00-Preface | 45.69 KB |
Preface
The H3C IMC User Behavior Auditor Administrator Guide includes 12 chapters, which describe how to configure UBA to process data and present reports, generic configuration procedures, and important parameters.
· Audience.
· Conventions.
· About the H3C IMC documentation set.
Audience
· Network planners.
· Network administrators working with the H3C IMC.
Conventions
This section describes the conventions used in the documentation.
Port numbering in examples
The port numbers in the documentation are for illustration only and might be unavailable on your device.
Command conventions
Convention |
Boldface |
Italic |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE: |
The H3C IMC documentation set includes the following categories of documents:
Category |
Documents |
Purposes |
Hardware specifications and installation |
H3C IMC Getting Started Guide |
Quickly guides you through the IMC main features and troubleshooting common problems. |
H3C IMC Centralized Deployment Guide with Embedded Database |
Provides a complete guide to IMC platform and components installation and centralized deployment using embedded database. |
H3C IMC Centralized Deployment Guide with Local Database |
Provides a complete guide to IMC platform and components installation and centralized deployment using local database. |
H3C IMC Centralized Deployment Guide with Remote Database |
Provides a complete guide to IMC platform and components installation and centralized deployment using remote database. |
H3C IMC Distributed Deployment Guide with Local Database |
Provides a complete guide to IMC platform and components installation and distributed deployment using local database. |
H3C IMC Distributed Deployment Guide with Remote Database |
Provides a complete guide to IMC platform and components installation and distributed deployment using remote database. |
H3C IMC Probe Installation Guide |
Provides a complete guide to IMC Probe installation and deployment. |
SQL Server 2008 Installation and Configuration Guide |
Guides you through installing SQL Server 2008 for IMC. |
SQL Server 2008 R2 Installation and Configuration Guide |
Guides you through installing SQL Server 2008 R2 for IMC. |
SQL Server 2012 Installation and Configuration Guide |
Guides you through installing SQL Server 2012 for IMC. |
SQL Server 2014 Installation and Configuration Guide |
Guides you through installing SQL Server 2014 for IMC. |
Oracle 11g Installation and Configuration Guide(for Linux) |
Guides you through installing Oracle 11g on Linux for IMC. |
Oracle 11g R2 Installation and Configuration Guide(for Linux) |
Guides you through installing Oracle 11g R2 on Linux for IMC. |
Oracle 12c Installation and Configuration Guide(for Linux) |
Guides you through installing Oracle 12c on Linux for IMC. |
Red Hat Enterprise Linux 6.4 Installation Guide |
Guides you through installing Red Hat Enterprise Linux 6.4 for IMC. |
Red Hat Enterprise Linux 7.0 Installation Guide |
Guides you through installing Red Hat Enterprise Linux 7.0 for IMC. |
Software configuration |
H3C IMC Enterprise and Standard Platform Administrator Guide |
Describes operation procedures on the IMC platform. |
H3C IMC Quality of Service Manager Administrator Guide |
Describes operation procedures on the IMC Quality of Service Manager. |
H3C IMC Resource Automation Manager Administrator Guide |
Describes operation procedures on the Resource Automation Manager. |
H3C IMC Service Health Manager Administrator Guide |
Describes operation procedures on the Service Health Manager. |
H3C IMC VAN Connection Manager Administrator Guide |
Describes operation procedures on the IMC VAN Connection Manager. |
H3C IMC VAN Software Defined Network Manager Administrator Guide |
Describes operation procedures on the IMC VAN Software Defined Network Manager. |
H3C IMC VAN Fabric Manager Administrator Guide |
Describes operation procedures on the IMC VAN Fabric Manager. |
H3C IMC Application Manager Administrator Guide |
Describes operation procedures on the IMC Application Manager. |
H3C IMC Branch Intelligent Management System Administrator Guide |
Describes operation procedures on the IMC Branch Intelligent Management System. |
H3C IMC Business Service Manager Administrator Guide |
Describes operation procedures on the IMC Business Service Manager. |
H3C IMC IPsec VPN Manager Administrator Guide |
Describes operation procedures on the IMC IPsec VPN Manager. |
H3C IMC MPLS VPN Manager Administrator Guide |
Describes operation procedures on the IMC MPLS VPN Manager. |
H3C IMC Network Traffic Analyzer Administrator Guide |
Describes operation procedures on the IMC Network Traffic Analyzer. |
H3C IMC Service Operation Manager Administrator Guide |
Describes operation procedures on the IMC Service Operation Manager. |
H3C IMC User Behavior Auditor Administrator Guide |
Describes operation procedures on the IMC User Behavior Auditor. |
H3C IMC UC Health Manager Admin Guide |
Describes operation procedures on the IMC UC Health Manager. |
H3C IMC Wireless Service Manager Administrator Guide |
Describes operation procedures on the IMC Wireless Service Manager. |
H3C IMC User Access Manager Administrator Guide |
Describes operation procedures on the IMC User Access Manager. |
H3C IMC TACACS+ Authentication Manager Administrator Guide |
Describes operation procedures on the IMC TACACS+ Authentication Manager. |
H3C IMC EAD Security Policy Administrator Guide |
Describes operation procedures on the IMC EAD Security Policy Manager. |
Online Help |
Helps you properly use IMC. |
Operations and maintenance |
Release Notes |
Provides most recent IMC release information. |
Obtaining documentation
To access the most up-to-date H3C product documentation, go to the H3C website at
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
Documentation feedback
We appreciate your comments.
