the undo snmp-agent trap enable ipsgt command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.247.1.1.1 (hh3cIpsgtNotifyDomain) |
Domain name |
N/A |
OCTET STRING |
SIZE (1..255) |
1.3.6.1.4.1.25506.2.247.1.1.2 (hh3cIpsgtNotifyPort) |
Server port number |
N/A |
Integer32 |
(0..65534) |
1.3.6.1.4.1.25506.2.247.1.1.3 (hh3cIpsgtNotifyServerType) |
IP-SGT tunnel type |
N/A |
INTEGER |
unknown (1), master (2), backup (3) |
Recommended action
No action is required.
hh3cIpsgtCloudConnectionDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.247.0.2 |
Cloud connection is disconnected from the EIA server. |
Informational |
Warning |
OFF |
System impact
OID
Event
Severity
Default status
Informational
Warning
OFF
This notification is generated when the cloud connection is disconnected between the device and the cloud-based EIA server that supports IP-SGT.
System impact
The IP-SGT service is interrupted.
Status control
ON
CLI: snmp-agent trap enable ipsgt
OFF
CLI: undo snmp-agent trap enable ipsgt
Object
OID (object name) |
Index |
Type |
Value range |
Domain name |
N/A |
OCTET STRING |
SIZE (1..255) |
N/A |
Integer32 |
(0..65534) |
N/A |
INTEGER |
Recommended action
1.Verify that IP-SGT related settings (such as the IP address of the cloud server) are configured correctly.
2.If the issue persists, contact Technical Support.
